Wallys//Routerboard/DR6018-CP01-wifi6-Qualcomm-IPQ6010-IPQ6018
DR6018(CP01)
Website below:
[u]https://www.wallystech.com/Routerboard/DR6018-CP01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-CP01-802-11AX-MU-MIMO-OFDMA.html[/u]
Qualcomm-Atheros IPQ6018
1GB DDRL3L System Memory
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
POE 24V~48V passive POE
DC Jack 12V power supply
LED header FFC/FPC Connector
Serial Port 1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D)219mm x 150mm x 16.5mm (Without Heatsink)
The Wally DR6018(CP01) is a high-performance router board designed for use in a variety of networking applications. It is based on the MediaTek MT7621A chipset, which features a dual-core 880MHz processor and 256MB of DDR3 RAM. This gives the DR6018(CP01) plenty of power to handle demanding networking tasks, such as VPNs, load balancing, and QoS.
One of the standout features of the DR6018(CP01) is its support for dual-band Wi-Fi, with both 2.4GHz and 5GHz bands available. This makes it an excellent choice for home or small business use, as it can provide fast and reliable Wi-Fi connectivity to a variety of devices.
In addition to its Wi-Fi capabilities, the DR6018(CP01) also includes four Gigabit Ethernet ports, allowing you to connect wired devices to your network as well. It also features a USB 3.0 port, which can be used to connect a variety of devices, including external hard drives and printers.
Another great feature of the DR6018(CP01) is its support for OpenWrt, an open-source firmware that allows you to customize and optimize your router’s performance to suit your specific needs. This makes it a great choice for tech-savvy users who want to take full control of their network and get the most out of their router.
Overall, the Wally DR6018(CP01) router board is an excellent choice for anyone looking for a powerful and versatile router for their home or small business network. With its dual-band Wi-Fi, Gigabit Ethernet ports, and support for OpenWrt, it offers a great balance of performance, flexibility, and customization options.
Wallys Communications (Suzhou) Co., LTD is a leading provider of advanced communication solutions for various industries. With a focus on research and development, the company is dedicated to creating innovative products and services that meet the evolving needs of its customers.
The company was founded in 2004 and has since grown to become a trusted name in the industry. It has a team of highly skilled engineers and technicians who work tirelessly to design, develop, and manufacture cutting-edge communication devices that are reliable, efficient, and cost-effective.
Our company:
Wallys Communications (Suzhou) Co., LTD [u]https://www.wallystech.com/index.html[/u]
EMAIL:​sales4@wallystech.com
