我司购买的你们的 3588 核心板 装在我们自己设计的底板上,使用你们提供的sdk无法启动 。
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-444-g1450d21e8:derrick.huang
NOTICE: BL31: Built : 16:25:50, Oct 12 2022
INFO: spec: 0x1
INFO: ext 32k is not valid
INFO: ddr: stride-en 4CH
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing BL32
INFO: hdmirx_handler: dma not on, ret
I/TC:
I/TC: OP-TEE version: 3.13.0-652-g4542e1efd #derrick.huang (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 2022年 09月 20日 星期二 09:41:09 CST aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: e8b5ef0c39)(sdk version: rk3588_linux_release_20221117_v1.0.4b)-ge8b5ef0c39 #lvsx (Nov 25 2Model: Rockchip RK3588 Evaluation Board
PreSerial: 2, raw, 0xfeb50000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: eda1c000
Relocation fdt: eb9f9fb8 - eb9fecc0
CR: M/C/I
mmc@fe2c0000: 1, mmc@fe2e0000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v2
boot mode: recovery (misc)
=================begin===================
165145 bytes read in 7 ms (22.5 MiB/s)
DTB(Distro): rk-kernel.dtb
I2c0 speed: 100000Hz
vsel-gpios- not found!
en-gpios- not found!
vdd_cpu_big0_s0 800000 uV
vdd_cpu_big1_s0 800000 uV
I2c1 speed: 100000Hz
vdd_npu_s0 800000 uV
spi2: RK806: 2
ON=0x00, OFF=0x00
vdd_gpu_s0 750000 uV
vdd_cpu_lit_s0 750000 uV
vdd_log_s0 750000 uV
vdd_vdenc_s0 init 750000 uV
vdd_ddr_s0 850000 uV
I2c6 speed: 400000Hz
Error reading output register
rockchip_panel_probe: Cannot get enable GPIO: -110
get vp0 plane mask:0x5, primary id:2, cursor_plane:-1, from dts
get vp1 plane mask:0xa, primary id:3, cursor_plane:-1, from dts
get vp2 plane mask:0x140, primary id:8, cursor_plane:-1, from dts
get vp3 plane mask:0x280, primary id:9, cursor_plane:-1, from dts
pre init conn error
Model: Firefly ITX-3588J MIPI101(Android)
vp0 have layer nr:2[0 2 ], primary plane: 2
vp1 have layer nr:2[1 3 ], primary planee: 8
vp3 have layer nr:2[7 9 ], primary plane: 9
hdmi@fde80000 disconnected
edid base block is 0, get edid failed
can’t get edid block:0
failed to get edid
color_format:0
hdmi_select_link_config use tmds mode
mode:1920x1080 bus_format:0x100a
hdmi@fdea0000: detailed mode clock 148500 kHz, flags[5]
H: 1920 2008 2052 2200
V: 1080 1084 1089 1125
bus_format: 100a
VOP update mode to: 1920x1080p60, type: HDMI1 for VP1
dclk:148500,if_pixclk_div;2,if_dclk_div:4
hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
hdptx phy pll locked!
VP1 set crtc_clock to 1485KHz
VOP VP1 enable Esmart1[500x501->500x501@710x289] fmt[2] addr[0xedf20000]
CEA mode used vic=16
mtmdsclock:148500000
dw_hdmi_setup HDMI mode
don’t use dsc mode
dw hdmi qp use tmds mode
bus_width:0x16a8c8,bit_rate:1485000
hdptx phy lane locked!
CLK: (uboot. arm: enter 1008000 KHz, init 1008000 KHz, kernel 0N/A)
b0pll 24000 KHz
b1pll 00 KHz
v0pll 24000 KHz
aupll 786431 KHz
cpll 1500000 KHz
gpll 1188000 KHz
npll 850000 KHz
ppll 1100000 KHz
aclk_center_root 702000 KHz
pclk_center_root 100000 KHz
hclk_center_root 396000 KHz
aclk_center_low_root 500000 KHz
aclk_top_root 594000 KHz
pclk_top_root 100000 KHz
aclk_low_top_root 396000 KHz
Net: eth0: ethernet@fe1b0000, eth1: ethernet@fe1c0000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image at 0xe6cc5980 with size 0x04b33600
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e6cc5980 …
Using ‘conf’ configuration
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe6cee780
Data Size: 41753088 Bytes = 39.8 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00400000
Entry Point: 0x00400000
Hash algo: sha256
Hash value: 32702911fc993c38188c0210e7ac59b843d701d06320456a6c9f493c2b1cedec
Verifying Hash Integrity … sha256+ OK
## Loading ramdisk from FIT Image at e6cc5980 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xe94c0180
Data Size: 36932945 Bytes = 35.2 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 993174280a559715c65c49c171ee705cba9c0043aa3dcea430d4bae4a474bb1e
Loading ramdisk from 0xe94c0180 to 0x0a200000
## Loading fdt from FIT Image at e6cc5980 …
Trying ‘fdt’ fd
Type: Flat Device Tree
Data Start: 0xe6cc6180
Data Size: 165145 Bytes = 161.3 KiB
Load Address: 0x08300000
Hash algo: sha256
Hash value: cfcd08da4812577ac619e78b7c0de9edae86c25328d503499df7bf7762d866b0
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0xe6cee780 to 0x00400000 … OK
kernel loaded at 0x00400000, end = 0x02bd1a00
‘reserved-memory’ cma: addr=10000000 size=10000000
Using Device Tree in place at 0000000008300000, end 000000000832b518
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Total: 4725.58 ms
[ 4.852376] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 4.852399] Linux version 5.10.110 (lvsx@tchip14) (ke 4a55b55733a0) (sdk version: rk3588_linux_release_20221117_v1.0.4b) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld -profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #4 SMP Thu Nov 24 10:42:13 CST 2022
[ 4.859541] Machine model: Firefly ITX-3588J MIPI101(Android)
[ 4.859619] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 4.864397] printk: bootconsole [uart8250] enabled
[ 4.866513] efi: UEFI not found.
[ 4.870645] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 4.871790] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 4.872528] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 4.981049] Zone ranges:
[ 4.981292] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 4.981863] DMA32 em4.982129] Normal [mem 0x000000000000-0x00000001ffffffff]
[ 4.982695] Movable zone start for each node
[ 4.983085] Early memory node ranges
[ 4.983413] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 4.983986] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 4.984560] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 4.985134] Initmem setup node 0 [mem 0x0000000000200000-0x00000001ffffffff]
[ 5.029563] psci: probing for conduit method from DT.
[ 5.030031] psci: PSCIv1.1 detected in firmware.
[ 5.030453] psci: Using standard PSCI v0.2 function IDs
[ 5.030933] psci: Trusted OS migration not required
[ 5.031381] psci: SMC Calling Convention v1.2
[ 5.032148] percpu: Embedded 32 pages/cpu s93160 r8192 d29720 u131072
[ 5.032937] Detected VIPT I-cache on CPU0
[ 5.033336] CPU features: detected: GIC system register CPU interface
[ 5.033925] CPU features: detected: Virtualization Host Extensions
[ 5.034494] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 5.035137] alternatives: patching kernel code
[ 5.037531] Built 1 zonelists, mobility grouping on. Total pages: 1995336
[ 5.038165] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/mmc@fe2e0000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 5.042591] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 5.043689] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 5.044406] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 5.050856] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 5.110138] Memory: 7544012K/8108032K available (22336K kernel code, 3782K rwdata, 6888K rodata, 7616K init, 656K bss, 301876K reserved, 262144K cma-reserved)
[ 5.111542] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 5.112166] ftrace: allocating 67395 entries in 264 pages
[ 5.205046] ftrace: allocated 264 pages with 2 groups
[ 5.205753] rcu: Hierarchical RCU implementation.
[ 5.206188] rcu: RCU event tracing is enabled.
[ 5.206603] Rude variant of Tasks RCU enabled.
[ 5.207018] Tracing variant of Tasks RCU enabled.
[ 5.207456] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 5.212857] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 5.215194] GICv3: GIC: Using split EOI/Deactivate mode
[ 5.215676] GICv3: 480 SPIs implemented
[ 5.216027] GICv3: 0 Extended SPIs implemented
[ 5.216456] GICv3: Distributor has no Range Selector support
[ 5.216978] GICv3: 16 PPIs implemented
[ 5.217361] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 5.218085] ITS [mem 0xfe640000-0xfe65ffff]
[ 5.218508] ITS@0x00000000fe640000: allocated 8192 Devices @100220000 (indirect, esz 8, psz 64K, shr 0)
[ 5.219381] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100230000 (flat, esz 2, psz 64K, shr 0)
[ 5.220328] ITS: using cache flushing for cmd queue
[ 5.220800] ITS [mem 0xfe660000-0xfe67ffff]
[ 5.221218] ITS@0x00000000fe660000: allocated 8192 Devices @100250000 (indirect, esz 8, psz 64K, shr 0)
[ 5.222092] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100260000 (flat, esz 2, psz 64K, shr 0)
[ 5.223038] ITS: using cache flushing for cmd queue
[ 5.223608] GICv3: using LPI property table @0x0000000100270000
[ 5.224253] GIC: using cache flushing for LPI property table
[ 5.224774] GICv3: CPU0: using allocated LPI pending table @0x0000000100280000
[ 5.225574] random: get_random_bytes called from start_kernel+0x3f0/0x65c with crng_init=0
[ 5.333866] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 5.335188] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 5.336183] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 5.337777] Console: colour dummy device 80x25
[ 5.338211] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 5.339159] pid_max: default: 32768 minimum: 301
[ 5.339664] LSM: Security Framework initializing
[ 5.340146] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 5.340856] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 5.343001] rcu: Hierarchical SRCU implementation.
[ 5.344175] Platform MSI: msi-controller@fe640000 domain created
[ 5.344740] Platform MSI: msi-controller@fe660000 domain created
[ 5.345544] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 5.346318] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 5.347172] EFI services will not be available.
[ 5.347844] smp: Bringing up secondary CPUs …
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
[ 5.349376] Detected VIPT I-cache on CPU1
[ 5.349402] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 5.349416] GICv3: CPU1: using allocated LPI pending table @0x0000000100290000
[ 5.349456] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 5.350618] Detected VIPT I-cache on CPU2
[ 5.350639] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 5.350653] GICv3: CPU2: using allocated LPI pending table @0x00000001002a0000
[ 5.350689] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 5.351822] Detected VIPT I-cache on CPU3
[ 5.351841] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 5.351853] GICv3: CPU3: using allocated LPI pending table @0x00000001002b0000
[ 5.351886] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 5.353047] CPU features: detected: Spectre-v4
[ 5.353049] CPU features: detected: Spectre-BHB
[ 5.353051] Detected PIPT I-cache on CPU4
[ 5.353062] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 5.353070] GICv3: CPU4: using allocated LPI pending table @0x00000001002c0000
[ 5.353092] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 5.354186] Detected PIPT I-cache on CPU5
[ 5.354197] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 5.354205] GICv3: CPU5: using allocated LPI pending table @0x00000001002d0000
[ 5.354227] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 5.355331] Detected PIPT I-cache on CPU6
[ 5.355342] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 5.355349] GICv3: CPU6: using allocated LPI pending table @0x00000001002e0000
[ 5.355371] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 5.356461] Detected PIPT I-cache on CPU7
[ 5.356471] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 5.356479] GICv3: CPU7: using allocated LPI pending table @0x00000001002f0000
[ 5.356501] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 5.356553] smp: Brought up 1 node, 8 CPUs
[ 5.373684] SMP: Total of 8 processors activated.
[ 5.374124] CPU features: detected: Privileged Access Never
[ 5.374637] CPU features: detected: User Access Override
[ 5.375126] CPU features: detected: 32-bit EL0 Support
[ 5.375600] CPU features: detected: Common not Private translations
[ 5.376177] CPU features: detected: RAS Extension Support
[ 5.376674] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 5.377471] CPU features: detected: CRC32 instructions
[ 5.377944] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 5.378587] CPU features: detected: RCpc load-acquire (LDAPR)
[ 5.379183] CPU: All CPU(s) started at EL2
[ 5.381520] devtmpfs: initialized
[ 5.389414] Registered cp15_barrier emulation handler
[ 5.389882] Registered setend emulation handler
[ 5.390363] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 5.391259] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 5.391994] pinctrl core: initialized pinctrl subsystem
[ 5.392667] DMI not present or invalid.
[ 5.393111] NET: Registered protocol family 16
[ 5.393927] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 5.394646] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 5.395372] audit: initializing netlink subsys (disabled)
[ 5.395912] audit: type=2000 audit(0.056:1): state=initialized audit_enabled=0 res=1
[ 5.396308] thermal_sys: Registered thermal governor ‘fair_share’
[ 5.396625] thermal_sys: Registered thermal governor ‘step_wise’
[ 5.397188] thermal_sys: Registered thermal governor ‘user_space’
[ 5.397739] thermal_sys: Registered thermal governor ‘power_allocator’
[ 5.398394] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 5.399744] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 5.400495] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 5.401250] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 5.402003] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 5.402756] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 5.403500] cpuidle: using governor menu
[ 5.403863] Registered FIQ tty driver
[ 5.404299] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 5.405010] ASID allocator initialised with 65536 entries
[ 5.406422] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 5.406910] ramoops: console 0x80000@0x0000000000130000
[ 5.407396] ramoops: pmsg 0x50000@0x00000000001b0000
[ 5.408069] printk: console [ramoops-1] enabled
[ 5.408490] pstore: Registered ramoops as persistent store backend
[ 5.409056] ramoops: using 0xf0000@0x110000, ecc: 0
[ 5.440862] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 5.441631] rockchip-gpio fec20000.gpio: probed /pnctrl/gpio@fec20000
[ 5.442398] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 5.443178] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 5.443945] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 5.444564] rockchip-pinctrl pinctrl: probed pinctrl
[ 5.452797] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 5.453412] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 5.454026] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 5.454640] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 5.514290] raid6: neonx8 gen() 5934 MB/s
[ 5.571011] raid6: neonx8 xor() 4688 MB/s
[ 5.627733] raid6: neonx4 gen() 5832 MB/s
[ 5.684453] raid6: neonx4 xor() 4985 MB/s
[ 5.741176] raid6: neonx2 gen() 5590 MB/s
[ 5.797897] raid6: neonx2 xor() 4425 MB/s
[ 5.854620] raid6: neonx1 gen() 4621 MB/s
[ 5.911339] raid6: neonx1 xor() 3836 MB/s
[ 5.968065] raid6: int64x8 gen() 2779 MB/s
[ 6.024786] raid6: int64x8 xor() 1646 MB/s
[ 6.081508] raid6: int64x4 gen() 3135 MB/s
[ 6.138229] raid6: int64x4 xor() 1654 MB/s
[ 6.194951] raid6: int64x2 gen() 2655 MB/s
[ 6.251669] raid6: int64x2 xor() 1431 MB/s
[ 6.308393] raid6: int64x1 gen() 2176 MB/s
[ 6.365114] raid6: int64x1 xor() 1143 MB/s
[ 6.365506] raid6: using algorithm neonx8 gen() 5934 MB/s
[ 6.366003] raid6: … xor() 4688 MB/s, rmw enabled
[ 6.366458] raid6: using neon recovery algorithm
[ 6.367297] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 6.367803] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 6.368332] fiq_debugger_probe: could not install nmi irq handltk: console [ttyFIQ0] enabled
6.368929] printk: console [ttyFIQ0] enabled
[ 6.369713] printk: bootconsole [uart8250] disabled
[ 6.370229] Registered fiq debugger ttyFIQ0
[ 6.370505] vcc5v0_sys: supplied by vcc12v_dcin
[ 6.370590] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 6.370669] vcc5v0_usb: supplied by vcc12v_dcin
[ 6.370748] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 6.370881] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 6.371097] iommu: Default domain type: Passthrough
[ 6.371154] rk_iommu fdab9000.iommu: version = 2
[ 6.371423] rk_iommu fdb50800.iommu: version = 2
[ 6.371614] rk_iommu fdb60f00.iommu: version = 2
[ 6.371751] rk_iommu fdb70f00.iommu: version = 2
[ 6.371880] rk_iommu fdb90480.iommu: version = 2
[ 6.372025] rk_iommu fdba0800.iommu: version = 2
[ 6.372176] rk_iommu fdba4800.iommu: version = 2
[ 6.372321] rk_iommu fdba8800.iommu: version = 2
[ 6.372468] rk_iommu fdbac800.iommu: version = 2
[ 6.372613] rk_iommu fdbb0800.iommu: version = 2
[ 6.372755] rk_iommu fdbdf000.iommu: version = 2
[ 6.372962] rk_iommu fdbef000.iommu: version = 2
[ 6.373192] rk_iommu fdc38700.iommu: version = 2
[ 6.373421] rk_iommu fdc48700.iommu: version = 2
[ 6.373585] rk_iommu fdce0800.iommu: version = 2
[ 6.373670] rk_iommu fdd97e00.iommu: version = 2
[ 6.373903] usbcore: registered new interface driver usbfs
[ 6.373915] usbcore: registered new interface driver hub
[ 6.373927] usbcore: registered new device driver usb
[ 6.373953] mc: Linux media interface: v0.10
[ 6.373962] videodev: Linux video capture interface: v2.00
[ 6.373983] pps_core: LinuxPPS API ver. 1 registered
[ 6.373987] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 6.373992] PTP clock support registered
[ 6.374187] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 6.374215] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 6.375028] Advanced Linux Sound Architecture Driver Initialized.
[ 6.375183] Bluetooth: Core ver 2.22
[ 6.375194] NET: Registered protocol family 31
[ 6.375196] Bluetooth: HCI device and connection manager initialized
[ 6.375201] Bluetooth: HCI socket layer initialized
[ 6.375205] Bluetooth: L2CAP socket layer initialized
[ 6.375211] Bluetooth: SCO socket layer initialized
[ 6.376459] rockchip-cpuinfo cpuinfo: SoC : 35881000
[ 6.376464] rockchip-cpuinfo cpuinfo: Serial : 3a688a2fa1912ae4
[ 6.376690] clocksource: Switched to clocksource arch_sys_counter
[ 6.623491] NET: Registered protocol family 2
[ 6.623584] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 6.625391] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes, linear)
[ 6.625465] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 6.625782] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 6.626505] TCP: Hash tables configured (established 65536 bind 65536)
[ 6.626549] UDP hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 6.626697] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes, linear)
[ 6.626879] NET: Registered protocol family 1
[ 6.627110] RPC: Registered named UNIX socket transport module.
[ 6.627114] RPC: Registered udp transport module.
[ 6.627117] RPC: Registered tcp transport module.
[ 6.627119] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 6.627420] PCI: CLS 0 bytes, default 64
[ 6.627640] Trying to unpack rootfs image as initramfs…
[ 7.150481] Freeing initrd memory: 36064K
[ 7.151023] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 7.151491] kvm [1]: IPA Size Limit: 40 bits
[ 7.151502] kvm [1]: GICv3: no GICV resource entry
[ 7.151505] kvm [1]: disabling GICv2 emulation
[ 7.151508] kvm [1]: GIC system register CPU interface enabled
[ 7.151604] kvm [1]: vgic interrupt IRQ9
[ 7.151725] kvm [1]: VHE mode initialized successfully
[ 7.153789] Initialise system trusted keyrings
[ 7.153869] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 7.155676] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 7.155908] NFS: Registering the id_resolver key type
[ 7.155918] Key type id_resolver registered
[ 7.155920] Key type id_legacy registered
[ 7.155926] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 7.156480] Key type cifs.spnego registered
[ 7.156485] Key type cifs.idmap registered
[ 7.156490] ntfs: driver 2.1.32 [Flags: R/O].
[ 7.156536] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 7.156612] fuse: init (API version 7.32)
[ 7.156728] SGI XFS with security attributes, no debug enabled
[ 7.176453] NET: Registered protocol family 38
[ 7.176460] xor: measuring software checksum speed
[ 7.177795] 8regs : 7425 MB/sec
[ 7.178905] 32regs : 8902 MB/sec
[ 7.179737] arm64_neon : 11888 MB/sec
[ 7.179741] xor: using function: arm64_neon (11888 MB/sec)
[ 7.179747] Key type asymmetric registered
[ 7.179750] Asymmetric key parser ‘x509’ registered
[ 7.179765] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 7.179839] io scheduler mq-deadline registered
[ 7.179844] io scheduler kyber registered
[ 7.180285] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 7.180512] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 7.182297] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 7.182637] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 7.183107] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 7.185022] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 7.185604] rockchip-hdptx-phy-hdmi fed70000.hdmiphy: hdptx phy init success
[ 7.186583] Firefly gpio driver init!
[ 7.186663] Firefly gpio driver register return : 0
[ 7.187598] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node
[ 7.187719] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 7.187730] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 7.187848] pwm-backlight backlight: supply power not found, using dummy regulator
[ 7.187864] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 7.187873] rk-pcie fe170000.pcie: IRQ msi not found
[ 7.187876] rk-pcie fe170000.pcie: use outband MSI support
[ 7.187880] rk-pcie fe170000.pcie: Missing config reg space
[ 7.187886] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 7.187897] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 7.187929] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 7.187935] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 7.187939] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 7.187960] rk-pcie fe170000.pcie: Missing config reg space
[ 7.187981] rk-pcie fe170000.pcie: invalid resource
[ 7.188077] iep: Module initialized.
[ 7.188103] mpp_service mpp-srv: 75e32fd43421 author: daijh 2022-11-02 Merge branch ‘rk3588/rockchip’ into rk3588/firefly
[ 7.188107] mpp_service mpp-srv: probe start
[ 7.189374] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 7.189392] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.189562] mpp_vdpu2 fdb50400.vdpu: probe device
[ 7.189646] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 7.189652] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 7.189748] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 7.189912] mpp_vepu2 jpege-ccu: probing start
[ 7.189917] mpp_vepu2 jpege-ccu: probing finish
[ 7.189995] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 7.190006] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.190136] mpp_vepu2 fdba0000.jpege-core: probing start
[ 7.190219] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 7.190304] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 7.190377] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 7.190386] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.190503] mpp_vepu2 fdba4000.jpege-core: probing start
[ 7.190577] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 7.190661] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 7.190743] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 7.190752] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.190880] mpp_vepu2 fdba8000.jpege-core: probing start
[ 7.190955] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 7.191048] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 7.191120] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 7.191129] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.191239] mpp_vepu2 fdbac000.jpege-core: probing start
[ 7.191310] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 7.191392] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 7.191614] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 7.191623] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.191734] mpp-iep2 fdbb0000.iep: probe device
[ 7.191825] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 7.191906] mpp-iep2 fdbb0000.iep: probing finish
[ 7.192076] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 7.192085] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.192252] mpp_jpgdec fdb90000.jpegd: probe device
[ 7.192414] mpp_jpgdec fdb90000.jpegd: probing finish
[ 7.192692] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 7.192734] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 7.192798] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 7.192807] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 7.394458] rk-pcie fe170000.pci
370.pdf (1.1 MB)
