Wallys/wifi6,Qualcomm,IPQ6010 QCN9074 wifi card, 802.11AX
NEWS-Wallys DR6018 Series Router Board Now Supports 6km Long Distance Transfer
Wallys DR6018 Series Router Board Now Supports 6km Long Distance Transfer, Perfect for 5G Base Stations and Networking Applications.
  1. DR6018
Website:
[b][u]https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html[/u][/b]
Yuotube:
[b][u]https://www.youtube.com/watch?v=RPk_6fZbHZU[/u][/b]
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2DR 6018-S
Website:
[b][u]https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html[/u][/b]
Youtube:
[b][u]https://www.youtube.com/watch?v=BX0-nb3RAIY[/u][/b]
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
8MB NOR Flash, 256MB NAND Flash
Supply Voltage 24V~48V(DC Jack) V
Symbol Parameter
CPU Qualcomm-Atheros IPQ6010
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot 1x SD Card Slot(Option)
USB /header 1x USB 3.0 Port(Option)
POE Option 1: 48V~56V passive POE/Active POE(Suport 802.3at)
Option 2: 24V~48V passive POE
DC Jack 24V~48V power supply
LED header 2.0 pitch pin header
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
4 x MMCX Connectors
Nor Flash 8MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension 125mm x 105mm x 20mm
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
