iCore-3568JQ , WIFI AP6275 不能启动
SDK包名称:rk3568_linux_release_20230114
SDK修改内容:WIFI 部分未修改
Log日志:log.zip
[ 668.243678] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 668.244432] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 668.244936] wifi_platform_set_power = 1, delay: 200 msec
[ 668.245414] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 668.245880] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 668.246302] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 668.246893] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 668.553398] sdio_reset_comm():
[ 668.673540] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 668.691695] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 668.705135] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 668.707513] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 668.709839] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 668.713768] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 668.817397] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 10000000Hz, actual 375000HZ div = 0)
[ 668.819138] sdioh_start: set sd_f2_blocksize 256
[ 668.826400]
[ 668.826400]
[ 668.826400] dhd_bus_devreset: == Power ON ==
[ 668.828973] F1 signature read @0x18000000=0x1042aae8
[ 668.913357] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 668.930272] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 668.931949] dhd_bus_devreset: making DHD_BUS_DOWN
[ 668.933160] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 668.936827] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 668.937630] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 668.938450] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 668.939243] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 668.940191] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 668.949245] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43752a2_ag.bin (743607 bytes) open success
[ 687.378710] dhd_os_open_image1: /vendor/etc/firmware/nvram_ap6275s.txt (8361 bytes) open success
[ 687.379619] NVRAM version: AP6275S_NVRAM_V1.2.1_20200311
[ 687.659509] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 687.738499] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 687.746156] bcmsdh_oob_intr_register: HW_OOB irq=111 flags=0x4
[ 687.747800] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 687.748537] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 692.964190] dhd_bus_rxctl: resumed on timeout, INT status=0x20A000C0
[ 692.979196] Dump dongle memory
[ 724.540832] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 724.541630] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 724.542394] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=36807
[ 724.543408] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c0908e, buf¶=1f5c0908e, bufsize=36807
[ 724.544265] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=36807
[ 724.545079] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 724.545840] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 724.546744] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 724.547554] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 724.548339] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 724.549086] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 724.550020] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 724.550831] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 724.551614] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 724.552410] dhd_schedule_memdump: scheduling mem dump..
[ 724.552918] dhd_bus_rxctl: rxcnt_timeout=1, rxlen=0
[ 724.554363] Dump dongle memory
[ 756.203606] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 756.204404] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 756.205168] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=38341
[ 756.205989] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c0968c, buf¶=1f5c0968c, bufsize=38341
[ 756.206954] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=38341
[ 756.207778] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 756.208542] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 756.209326] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 756.210231] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 756.211045] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 756.211806] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 756.212589] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 756.213534] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 756.214320] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 756.215117] dhd_schedule_memdump: scheduling mem dump..
[ 756.215619] dhd_deferred_schedule_work: failed to schedule deferred work, priority=2, bytes_copied=0
[ 756.216480] dhd_check_hang: Event HANG send up due to re=1 te=0 e=-110 s=2
[ 756.217236]
[ 756.217415] dhd_os_send_hang_message: device is not ready
[ 761.230935] dhd_bus_rxctl: resumed on timeout, INT status=0x20A000C0
[ 761.246937] Dump dongle memory
[ 792.698941] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 792.699739] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 792.700631] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=40200
[ 792.701468] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c09dcf, buf¶=1f5c09dcf, bufsize=40200
[ 792.702291] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=40200
[ 792.703102] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 792.703969] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 792.704769] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 792.705567] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 792.706351] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 792.707217] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 792.708017] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 792.708814] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 792.709597] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 792.710539] dhd_schedule_memdump: scheduling mem dump..
[ 792.711055] dhd_deferred_schedule_work: failed to schedule deferred work, priority=2, bytes_copied=0
[ 792.711889] dhd_bus_rxctl: rxcnt_timeout=2, rxlen=0
[ 792.713261] Dump dongle memory
[ 824.248178] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 824.248977] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 824.249742] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=41839
[ 824.250696] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c0a436, buf¶=1f5c0a436, bufsize=41839
[ 824.251529] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=41839
[ 824.252341] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 824.253100] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 824.253992] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 824.254802] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 824.255588] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 824.256324] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 824.257212] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 824.258021] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 824.258805] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 824.259601] dhd_schedule_memdump: scheduling mem dump..
[ 824.260206] dhd_deferred_schedule_work: failed to schedule deferred work, priority=2, bytes_copied=0
[ 824.261078] dhd_check_hang: Event HANG send up due to re=2 te=0 e=-110 s=2
[ 824.261722]
[ 824.261886] dhd_os_send_hang_message: device is not ready
[ 824.262393] dhd_dbg_detach_pkt_monitor, 2100
[ 824.262807] dhd_bus_devreset: == Power OFF ==
[ 830.350119] dhdsdio_advertise_bus_cleanup : Timeout due to dhd_bus_busy_state=0x1000
[ 830.354146] dhd_bus_stop: making DHD_BUS_DOWN
[ 830.355267] bcmsdh_oob_intr_unregister: Enter
[ 830.355787] dhd_bus_devreset: making dhdpub up FALSE
[ 830.356257] dhd_txglom_enable: enable 0
[ 830.356831] dhd_bus_devreset: making DHD_BUS_DOWN
[ 830.357287] dhd_bus_devreset: WLAN OFF DONE
[ 830.358942] wifi_platform_set_power = 0, delay: 0 msec
[ 830.359453] ======== PULL WL_REG_ON(-1) LOW! ========
[ 830.360091] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 830.360581] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.361122] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.361658] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 830.362149] [dhd-wlan0] wl_android_wifi_on : Failed
[ 830.362602] dhd_open : wl_android_wifi_on failed (-14)
[ 830.363093] dhd_stop: Enter wlan0
[ 830.363587] [dhd-wlan0] wl_android_wifi_off : in g_wifi_on=0, on_failure=1
[ 830.364236] dhd_dbg_detach_pkt_monitor, 2100
[ 830.364657] dhd_net_bus_devreset: dhd_bus_devreset: -35
[ 830.366168] sdioh_disable_func_intr: error for read SDIO_CCCR_IENx : 0xffffff92
[ 830.366988] wifi_platform_set_power = 0, delay: 0 msec
[ 830.367485] ======== PULL WL_REG_ON(-1) LOW! ========
[ 830.367961] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 830.368420] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.368958] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.369494] [WLAN_RFKILL]: wifi shut off power [GPIO-1-1]
[ 830.370107] [dhd-wlan0] wl_android_wifi_off : out
[ 830.383576] dhd_stop: Exit wlan0
[ 830.383912] dhd_open : the lock is released.
[ 830.384304] dhd_open: Exit wlan0 ret=-1
[ 830.384657] Failed to open primary dev ret -1
[ 830.390866] dhd_open: Enter wlan0
[ 830.391211] dhd_open : no mutex held. set lock
[ 830.391622]
[ 830.391622] Dongle Host Driver, version 100.10.545.9 (r826445-20200316-8)
[ 830.392377] [dhd-wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 830.392880] wifi_platform_set_power = 1, delay: 200 msec
[ 830.393524] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 830.393996] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 830.394417] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 830.394937] [WLAN_RFKILL]: wifi turn on power [GPIO-1-0]
[ 830.700012] sdio_reset_comm():
[ 830.823484] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 400000Hz, actual 375000HZ div = 0)
[ 830.841218] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 375000Hz, actual 375000HZ div = 0)
[ 830.854137] mmc3: queuing unknown CIS tuple 0x80 (2 bytes)
[ 830.856557] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 830.859011] mmc3: queuing unknown CIS tuple 0x80 (3 bytes)
[ 830.863142] mmc3: queuing unknown CIS tuple 0x80 (7 bytes)
[ 830.963004] mmc_host mmc3: Bus speed (slot 0) = 375000Hz (slot req 10000000Hz, actual 375000HZ div = 0)
[ 830.964774] sdioh_start: set sd_f2_blocksize 256
[ 830.971574]
[ 830.971574]
[ 830.971574] dhd_bus_devreset: == Power ON ==
[ 830.974033] F1 signature read @0x18000000=0x1042aae8
[ 831.052075] F1 signature OK, socitype:0x1 chip:0xaae8 rev:0x2 pkg:0x4
[ 831.068447] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 831.070130] dhd_bus_devreset: making DHD_BUS_DOWN
[ 831.071572] dhdsdio_probe_init: making DHD_BUS_DOWN
[ 831.075071] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 831.075872] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_ag.bin
[ 831.076808] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_ap6275s.txt
[ 831.077611] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_ag.blob
[ 831.078468] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 831.086899] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43752a2_ag.bin (743607 bytes) open success
[ 849.502972] dhd_os_open_image1: /vendor/etc/firmware/nvram_ap6275s.txt (8361 bytes) open success
[ 849.503940] NVRAM version: AP6275S_NVRAM_V1.2.1_20200311
[ 849.783297] dhdsdio_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 849.862399] dhd_bus_init: enable 0x06, ready 0x06 (waited 0us)
[ 849.870793] bcmsdh_oob_intr_register: HW_OOB irq=111 flags=0x4
[ 849.872593] get_mem_val_from_file: File [/data/misc/wifi/.memdump.info] doesn’t exist
[ 849.873451] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 855.097577] dhd_bus_rxctl: resumed on timeout, INT status=0x20A000C0
[ 855.112934] Dump dongle memory
[ 886.659824] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 886.660684] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 886.661449] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=45338
[ 886.662270] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c0b1e1, buf¶=1f5c0b1e1, bufsize=45338
[ 886.663092] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=45338
[ 886.664028] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 886.664798] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 886.665584] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 886.666381] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 886.667257] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 886.668014] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 886.668800] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 886.669596] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 886.670487] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 886.671292] dhd_schedule_memdump: scheduling mem dump..
[ 886.671798] dhd_deferred_schedule_work: failed to schedule deferred work, priority=2, bytes_copied=0
[ 886.672630] dhd_bus_rxctl: rxcnt_timeout=1, rxlen=0
[ 886.674103] Dump dongle memory
[ 918.162974] -------- memdump: buf(va)=ffffffc0cc600000, buf¶=cc600000, bufsize=1310720
[ 918.163838] -------- dlb_buf[0]: buf(va)=ffffff8009883a18, buf¶=1a83a18, bufsize=1048576
[ 918.164604] -------- dlb_buf[0] buffer: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=46977
[ 918.165427] -------- dlb_buf[0] present: buf(va)=ffffffc1f5c0b848, buf¶=1f5c0b848, bufsize=46977
[ 918.166249] -------- dlb_buf[0] front: buf(va)=ffffffc1f5c00000, buf¶=1f5c00000, bufsize=46977
[ 918.167196] -------- dlb_buf[1]: buf(va)=ffffff8009883a68, buf¶=1a83a68, bufsize=524288
[ 918.167965] -------- dlb_buf[1] buffer: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 918.168753] -------- dlb_buf[1] present: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 918.169548] -------- dlb_buf[1] front: buf(va)=ffffffc1f5d00000, buf¶=1f5d00000, bufsize=0
[ 918.170445] -------- dlb_buf[2]: buf(va)=ffffff8009883ab8, buf¶=1a83ab8, bufsize=8192
[ 918.171193] -------- dlb_buf[2] buffer: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 918.171979] -------- dlb_buf[2] present: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 918.172774] -------- dlb_buf[2] front: buf(va)=ffffffc1f66ca000, buf¶=1f66ca000, bufsize=0
[ 918.173682] -------- concise_dbg_buf: buf(va)=ffffffc1f6780000, buf¶=1f6780000, bufsize=16384
[ 918.174491] dhd_schedule_memdump: scheduling mem dump..
[ 918.174995] dhd_deferred_schedule_work: failed to schedule deferred work, priority=2, bytes_copied=0
[ 918.175857] dhd_check_hang: Event HANG send up due to re=1 te=0 e=-110 s=2
[ 918.176616]
[ 918.176791] dhd_os_send_hang_message: device is not ready
log.zip (3.39 KB)
