Wallys:DR4018L-R-Qualcomm-IPQ4018-2T2R-Dual-Band-2-4GHz-5GHz--OpenWRT-802.11aX
D4018L-R
Website:
[b][u]https://www.wallystech.com/Routerboard/DR4018L-R-Qualcomm-IPQ4018-2T2R-Dual-Band-2-4GHz-5GHz-support-OpenWRT-802.11ac-Wave-2.html[/u][/b]
Featuring with industrial-grade IPQ4018 chipset
Integrated with 2x 2 5G Radio module and 2x2 Radio module
Support 5.180GHz to 5.825GHz Frequency Range
Support 2.412GHz to2.482GHz
Support 2 x 5G UFL Connectors and 2x2.4G UFL
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/802.11AC wave2 mode
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 12 V
Storage Temperature Range -65 to +105 ºC
Hardware Specifications
Symbol Parameter
CPU IPQ4018
Antenna Connector 4xUFL 10/100/1000Mbps Gigabit Ethernet 5xRJ45
SFP connector NO 3G/4G connector
NO USB connector1xUSB 3.0 connector
POE NO
DC Jack 12 power supply
ROHS Compliance YES
Dimension NA
Max Power 15W
Benefit:
Wallys Routerboard DR4018L-R is a high-performance router designed for enterprise-level networking applications. This routerboard is equipped with powerful hardware and software features that make it a top choice for businesses that require reliable and fast networking.
The DR4018L-R is powered by a quad-core ARM Cortex-A53 CPU, which provides high-speed processing capabilities. It also comes with 2GB of DDR4 RAM and 16GB of eMMC storage, ensuring that it can handle multiple network connections and heavy data traffic with ease.
One of the key features of the DR4018L-R is its support for dual-band 802.11ac Wi-Fi. This allows the router to provide fast and reliable wireless connectivity for devices that support the 5GHz frequency band. Additionally, the router comes with four Gigabit Ethernet ports, which provide fast wired connections for devices that require high-speed data transfer rates.
Another important feature of the DR4018L-R is its support for a range of network protocols, including TCP/IP, DHCP, PPPoE, and more. This makes it easy to set up and manage network connections, and ensures that the router is compatible with a wide range of networking equipment.
The DR4018L-R also comes with a range of security features, including support for WPA2-PSK encryption and MAC address filtering. This ensures that the router is secure and helps to prevent unauthorized access to the network.
In terms of management and configuration, the DR4018L-R offers a range of options. It can be managed using a web-based interface, which allows administrators to easily configure and monitor the router. Additionally, the router supports SNMP, allowing it to be integrated into larger network management systems.
Overall, the Wallys Routerboard DR4018L-R is a high-performance router that offers a range of features and capabilities that make it a great choice for enterprise-level networking applications. With its powerful hardware and software features, as well as its support for a range of network protocols and security features, it is well-suited to handle the demands of even the most complex network environments.
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
