Wallys // DR342&DR344 Routerboard QCU9074 wifi5 wifi6E
1.DR342
[u]https://www.wallystech.com/Routerboard/DR342-Qualcomm-AR9342-2T2R-5G-high-power-30dbm-1-GETH-port-support-LTE.html[/u]
Featuring with industrial-grade Atheros’s AR9342(533 MHz) chipset DR342
Integrated with 2x 2 5G high power (up to 30dBm aggregate ) Radio Card
5.180GHz to 5.825GHz Frequency Range
1x10/100/1000Mbps Gigabit Ethernet Port
2 x 5G MMCX Connectors
20M/40M Bandwidth
Support LTE/WiFi Card
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 0 to +56 V
Operating Temperature Range -40 to +70 oC
Storage Temperature Range -65 to +105 oC
Storage Humidity Range 0 to +90 (non-condensing)
Operating Conditions
Supply Voltage(DC Jack) +12 to +56 V
POE+24 to +56 V
Temperature -40 to +70 oC
Hardware Specifications
Symbol Parameter
CPU Atheros AR9342 530MHz processor frequency
System Memory64M DDR2
NOR Flash 16MB
Switch IC Atheros AR8035-AL1AR 1 GIGA port PHY/RGMII switch
Power IC TI/TPS5436
Power consumption 6W(Board Only) 1000MLAN port
POE define Pin 4/5 and pin 7/8 connect to the anode or cathode respectively
POE input
Antenna Connector 2 x 5G MMCX connectors
Power Connector 1 x DC JACK D(center)=2.1mm Max 50V DC
Power Solution DC Jack Input: 12-56V, Passive POE: 24 -56V
LAN Connector 1 x 1000M LAN port
ROHS Compliance YES
Reset Button RT push button
Dimension 99mm x 85mm x 16mm
Socket Height Mini PCIE 9.2mm
2.DR344
[u]https://www.wallystech.com/Routerboard/DR344-Qualcomm-AR9344-support-MU-MIMO-2T2R-5G-2-GETH-port-support-Minipcie-card.html[/u]
Featuring with industrial-grade Atheros/ AR9344(560 MHz)chipset,DR344
Integrated with 1 x 5G high power (up to 30dBm aggregate ) radio card
Supports 1 x 10/100Mbps Fast Ethernet Port and 1 x 10/100/1000Mbps Gigabit Ethernet Port
Support WiFi application(Optional)
Support 2 x 5G MMCX connectors
Support 5M/10M/20M/40M Bandwidth
Support 1 x USB2.0(Optional)
Support operating frequency from 2.312 GHz to 2.502 GHz and 4.92GHz to 6.085GHz
Technical Specifications
Hardware Information
CPU Atheros/AR9344-AC2A 560 MHz processor frequency
System Memory 64MB(max 128MB DDR2 optional)
NOR Flash 8MB (max 16MB optional)
Switch IC Atheros/AR8035-AL1A-R 1 GIGA port PHY/RGMII switch
Power IC TI/TPS54531 24V to 5V 5A regulator
AME/AME5291 5V to 3.3V 2A regulator
Power consumption 2.04W(Board Only) 6.6W(Board + 2.4G card) 7.1W(Board + 5G card)
1000M LAN port POE define Pin 4/5 and pin 7/8 connect to the anode or cathode respectively 24V input
Antenna Connector 2 x 5G MMCX connectors(U3&U5)
Power Connector 1 x DC JACK(J2)D(center)=2.1mm Max 24V DC input /1 x 2 pin header pitch=3.96mm(J32)
LAN Connector 1 x 100M LAN(J4) port / 1 x 1000M LAN port(J3)
ROHS Compliance YES
Humidity Operating: 5% to 95% (non-condensing); Storage: Max.90% (non-condensing)
Temperature Range Operating: -20oC to 70oC; Storage: -40oC to 90oC
Reset Button RT push button(SW6)
Dimension 105mm x 105mm x 15.1mm
Here is Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
1.Company profile
Founded in 2010, Wallys is mainly engaged in the research and development and production of wireless communication products, providing OEM/ODM/JDM services for customers. The annual output value can reach 50 million RMB. The number of employees is 120
Equipment and capacity: The company has 4 SMT production lines, 2 wave welders and manual welding lines, and 2 test assembly lines, with an annual production capacity of10 million PCS.
Company address: 116 Chengyang Road, Xiangcheng District, Suzhou City, Jiangsu Province.
2.Innovation
We can design special products based on Qualcomm chipset such as down- conversion 900M ,WFC900, high power 5w, 5.8GHz wifi products and etc
Our software is also innovative. For example, based on 4.9 GHz, 6 GHz TDMA protocol, we can add special algorithms to improve the anti-interference capability of the products.Based on our innovation ,we can provide customer -specific solution .Wecan provide one-stop service for our customers, from idea, design ,manufacture to put the product into market.
3.Software and hardware design
We have experienced R&D engineer team with a demonstrated history of working in the wireless industry.Skilled inRF and embedded communications,network protocol,firmware,openwrt,linux,system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout and etc.,Many years of expertise in software and hardware design allows us to deliver solutions based on your specification list for commercial and industrial applications. We are able to think ahead and deliver design that meet and exceed customer requirement.
4.Product range
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IPQ9074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344
EMAIL:​sales4@wallystech.com
