rk3328在linux怎样打开weston
固件文件名称:rk3399/firefly: e09d1b2795b31fac383801f3e277707224
Log日志:log.txt
怎样在linux系统下打开weston
[root@rk3328:/]# XDG_RUNTIME_DIR=/tmp/xdg weston
librga:RGA_GET_VERSION:4.00,4.000000
ctx=0x165abc20,ctx->rgaFd=3
Rga built version:version:+2017-09-28 10:12:42
Date: 2016-01-21 UTC
[10:41:36.065] weston 3.0.0
http://wayland.freedesktop.org
Bug reports to: https://bugs.freedesktop.org/enter_bug.cgi?product=Wayland&component=weston&version=3.0.0
Build: unknown (not built from git or tarball)
[10:41:36.067] Command line: weston
[10:41:36.067] OS: Linux, 4.4.194-ge09d1b2795b3, #196 SMP Thu Jul 30 14:40:02 CST 2020, aarch64
[10:41:36.068] warning: XDG_RUNTIME_DIR “/tmp/xdg” is not configured
correctly. Unix access mode must be 0700 (current mode is 755),
and must be owned by the user (current owner is UID 0).
Refer to your distribution on how to get it, or
http://www.freedesktop.org/wiki/Specifications/basedir-spec
on how to implement it.
[10:41:36.074] Using config file ‘/etc/xdg/weston/weston.ini’
[10:41:36.076] Output repaint window is 15 ms maximum.
[10:41:36.077] Loading module ‘/usr/lib/libweston-3/drm-backend.so’
[10:41:36.095] initializing drm backend
[10:41:36.096] not a vt
[10:41:36.096] if running weston from ssh, use --tty to specify a tty
[10:41:36.096] fatal: drm backend should be run using weston-launch binary or as root
[10:41:36.097] fatal: failed to create compositor backend
log.txt (1.33 KB)
