SDK包名称:rk356x_linux_release_v1.2.0_202111019_split_dir
SDK修改内容:无
Log日志:log.tar.gz
rk3568 buildroot编译报错
2023-04-03T10:45:21 checking for memrchr… yes
2023-04-03T10:45:21 checking whether mkdir handles trailing slash… yes
2023-04-03T10:45:21 checking whether mkdir handles trailing dot… yes
2023-04-03T10:45:21 checking for mkdtemp… yes
2023-04-03T10:45:21 checking whether mkfifo rejects trailing slashes… yes
2023-04-03T10:45:21 checking whether mknod can create fifo without root privileges… configure: error: in /home/autolabor/proj_j/rk356x_linux_release_20211019/buildroot/output/rockchip_rk3568/build/host-tar-1.29': 2023-04-03T10:45:21 configure: error: you should not run configure as root (set FORCE_UNSAFE_CONFIGURE=1 in environment to bypass this check) 2023-04-03T10:45:21 See config.log’ for more details
2023-04-03T10:45:21 make[1]: *** [package/pkg-generic.mk:221: /home/autolabor/proj_j/rk356x_linux_release_20211019/buildroot/output/rockchip_rk3568/build/host-tar-1.29/.stamp_configured] Error 1
2023-04-03T10:45:21 make: *** [/home/autolabor/proj_j/rk356x_linux_release_20211019/buildroot/output/rockchip_rk3568/Makefile:16: _all] Error 2
you take 0:25.27 to build builroot
ERROR: Running build_buildroot failed!
ERROR: exit code 1 from line 893:
/usr/bin/time -f “you take %E to build builroot” $COMMON_DIR/mk-buildroot.sh $BOARD_CONFIG
log.tar.gz (2.38 KB)
