固件文件名称:rk356x_linux_release_20220726_v1.3.0a
Log日志:2023-03-07_16_36_51.zip
AP6275S 不能正常开机 , ifconfig -A 可以看到 wlan0
[ OK ] Reached target Swap.
skipped.
[ 5.999344] systemd[1]: Reached target Remote File Systems.
[ 6.000107] systemd[1]: Reached target Slices.
[ 6.000656] systemd[1]: Reached target Swap.
[ 6.003427] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 6.004480] systemd[1]: Listening on initctl Compatibility Named P[ OK ] Listeninipg on initctl Compatibility Named Pipe.
[ 6.006677] systemd[1]: Listening on Journal Audit Socket.
[ OK ] Listening on Journal Audit Socket.
[ 6.007923] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ OK ] Listening on 9 m J o u6r.n0a0l9 2S2o5c]k et.
systemd[1]: Listening on Journal Socket.
[ 6.010515] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 6.011676] systemd[1]: List[ening onu0d;e3v2 mK e rOnKe l 0m] Listening on udocev Kernel Socket.
ket.
[ 6.018220] systemd[1]: Mounting Huge Pages File System…
[ 6.025569] systemd[1]: Mounting POSIX Message Queue File System… Mounting POSIX Message Queue File System…
[ 6.034003] systemd[1]: Mounting Kernel Debug File System…
[ 6.043442] systemd[1]: Mounting Kernel Trace File System…
[ 6.054157] systemd[1]: Starting Journal Service…
[ 6.063307] systemd[1]: Starting Set the console keyboard layout…
[ 6.073831] systemd[1]: Starting Create list of static device nodes for the current kernel…
Starting Create list of st…odes for the current kernel…
[ 6.075586] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 6.078818] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 6.090079] systemd[1]: Starting Load Kernel Modules…
[ 6.099346] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 6.108935] systemd[1]: Starting udev Coldplug all Devices…
[ 6.123447] systemd[1]: Mounted Huge Pages File System.
[ OK ] Mounted Huge Pages File System.
[ 6.126019] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 6.127924] systemd[1]: Mounted Kernel Debug File System.
[ OK ] Mounted Kernel Debug File System.
[ 6.129840] systemd[1]: Mounted Kernel Trace File System.
[ OK ] Mounted Kernel Trace File System.
[ 6.133566] systemd[1]: Finished Create list of static device nodes[ OK ] Finished or 9mCreate list of st… nodes for tthe he current kernel.
current kernel.
[ 6.142176] systemd[1]: Finished Load Kernel Modules.
[ OK ] Finished Load Kernel Modules.
[ 6.146869] systemd[1]: Finished Remount Root and Kernel File Syste[ OK ] Finished s[0;1;39mRemount Root and Kernel File Systems.
[ 6.153687] systemd[1]: Mounting FUSE Control File System…
[ 6.159332] systemd[1]: Mounting Kernel Configuration File System.. Mounting Kern.el Configuration File System…
[ 6.172956] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 6.173241] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 6.177766] systemd[1]: Starting Load/Save Random Seed…
[ 6.182947] systemd[1]: Starting Apply Kernel Variables…
[ 6.188370] systemd[1]: Starting Create System Users…
[ 6.194994] systemd[1]: Mounted FUSE Control File System.
[ OK ] Mounted FUSE Control File System.
[ 6.200069] systemd[1]: Mounted Kernel Configuration File System.
[ OK ] Mounted Kernel Configuration File System.
[ 6.214861] systemd[1]: Finished Load/Save Random Seed.
[ OK ] Finished Load/Save Random Seed.
[ OK ] Finished Create System Users.
Starting Create Static Device Nodes in /dev…
[ OK ] Finished Apply Kernel Variables.
[ OK ] Finished Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager…
[ OK ] Finished Set the console keyboard layout.
[ OK ] Reached target Local File Systems (Pre).
[ OK ] Reached target Local File Systems.
Starting Set console font and keymap…
Starting Tell Plymouth To Write Out Runtime Data…
[ OK ] Finished Set console font and keymap.
[ OK ] Finished Tell Plymouth To Write Out Runtime Data.
[ OK ] Finished udev Coldplug all Devices.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Dispatch Password …ts to Console Directory Watch.
[ OK ] Reached target Local Encrypted Volumes.
[ OK ] Reached target Paths.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage…
[ OK ] Finished Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories…
[ OK ] Finished Create Volatile Files and Directories.
Starting Network Name Resolution…
Starting Network Time Synchronization…
Starting Update UTMP about System Boot/Shutdown…
[ OK ] Finished Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target System Time Set.
[ OK ] Reached target System Time Synchronized.
[ OK ] Started Trigger anacron every hour.
[ OK ] Started Daily apt download activities.
[ OK ] Started Daily apt upgrade and clean activities.
[ OK ] Started Periodic ext4 Onli…ata Check for All Filesystems.
[ OK ] Started Discard unused blocks once a week.
[ OK ] Started Ubuntu Advantage update messaging.
[ OK ] Reached target Timers.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Adbd for linux…
[ OK ] Started Run anacron jobs.
Starting Avahi mDNS/DNS-SD Stack…
Starting Bluetooth management mechanism…
[ OK ] Started D-Bus System Message Bus.
Starting Network Manager…
[ OK ] Started Save initial kernel messages after boot.
Starting Remove Stale Onli…t4 Metadata Check Snapshots…
[ OK ] Started Set the CPU Frequency Scaling governor.
Starting Authorization Manager…
Starting Restore /etc/reso… the ppp link was shut down…
Starting rkaiq 3A engine…
Starting System Logging Service…
Starting Login Service…
Starting Disk Manager…
Starting WPA supplicant…
[ OK ] Started Network Name Resolution.
[ OK ] Started System Logging Service.
[ OK ] Finished Restore /etc/reso…re the ppp link was shut down.
[ OK ] Started rkaiq 3A engine.
[ OK ] Found device /dev/ttyFIQ0.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started WPA supplicant.
[ OK ] Started Authorization Manager.
[ OK ] Reached target Host and Network Name Lookups.
[ OK ] Listening on Load/Save RF …itch Status /dev/rfkill Watch.
Starting Modem Manager…
Starting Save/Restore Sound Card State…
[ OK ] Finished Remove Stale Onli…ext4 Metadata Check Snapshots.
Starting Load/Save RF Kill Switch Status…
[ OK ] Started Login Service.
[ OK ] Started Load/Save RF Kill Switch Status.
[ OK ] Finished Save/Restore Sound Card State.
[ OK ] Reached target Sound Card.
Starting Hostname Service…
[ OK ] Started Modem Manager.
[ OK ] Started Disk Manager.
[ OK ] Started Hostname Service.
Starting Network Manager Script Dispatcher Service…
[ OK ] Started Network Manager Script Dispatcher Service.
[ 9.183954] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ OK ] Started Adbd for linux.
[ OK ] Started Setup rockchip platform environment.
[ 10.040970] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 10.041050] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 10.041059] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 10.041069] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 10.041076] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ OK ] Started Bluetooth management mechanism.
[ *] A start job is running for Network Manager (12s / 1min 32s)
[ 18.182042] [dhd-wlan0] wl_android_wifi_on : Failed
[ 18.182176] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 18.183355] [dhd-wlan0] wl_android_wifi_off : out
[ OK ] Started Network Manager.
[ OK ] Reached target Network.
[ OK ] Reached target Network is Online.
Starting OpenBSD Secure Shell server…
Starting Permit User Sessions…
[ OK ] Started crash report submission daemon.
[ OK ] Finished Permit User Sessions.
Starting Light Display Manager…
Starting Hold until boot process finishes up…
[ OK ] Finished Hold until boot process finishes up.
[ OK ] Started Serial Getty on ttyFIQ0.
Starting Set console scheme…
Ubuntu 20.04.3 LTS firefly ttyFIQ0
firefly login: root (automatic login)
[ 19.139337] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 19.139399] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 19.139414] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 19.139425] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 19.139436] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 27.054763] [dhd-wlan0] wl_android_wifi_on : Failed
[ 27.054805] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 27.055777] [dhd-wlan0] wl_android_wifi_off : out
[ 27.083080] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 28.052949] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 28.053005] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 28.053012] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 28.053018] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 28.053024] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 35.995619] [dhd-wlan0] wl_android_wifi_on : Failed
[ 35.995842] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 35.997005] [dhd-wlan0] wl_android_wifi_off : out
| () __ ___ / | | _
| | | | '/ _ \ || | | | |
| | | | | | __/ | | || |
|| ||_| _|| ||_, |
|__/
Welcome to Ubuntu 20.04.3 LTS (GNU/Linux 4.19.232 aarch64)
- Documentation: http://wiki.t-firefly.com
- Management: http://www.t-firefly.com
System information as of Tue Mar 7 08:37:38 UTC 2023
System load: 2.10 0.51 0.17 Up time: 0 min
Memory usage: 8 % of 3887MB IP:
Usage of /: 4% of 12G
Last login: Tue Mar 7 08:33:49 UTC 2023 on ttyFIQ0
root@firefly:~# [ 46.027754] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 46.932964] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 46.933098] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 46.933127] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 46.933150] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 46.933172] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 55.002045] [dhd-wlan0] wl_android_wifi_on : Failed
[ 55.002141] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 55.003249] [dhd-wlan0] wl_android_wifi_off : out
[ 55.035875] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 55.941396] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 55.941529] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 55.941558] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 55.941581] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 55.941604] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
^C
root@firefly:~# [ 64.002169] [dhd-wlan0] wl_android_wifi_on : Failed
[ 64.002304] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 64.003455] [dhd-wlan0] wl_android_wifi_off : out
[ 74.034887] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 74.950300] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 74.950418] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 74.950450] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 74.950474] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 74.950497] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 83.015852] [dhd-wlan0] wl_android_wifi_on : Failed
[ 83.015979] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 83.017162] [dhd-wlan0] wl_android_wifi_off : out
[ 83.034633] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 83.955023] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 83.955127] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 83.955148] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 83.955169] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 83.955186] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 91.995570] [dhd-wlan0] wl_android_wifi_on : Failed
[ 91.995700] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 91.996929] [dhd-wlan0] wl_android_wifi_off : out
[ 102.024726] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 102.956690] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 102.956814] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 102.956842] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 102.956866] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 102.956889] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 111.029443] [dhd-wlan0] wl_android_wifi_on : Failed
[ 111.029801] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 111.031063] [dhd-wlan0] wl_android_wifi_off : out
[ 111.047760] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 111.994299] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 111.994438] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 111.994468] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 111.994491] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 111.994514] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 120.161994] [dhd-wlan0] wl_android_wifi_on : Failed
[ 120.162120] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 120.163328] [dhd-wlan0] wl_android_wifi_off : out
[ 130.033590] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 130.928254] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 130.928384] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 130.928413] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 130.928437] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 130.928460] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 139.025439] [dhd-wlan0] wl_android_wifi_on : Failed
[ 139.025569] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 139.026688] [dhd-wlan0] wl_android_wifi_off : out
[ 139.048059] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 139.988067] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 139.988196] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 139.988225] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 139.988250] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 139.988272] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 148.076011] [dhd-wlan0] wl_android_wifi_on : Failed
[ 148.076313] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 148.077604] [dhd-wlan0] wl_android_wifi_off : out
[ 158.028503] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 158.953951] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 158.954079] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 158.954108] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 158.954132] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 158.954156] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 167.059258] [dhd-wlan0] wl_android_wifi_on : Failed
[ 167.059389] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 167.060859] [dhd-wlan0] wl_android_wifi_off : out
[ 167.065734] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 168.040281] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 168.040411] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 168.040440] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 168.040464] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 168.040486] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 176.236496] [dhd-wlan0] wl_android_wifi_on : Failed
[ 176.236633] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
2023-03-07_16_36_51.zip (28.4 KB)
