Wallys// DR80729(HK09)VS DR8072V01 Qualcomm-IPQ8072A support-OpenWRT-802.11AX
Wallys Routerboard DR8072 (HK09) and DR8072 V01 are two different versions of the same routerboard model manufactured by Wallys Communications. There are a few key differences between the two versions that are worth noting.
The first and most obvious difference is the model number itself. The HK09 version of the DR8072 was the original version released by Wallys, while the V01 version is a newer iteration of the same model.
One of the most significant differences between the two versions is the processing power. The DR8072 V01 has a more powerful CPU, with a 1.2GHz quad-core ARM Cortex-A53 processor, while the HK09 version has a 1GHz dual-core ARM Cortex-A9 processor. This means that the V01 version should be able to handle more demanding tasks and higher traffic volumes than the HK09 version.
Another difference between the two versions is the amount of RAM. The DR8072 V01 has 2GB of RAM, while the HK09 version has only 1GB. This means that the V01 version should be able to handle more concurrent connections and larger data transfers than the HK09 version.
Finally, the DR8072 V01 has a few additional features that are not present in the HK09 version. These include support for hardware-accelerated encryption and decryption, as well as support for VLAN tagging and advanced QoS features.
In summary, while both the HK09 and V01 versions of the Wallys Routerboard DR8072 are capable and reliable routers, the V01 version offers better processing power, more RAM, and additional features that make it better suited for demanding network environments.
Different parameters
  1. DR8072(HK09)
Website:
[u]https://www.wallystech.com/Routerboard/DR8072A-HK09-wifi6-Qualcomm-IPQ8072A-4T4R-2-2.5GE-port-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html[/u]
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
MiniPCIe Slot 1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons 1x S/W Reset Button
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port
2x USB 3.0 Port 1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR8072V01:
Website:
[u]https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html[/u]
Features
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Symbol Parameter
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
Flash
NOR Flash: 8 MB
NAND Flash: 256MB(1GB optional)
Wireless On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain 8x U.FL Connectors
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
Our company:
Wallys Communications (Suzhou) Co., LTD [u]www.wallystech.com/index.html[/u]
EMAIL:​[u]sales4@wallystech.com[/u]
