k_v1.0.2a/prebuilts/gcc/linux-x86/aarch64/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin/aarch64-none-linux-gnu-
2023-03-30T11:30:05 arm64 arm64 arm64
2023-03-30T11:30:07 /usr/bin/make -j1 O=/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588 HOSTCC=“/usr/bin/gcc” HOSTCXX=“/usr/bin/g++” syncconfig
2023-03-30T11:30:07 >>> host-libtool 2.4.6 Installing to host directory
2023-03-30T11:30:07 PATH=“/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/host/bin:/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/host/sbin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin” PKG_CONFIG=“/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/host/bin/pkg-config” PKG_CONFIG_SYSROOT_DIR=“/” PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR=“/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/host/lib/pkgconfig:/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/host/share/pkgconfig” /usr/bin/make -j65 install -C /home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/build/host-libtool-2.4.6/.
2023-03-30T11:30:07 make[2]: *** No rule to make target ‘m4/ltversion.in’, needed by ‘m4/ltversion.m4’. Stop.
2023-03-30T11:30:07 make[1]: *** [package/pkg-generic.mk:307: /home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/build/host-libtool-2.4.6/.stamp_host_installed] Error 2
2023-03-30T11:30:07 make: *** [/home/gmj/rk3588_repo_sdk_v1.0.2a/buildroot/output/firefly_rk3588/Makefile:23: _all] Error 2
you take 0:06.84 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 893:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
看维基更新sdk
