Here is Wallys Communications (SuZhou) Co.,
We can design special products based on Qualcomm chipset such as down- conversion 900M ,WFC900, high power 5w, 5.8GHz wifi products and etc
Our software is also innovative. For example, based on 4.9 GHz, 6 GHz TDMA protocol, we can add special algorithms to improve the anti-interference capability of the products.Based on our innovation ,we can provide customer -specific solution .Wecan provide one-stop service for our customers, from idea, design ,manufacture to put the product into market.
1.DR6000
IPQ6000 802.11ax 2x2 2.4GHz&5GHz
802.11ax 2x2 2.4G 2x2 5G 1.7Gbps
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
2 on board radios (Dual Band Concurrent Radio)
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 12 V
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -45 to +90 ºC
Hardware Specifications
Symbol Parameter
CPU Qualcomm-Atheros IPQ6000
CPU Frequency Quad-core ARM 64 bit A53 @1.2GHz processor
System Memory DDR3L 512MB 16-bit interface
Nand Flash 128MB
NOR Flash 16MB
Ethernet Port 2x 1Gbps Ethernet Ports
DC Jack Input 1x DC Jack Connector: 12V
Power Consumption(Board Only) 1TD
On Board Radio 2 radios (Dual band concurrent radio)
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
2.4GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QA256-QAM,1024QAM
LED 4x LED Indicators
USB /Header 1x MicroUSB 2.0 Port
Serial Port 1x Serial Interface 12 Pin Connectors
Certification TBD
Humidity Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
Temperature Range Operating: TBD Storage: -40ºC to 90ºC
Dimension (Diameter x Height) 100mm x 23.5mm (Without Heatsink)
2. DR2G41
Support 4 x Mini PCIe Card or 4 x M.2 Card
Adapter Card 4 x Mini PCIe Card 4 x M.2 Card
Features
Support 4pcs Mini PCIE cards or 4 pcs M.2 cards
RoHS compliance ensure a high level protection of human health and the
environment from risks that can be posed by chemicals
Product Description
DR2G41 is an adapter card with four MiniPCIe and four M.2 slots. It can be used in a PC with a PCIe slot. Use this new adapter to expand your connectivity and upgrade your device to use the latest miniPCIe and m.2 interface cards. Each comes with both low and regular profile brackets.
Brackets include holes for mounting SMA connectors, or for using as cable exit holes.
Specifications
Input voltage 12 V
Output Voltage 3.3 V
Operating Temperature -40 to +70 ºC
ROHS Compliance YES
Switch control instruction
Switch up/down Operation
Switch 1 up M.2-1
down MiniPCIE-1
Switch 2 up M.2-2
down MiniPCIE-2
Switch 3 up M.2-3
down MiniPCIE-3
Switch 4 N/A M.2-4 and MiniPCIE-4 can work simultaneously,not controlled by the switch 4
Outline
Length 180 Mm
Width 66 Mm
- DR531-S
Featuring with industrial-grade QCA-Atheros AR9531 (550 MHz)chipset
Integrated with 1 x 2.4G high power Radio Card.
Supports 1 x 10/100Mbps FE Port.
Supports 1 x 2.4G MMCX connectors.
Support 5M/10M/20M/40M Bandwidth.
Supports operating frequency from 2.312 GHz to 2.7 GHz.
RoHS compliance
Part Number DR531-S
Chipset QCA9531
Power supply 5V 100/10 M FE 12.4G
27dbm@mcs0 perchain -93dbm@mcs0 Rssi 1*MMCX
MiniPCIe/MiniPCI Used for connected to Minipcie module
4.PD-25
PD-25 802.3AT/AT Input Output
802.3AT/AT 85% Efficiency 10/100/1000M GE Surge Protection
Support 802.3BT/AT/AF
The output voltage is 48V
The efficiency is 90%
Support surge protection
Support RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Applications
Input voltage 42~56 V
Output Voltage 48 V
The maximum output voltage 56 V
10/100/1000Mbps Gigabit Ethernet 2xRJ45(one is for input,one is for output Surge protection Yes
ROHS Compliance YES
Applications
Length 100.7 Mm
Width 27.4 Mm
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
