DR4019-S
Website:
DR4019-S
Featuring withindustrial-grade IPQ4019 chipset
Integrated with 2x 2 5G high power
Radio module and 2x2 2.4G high power Radio module
Support 5.180GHz to5.825GHz Frequency Range;
Support 2.412GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC
RoHS compliance ensure a high level
protection of human health and the environment from risks that can be posed by
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter
CPU IPQ4019(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps
Gigabit Ethernet 2xRJ45 DC Jack 12 power supply
ROHS Compliance YES
Dimension 65mmx35mm x 16mm
Max Power 12V x 0.8A= 9.6W
Nor Flash 32MB
DDR 256MB
Benifits:
Wallys Routerboard DR4019-S is a powerful network router that is designed to meet the demands of high-performance network environments. With its robust hardware and advanced features, this routerboard is capable of delivering lightning-fast internet connectivity and reliable network performance.
The DR4019s is powered by a quad-core ARM Cortex A15 CPU that is clocked at 1.4 GHz. It also comes equipped with 2GB of DDR3 RAM, making it capable of handling high-bandwidth network traffic with ease. In addition, it features 16 Gigabit Ethernet ports, two SFP+ ports, and a USB 3.0 port, allowing for flexible network connectivity options.
One of the key benefits of the DR4019s is its flexibility in terms of network configuration. It supports multiple routing protocols, including OSPF, BGP, and RIP, as well as firewall and NAT rules. It also supports VLANs, which can be used to segment the network and improve security.
Overall, the Wallys Routerboard DR4019s is a powerful and versatile network router that is ideal for use in large enterprise networks or data centers. With its advanced features, flexible configuration options, and reliable performance, it is an excellent choice for organizations that require high-performance networking capabilities.
OUR COMPANY:
Here is Wallys Communications (SuZhou) Co., Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
1.Company profile
Founded in 2010, Wallys is mainly engaged in the research and development and production of wireless communication products, providing OEM/ODM/JDM services for customers. The annual output value can reach 50 million RMB. The number of employees is 120.
Equipment and capacity: The company has 4 SMT production lines, 2 wave welders and manual welding lines, and 2 test assembly lines, with an annual production capacity of10 million PCS.
Company address: 116 Chengyang Road, Xiangcheng District, Suzhou City, Jiangsu Province.
2.Innovation
We can design special products based on Qualcomm chipset such as down- conversion 900M ,WFC900, high power 5w, 5.8GHz wifi products and etc
Our software is also innovative. For example, based on 4.9 GHz, 6 GHz TDMA protocol, we can add special algorithms to improve the anti-interference capability of the products.Based on our innovation ,we can provide customer -specific solution .Wecan provide one-stop service for our customers, from idea, design ,manufacture to put the product into market.
3.Software and hardware design
We have experienced R&D engineer team with a demonstrated history of working in the wireless industry.Skilled inRF and embedded communications,network protocol,firmware,openwrt,linux,system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout and etc.,Many years of expertise in software and hardware design allows us to deliver solutions based on your specification list for commercial and industrial applications. We are able to think ahead and deliver design that meet and exceed customer requirement.
4.Product range
MT7915/MT7975/IPQ6000/IPQ6018/IPQ6010/IPQ4019/IPQ4029/ipq4018/IPQ4028/IPQ8072/IPQ8072A/IPQ8074/IPQ8074A/IPQ9074/QCN9074/QCN9072/QCN9024/IPQ5018/AR9223/QCA9880/QCA9882 /AR9582/AR9531/AR9344
