Dts修改SPI,只更新extboot.img,下载结束正常启动,按Reset键后,重新启动失败
SDK包名称:rk356x_linux_release_v1.3.0b_20221213_split_dir
SDK修改内容:&spi1 {
status = "disabled";
max-freq = <48000000>;
dev-port = <0>;
pinctrl-0 = <&spi1m1_pins>;
pinctrl-1 = <&spi1m1_pins_hs>;
spi_wk2xxx: spi_wk2xxx@00{
compatible = "firefly,spi-wk2xxx";
reg = <0x00>;
spi-max-frequency = <10000000>;
power-gpio = <&pca9555 PCA_IO1_7 GPIO_ACTIVE_HIGH>;
reset-gpio = <&pca9555 PCA_IO1_1 GPIO_ACTIVE_HIGH>;
irq-gpio = <&gpio0 RK_PA6 IRQ_TYPE_EDGE_FALLING>;
cs-gpio = <&gpio3 RK_PA1 GPIO_ACTIVE_HIGH>;
/* rk3399 driver support SPI_CPOL | SPI_CPHA | SPI_CS_HIGH /
//spi-cpha; /
SPI mode: CPHA=1 /
//spi-cpol; /
SPI mode: CPOL=1 */
//spi-cs-high;
spidev1: spidev@00
status = "okay";
compatible = "rockchip,spidev";
reg = <0x00>;
spi-max-frequency = <4000000>;
Log日志:log-2023-0410.rar
1、SDK版本:rk356x_linux_release_v1.3.0b_20221213_split_dir
修改波特率115200
Loader: vi rkbin/tools/ddrbin_param.txt ./tools/ddrbin_tool tools/ddrbin_param.txt bin/rk35/rk3568_ddr_1560MHz_v1.13.bin
UBoot:~\u-boot\configs\firefly-rk3568_defconfig CONFIG_BAUDRATE=115200
Kernel:~\kernel\arch\arm64\boot\dts\rockchip\rk3568_linux.dtsi figdebugger{}
 文件系统:mkdir ubuntu_rootfs    mv ubuntu-aarch64-rootfs.img ubuntu_rootfs/rk356x_ubuntu_rootfs.img
 编译过程:
 sudo ./build.sh uboot
 sudo ./build.sh extboot
 sudo ./build.sh recovery
 sudo ./mkfirmware.sh
 sudo ./build.sh updateimg
生成的2.4G img文件 使用RKDevTool_Release_v2.84 下载更新
Upgrade Firmware ->Firmware ->Upgrade
系统可以正常启动
2、dtsi 修改部分:
【rk3568-firefly-aioj.dtsi】
&i2c0 {
status = “disabled”;//2023-0409
&i2c1 {
#if 0
&spi0 {
status = “okay”;//2023-0409
&spi2 {
#endif
&spi_wk2xxx {
【rk3568-firefly-port.dtsi】
&spi1 {
dev-port = <0>;
	reg = <0x00>;
	/* rk3399 driver support SPI_CPOL | SPI_CPHA | SPI_CS_HIGH */
	//spi-cpha;     /* SPI mode: CPHA=1 */
	//spi-cpol;     /* SPI mode: CPOL=1 */
	//spi-cs-high;
spidev1: spidev@00
	status = "okay";
	reg = <0x00>;
#if 0
&spi0 {//2023-0409
dev-port = <0>;
pinctrl-0 = <&spi0m0_pins>;
pinctrl-1 = <&spi0m0_pins_hs>;
spidev0: spidev@00
	status = "okay";
	reg = <0x00>;
&spi2 {//2023-0409
dev-port = <0>;
pinctrl-0 = <&spi2m1_pins>;
pinctrl-1 = <&spi2m1_pins_hs>;
spidev2: spidev@00
	status = "okay";
	reg = <0x00>;
#endif
spi 0 spi2 多次试验中也编译过
修改完成后 执行 sudo ./build.sh extboot 编译无报错 开放spi0 spi2 编译也无报错
extboot.img使用RKDevTool_Release_v2.84 下载更新
Addr: 0x00008000 Boot 选项 更新完成后,自行启动正常,执行reboot指令也正常启动,可以在终端内查看到spidev1.0设备
按键Reset后启动失败、重新上电,启动失败
第二次在单独更新Boot选项,更新结束后自行启动失败
尝试将Loader、parameter-ubuntu-fit.txt、Uboot、Boot一起更新,更新结束后自行启动失败
Loader:0x00000000
Parameter-ubuntu-fit.txt : 0x00000000
Uboot:0x00004000
Boot:0x00008000
失败提示如下
DDR Version V1.13 20220218
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: -24ps, dqs1: -120ps, dqs2: -96ps, dqs3: -192ps,
tdqss: cs1 dqs0: -24ps, dqs1: -120ps, dqs2: -96ps, dqs3: -192ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x64
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1560MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x35
cs 0:
the read training result:
DQS0:0x37, DQS1:0x35, DQS2:0x38, DQS3:0x33,
min :0x14 0x14 0x14 0x10 0x2 0x6 0x9 0x4 , 0xc 0xc 0x2 0x2 0xe 0x8 0xb 0x5 ,
0x16 0x15 0xf 0xe 0x5 0x1 0x2 0x4 ,0x12 0xd 0x8 0x2 0xf 0xd 0xc 0xe ,
mid :0x2f 0x2f 0x2f 0x2c 0x1e 0x21 0x24 0x1f ,0x28 0x27 0x1d 0x1c 0x29 0x24 0x26 0x21 ,
0x30 0x30 0x29 0x28 0x1e 0x1a 0x1c 0x1e ,0x2b 0x26 0x23 0x1d 0x29 0x28 0x25 0x28 ,
max :0x4b 0x4a 0x4b 0x49 0x3a 0x3c 0x3f 0x3a ,0x44 0x43 0x39 0x37 0x44 0x40 0x42 0x3e ,
0x4a 0x4b 0x43 0x42 0x37 0x33 0x36 0x38 ,0x45 0x3f 0x3f 0x38 0x44 0x44 0x3f 0x42 ,
range:0x37 0x36 0x37 0x39 0x38 0x36 0x36 0x36 ,0x38 0x37 0x37 0x35 0x36 0x38 0x37 0x39 ,
0x34 0x36 0x34 0x34 0x32 0x32 0x34 0x34 ,0x33 0x32 0x37 0x36 0x35 0x37 0x33 0x34 ,
the write training result:
DQS0:0x31, DQS1:0x1e, DQS2:0x22, DQS3:0xf,
min :0x6d 0x70 0x70 0x6f 0x5d 0x62 0x65 0x67 0x64 ,0x52 0x50 0x48 0x4a 0x54 0x51 0x53 0x50 0x4b ,
0x5f 0x5f 0x58 0x58 0x4e 0x4c 0x4f 0x53 0x53 ,0x47 0x44 0x3f 0x3d 0x4a 0x4a 0x45 0x4b 0x3f ,
mid :0x88 0x8a 0x8a 0x89 0x78 0x7d 0x80 0x81 0x7d ,0x6f 0x6d 0x64 0x66 0x71 0x6e 0x70 0x6d 0x68 ,
0x79 0x79 0x72 0x73 0x6a 0x67 0x69 0x6d 0x6e ,0x62 0x5f 0x5a 0x58 0x65 0x65 0x61 0x66 0x59 ,
max :0xa3 0xa5 0xa4 0xa4 0x94 0x98 0x9b 0x9b 0x97 ,0x8c 0x8b 0x81 0x83 0x8f 0x8c 0x8d 0x8b 0x86 ,
0x94 0x93 0x8d 0x8f 0x86 0x82 0x84 0x88 0x89 ,0x7e 0x7a 0x76 0x74 0x80 0x81 0x7d 0x82 0x74 ,
range:0x36 0x35 0x34 0x35 0x37 0x36 0x36 0x34 0x33 ,0x3a 0x3b 0x39 0x39 0x3b 0x3b 0x3a 0x3b 0x3b ,
0x35 0x34 0x35 0x37 0x38 0x36 0x35 0x35 0x36 ,0x37 0x36 0x37 0x37 0x36 0x37 0x38 0x37 0x35 ,
cs 1:
DQS0:0x35, DQS1:0x33, DQS2:0x38, DQS3:0x31,
min :0x12 0x13 0x13 0xf 0x2 0x7 0x8 0x4 , 0x9 0x9 0x1 0x1 0xb 0x5 0x8 0x4 ,
0x18 0x16 0x10 0xf 0x7 0x2 0x2 0x4 ,0x10 0xe 0x7 0x1 0xe 0xd 0xc 0xe ,
mid :0x2c 0x2c 0x2d 0x2a 0x1d 0x20 0x23 0x1e ,0x25 0x23 0x1b 0x1b 0x26 0x21 0x23 0x1f ,
0x31 0x31 0x2a 0x29 0x20 0x1c 0x1c 0x1e ,0x2a 0x26 0x21 0x1c 0x29 0x28 0x25 0x28 ,
max :0x46 0x46 0x47 0x46 0x38 0x39 0x3e 0x38 ,0x41 0x3e 0x36 0x36 0x41 0x3d 0x3e 0x3a ,
0x4b 0x4c 0x44 0x43 0x3a 0x36 0x37 0x39 ,0x44 0x3f 0x3c 0x37 0x44 0x44 0x3f 0x42 ,
range:0x34 0x33 0x34 0x37 0x36 0x32 0x36 0x34 ,0x38 0x35 0x35 0x35 0x36 0x38 0x36 0x36 ,
0x33 0x36 0x34 0x34 0x33 0x34 0x35 0x35 ,0x34 0x31 0x35 0x36 0x36 0x37 0x33 0x34 ,
min :0x6e 0x72 0x73 0x71 0x5f 0x63 0x67 0x68 0x65 ,0x57 0x54 0x4c 0x4c 0x58 0x55 0x56 0x54 0x4e ,
0x5f 0x5f 0x5a 0x58 0x4e 0x4a 0x4d 0x53 0x50 ,0x48 0x42 0x3f 0x3d 0x49 0x49 0x44 0x4c 0x3e ,
mid :0x8b 0x8f 0x8f 0x8d 0x7c 0x7f 0x84 0x82 0x80 ,0x71 0x6f 0x67 0x67 0x73 0x70 0x71 0x6f 0x6a ,
0x7b 0x7b 0x74 0x74 0x6b 0x67 0x69 0x6f 0x6c ,0x64 0x5f 0x5c 0x58 0x66 0x66 0x60 0x67 0x5b ,
max :0xa8 0xac 0xab 0xa9 0x99 0x9c 0xa1 0x9c 0x9b ,0x8c 0x8b 0x82 0x83 0x8f 0x8b 0x8d 0x8b 0x87 ,
0x97 0x97 0x8f 0x91 0x88 0x84 0x86 0x8b 0x89 ,0x81 0x7c 0x79 0x74 0x83 0x84 0x7d 0x82 0x78 ,
range:0x3a 0x3a 0x38 0x38 0x3a 0x39 0x3a 0x34 0x36 ,0x35 0x37 0x36 0x37 0x37 0x36 0x37 0x37 0x39 ,
0x38 0x38 0x35 0x39 0x3a 0x3a 0x39 0x38 0x39 ,0x39 0x3a 0x3a 0x37 0x3a 0x3b 0x39 0x36 0x3a ,
CA Training result:
cs:0 min :0x5c 0x4f 0x4f 0x40 0x4f 0x3b 0x50 ,0x5a 0x4b 0x4e 0x3b 0x4c 0x3b 0x52 ,
cs:0 mid :0x93 0x94 0x86 0x85 0x85 0x81 0x7a ,0x91 0x8e 0x85 0x81 0x82 0x80 0x7b ,
cs:0 max :0xcb 0xda 0xbe 0xca 0xbb 0xc7 0xa5 ,0xc9 0xd1 0xbc 0xc7 0xb9 0xc6 0xa5 ,
cs:0 range:0x6f 0x8b 0x6f 0x8a 0x6c 0x8c 0x55 ,0x6f 0x86 0x6e 0x8c 0x6d 0x8b 0x53 ,
cs:1 min :0x56 0x54 0x4b 0x45 0x4c 0x40 0x4f ,0x59 0x4d 0x4d 0x42 0x4c 0x40 0x52 ,
cs:1 mid :0x92 0x94 0x84 0x84 0x85 0x80 0x7b ,0x94 0x8e 0x87 0x81 0x85 0x82 0x7c ,
cs:1 max :0xcf 0xd5 0xbe 0xc4 0xbf 0xc1 0xa8 ,0xcf 0xcf 0xc1 0xc1 0xbf 0xc4 0xa6 ,
cs:1 range:0x79 0x81 0x73 0x7f 0x73 0x81 0x59 ,0x76 0x82 0x74 0x7f 0x73 0x84 0x54 ,
out
U-Boot SPL board init
U-Boot SPL 2017.09(u-boot commit id: 5632bd78657087f957deb24cdd207cc70e813a99)(sdk version:
rk356x_linux_release_20221015_v1.3.0b.xml)-g5632bd7865-dirty #root (Apr 07 2023 - 11:59:42)
Trying to boot from MMC2
mmc_init: -95, time 13
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(6204b6f381…) + OK
## Checking uboot 0x00a00000 … sha256(ecbc03f0f5…) + OK
## Checking fdt 0x00b2fae8 … sha256(bf758d1c80…) + OK
## Checking atf-2 0xfdcc1000 … sha256(5563d929da…) + OK
## Checking atf-3 0x0006a000 … sha256(b04372ab0f…) + OK
## Checking atf-4 0xfdcd0000 … sha256(b46eaa95b8…) + OK
## Checking atf-5 0xfdcce000 … sha256(2f8839c803…) + OK
## Checking atf-6 0x00068000 … sha256(6e9d32ba23…) + OK
## Checking optee 0x08400000 … sha256(66bbd17352…) + OK
Total: 227.440 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-365-gae7c295ca:derrick.huang
NOTICE: BL31: Built : 15:37:13, May 17 2022
INFO: pmu v1 is valid 220114
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-641-g4167319d3 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile
Architecture 10.2-2020.11 (arm-10.16))) #8 Wed Mar 16 15:14:56 CST 2022 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: 5632bd78657087f957deb24cdd207cc70e813a99)(sdk version:
rk356x_linux_release_20221015_v1.3.0b.xml)-g5632bd7865-dirty #root (Apr 07 2023 - 11:59:42 -0700)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed349000
Relocation fdt: eb9f87c0 - eb9fecd8
CR: M/C/I
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
boot mode: None
=================begin===================
134625 bytes read in 10 ms (12.8 MiB/s)
DTB(Distro): rk-kernel.dtb
of_get_regulator: Get (pmuio1-supply) regulator: /i2c@fdd40000/pmic@20/regulators/LDO_REG6 failed, ret=-19
of_get_regulator: Get (pmuio2-supply) regulator: /i2c@fdd40000/pmic@20/regulators/LDO_REG6 failed, ret=-19
of_get_regulator: Get (vccio1-supply) regulator: /i2c@fdd40000/pmic@20/regulators/LDO_REG4 failed, ret=-19
of_get_regulator: Get (vccio3-supply) regulator: /i2c@fdd40000/pmic@20/regulators/LDO_REG5 failed, ret=-19
of_get_regulator: Get (vccio4-supply) regulator: /i2c@fdd40000/pmic@20/regulators/DCDC_REG5 failed, ret=-19
of_get_regulator: Get (vccio5-supply) regulator: /i2c@fdd40000/pmic@20/regulators/SWITCH_REG1 failed, ret=-19
of_get_regulator: Get (vccio6-supply) regulator: /i2c@fdd40000/pmic@20/regulators/DCDC_REG5 failed, ret=-19
of_get_regulator: Get (vccio7-supply) regulator: /i2c@fdd40000/pmic@20/regulators/SWITCH_REG1 failed, ret=-19
io-domain: OK
Model: AIO-3568J HDMI (Linux)
No resource partition
No file: logo.bmp
512 bytes read in 6 ms (83 KiB/s)
logo(Distro): logo.bmp
127818 bytes read in 7 ms (17.4 MiB/s)
VOP have 1 active VP
vp0 have layer nr:6[0 2 4 1 3 5 ], primary plane: 4
vp1 have layer nr:0, primary plane: 0
vp2 have layer nr:0, primary plane: 0
hdmi@fe0a0000 disconnected
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000, eth0: ethernet@fe2a0000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
## Booting Rockchip Format Image
Could not find kernel partition, ret=-1
switch to partitions #0, OK
Scanning mmc 0:3…
Found /extlinux/extlinux.conf
Retrieving file: /extlinux/extlinux.conf
104 bytes read in 7 ms (13.7 KiB/s)
1: rk-kernel.dtb linux-4.19.232
Retrieving file: /initrd-4.19.232
9239184 bytes read in 58 ms (151.9 MiB/s)
Retrieving file: /Image-4.19.232
24678408 bytes read in 161 ms (146.2 MiB/s)
Retrieving file: /rk-kernel.dtb
Fdt Ramdisk skip relocation
## Flattened Device Tree blob at 0x0a100000
Using Device Tree in place at 000000000a100000, end 000000000a123de0
No file: logo_kernel.bmp
vp0, plane_mask:0x3f, primary-id:4, curser-id:-1
vp1, plane_mask:0x0, primary-id:0, curser-id:-1
vp2, plane_mask:0x0, primary-id:0, curser-id:-1
Adding bank: 0x1f0000000 - 0x200000000 (size: 0x10000000)
Total: 916.868 ms
[ 0.000000] Linux version 4.19.232 (root@ubuntu) (firefly: de4cbd1026ad12db7a811180023b5ab6704f0dc8) (sdk version:
rk356x_linux_release_20221015_v1.3.0b.xml) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05), GNU ld (Linaro_Binutils-2017.05)
2.27.0.20161019) #1 SMP Fri Apr 7 12:04:55 PDT 2023
[ 0.000000] Machine model: AIO-3568J HDMI (Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000,
size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1027656
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal
storagenode=/sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000
console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1
coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 swiotlb=0x10000
[ 0.000000] software IO TLB: mapped [mem 0xe5f00000-0xedf00000] (128MB)
[ 0.000000] Memory: 3902592K/4175872K available (15166K kernel code, 1956K rwdata, 5328K rodata, 1600K init, 598K bss,
256896K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 54469 entries in 213 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @ee810000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @ee820000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ee830000
[ 0.000000] CPU0: using LPI pending table @0x00000000ee840000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x36c/0x514 with crng_init=0
[ 0.010347] Console: colour dummy device 80x25
[ 0.015283] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.026568] pid_max: default: 32768 minimum: 301
[ 0.031790] Security Framework initialized
[ 0.036310] AppArmor: AppArmor disabled by boot time parameter
[ 0.042795] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.050185] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.060000] ASID allocator initialised with 32768 entries
[ 0.066141] rcu: Hierarchical SRCU implementation.
[ 0.074359] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.082111] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.092647] smp: Bringing up secondary CPUs …
[ 0.106237] Detected VIPT I-cache on CPU1
[ 0.106278] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.106330] CPU1: using LPI pending table @0x00000000ee850000
[ 0.106389] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.115085] Detected VIPT I-cache on CPU2
[ 0.115120] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.115174] CPU2: using LPI pending table @0x00000000ee860000
[ 0.115224] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.123871] Detected VIPT I-cache on CPU3
[ 0.123903] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.123955] CPU3: using LPI pending table @0x00000000ee870000
[ 0.124002] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.124147] smp: Brought up 1 node, 4 CPUs
[ 0.205527] SMP: Total of 4 processors activated.
[ 0.210701] CPU features: detected: GIC system register CPU interface
[ 0.217782] CPU features: detected: Privileged Access Never
[ 0.223908] CPU features: detected: LSE atomic instructions
[ 0.230033] CPU features: detected: User Access Override
[ 0.235874] CPU features: detected: 32-bit EL0 Support
[ 0.241523] CPU features: detected: RAS Extension Support
[ 0.247648] CPU: All CPU(s) started at EL2
[ 0.252197] alternatives: patching kernel code
[ 0.264144] devtmpfs: initialized
[ 0.300000] Registered cp15_barrier emulation handler
[ 0.305611] Registered setend emulation handler
[ 0.310971] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.321699] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.329400] pinctrl core: initialized pinctrl subsystem
[ 0.336346] NET: Registered protocol family 16
[ 0.342467] audit: initializing netlink subsys (disabled)
[ 0.348694] audit: type=2000 audit(0.196:1): state=initialized audit_enabled=0 res=1
[ 0.357285] cpuidle: using governor menu
[ 0.361639] Registered FIQ tty driver
[ 0.366655] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.375671] DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.386007] persistent_ram: found existing invalid buffer, size 23953, start 23957
[ 0.395353] console [pstore-1] enabled
[ 0.399484] pstore: Registered ramoops as persistent store backend
[ 0.406281] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[ 0.454176] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.462048] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.469888] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.477686] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.485503] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.492715] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.517228] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.524862] cryptd: max_cpu_qlen set to 1000
[[ 0.531596] console [ttyFIQ0] enabled
[ 0.539318] bootconsole [uart8250] disabled
[ 0.544206] Registered fiq debugger ttyFIQ0
[ 0.545319] vcc3v3_sys: supplied by dc_12v
[ 0.545839] vcc5v0_sys: supplied by dc_12v
[ 0.548160] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.548704] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.549183] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.549699] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.550204] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.565788] rockchip-pm-domain fdd90000.power-management:power-controller: failed to get ack on domain ‘pd_npu’,
target_idle = 0, target_ack = 0, val=0x6
[ 0.565827] Kernel panic - not syncing: panic_on_set_idle set …
[ 0.565827]
[ 0.606790] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.19.232 #1
[ 0.612877] Hardware name: AIO-3568J HDMI (Linux) (DT)
[ 0.618011] Call trace:
[ 0.620479] dump_backtrace+0x0/0x188
[ 0.624145] show_stack+0x24/0x30
[ 0.627463] dump_stack+0x8c/0xb4
[ 0.630780] panic+0x138/0x2b0
[ 0.633847] rockchip_pmu_set_idle_request+0x1b4/0x1cc
[ 0.638983] rockchip_pd_power+0x294/0x2e8
[ 0.643082] rockchip_pd_power_on+0x2c/0x40
[ 0.647269] genpd_power_on.part.9+0x15c/0x1fc
[ 0.651718] __genpd_dev_pm_attach+0x1a8/0x1fc
[ 0.656167] genpd_dev_pm_attach+0x60/0x64
[ 0.660268] dev_pm_domain_attach+0x28/0x44
[ 0.664454] platform_drv_probe+0x40/0xa4
[ 0.668468] really_probe+0x2a8/0x3a4
[ 0.672132] driver_probe_device+0x124/0x134
[ 0.676411] device_driver_attach+0x50/0x7c
[ 0.680595] __driver_attach+0x13c/0x140
[ 0.684523] bus_for_each_dev+0x8c/0xd4
[ 0.688367] driver_attach+0x30/0x3c
[ 0.691947] bus_add_driver+0x1b4/0x1f8
[ 0.695790] driver_register+0xb8/0xf0
[ 0.699541] __platform_driver_register+0x58/0x64
[ 0.704245] rk_iommu_init+0x20/0x28
[ 0.707826] do_one_initcall+0xa0/0x1c0
[ 0.711672] kernel_init_freeable+0x330/0x334
[ 0.716036] kernel_init+0x18/0x108
[ 0.719531] ret_from_fork+0x10/0x18
[ 0.723114] SMP: stopping secondary CPUs
[ 0.727047] PMU CRU:
[ 0.729251] 00000000: 00006064 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.737776] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.746299] 00000040: 00002063 00001481 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.754833] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.763356] 00000080: 00000001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.771879] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.780403] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.788925] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.797448] 00000100: 00000080 0040b71b 00000001 00000001 00000800 00000000 00000001 00000009
[ 0.805970] 00000120: 0000050f 00008bbb 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.814492] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.823014] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.831536] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.840069] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.848590] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.857113] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.865636] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.874158] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.882674] 00000240: 00040020 00000000
[ 0.886514] CRU:
[ 0.888364] 00000000: 00002044 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.896887] 00000020: 00004082 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.905409] 00000040: 00002063 00001441 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.913931] 00000060: 0000107d 00001443 00000000 00000007 00007f00 00000000 00000000 00000000
[ 0.922452] 00000080: 00002064 00001441 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.930975] 000000a0: 0000307d 00001442 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.939496] 000000c0: 00000455 00000000 00000000 00000000 00640064 00000000 00000000 00000103
[ 0.948028] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.956551] 00000100: 00000000 00000000 00000001 00000303 00000303 00000111 00004191 00000011
[ 0.965074] 00000120: 00000053 00000100 00000001 00008000 00040004 00008000 00040004 00008000
[ 0.973597] 00000140: 00040004 00008000 00040004 00008000 00040004 00008000 00040004 00004000
[ 0.982120] 00000160: 00040004 0000000b 00000000 00000010 00001031 00001c30 00000520 00000004
[ 0.990642] 00000180: 00000020 00000004 00000310 0000c001 0000c0c0 00003100 00000001 00000000
[ 0.999165] 000001a0: 00000001 00000003 00000103 00002100 00000203 00000003 00000000 00000103
[ 1.007687] 000001c0: 00000003 00000301 00000001 00001300 0000200b 00000000 0000200b 00000000
[ 1.016210] 000001e0: 0000200b 00000000 0000200b 00000000 0000200b 00000000 0000200b 00000000
[ 1.024732] 00000200: 0000200b 00000000 0000200b 00000000 0000200b 00000000 00000303 00000203
[ 1.033256] 00000220: 00001500 00000000 0000001f 00000302 00000705 00000f0b 0000013b 00000303
[ 1.041779] 00000240: 00000f07 00002713 00001f09 00008000 00040004 00003b2f 00000101 00000302
[ 1.050300] 00000260: 00000704 0000130f 00001f27 00000000 00000000 00000000 00000000 00000000
[ 1.058823] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.067345] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.075876] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.084397] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.092929] 00000300: 00000000 00000000 00000000 00000000 00000000 00000000 00003333 0000c333
[ 1.101451] 00000320: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.109973] 00000340: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.118494] 00000360: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.127025] 00000380: 00000000 00000000 00004000 00000000 00000000 00000000 00000000 00000000
[ 1.135547] 000003a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.144078] 000003c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.152600] 000003e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.161122] 00000400: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.169654] 00000420: 00000000 00000000 00000002 00000002 00000002 00000000 00000000 00000000
[ 1.178177] 00000440: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.186700] 00000460: 00000000 00000000 00000400 00000000 000002a0 00000000 00000000 00000000
[ 1.195221] 00000480: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.203743] 000004a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.212273] 000004c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.220795] 000004e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.229327] 00000500: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 1.237849] 00000520: 00040020 00000000 00040020 00000000 00040020 00000000 00040020 00000000
[ 1.246381] 00000540: 00040020 00000000 00040020 00000000 00000000 00000000 00000000 00000000
[ 1.254913] 00000560: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.263428] 00000580: 00000004 00000000
[ 1.267271] CPU0 online:0
[ 1.269904] EL2(NS) PC: <0xffffff8008095498> handle_IPI+0x23c/0x2a0
[ 1.276328]
[ 1.277830] CPU1 online:0
[ 1.280461] EL2(NS) PC: <0xffffff8008095498> handle_IPI+0x23c/0x2a0
[ 1.286884]
[ 1.288386] CPU2 online:0
[ 1.291016] EL2(NS) PC: <0xffffff8008095494> handle_IPI+0x238/0x2a0
[ 1.297439]
[ 1.298941] CPU3 online:1
[ 1.301573] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.308799] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.316024] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.323249] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.330474] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.337700] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.344924] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.352150] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.359375] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.366602] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.373827] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.381054] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.388280] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.395505] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.402730] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.409956] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.417182] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.424408] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.431633] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.438859] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.446084] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.453312] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.460536] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.467763] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.474988] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.482214] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.489439] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.496666] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.503891] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.511118] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.518343] EL2(NS) PC: <0xffffff8008621220> rockchip_panic_notify+0x8c/0x244
[ 1.525570] EL2(NS) PC: <0xffffff800862121c> rockchip_panic_notify+0x88/0x244
[ 1.532787]
[ 1.534289] PMU:
[ 1.536142] 00000000: 03003566 00000e0c 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.544665] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.553188] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.561711] 00000060: 00000006 00000000 00000006 00000000 0000ffff 0000000f 00000000 00000000
[ 1.570234] 00000080: 00000000 00000000 00000000 00000002 00000000 00000000 00000001 00000000
[ 1.578757] 000000a0: 00000001 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[ 1.587280] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.595804] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.605708] —[ end Kernel panic - not syncing: panic_on_set_idle set …
[ 1.605708] ]—
log-2023-0410.rar (8.77 KB)
i2c0上挂着cpu、电源控制芯片,不能关闭
谢谢{:5_247:}
