Here is Wallys Communications (SuZhou) Co.,
We can design special products based on Qualcomm chipset such as down- conversion 900M ,WFC900, high power 5w, 5.8GHz wifi products and etc
Our software is also innovative. For example, based on 4.9 GHz, 6 GHz TDMA protocol, we can add special algorithms to improve the anti-interference capability of the products.Based on our innovation ,we can provide customer -specific solution .Wecan provide one-stop service for our customers, from idea, design ,manufacture to put the product into market.
1. DR40X9
Link here get more information:
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX10/100/1000Mbps Gigabit Ethernet 2xRJ45
SFP connector 1xSFP fiber module connector (optional)3G/4G connector 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack24V~48V power supply
ROHS Compliance YES
Dimension 115mm x 105mm x 16mm
Max Power 48.1V x 0.180A= 8.658W
Nor Flash 2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
!(file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml6092/wps28.jpg)
- DR4019S
Featuring withindustrial-grade IPQ4019 chipset
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 11ABGN/802.11AC
Storage Humidity Range 0 to +90 (non-condensing)%
Symbol Parameter
CPU IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
DC Jack 12 power supply
ROHS Compliance YES
Dimension 65mmx35mm x 16mm
Max Power 12V x 0.8A= 9.6W
Nor Flash 32MB
DDR 256MB
!(file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml6092/wps29.jpg)
- DR40X8H
Featuring with industrial-grade IPQ4018/IPQ4028 chipset
Support 4.940GHz to 5.825GHz Frequency Range;
Support 11ABGN/AC
Supply Voltage 24V~48V V
Operating Temperature Range -40 to +60 ºC
Storage Temperature Range -65 to +105 ºC
Symbol Parameter
CPU IPQ4018 (Quad core ARM Cortex A7 at 710 MHz)
SFP connector1xSFP fiber module connector (optional)3G/4G connector1xminipcie 3G/4G connector support with two sim card
DC Jack 24V~48V power supply
ROHS Compliance YES
Nor Flash 2MB~32MB
Nand Flash 128MB
DDR 256MB
!(file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml6092/wps30.png)
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
