Wallys QCN9074|QCN9024 5G & WiFi6E Network Cards
QCN9074 is a system-on-chip (SoC) designed by Qualcomm for use in mobile devices such as smartphones and tablets. It is part of the Snapdragon series of processors and is the company’s first 5G modem-integrated mobile chipset.
Wally’s Network Card DR9074E, DR9074(5G), and DR90746E are all network interface cards based on QCN9074 (NICs) designed for use in computer systems.
The DR9074E is a 1GbE network card that supports both copper and fiber connections. It features PCI Express 2.0 x1 interface and supports Wake-on-LAN (WoL), VLAN tagging, and Jumbo Frames. It is designed to provide high performance and reliability in a low-profile design, making it suitable for use in small form factor (SFF) systems.
The DR9074(5G) is a 5GbE network card that supports copper connections. It features PCI Express 3.0 x4 interface and supports WoL, VLAN tagging, and Jumbo Frames. It is designed to provide high-speed connectivity for data-intensive applications, such as high-definition video streaming and large file transfers.
The DR90746E is a 10GbE network card that supports both copper and fiber connections. It features PCI Express 3.0 x8 interface and supports WoL, VLAN tagging, and Jumbo Frames. It is designed to provide high-performance networking for demanding applications, such as data centers, high-performance computing (HPC), and cloud computing.
All three NICs are compatible with Windows, Linux, and VMware operating systems, and are designed to deliver low latency, high throughput, and efficient use of CPU resources. They are also equipped with advanced features such as TCP/IP offloading and checksum offloading to further improve network performance.
In summary, Wally’s Network Card DR9074E, DR9074(5G), and DR90746E are all high-performance network interface cards designed for use in various computer systems. They offer different levels of network speed and connectivity options to meet different application requirements, and are equipped with advanced features to enhance network performance.
Parameters of the product
1.DR9074E
Website:[b][u]https://www.wallystech.com/Network_Card/DR9074E-Qualcomm-QCN9074-QCN9024-WiFi6-and-WiFi6E-4x4-MU-MIMO-Dual-Band-WiFi-Module-MiniPCIe.html[/u][/b]
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Data Rateup to 4949Mbps
■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to 70ºC
Storage Temperature Range -40 to 90ºC
Storage Humidity Range 0 to +90 (non-condensing)%
Hardware Specifications
Symbol Parameter
Qualcomm Atheros QCN9074(QCN9024)
WLAN Host Interface PCI Express 3.0 Interface
System Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 3.3V
Operating Systems QSDK
Host Interface MiniPCIE
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range 5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALN Maxim TX power 20dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN Support 20/40/80/160MHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Power Consumption 15W(Maximum),9.5W(Normally)
Dimensions (WxHxD) 30mm x 50mm x 14.5mm
2.DR9074-5G(PN02.1)
Website:
[b][u]https://www.wallystech.com/Network_Card/DR9074-5G-PN02.1-Wifi-6-Qualcomm-QCN9074-Single-Band-5-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html[/u][/b]
Features
■ Qualcomm Atheros QCN9074
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
■ Supports Dynamic Frequency Selection (DFS)
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074
WLAN Host Interface
System Memory
Standard Operating Voltage 5V
Host Interface M.2 E Key
Antenna Cable / Port4 x MMCX Connectors,4T4R
Frequency Range 5.15GHz-5.95GHz
Data Rates for WALN 5GHz, max 23dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN Support 20/40/80/160MHz at 5GHz
Certification
TBD Power Consumption
TBD
Reference DesignPN02.1
Dimensions (WxHxD) 57mm x 63mm x 6mm
  1. DR9074-6E(PN02.7)
Website:[b][u]https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-Interface-802-11ax.html[/u][/b]
Features
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
Symbol Parameter Chipset
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Channel Spectrum Widths for WLAN Support 20/40/80/160MHz at 6GHz
Certification TBD
Power Consumption TBD
Reference Design PN02.7
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
