使能Type-C DP0 音频功能系统卡死
SDK包名称:Android12-7寸屏源码
SDK修改内容:/* display port0 */
&dp0_sound{
status = "okay";
&spdif_tx2{
status = "okay";
&dp0 {
status = "okay";
&dp0_in_vp1 {
status = "okay";
Log日志:使能DP输出音频启动卡死.txt
/* display port0 */
&dp0_sound{
status = “okay”;
&spdif_tx2{
status = “okay”;
&dp0 {
status = “okay”;
&dp0_in_vp1 {
status = “okay”;
如上配置DP0,外接带音频接口的DP设备,重新上电启动,系统卡死;
/* display port0 */
//&dp0_sound{
// status = “okay”;
&spdif_tx2{
status = “okay”;
&dp0 {
status = “okay”;
&dp0_in_vp1 {
status = “okay”;
屏蔽dp0_sound节点,重新上电启动系统正常。
使能DP输出音频启动卡死.txt (203 KB)
从你提供的log来看应该是I2C communication ERROR,但是你抓取的log前面开头有乱码,请提供完整清晰的log
或者可以同步最新的sdk后再尝试
e12ba531a1ef63b99ce4d8b17b9daf2ea30f69ec
1.Fix Camera issue 2.Add uart permission 3.Optimizing system stability
感谢您的回复,乱码部分是Uboot启动日志。系统正常启动的时候也会打印 I2C communication ERROR!
如你这个所示,是否是dp sound配置好,不接外接带音频接口的DP设备,系统就是可以正常起来?只有接带音频接口的DP设备才会出问题?
可以拍个照来看下带音频接口的DP设备和其对应以及型号
另外sdk更新最新后是否会出现
