SDK包名称:Firefly-RK356X_Android11.0_git_20220929
SDK修改内容:使用原厂固件烧录会卡在开机logo阶段,做出了以下修改:
设备树dtsi文件中禁用rkisp,csi2,pcie以及修改了kernel/drivers/mmc
以上条件改完之后能够进入安卓阶段,但是不能进入安卓桌面,串口一直在重复打印
Log日志:长时间运行之后板子重启recovery从而显示异常.log
diff --git a/kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-port.dtsi b/kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-port.dtsi
index f50fd7497b..f173b49371 100644
— a/kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-port.dtsi
+++ b/kernel/arch/arm64/boot/dts/rockchip/rk3568-firefly-port.dtsi
@@ -190,7 +190,8 @@
&csi2_dphy_hw {
status = "okay";
//status = "okay"; -
status = "disabled";
&csi2_dphy0 {
@@ -247,15 +248,18 @@
&rkisp {
status = "okay";
&rkisp_mmu {
status = "okay";
&rkisp_vir0 {
status = "okay";
status = "disabled"; port { #address-cells = <1>; #size-cells = <0>;
@@ -268,7 +272,8 @@
&rkisp_vir1 {
status = "okay";
status = "disabled"; port { reg = <0>;
@@ -355,7 +360,8 @@
&mipi_csi2 {
status = "okay";
status = "disabled"; ports { #address-cells = <1>;
@@ -388,7 +394,8 @@
&rkcif_mipi_lvds {
status = "okay";
status = "disabled"; port { cif_mipi_in: endpoint { remote-endpoint = <&mipi_csi2_output>;
diff --git a/kernel/drivers/mmc/core/block.c b/kernel/drivers/mmc/core/block.c
index 1c6552b2f8..39a5337753 100644
— a/kernel/drivers/mmc/core/block.c
+++ b/kernel/drivers/mmc/core/block.c
@@ -49,7 +49,6 @@
#include “queue.h”
#include “block.h”
-#include “block_data.h”
#include “core.h”
#include “card.h”
#include “crypto.h”
@@ -98,7 +97,6 @@ static int max_devices;
static DEFINE_IDA(mmc_blk_ida);
static DEFINE_IDA(mmc_rpmb_ida);
-#ifndef _MMC_CORE_BLOCK_DATA_H
- There is one mmc_blk_data per slot.
@@ -138,7 +136,6 @@ struct mmc_blk_data {
struct dentry *status_dentry;
struct dentry ext_csd_dentry;
-#endif / _MMC_CORE_BLOCK_DATA_H */
/* Device type for RPMB character devices */
static dev_t mmc_rpmb_devt;
@@ -148,7 +145,6 @@ static struct bus_type mmc_rpmb_bus_type = {
.name = “mmc_rpmb”,
- struct mmc_rpmb_data - special RPMB device type for these areas
- @dev: the device for the RPMB area
@@ -166,7 +162,6 @@ struct mmc_rpmb_data {
struct mmc_blk_data md;
struct list_head node;
static DEFINE_MUTEX(open_lock);
@@ -347,14 +342,12 @@ mmc_blk_getgeo(struct block_device *bdev, struct hd_geometry *geo)
return 0;
struct mmc_blk_ioc_data {
struct mmc_ioc_cmd ic;
unsigned char *buf;
u64 buf_bytes;
struct mmc_rpmb_data rpmb;
static struct mmc_blk_ioc_data *mmc_blk_ioctl_copy_from_user(
struct mmc_ioc_cmd __user *user)
@@ -1694,31 +1687,31 @@ static void mmc_blk_read_single(struct mmc_queue *mq, struct request *req)
struct mmc_card *card = mq->card;
struct mmc_host *host = card->host;
blk_status_t error = BLK_STS_OK;
int retries = 0; do { u32 status; int err;
int retries = 0;
mmc_blk_rw_rq_prep(mqrq, card, 1, mq);
while (retries++ <= MMC_READ_SINGLE_RETRIES) { -
mmc_wait_for_req(host, mrq);
err = mmc_send_status(card, &status); -
if (err) -
goto error_exit; -
if (!mmc_host_is_spi(host) && -
!mmc_blk_in_tran_state(status)) { -
err = mmc_blk_fix_state(card, req);
err = mmc_send_status(card, &status); if (err) goto error_exit;
if (mrq->cmd->error && retries++ < MMC_READ_SINGLE_RETRIES) -
continue;
err = mmc_blk_fix_state(card, req); -
if (err) -
goto error_exit; -
retries = 0;
if (!mrq->cmd->error) -
break; -
} if (mrq->cmd->error || mrq->data->error ||
@@ -2962,10 +2955,6 @@ static int mmc_blk_probe(struct mmc_card *card)
goto out;
- if (card->host->restrict_caps & RESTRICT_CARD_TYPE_EMMC) {
mmc_blk_data_init(md); - }
/* Add two debugfs entries */ mmc_blk_add_debugfs(card, md);
@@ -3000,10 +2989,6 @@ static void mmc_blk_remove(struct mmc_card *card)
this_card = NULL;
#endif
mmc_blk_data_deinit(md); - }
mmc_blk_remove_parts(card, md); pm_runtime_get_sync(&card->dev); if (md->part_curr != md->part_type) {
长时间运行之后板子重启recovery从而显示异常.log (1.45 MB)
