If you’re looking for a high-performance routerboard that can handle heavy traffic and provide seamless connectivity, the DR8072(HK09) is an excellent choice. This routerboard is designed to deliver exceptional speed and reliability, thanks to its advanced hardware and software features.
Website:
Wally’s Routerboard DR8072(HK09) is a compact and powerful network router designed for small to medium-sized businesses and home users. This routerboard is manufactured by Wally Technologies, a company that specializes in providing high-quality networking products and services.
The DR8072(HK09) model is equipped with a dual-core ARM Cortex-A9 processor running at 1.2 GHz and 1GB of DDR3 RAM. It also features 4 Gigabit Ethernet ports, 2 USB 2.0 ports, and 1 RS-232 port. The routerboard is powered by a 12V DC power supply and has a maximum power consumption of 9W.
One of the standout features of the DR8072(HK09) is its support for multiple network protocols, including IPv4, IPv6, and MPLS. It also supports dynamic routing protocols such as OSPF, BGP, and RIP, making it suitable for use in complex network environments. Additionally, the routerboard supports advanced QoS (Quality of Service) features, including packet filtering, traffic shaping, and bandwidth management, ensuring smooth and efficient data transfer.
The DR8072(HK09) is also designed with security in mind, featuring a built-in firewall and support for VPN (Virtual Private Network) protocols such as PPTP, L2TP, and OpenVPN. It also supports hotspot and captive portal functionality, enabling network administrators to control access to their network and ensure secure communication.
In terms of software, the DR8072(HK09) runs on RouterOS, a Linux-based operating system developed by Wally Technologies specifically for their networking devices. RouterOS provides a user-friendly interface for configuring and managing the router, as well as advanced networking features such as routing, firewall, and bandwidth management.
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
MiniPCIe Slot 1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons 1x S/W Reset Button
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port
2x USB 3.0 Port 1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
Overall, the Wally’s Routerboard DR8072(HK09) is a high-performance, versatile, and secure router that is well-suited for small to medium-sized businesses and home users who require reliable and efficient network connectivity.
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:sales4@wallystech.com
