DR5018
Website:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 12 V
Storage Temperature Range 45 to +105 ºC
OperSymbol
Parameter
CPU Qualcomm-Atheros IPQ5018
CPU Frequency Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory 512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port 4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC 4G/8G(optional)
USB /header 1x USB 3.0 Port
POE NA
DC Jack 12V power supply
LED header LED for power ,Wifi strength
Serial Port
SupportWireless On-board 2x22.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain 2x IPEX Connectors
Bluetooth BT5.1
Nor Flash 8MB
Nand Flash 128 MB
DDR 512MB
Dimension 170mm x 120mm x 15mmating Humidity Range 5 to +95 (non-condensing) %
Benefits:
The Wally’s router board DR5018 is a powerful and versatile router board that is designed to meet the needs of both home and business users. It is equipped with a 1.8GHz ARM Cortex-A17 CPU, which provides plenty of processing power to handle even the most demanding networking tasks. The board also features 1GB of RAM and 16GB of eMMC storage, giving you plenty of space to store your network configurations and other data.
One of the key features of the DR5018 is its support for multiple wireless protocols. The board supports both 2.4GHz and 5GHz Wi-Fi, as well as Bluetooth 4.2, making it a great choice for users who need to connect a variety of devices to their network. The board also includes two Gigabit Ethernet ports, which allow you to connect wired devices directly to your network.
The DR5018 runs on OpenWRT, an open-source operating system that is known for its stability, security, and flexibility. OpenWRT allows you to customize your router’s settings and features to meet your specific needs, and it is supported by a large community of developers who are constantly working to improve the platform.
Overall, the Wally’s router board DR5018 is an excellent choice for anyone who needs a powerful and versatile router board that can handle a wide range of networking tasks. Whether you are a home user looking for a reliable Wi-Fi router or a business user who needs to connect multiple devices to your network, the DR5018 is sure to meet your needs.
OUR COMPANY:
Here is Wallys Communications (SuZhou) Co.,
Ltd., http://www.wallystech.com,which is a professional supplier specializing in product design, manufacturing and offering superior OEM/ODM/JDM services in wireless communications. As a specialized manufacturer and exporter for these products in China,We sincerely hope to establish business relations with your esteemed corporation.
1.Company profile
Founded in 2010, Wallys is mainly engaged in the research and development and production of wireless communication products, providing OEM/ODM/JDM services for customers. The annual output value can reach 50 million RMB. The number of employees is 120
Equipment and capacity: The company has 4 SMT production lines, 2 wave welders and manual welding lines, and 2 test assembly lines, with an annual production capacity of10 million PCS.
Company address: 116 Chengyang Road, Xiangcheng District, Suzhou City, Jiangsu Province.
2.Innovation
We can design special products based on Qualcomm chipset such as down- conversion 900M ,WFC900, high power 5w, 5.8GHz wifi products and etc
Our software is also innovative. For example, based on 4.9 GHz, 6 GHz TDMA protocol, we can add special algorithms to improve the anti-interference capability of the products.Based on our innovation ,we can provide customer -specific solution .Wecan provide one-stop service for our customers, from idea, design ,manufacture to put the product into market.
3.Software and hardware design
We have experienced R&D engineer team with a demonstrated history of working in the wireless industry.Skilled inRF and embedded communications,network protocol,firmware,openwrt,linux,system,development,analog and Digital Circuit Design,Network Processors,Power supplies,PCB design and layout and etc.,Many years of expertise in software and hardware design allows us to deliver solutions based on your specification list for commercial and industrial applications. We are able to think ahead and deliver design that meet and exceed customer requirement.
EMAIL:sales4@wallystech.com
