固件文件名称:Core-3399Pro-JD4-Android9.0
固件下载地址:官网
Log日志:123.txt
Core-3399Pro-JD4 上电 PCIE-LED 和 DIY-LED 闪动 无法正常开机 刷了固件后时好时坏, 刚买的新板子, 用不了了。
123.txt (8 KB)
固件下载地址:官网
Log日志:123.txt
1 刷的是哪个固件呢,麻烦提供下;
2 参照wiki,接个调试串口,看下提示什么内容;
https://wiki.t-firefly.com/AIO-3399Pro-JD4/debug.html
zhangzhenzhao 发表于 2023-3-14 10:26
1 刷的是哪个固件呢,麻烦提供下;
https://wiki.t-fir …
刷的是RK3399PRO_Firefly_Android9.0_20211213.7z这个固件 firefly官网下载的, 我一会打印下Log贴出来哈。
challee 发表于 2023-3-14 10:44
刷的是RK3399PRO_Firefly_Android9.0_20211213.7z这个固件 firefly官网下载的, 我一会打印下Log贴出来 …
你好,我换了一块板子 型号是 RK3399 PC -Pro 刷Ubuntu固件 固件版本是ROC-RK3399-PC-PLUS_Ubuntu18.04-r240_v2.5.1d_230330.img 然后启动不起来。
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 416MHz 0,1
Channel 0: LPDDR4,416MHz
Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,416MHz
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 856MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x40
ch 1 ddrconfig = 0x101, ddrsize = 0x40
pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD
Boot1 Release Time: Jun 2 2020 15:02:17, version: 1.26
CPUId = 0x0
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
FwPartOffset=2000 , 100000
UsbBoot …76220
powerOn 88490
DDR Version 1.26 20210628
soft reset
SRX
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0, cs 0, advanced training done
channel 1, cs 0, advanced training done
ddr_set_rate to 328MHZ
ddr_set_rate to 666MHZ
ddr_set_rate to 416MHZ, ctl_index 0
ddr_set_rate to 856MHZ, ctl_index 1
support 416 856 328 666 MHz, current 856MHz
Boot1 Release Time: May 29 2020 17:36:36, version: 1.26
CPUId = 0x0
ChipType = 0x10, 448
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 73952
SecureMode = 0
SecureInit read PBA: 0x4
SecureInit read PBA: 0x404
SecureInit read PBA: 0x804
SecureInit read PBA: 0xc04
SecureInit read PBA: 0x1004
SecureInit read PBA: 0x1404
SecureInit read PBA: 0x1804
SecureInit read PBA: 0x1c04
atags_set_bootdev: ret:(0)
GPT part: 0, name: security, start:0x2000, size:0x2000
GPT part: 1, name: uboot, start:0x4000, size:0x2000
GPT part: 2, name: trust, start:0x6000, size:0x2000
GPT part: 3, name: misc, start:0x8000, size:0x2000
GPT part: 4, name: dtbo, start:0xa000, size:0x2000
GPT part: 5, name: vbmeta, start:0xc000, size:0x800
GPT part: 6, name: boot, start:0xc800, size:0x20000
GPT part: 7, name: recovery, start:0x2c800, size:0x30000
GPT part: 8, name: backup, start:0x5c800, size:0x38000
GPT part: 9, name: cache, start:0x94800, size:0xc0000
GPT part: 10, name: metadata, start:0x154800, size:0x8000
GPT part: 11, name: frp, start:0x15c800, size:0x400
GPT part: 12, name: super, start:0x15cc00, size:0x714000
GPT part: 13, name: oem, start:0x870c00, size:0x100000
GPT part: 14, name: userdata, start:0x970c00, size:0x30cd3df
find part:uboot OK. first_lba:0x4000.
find part:trust OK. first_lba:0x6000.
Trust Addr:0x6000, 0x58334c42
No find bl30.bin
Load uboot, ReadLba = 4000
Load OK, addr=0x200000, size=0xe8748
RunBL31 0x40000 @ 122186 us
NOTICE: BL31: v1.3(release):845ee93
NOTICE: BL31: Built : 15:51:11, Jul 22 2020
INFO: boot cpu mask: 0
INFO: plat_rockchip_pmu_init(1196): pd status 3e
INFO: BL31: Initializing BL32
INF [0x0] TEE-CORE:init_primary_helper:337: Initializing (1.1.0-278-gef70f120a #zhangzj #9 Fri Sep 17 09:39:24 UTC 2021 aarch64)
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: e24f0b9f2b)(sdk version: rk3399_linux_release_20230328_v2.5.1d)-ge24f0b9f2b #weicz (Mar 30 2023 - 19:46:42 +0800)
Model: Firefly-RK3399 Board
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
Relocation Offset: f5bdb000, fdt: f3dcf4d8
Bootdev(atags): mmc 0
MMC0: HS400, 50Mhz
PartType: EFI
boot mode: recovery (misc)
No resource partition
Failed to load DTB
Failed to get kernel dtb, ret=-19
In: serial
Out: serial
Err: serial
rockchip_set_serialno: could not find efuse device
CLK: (uboot. arml: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
CLK: (uboot. armb: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
aclk_perihp 133333 KHz
hclk_perihp 66666 KHz
pclk_perihp 33333 KHz
aclk_perilp0 266666 KHz
hclk_perilp0 88888 KHz
pclk_perilp0 44444 KHz
hclk_perilp1 100000 KHz
pclk_perilp1 50000 KHz
Net: No ethernet found.
No FDT memory address configured. Default at 0xf3dcf4d8
** Invalid Android Image header **
Android image load failed
## Booting Rockchip Format Image
Could not find kernel partition, ret=-1
mmc_init: -95, time 9
switch to partitions #0, OK
** Unrecognized filesystem type **
starting USB…
No working controllers found
USB is stopped. Please issue ‘usb start’ first.
starting USB…
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
starting USB…
No ethernet found.
No ethernet found.
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x18
MR4=0x1
MR5=0x1
MR8=0x10
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CPUId = 0x0
ChipType = 0x10, 351
SdmmcInit=2 0
BootCapSize=100000
UserCapSize=29820MB
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
mmc0:cmd8,20
mmc0:cmd5,20
mmc0:cmd55,20
mmc0:cmd1,20
SdmmcInit=0 1
StorageInit ok = 73371
SecureMode = 0
No find bl30.bin
RunBL31 0x40000 @ 118612 us
INFO: SPSR = 0x3c9
PreSerial: 2
DRAM: 3.8 GiB
Sysmem: init
MMC0: HS400, 50Mhz
PartType: EFI
Failed to load DTB
In: serial
Out: serial
Err: serial
aplll 816000 KHz
apllb 816000 KHz
dpll 856000 KHz
cpll 24000 KHz
gpll 800000 KHz
npll 600000 KHz
vpll 24000 KHz
starting USB…
starting USB…
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
starting USB…
No ethernet found.
No ethernet found.
