IPQ4019 IPQ4029 routerboard Supported by OpenWrt
Are you looking for a routerboard that supported by OpenWrt? Look no further than Wallys DR4019!
The DR4019 is a powerful routerboard that comes equipped with a 1.2 GHz dual-core ARM processor, 512 MB of RAM, and 256 MB of flash memory. It also features five gigabit Ethernet ports, as well as a USB 3.0 port for external storage or other devices.
One of the best things about the DR4019 is that it is fully supported by OpenWrt.
Link:[u]https://git.openwrt.org/?p=openwrt/openwrt.git;a=commit;h=eb564690c995b284204aa762c0f77f3064419a9[/u][u]c[/u]
OpenWrt is a free and open-source operating system based on Linux that is specifically designed for embedded devices like routers. It offers a wide range of features and customizability, making it a great choice for power users and network enthusiasts.
With OpenWrt installed on the DR4019, you can take advantage of advanced features like QoS (Quality of Service) and VPN (Virtual Private Network) support, as well as a wide range of network management and monitoring tools. You can also install additional packages to extend the router’s functionality even further.
Setting up OpenWrt on the DR4019 is a straightforward process, and there are plenty of resources available online to help you get started. Whether you’re a seasoned network administrator or just starting out, the DR4019 with OpenWrt is a great choice for a reliable and customizable routerboard.
In conclusion, if you’re looking for a powerful and versatile routerboard that supports OpenWrt, the Wallys DR4019 is definitely worth considering. Its powerful hardware, gigabit Ethernet ports, and USB 3.0 support make it a great choice for both home and office use. Plus, with OpenWrt, you can unlock a whole new level of customization and control over your network.
DR4019
Website [b][u]https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html[/u][/b]
Product Parameter
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Storage Humidity Range 0 to +90 (non-condensing)%
Hardware Specifications
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional)
3G/4G 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
