AIO-3588Q 插U盘的时候,鼠标键盘卡顿很难移动
固件文件名称:AIO-3588Q_Ubuntu20.04-Gnome-r240_v1.0.6e_230330
固件下载地址:百度网盘
Log日志:log1.zip
如题,在板子中的3.0接口中插入u盘,鼠标键盘就很难移动。
log1.zip (153 Bytes)
插入u盘的时候,板子终端执行dmesg命令。将输出的信息发上来分析。
Xshell 7 (Build 0122)
Copyright (c) 2020 NetSarang Computer, Inc. All rights reserved.
Type `help’ to learn how to use Xshell prompt.
[C:~]$
Connecting to 10.219.186.152:22…
Connection established.
To escape to local shell, press ‘Ctrl+Alt+]’.
| () __ ___ / | | _
| | '/ _ \ || | | | |
| | | | | | __/ | | || |
|_| _
|| ||_, |
__/
Welcome to Ubuntu 20.04.5 LTS (GNU/Linux 5.10.110 aarch64)
System information as of Thu Apr 27 07:53:37 UTC 2023
System load: 0.41 0.40 1.02 Up time: 5:52 hours Local users: 4
Memory usage: 12 % of 15692MB IP: 192.168.8.1 10.219.186.152
Usage of /: 11% of 198G storage/: 47% of 58G
Last login: Thu Apr 27 07:53:31 2023 from 10.219.190.81
firefly@firefly:~$ dmesg
[ 2.314291] Booting Linux on physical CPU 0x0000000000 [0x412fd050]
[ 2.314315] Linux version 5.10.110 (lvsx@tchip14) (kernel commit id: 8b4c629a78e2) (sdk version: rk3588_linux_release_20230301_v1.0.6e) (aarch64-none-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 10.3.1 20210621, GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #20 SMP Fri Mar 3 15:56:13 CST 2023
[ 2.321994] Machine model: Firefly AIO-3588Q MIPI101(Linux)
[ 2.322083] earlycon: uart8250 at MMIO32 0x00000000feb50000 (options ‘’)
[ 2.326840] printk: bootconsole [uart8250] enabled
[ 2.329067] efi: UEFI not found.
[ 2.333451] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 2.334596] Reserved memory: created CMA memory pool at 0x0000000010000000, size 256 MiB
[ 2.335335] OF: reserved mem: initialized node cma, compatible id shared-dma-pool
[ 2.554475] Zone ranges:
[ 2.554713] DMA [mem 0x0000000000200000-0x00000000ffffffff]
[ 2.555282] DMA32 empty
[ 2.555549] Normal [mem 0x0000000100000000-0x00000004ffffffff]
[ 2.556115] Movable zone start for each node
[ 2.556505] Early memory node ranges
[ 2.556833] node 0: [mem 0x0000000000200000-0x00000000083fffff]
[ 2.557406] node 0: [mem 0x0000000009400000-0x00000000efffffff]
[ 2.557980] node 0: [mem 0x0000000100000000-0x00000003fbffffff]
[ 2.558556] node 0: [mem 0x00000003fc500000-0x00000003ffefffff]
[ 2.559127] node 0: [mem 0x00000004f0000000-0x00000004ffffffff]
[ 2.559701] Initmem setup node 0 [mem 0x0000000000200000-0x00000004ffffffff]
[ 2.560346] On node 0 totalpages: 4188160
[ 2.560352] DMA zone: 15288 pages used for memmap
[ 2.560355] DMA zone: 0 pages reserved
[ 2.560359] DMA zone: 978432 pages, LIFO batch:63
[ 2.560364] Normal zone: 50152 pages used for memmap
[ 2.560367] Normal zone: 3209728 pages, LIFO batch:63
[ 2.651514] On node 0, zone Normal: 256 pages in unavailable ranges
[ 2.651653] psci: probing for conduit method from DT.
[ 2.652690] psci: PSCIv1.1 detected in firmware.
[ 2.653113] psci: Using standard PSCI v0.2 function IDs
[ 2.653592] psci: Trusted OS migration not required
[ 2.654040] psci: SMC Calling Convention v1.2
[ 2.654832] percpu: Embedded 32 pages/cpu s93288 r8192 d29592 u131072
[ 2.655469] pcpu-alloc: s93288 r8192 d29592 u131072 alloc=32*4096
[ 2.655475] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 2.655629] Detected VIPT I-cache on CPU0
[ 2.656032] CPU features: detected: GIC system register CPU interface
[ 2.656621] CPU features: detected: Virtualization Host Extensions
[ 2.657190] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 2.657834] alternatives: patching kernel code
[ 2.660413] Built 1 zonelists, mobility grouping on. Total pages: 4122720
[ 2.661046] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal dsi-0=2 storagenode=/mmc@fe2e0000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
[ 2.666358] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 2.667854] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 2.668578] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 2.675340] software IO TLB: mapped [mem 0x00000000e9f00000-0x00000000edf00000] (64MB)
[ 2.805813] Memory: 16051012K/16752640K available (22464K kernel code, 3824K rwdata, 6956K rodata, 7616K init, 673K bss, 439484K reserved, 262144K cma-reserved)
[ 2.807235] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 2.807860] ftrace: allocating 67815 entries in 265 pages
[ 2.905655] ftrace: allocated 265 pages with 3 groups
[ 2.906380] rcu: Hierarchical RCU implementation.
[ 2.906814] rcu: RCU event tracing is enabled.
[ 2.907229] Rude variant of Tasks RCU enabled.
[ 2.907642] Tracing variant of Tasks RCU enabled.
[ 2.908081] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 2.914069] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 2.916402] GICv3: GIC: Using split EOI/Deactivate mode
[ 2.916884] GICv3: 480 SPIs implemented
[ 2.917235] GICv3: 0 Extended SPIs implemented
[ 2.917664] GICv3: Distributor has no Range Selector support
[ 2.918185] GICv3: 16 PPIs implemented
[ 2.918568] GICv3: CPU0: found redistributor 0 region 0:0x00000000fe680000
[ 2.919297] ITS [mem 0xfe640000-0xfe65ffff]
[ 2.919723] ITS@0x00000000fe640000: allocated 8192 Devices @100120000 (indirect, esz 8, psz 64K, shr 0)
[ 2.920597] ITS@0x00000000fe640000: allocated 32768 Interrupt Collections @100130000 (flat, esz 2, psz 64K, shr 0)
[ 2.921543] ITS: using cache flushing for cmd queue
[ 2.922017] ITS [mem 0xfe660000-0xfe67ffff]
[ 2.922436] ITS@0x00000000fe660000: allocated 8192 Devices @100150000 (indirect, esz 8, psz 64K, shr 0)
[ 2.923309] ITS@0x00000000fe660000: allocated 32768 Interrupt Collections @100160000 (flat, esz 2, psz 64K, shr 0)
[ 2.924254] ITS: using cache flushing for cmd queue
[ 2.924821] GICv3: using LPI property table @0x0000000100170000
[ 2.925471] GIC: using cache flushing for LPI property table
[ 2.925992] GICv3: CPU0: using allocated LPI pending table @0x0000000100180000
[ 2.926798] random: get_random_bytes called from start_kernel+0x3f0/0x65c with crng_init=0
[ 3.039906] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 3.041225] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 3.042216] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 3.043812] Console: colour dummy device 80x25
[ 3.044247] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 3.045194] pid_max: default: 32768 minimum: 301
[ 3.045705] LSM: Security Framework initializing
[ 3.046199] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 3.046923] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 3.049232] rcu: Hierarchical SRCU implementation.
[ 3.050427] Platform MSI: msi-controller@fe640000 domain created
[ 3.050991] Platform MSI: msi-controller@fe660000 domain created
[ 3.051801] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe640000 domain created
[ 3.052574] PCI/MSI: /interrupt-controller@fe600000/msi-controller@fe660000 domain created
[ 3.053431] EFI services will not be available.
[ 3.054132] smp: Bringing up secondary CPUs …
[ 3.055747] Detected VIPT I-cache on CPU1
[ 3.055774] GICv3: CPU1: found redistributor 100 region 0:0x00000000fe6a0000
[ 3.055789] GICv3: CPU1: using allocated LPI pending table @0x0000000100190000
[ 3.055831] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 3.057064] Detected VIPT I-cache on CPU2
[ 3.057085] GICv3: CPU2: found redistributor 200 region 0:0x00000000fe6c0000
[ 3.057100] GICv3: CPU2: using allocated LPI pending table @0x00000001001a0000
[ 3.057137] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 3.058335] Detected VIPT I-cache on CPU3
[ 3.058353] GICv3: CPU3: found redistributor 300 region 0:0x00000000fe6e0000
[ 3.058366] GICv3: CPU3: using allocated LPI pending table @0x00000001001b0000
[ 3.058402] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 3.059606] CPU features: detected: Spectre-v4
[ 3.059609] CPU features: detected: Spectre-BHB
[ 3.059610] Detected PIPT I-cache on CPU4
[ 3.059622] GICv3: CPU4: found redistributor 400 region 0:0x00000000fe700000
[ 3.059630] GICv3: CPU4: using allocated LPI pending table @0x00000001001c0000
[ 3.059652] CPU4: Booted secondary processor 0x0000000400 [0x414fd0b0]
[ 3.060803] Detected PIPT I-cache on CPU5
[ 3.060815] GICv3: CPU5: found redistributor 500 region 0:0x00000000fe720000
[ 3.060822] GICv3: CPU5: using allocated LPI pending table @0x00000001001d0000
[ 3.060845] CPU5: Booted secondary processor 0x0000000500 [0x414fd0b0]
[ 3.062007] Detected PIPT I-cache on CPU6
[ 3.062018] GICv3: CPU6: found redistributor 600 region 0:0x00000000fe740000
[ 3.062026] GICv3: CPU6: using allocated LPI pending table @0x00000001001e0000
[ 3.062049] CPU6: Booted secondary processor 0x0000000600 [0x414fd0b0]
[ 3.063201] Detected PIPT I-cache on CPU7
[ 3.063213] GICv3: CPU7: found redistributor 700 region 0:0x00000000fe760000
[ 3.063220] GICv3: CPU7: using allocated LPI pending table @0x00000001001f0000
[ 3.063243] CPU7: Booted secondary processor 0x0000000700 [0x414fd0b0]
[ 3.063300] smp: Brought up 1 node, 8 CPUs
[ 3.080364] SMP: Total of 8 processors activated.
[ 3.080796] CPU features: detected: Privileged Access Never
[ 3.081307] CPU features: detected: User Access Override
[ 3.081794] CPU features: detected: 32-bit EL0 Support
[ 3.082266] CPU features: detected: Common not Private translations
[ 3.082840] CPU features: detected: RAS Extension Support
[ 3.083340] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 3.084131] CPU features: detected: CRC32 instructions
[ 3.084599] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 3.085238] CPU features: detected: RCpc load-acquire (LDAPR)
[ 3.085847] CPU: All CPU(s) started at EL2
[ 3.090614] devtmpfs: initialized
[ 3.098836] Registered cp15_barrier emulation handler
[ 3.099302] Registered setend emulation handler
[ 3.099779] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 3.100676] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 3.101416] pinctrl core: initialized pinctrl subsystem
[ 3.102075] DMI not present or invalid.
[ 3.102528] NET: Registered protocol family 16
[ 3.103401] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 3.104128] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 3.104853] audit: initializing netlink subsys (disabled)
[ 3.105398] audit: type=2000 audit(0.059:1): state=initialized audit_enabled=0 res=1
[ 3.105794] thermal_sys: Registered thermal governor ‘fair_share’
[ 3.106106] thermal_sys: Registered thermal governor ‘step_wise’
[ 3.106662] thermal_sys: Registered thermal governor ‘user_space’
[ 3.107208] thermal_sys: Registered thermal governor ‘power_allocator’
[ 3.107873] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 3.109214] thermal thermal_zone2: power_allocator: sustainable_power will be estimated
[ 3.109965] thermal thermal_zone3: power_allocator: sustainable_power will be estimated
[ 3.110777] thermal thermal_zone4: power_allocator: sustainable_power will be estimated
[ 3.111530] thermal thermal_zone5: power_allocator: sustainable_power will be estimated
[ 3.112279] thermal thermal_zone6: power_allocator: sustainable_power will be estimated
[ 3.113023] cpuidle: using governor menu
[ 3.113385] Registered FIQ tty driver
[ 3.113845] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 3.114562] ASID allocator initialised with 65536 entries
[ 3.116008] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 3.116660] ramoops: console 0x80000@0x0000000000130000
[ 3.117144] ramoops: pmsg 0x50000@0x00000000001b0000
[ 3.117830] printk: console [ramoops-1] enabled
[ 3.118245] pstore: Registered ramoops as persistent store backend
[ 3.118819] ramoops: using 0xf0000@0x110000, ecc: 0
[ 3.151903] rockchip-gpio fd8a0000.gpio: probed /pinctrl/gpio@fd8a0000
[ 3.152665] rockchip-gpio fec20000.gpio: probed /pinctrl/gpio@fec20000
[ 3.153412] rockchip-gpio fec30000.gpio: probed /pinctrl/gpio@fec30000
[ 3.154182] rockchip-gpio fec40000.gpio: probed /pinctrl/gpio@fec40000
[ 3.154931] rockchip-gpio fec50000.gpio: probed /pinctrl/gpio@fec50000
[ 3.155546] rockchip-pinctrl pinctrl: probed pinctrl
[ 3.163638] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 3.164253] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 3.164864] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 3.165476] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 3.223509] raid6: neonx8 gen() 5719 MB/s
[ 3.280234] raid6: neonx8 xor() 4512 MB/s
[ 3.336963] raid6: neonx4 gen() 5645 MB/s
[ 3.393687] raid6: neonx4 xor() 4806 MB/s
[ 3.450415] raid6: neonx2 gen() 5392 MB/s
[ 3.507139] raid6: neonx2 xor() 4261 MB/s
[ 3.563866] raid6: neonx1 gen() 4428 MB/s
[ 3.620592] raid6: neonx1 xor() 3708 MB/s
[ 3.677320] raid6: int64x8 gen() 2679 MB/s
[ 3.734042] raid6: int64x8 xor() 1586 MB/s
[ 3.790773] raid6: int64x4 gen() 3016 MB/s
[ 3.847498] raid6: int64x4 xor() 1590 MB/s
[ 3.904220] raid6: int64x2 gen() 2558 MB/s
[ 3.960949] raid6: int64x2 xor() 1381 MB/s
[ 4.017683] raid6: int64x1 gen() 2098 MB/s
[ 4.074409] raid6: int64x1 xor() 1101 MB/s
[ 4.074797] raid6: using algorithm neonx8 gen() 5719 MB/s
[ 4.075289] raid6: … xor() 4512 MB/s, rmw enabled
[ 4.075742] raid6: using neon recovery algorithm
[ 4.076627] fiq_debugger fiq_debugger.0: IRQ fiq not found
[ 4.077128] fiq_debugger fiq_debugger.0: IRQ wakeup not found
[ 4.077654] fiq_debugger_probe: could not install nmi irq handler
[ 4.078251] printk: console [ttyFIQ0] enabled
[ 4.079026] printk: bootconsole [uart8250] disabled
[ 4.079524] Registered fiq debugger ttyFIQ0
[ 4.079822] vcc5v0_sys: supplied by vcc12v_dcin
[ 4.079911] vcc5v0_usbdcin: supplied by vcc12v_dcin
[ 4.079992] vcc5v0_usb: supplied by vcc12v_dcin
[ 4.080077] vcc_1v1_nldo_s3: supplied by vcc5v0_sys
[ 4.080213] vcc3v3_pcie30: supplied by vcc12v_dcin
[ 4.080445] iommu: Default domain type: Passthrough
[ 4.080503] rk_iommu fdab9000.iommu: version = 2
[ 4.080786] rk_iommu fdb50800.iommu: version = 2
[ 4.080986] rk_iommu fdb60f00.iommu: version = 2
[ 4.081130] rk_iommu fdb70f00.iommu: version = 2
[ 4.081265] rk_iommu fdb90480.iommu: version = 2
[ 4.081418] rk_iommu fdba0800.iommu: version = 2
[ 4.081573] rk_iommu fdba4800.iommu: version = 2
[ 4.081723] rk_iommu fdba8800.iommu: version = 2
[ 4.081876] rk_iommu fdbac800.iommu: version = 2
[ 4.082028] rk_iommu fdbb0800.iommu: version = 2
[ 4.082179] rk_iommu fdbdf000.iommu: version = 2
[ 4.082392] rk_iommu fdbef000.iommu: version = 2
[ 4.082626] rk_iommu fdc38700.iommu: version = 2
[ 4.082864] rk_iommu fdc48700.iommu: version = 2
[ 4.083033] rk_iommu fdce0800.iommu: version = 2
[ 4.083129] rk_iommu fdd97e00.iommu: version = 2
[ 4.083367] usbcore: registered new interface driver usbfs
[ 4.083380] usbcore: registered new interface driver hub
[ 4.083394] usbcore: registered new device driver usb
[ 4.083421] mc: Linux media interface: v0.10
[ 4.083429] videodev: Linux video capture interface: v2.00
[ 4.083448] pps_core: LinuxPPS API ver. 1 registered
[ 4.083451] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 4.083457] PTP clock support registered
[ 4.083664] arm-scmi firmware:scmi: SCMI Notifications - Core Enabled.
[ 4.083694] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 4.084485] Advanced Linux Sound Architecture Driver Initialized.
[ 4.084647] Bluetooth: Core ver 2.22
[ 4.084658] NET: Registered protocol family 31
[ 4.084661] Bluetooth: HCI device and connection manager initialized
[ 4.084665] Bluetooth: HCI socket layer initialized
[ 4.084669] Bluetooth: L2CAP socket layer initialized
[ 4.084675] Bluetooth: SCO socket layer initialized
[ 4.085914] rockchip-cpuinfo cpuinfo: SoC : 35880000
[ 4.085918] rockchip-cpuinfo cpuinfo: Serial : e3c4b7a0d14454df
[ 4.086171] clocksource: Switched to clocksource arch_sys_counter
[ 4.343792] NET: Registered protocol family 2
[ 4.343955] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 4.347548] tcp_listen_portaddr_hash hash table entries: 8192 (order: 6, 327680 bytes, linear)
[ 4.347707] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 4.348352] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 4.349125] TCP: Hash tables configured (established 131072 bind 65536)
[ 4.349177] UDP hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 4.349473] UDP-Lite hash table entries: 8192 (order: 7, 786432 bytes, linear)
[ 4.349823] NET: Registered protocol family 1
[ 4.350083] RPC: Registered named UNIX socket transport module.
[ 4.350088] RPC: Registered udp transport module.
[ 4.350091] RPC: Registered tcp transport module.
[ 4.350094] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 4.350426] PCI: CLS 0 bytes, default 64
[ 4.350650] Trying to unpack rootfs image as initramfs…
[ 4.554074] Freeing initrd memory: 9016K
[ 4.554667] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 4.555034] kvm [1]: IPA Size Limit: 40 bits
[ 4.555047] kvm [1]: GICv3: no GICV resource entry
[ 4.555051] kvm [1]: disabling GICv2 emulation
[ 4.555054] kvm [1]: GIC system register CPU interface enabled
[ 4.555163] kvm [1]: vgic interrupt IRQ9
[ 4.555298] kvm [1]: VHE mode initialized successfully
[ 4.557524] Initialise system trusted keyrings
[ 4.557611] workingset: timestamp_bits=46 max_order=22 bucket_order=0
[ 4.559420] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 4.559661] NFS: Registering the id_resolver key type
[ 4.559671] Key type id_resolver registered
[ 4.559674] Key type id_legacy registered
[ 4.559681] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 4.560264] Key type cifs.spnego registered
[ 4.560269] Key type cifs.idmap registered
[ 4.560274] ntfs: driver 2.1.32 [Flags: R/O].
[ 4.560321] jffs2: version 2.2. (NAND) ? 2001-2006 Red Hat, Inc.
[ 4.560398] fuse: init (API version 7.32)
[ 4.560514] SGI XFS with security attributes, no debug enabled
[ 4.580676] NET: Registered protocol family 38
[ 4.580683] xor: measuring software checksum speed
[ 4.582063] 8regs : 7151 MB/sec
[ 4.583223] 32regs : 8569 MB/sec
[ 4.584103] arm64_neon : 11464 MB/sec
[ 4.584107] xor: using function: arm64_neon (11464 MB/sec)
[ 4.584112] Key type asymmetric registered
[ 4.584115] Asymmetric key parser ‘x509’ registered
[ 4.584130] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 4.584210] io scheduler mq-deadline registered
[ 4.584216] io scheduler kyber registered
[ 4.584629] rockchip-csi2-dphy-hw fedc0000.csi2-dphy0-hw: csi2 dphy hw probe successfully!
[ 4.584825] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 4.586617] rockchip-usb2phy fd5d8000.syscon:usb2-phy@8000: failed to create phy
[ 4.586962] rockchip-usb2phy fd5dc000.syscon:usb2-phy@c000: failed to create phy
[ 4.587421] rockchip-usb2phy fd5d4000.syscon:usb2-phy@4000: failed to create phy
[ 4.589372] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy init success
[ 4.590105] Firefly gpio driver init!
[ 4.590182] Firefly gpio driver register return : 0
[ 4.591161] rk-pcie fe150000.pcie: invalid prsnt-gpios property in node
[ 4.591255] rk-pcie fe170000.pcie: invalid prsnt-gpios property in node
[ 4.591279] rk-pcie fe170000.pcie: no vpcie3v3 regulator found
[ 4.591321] pwm-backlight backlight: supply power not found, using dummy regulator
[ 4.591571] rk-pcie fe170000.pcie: missing legacy IRQ resource
[ 4.591591] rk-pcie fe170000.pcie: IRQ msi not found
[ 4.591599] rk-pcie fe170000.pcie: use outband MSI support
[ 4.591601] iep: Module initialized.
[ 4.591612] rk-pcie fe170000.pcie: Missing config reg space
[ 4.591627] rk-pcie fe170000.pcie: host bridge /pcie@fe170000 ranges:
[ 4.591629] mpp_service mpp-srv: 42c7305fbcbc author: Chandler Chen 2022-12-15 video: rockchip: mpp: rkvdec: add task timing & timeout for rkvdec
[ 4.591633] mpp_service mpp-srv: probe start
[ 4.591653] rk-pcie fe170000.pcie: err 0x00f2000000..0x00f20fffff → 0x00f2000000
[ 4.591671] rk-pcie fe170000.pcie: IO 0x00f2100000..0x00f21fffff → 0x00f2100000
[ 4.591689] rk-pcie fe170000.pcie: MEM 0x00f2200000..0x00f2ffffff → 0x00f2200000
[ 4.591702] rk-pcie fe170000.pcie: MEM 0x0980000000..0x09bfffffff → 0x0980000000
[ 4.591732] rk-pcie fe170000.pcie: Missing config reg space
[ 4.591765] rk-pcie fe170000.pcie: invalid resource
[ 4.592981] mpp_vdpu2 fdb50400.vdpu: Adding to iommu group 1
[ 4.592998] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.593190] mpp_vdpu2 fdb50400.vdpu: probe device
[ 4.593278] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 4.593284] mpp_vdpu2 fdb50400.vdpu: reset_group->rw_sem_on=0
[ 4.593390] mpp_vdpu2 fdb50400.vdpu: probing finish
[ 4.593555] mpp_vepu2 jpege-ccu: probing start
[ 4.593560] mpp_vepu2 jpege-ccu: probing finish
[ 4.593649] mpp_vepu2 fdba0000.jpege-core: Adding to iommu group 5
[ 4.593659] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.593784] mpp_vepu2 fdba0000.jpege-core: probing start
[ 4.593869] mpp_vepu2 fdba0000.jpege-core: attach ccu success
[ 4.593964] mpp_vepu2 fdba0000.jpege-core: probing finish
[ 4.594049] mpp_vepu2 fdba4000.jpege-core: Adding to iommu group 6
[ 4.594058] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.594184] mpp_vepu2 fdba4000.jpege-core: probing start
[ 4.594260] mpp_vepu2 fdba4000.jpege-core: attach ccu success
[ 4.594353] mpp_vepu2 fdba4000.jpege-core: probing finish
[ 4.594429] mpp_vepu2 fdba8000.jpege-core: Adding to iommu group 7
[ 4.594438] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.594578] mpp_vepu2 fdba8000.jpege-core: probing start
[ 4.594655] mpp_vepu2 fdba8000.jpege-core: attach ccu success
[ 4.594760] mpp_vepu2 fdba8000.jpege-core: probing finish
[ 4.594845] mpp_vepu2 fdbac000.jpege-core: Adding to iommu group 8
[ 4.594855] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.594974] mpp_vepu2 fdbac000.jpege-core: probing start
[ 4.595049] mpp_vepu2 fdbac000.jpege-core: attach ccu success
[ 4.595147] mpp_vepu2 fdbac000.jpege-core: probing finish
[ 4.595368] mpp-iep2 fdbb0000.iep: Adding to iommu group 9
[ 4.595378] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.595497] mpp-iep2 fdbb0000.iep: probe device
[ 4.595593] mpp-iep2 fdbb0000.iep: allocate roi buffer failed
[ 4.595669] mpp-iep2 fdbb0000.iep: probing finish
[ 4.595841] mpp_jpgdec fdb90000.jpegd: Adding to iommu group 4
[ 4.595852] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.596043] mpp_jpgdec fdb90000.jpegd: probe device
[ 4.596225] mpp_jpgdec fdb90000.jpegd: probing finish
[ 4.596514] mpp_rkvdec2 fdc30000.rkvdec-ccu: rkvdec-ccu, probing start
[ 4.596560] mpp_rkvdec2 fdc30000.rkvdec-ccu: probing finish
[ 4.596623] mpp_rkvdec2 fdc38100.rkvdec-core: Adding to iommu group 12
[ 4.596633] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.596841] mpp_rkvdec2 fdc38100.rkvdec-core: rkvdec-core, probing start
[ 4.596929] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_a is not found!
[ 4.596932] rkvdec2_init:1010: No niu aclk reset resource define
[ 4.596936] mpp_rkvdec2 fdc38100.rkvdec-core: shared_niu_h is not found!
[ 4.596939] rkvdec2_init:1013: No niu hclk reset resource define
[ 4.596955] mpp_rkvdec2 fdc38100.rkvdec-core: no regulator, devfreq is disabled
[ 4.597005] mpp_rkvdec2 fdc38100.rkvdec-core: core_mask=00010001
[ 4.597009] mpp_rkvdec2 fdc38100.rkvdec-core: attach ccu as core 0
[ 4.597147] mpp_rkvdec2 fdc38100.rkvdec-core: sram_start 0x00000000ff001000
[ 4.597150] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_iova 0x00000000fff00000
[ 4.597154] mpp_rkvdec2 fdc38100.rkvdec-core: sram_size 491520
[ 4.597158] mpp_rkvdec2 fdc38100.rkvdec-core: rcb_size 1048576
[ 4.597162] mpp_rkvdec2 fdc38100.rkvdec-core: min_width 512
[ 4.597184] mpp_rkvdec2 fdc38100.rkvdec-core: probing finish
[ 4.597245] mpp_rkvdec2 fdc48100.rkvdec-core: Adding to iommu group 13
[ 4.597254] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.597441] mpp_rkvdec2 fdc48100.rkvdec-core: rkvdec-core, probing start
[ 4.597528] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_a is not found!
[ 4.597531] rkvdec2_init:1010: No niu aclk reset resource define
[ 4.597536] mpp_rkvdec2 fdc48100.rkvdec-core: shared_niu_h is not found!
[ 4.597539] rkvdec2_init:1013: No niu hclk reset resource define
[ 4.597552] mpp_rkvdec2 fdc48100.rkvdec-core: no regulator, devfreq is disabled
[ 4.597587] mpp_rkvdec2 fdc48100.rkvdec-core: core_mask=00020002
[ 4.597603] mpp_rkvdec2 fdc48100.rkvdec-core: attach ccu as core 1
[ 4.597763] mpp_rkvdec2 fdc48100.rkvdec-core: sram_start 0x00000000ff079000
[ 4.597767] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_iova 0x00000000ffe00000
[ 4.597770] mpp_rkvdec2 fdc48100.rkvdec-core: sram_size 487424
[ 4.597774] mpp_rkvdec2 fdc48100.rkvdec-core: rcb_size 1048576
[ 4.597777] mpp_rkvdec2 fdc48100.rkvdec-core: min_width 512
[ 4.597802] mpp_rkvdec2 fdc48100.rkvdec-core: probing finish
[ 4.597943] mpp_rkvenc2 rkvenc-ccu: probing start
[ 4.597949] mpp_rkvenc2 rkvenc-ccu: probing finish
[ 4.598039] mpp_rkvenc2 fdbd0000.rkvenc-core: Adding to iommu group 10
[ 4.598048] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.598196] mpp_rkvenc2 fdbd0000.rkvenc-core: probing start
[ 4.598213] mpp_rkvenc2 fdbd0000.rkvenc-core: link mode task capacity 8
[ 4.598329] mpp_rkvenc2 fdbd0000.rkvenc-core: attach ccu as core 0
[ 4.598431] mpp_rkvenc2 fdbd0000.rkvenc-core: probing finish
[ 4.598484] mpp_rkvenc2 fdbe0000.rkvenc-core: Adding to iommu group 11
[ 4.598494] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.598694] mpp_rkvenc2 fdbe0000.rkvenc-core: probing start
[ 4.598709] mpp_rkvenc2 fdbe0000.rkvenc-core: link mode task capacity 8
[ 4.598840] mpp_rkvenc2 fdbe0000.rkvenc-core: attach ccu as core 1
[ 4.598937] mpp_rkvenc2 fdbe0000.rkvenc-core: probing finish
[ 4.599347] mpp_av1dec: Adding child /av1d@fdc70000
[ 4.599401] mpp_av1dec: register device av1d-master
[ 4.599424] mpp_av1dec av1d-master: av1_iommu_of_xlate,784
[ 4.599440] av1_iommu_probe_device,736, consumer : av1d-master, supplier : fdca0000.iommu
[ 4.599464] mpp_av1dec av1d-master: Adding to iommu group 16
[ 4.599474] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.599668] mpp_av1dec av1d-master: probing start
[ 4.599858] mpp_av1dec av1d-master: probing finish
[ 4.599884] mpp_service mpp-srv: probe success
[ 4.604970] dma-pl330 fea10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.604977] dma-pl330 fea10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.605652] dma-pl330 fea30000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.605658] dma-pl330 fea30000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.606316] dma-pl330 fed10000.dma-controller: Loaded driver for PL330 DMAC-241330
[ 4.606322] dma-pl330 fed10000.dma-controller: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 4.606603] rockchip-pvtm fda40000.pvtm: pvtm@0 probed
[ 4.606648] rockchip-pvtm fda50000.pvtm: pvtm@1 probed
[ 4.606687] rockchip-pvtm fda60000.pvtm: pvtm@2 probed
[ 4.606724] rockchip-pvtm fdaf0000.pvtm: pvtm@3 probed
[ 4.606759] rockchip-pvtm fdb30000.pvtm: pvtm@4 probed
[ 4.607154] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 4.607679] rk-pcie fe150000.pcie: missing legacy IRQ resource
[ 4.607702] rk-pcie fe150000.pcie: IRQ msi not found
[ 4.607712] rk-pcie fe150000.pcie: use outband MSI support
[ 4.607723] rk-pcie fe150000.pcie: Missing config reg space
[ 4.607747] rk-pcie fe150000.pcie: host bridge /pcie@fe150000 ranges:
[ 4.607777] rk-pcie fe150000.pcie: err 0x00f0000000..0x00f00fffff → 0x00f0000000
[ 4.607799] rk-pcie fe150000.pcie: IO 0x00f0100000..0x00f01fffff → 0x00f0100000
[ 4.607821] rk-pcie fe150000.pcie: MEM 0x00f0200000..0x00f0ffffff → 0x00f0200000
[ 4.607838] rk-pcie fe150000.pcie: MEM 0x0900000000..0x093fffffff → 0x0900000000
[ 4.607873] rk-pcie fe150000.pcie: Missing config reg space
[ 4.607908] rk-pcie fe150000.pcie: invalid resource
[ 4.608082] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 4.608367] fd890000.serial: ttyS0 at MMIO 0xfd890000 (irq = 28, base_baud = 1500000) is a 16550A
[ 4.608623] feb40000.serial: ttyS1 at MMIO 0xfeb40000 (irq = 95, base_baud = 1500000) is a 16550A
[ 4.608788] feb80000.serial: ttyS5 at MMIO 0xfeb80000 (irq = 96, base_baud = 1500000) is a 16550A
[ 4.609005] feb90000.serial: ttyS6 at MMIO 0xfeb90000 (irq = 97, base_baud = 1500000) is a 16550A
[ 4.609921] random: fast init done
[ 4.609973] random: crng init done
[ 4.610574] rockchip-vop2 fdd90000.vop: Adding to iommu group 15
[ 4.610588] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 4.618124] panel-simple-dsi fde20000.dsi.0: supply power not found, using dummy regulator
[ 4.620390] brd: module loaded
[ 4.622956] loop: module loaded
[ 4.623123] zram: Added device: zram0
[ 4.623232] lkdtm: No crash points registered, enable through debugfs
[ 4.623598] system_heap: orders[0] = 6
[ 4.623602] system_heap: orders[1] = 4
[ 4.623605] system_heap: orders[2] = 0
[ 4.624811] rockchip-spi feb10000.spi: no high_speed pinctrl state
[ 4.625268] rockchip-spi feb20000.spi: no high_speed pinctrl state
[ 4.626315] rk806 spi2.0: chip id: RK806,ver:0x2, 0x1
[ 4.626455] rk806 spi2.0: ON: 0x40 OFF:0x0
[ 4.628054] vdd_gpu_s0: supplied by vcc5v0_sys
[ 4.629061] vdd_cpu_lit_s0: supplied by vcc5v0_sys
[ 4.629652] vdd_log_s0: supplied by vcc5v0_sys
[ 4.630214] vdd_vdenc_s0: supplied by vcc5v0_sys
[ 4.630830] vdd_ddr_s0: supplied by vcc5v0_sys
[ 4.631206] vdd2_ddr_s3: supplied by vcc5v0_sys
[ 4.631730] vdd_2v0_pldo_s3: supplied by vcc5v0_sys
[ 4.632201] vcc_3v3_s3: supplied by vcc5v0_sys
[ 4.632651] vddq_ddr_s0: supplied by vcc5v0_sys
[ 4.633180] vcc_1v8_s3: supplied by vcc5v0_sys
[ 4.633698] vdd_0v75_s3: supplied by vcc_1v1_nldo_s3
[ 4.634269] vdd_ddr_pll_s0: supplied by vcc_1v1_nldo_s3
[ 4.634732] avdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 4.635197] vdd_0v85_s0: supplied by vcc_1v1_nldo_s3
[ 4.635653] vdd_0v75_s0: supplied by vcc_1v1_nldo_s3
[ 4.636203] avcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 4.636821] vcc_1v8_s0: supplied by vdd_2v0_pldo_s3
[ 4.637354] avdd_1v2_s0: supplied by vdd_2v0_pldo_s3
[ 4.637879] vcc_3v3_s0: supplied by vcc5v0_sys
[ 4.638335] vccio_sd_s0: supplied by vcc5v0_sys
[ 4.638844] pldo6_s3: supplied by vcc5v0_sys
[ 4.639278] rk806 spi2.0: no sleep-setting state
[ 4.639283] rk806 spi2.0: no reset-setting pinctrl state
[ 4.639287] rk806 spi2.0: no dvs-setting pinctrl state
[ 4.641132] wk2xxx_init: SPI driver for spi to Uart chip WK2XXX, etc.
[ 4.641137] wk2xxx_init: V2.4 On 2022.07.24
[ 4.641155] register firefly_spi_init spi return v = :0
[ 4.641424] wireguard: allowedips self-tests: pass
[ 4.645688] wireguard: nonce counter self-tests: pass
[ 4.797329] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.813989] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.822862] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.839530] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x1
[ 4.849531] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.866202] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x1
[ 4.876200] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.892865] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 4.902863] rk-pcie fe170000.pcie: PCIe Linking… LTSSM is 0x3
[ 4.915768] wireguard: ratelimiter self-tests: pass
[ 4.915856] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 4.915861] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[ 4.916226] tun: Universal TUN/TAP device driver, 1.6
[ 4.916388] CAN device driver interface
[ 4.918025] rk_gmac-dwmac fe1b0000.ethernet: IRQ eth_lpi not found
[ 4.918169] rk_gmac-dwmac fe1b0000.ethernet: no regulator found
[ 4.918176] rk_gmac-dwmac fe1b0000.ethernet: clock input or output? (output).
[ 4.918181] rk_gmac-dwmac fe1b0000.ethernet: TX delay(0x47).
[ 4.918185] rk_gmac-dwmac fe1b0000.ethernet: Can not read property: rx_delay.
[ 4.918190] rk_gmac-dwmac fe1b0000.ethernet: set rx_delay to 0xffffffff
[ 4.918204] rk_gmac-dwmac fe1b0000.ethernet: integrated PHY? (no).
[ 4.918210] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_rx
[ 4.918215] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock mac_clk_tx
[ 4.918225] rk_gmac-dwmac fe1b0000.ethernet: cannot get clock clk_mac_speed
[ 4.918444] rk_gmac-dwmac fe1b0000.ethernet: init for RGMII_RXID
[ 4.918560] rk_gmac-dwmac fe1b0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 4.918566] rk_gmac-dwmac fe1b0000.ethernet: DWMAC4/5
[ 4.918571] rk_gmac-dwmac fe1b0000.ethernet: DMA HW capability register supported
[ 4.918575] rk_gmac-dwmac fe1b0000.ethernet: RX Checksum Offload Engine supported
[ 4.918579] rk_gmac-dwmac fe1b0000.ethernet: TX Checksum insertion supported
[ 4.918583] rk_gmac-dwmac fe1b0000.ethernet: Wake-Up On Lan supported
[ 4.918614] rk_gmac-dwmac fe1b0000.ethernet: TSO supported
[ 4.918618] rk_gmac-dwmac fe1b0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 4.918624] rk_gmac-dwmac fe1b0000.ethernet: Enabled Flow TC (entries=2)
[ 4.918627] rk_gmac-dwmac fe1b0000.ethernet: TSO feature enabled
[ 4.918632] rk_gmac-dwmac fe1b0000.ethernet: Using 32 bits DMA width
[ 4.919545] rk-pcie fe150000.pcie: PCIe Linking… LTSSM is 0x0
[ 5.053111] RTL8211F Gigabit Ethernet stmmac-0:01: [phy_probe-2991] led_status_value normal
[ 5.053697] rk_gmac-dwmac fe1c0000.ethernet: IRQ eth_lpi not found
[ 5.053815] rk_gmac-dwmac fe1c0000.ethernet: no regulator found
[ 5.053822] rk_gmac-dwmac fe1c0000.ethernet: clock input or output? (output).
[ 5.053827] rk_gmac-dwmac fe1c0000.ethernet: TX delay(0x4f).
[ 5.053831] rk_gmac-dwmac fe1c0000.ethernet: Can not read property: rx_delay.
[ 5.053835] rk_gmac-dwmac fe1c0000.ethernet: set rx_delay to 0xffffffff
[ 5.053843] rk_gmac-dwmac fe1c0000.ethernet: integrated PHY? (no).
[ 5.053849] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_rx
[ 5.053854] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock mac_clk_tx
[ 5.053865] rk_gmac-dwmac fe1c0000.ethernet: cannot get clock clk_mac_speed
[ 5.054082] rk_gmac-dwmac fe1c0000.ethernet: init for RGMII_RXID
[ 5.054200] rk_gmac-dwmac fe1c0000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 5.054206] rk_gmac-dwmac fe1c0000.ethernet: DWMAC4/5
[ 5.054211] rk_gmac-dwmac fe1c0000.ethernet: DMA HW capability register supported
[ 5.054215] rk_gmac-dwmac fe1c0000.ethernet: RX Checksum Offload Engine supported
[ 5.054219] rk_gmac-dwmac fe1c0000.ethernet: TX Checksum insertion supported
[ 5.054223] rk_gmac-dwmac fe1c0000.ethernet: Wake-Up On Lan supported
[ 5.054250] rk_gmac-dwmac fe1c0000.ethernet: TSO supported
[ 5.054254] rk_gmac-dwmac fe1c0000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 5.054260] rk_gmac-dwmac fe1c0000.ethernet: Enabled Flow TC (entries=2)
[ 5.054263] rk_gmac-dwmac fe1c0000.ethernet: TSO feature enabled
[ 5.054268] rk_gmac-dwmac fe1c0000.ethernet: Using 32 bits DMA width
[ 5.189024] phy_rtl8211f_led_fixup in
[ 5.209672] hcq : phy_rtl8211e_eee_fixup in
[ 5.230894] RTL8211F Gigabit Ethernet stmmac-1:01: [phy_probe-2991] led_status_value normal
[ 5.231768] usbcore: registered new interface driver asix
[ 5.231798] usbcore: registered new interface driver ax88179_178a
[ 5.231811] usbcore: registered new interface driver cdc_ether
[ 5.231822] usbcore: registered new interface driver net1080
[ 5.231835] usbcore: registered new interface driver cdc_subset
[ 5.231848] usbcore: registered new interface driver zaurus
[ 5.231864] usbcore: registered new interface driver cdc_ncm
[ 5.231878] usbcore: registered new interface driver qmi_wwan_q
[ 5.231890] usbcore: registered new interface driver qmi_wwan
[ 5.234214] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 5.234223] ehci-pci: EHCI PCI platform driver
[ 5.234256] ehci-platform: EHCI generic platform driver
[ 5.234435] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 5.234443] ohci-platform: OHCI generic platform driver
[ 5.234783] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.234851] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 1
[ 5.234933] xhci-hcd xhci-hcd.3.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 5.234958] xhci-hcd xhci-hcd.3.auto: irq 134, io mem 0xfcd00000
[ 5.235086] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.235092] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.235097] usb usb1: Product: xHCI Host Controller
[ 5.235101] usb usb1: Manufacturer: Linux 5.10.110 xhci-hcd
[ 5.235105] usb usb1: SerialNumber: xhci-hcd.3.auto
[ 5.235281] hub 1-0:1.0: USB hub found
[ 5.235294] hub 1-0:1.0: 1 port detected
[ 5.235410] xhci-hcd xhci-hcd.3.auto: xHCI Host Controller
[ 5.235462] xhci-hcd xhci-hcd.3.auto: new USB bus registered, assigned bus number 2
[ 5.235469] xhci-hcd xhci-hcd.3.auto: Host supports USB 3.0 SuperSpeed
[ 5.235493] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.235532] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.235537] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.235542] usb usb2: Product: xHCI Host Controller
[ 5.235546] usb usb2: Manufacturer: Linux 5.10.110 xhci-hcd
[ 5.235550] usb usb2: SerialNumber: xhci-hcd.3.auto
[ 5.235691] hub 2-0:1.0: USB hub found
[ 5.235705] hub 2-0:1.0: 1 port detected
[ 5.235846] usbcore: registered new interface driver cdc_acm
[ 5.235850] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 5.235864] usbcore: registered new interface driver cdc_wdm
[ 5.235897] usbcore: registered new interface driver usbserial_generic
[ 5.235907] usbserial: USB Serial support registered for generic
[ 5.235920] usbcore: registered new interface driver ch341
[ 5.235929] usbserial: USB Serial support registered for ch341-uart
[ 5.235942] usbcore: registered new interface driver cp210x
[ 5.235950] usbserial: USB Serial support registered for cp210x
[ 5.235966] usbcore: registered new interface driver ftdi_sio
[ 5.235974] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 5.236003] usbcore: registered new interface driver keyspan
[ 5.236011] usbserial: USB Serial support registered for Keyspan - (without firmware)
[ 5.236020] usbserial: USB Serial support registered for Keyspan 1 port adapter
[ 5.236028] usbserial: USB Serial support registered for Keyspan 2 port adapter
[ 5.236036] usbserial: USB Serial support registered for Keyspan 4 port adapter
[ 5.236049] usbcore: registered new interface driver option
[ 5.236057] usbserial: USB Serial support registered for GSM modem (1-port)
[ 5.236092] usbcore: registered new interface driver oti6858
[ 5.236101] usbserial: USB Serial support registered for oti6858
[ 5.236114] usbcore: registered new interface driver pl2303
[ 5.236122] usbserial: USB Serial support registered for pl2303
[ 5.236137] usbcore: registered new interface driver qcserial
[ 5.236144] usbserial: USB Serial support registered for Qualcomm USB modem
[ 5.236159] usbcore: registered new interface driver sierra
[ 5.236176] usbserial: USB Serial support registered for Sierra USB modem
[ 5.236580] [HXTP] himax_hx83102_init
[ 5.236585] [HXTP] himax_hx83102_probe:Enter
[ 5.236589] [HXTP] Himax common touch panel driver init
[ 5.236630] usbcore: registered new interface driver usbtouchscreen
[ 5.237519] input: rk805 pwrkey as /devices/platform/feb20000.spi/spi_master/spi2/spi2.0/rk805-pwrkey.1.auto/input/input0
[ 5.237710] i2c /dev entries driver
[ 5.241095] vdd_cpu_big0_s0: supplied by vcc5v0_sys
[ 5.249547] vdd_cpu_big1_s0: supplied by vcc5v0_sys
[ 5.258404] vdd_npu_s0: supplied by vcc5v0_sys
[ 5.264106] [HXTP] himax_chip_common_probe:Enter
[ 5.264112] [HXTP] Prepare kernel fp
[ 5.270036] [HXTP] PDATA START
[ 5.270042] [HXTP] ic_data START
[ 5.270049] [HXTP] DT-himax_parse_dt:panel-coords = 0, 799, 0, 1279
[ 5.270055] [HXTP] DT-himax_parse_dt:display-coords = (800, 1280)
[ 5.270070] [HXTP] DT:gpio_3v3_en value is not valid
[ 5.270074] [HXTP] DT:gpio_irq=112, gpio_rst=113, gpio_3v3_en=-2
[ 5.270078] [HXTP] DT:protocol_type=1
[ 5.270082] [HXTP] DT-No vk info in DT
[ 5.272121] [HXTP] himax_get_ksym_idx: symtable size: 1
[ 5.272126] [HXTP] hx83102_pin_reset: Now reset the Touch chip.
[ 5.353260] [HXTP][ERROR] himax_bus_read: i2c_read_block retry over 3
[ 5.353265] [HXTP][ERROR] hx83102_chip_detect: i2c access fail!
[ 5.353270] [HXTP] himax_chip_common_init:num=0,chip NOT found! go Next
[ 5.353273] [HXTP][ERROR] himax_chip_common_init: chip detect failed!
[ 5.353289] himax_tp: probe of 1-0048 failed with error -9
[ 5.354487] pca953x 6-0021: supply vcc not found, using dummy regulator
[ 5.354535] pca953x 6-0021: using no AI
[ 5.356095] rtc-hym8563 6-0051: rtc information is valid
[ 5.357537] rtc-hym8563 6-0051: registered as rtc0
[ 5.357811] rtc-hym8563 6-0051: setting system clock to 2023-04-27T02:01:20 UTC (1682560880)
[ 5.359027] pca953x 6-0020: supply vcc not found, using dummy regulator
[ 5.359076] pca953x 6-0020: using no AI
[ 5.360208] rkcifhw fdce0000.rkcif: Adding to iommu group 14
[ 5.360228] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.360499] rkcifhw fdce0000.rkcif: No reserved memory region assign to CIF
[ 5.360568] rkcif rkcif-mipi-lvds2: Adding to iommu group 14
[ 5.360582] rkcif rkcif-mipi-lvds2: rkcif driver version: v00.01.0a
[ 5.360628] rkcif rkcif-mipi-lvds2: attach to cif hw node
[ 5.360632] rkcif rkcif-mipi-lvds2: rkcif wait line 0
[ 5.360638] : terminal subdev does not exist
[ 5.360642] : terminal subdev does not exist
[ 5.360645] : terminal subdev does not exist
[ 5.360649] : terminal subdev does not exist
[ 5.360653] : get_remote_sensor: video pad[0] is null
[ 5.360657] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.360662] : get_remote_sensor: video pad[0] is null
[ 5.360665] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.360669] : get_remote_sensor: video pad[0] is null
[ 5.360672] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.360676] : get_remote_sensor: video pad[0] is null
[ 5.360680] : rkcif_update_sensor_info: stream[0] get remote sensor_sd failed!
[ 5.361255] rkcif rkcif-mipi-lvds2: No memory-region-thunderboot specified
[ 5.361912] rkcif rkcif-mipi-lvds2: Entity type for entity rockchip-mipi-csi2 was not initialized!
[ 5.361919] rockchip-mipi-csi2: Async registered subdev
[ 5.361926] rockchip-mipi-csi2: probe success, v4l2_dev:rkcif-mipi-lvds2!
[ 5.363309] rk_hdmirx fdee0000.hdmirx-controller: No reserved memory for HDMIRX, use default CMA
[ 5.363329] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_probe: cpu_aff:0x400, Bound_cpu:4, wdt_cfg_bound_cpu:5
[ 5.363811] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_audio_interrupts_setup: 0
[ 5.364441] rk_hdmirx fdee0000.hdmirx-controller: rk_hdmirx_hdcp_register success
[ 5.364458] rk_hdmirx fdee0000.hdmirx-controller: fdee0000.hdmirx-controller driver probe ok!
[ 5.364535] usbcore: registered new interface driver uvcvideo
[ 5.364539] USB Video Class driver (1.1.1)
[ 5.366247] rockchip-thermal fec00000.tsadc: Missing rockchip,grf property
[ 5.366703] rockchip-thermal fec00000.tsadc: tsadc is probed successfully!
[ 5.367175] device-mapper: ioctl: 4.44.0-ioctl (2021-02-01) initialised: dm-devel@redhat.com
[ 5.367308] Bluetooth: HCI UART driver ver 2.3
[ 5.367313] Bluetooth: HCI UART protocol H4 registered
[ 5.367317] Bluetooth: HCI UART protocol ATH3K registered
[ 5.367338] usbcore: registered new interface driver bfusb
[ 5.368025] cpu cpu0: bin=0
[ 5.368198] cpu cpu0: leakage=13
[ 5.369610] cpu cpu0: pvtm=1452
[ 5.369677] cpu cpu0: pvtm-volt-sel=2
[ 5.371562] cpu cpu4: bin=0
[ 5.371732] cpu cpu4: leakage=11
[ 5.378181] cpu cpu4: pvtm=1683
[ 5.382091] cpu cpu4: pvtm-volt-sel=4
[ 5.384727] cpu cpu6: bin=0
[ 5.384899] cpu cpu6: leakage=11
[ 5.391361] cpu cpu6: pvtm=1696
[ 5.395287] cpu cpu6: pvtm-volt-sel=4
[ 5.396788] cpu cpu0: avs=0
[ 5.397383] cpu cpu4: avs=0
[ 5.397963] cpu cpu6: avs=0
[ 5.398090] cpu cpu0: EM: OPP:816000 is inefficient
[ 5.398093] cpu cpu0: EM: OPP:600000 is inefficient
[ 5.398159] cpu cpu0: EM: created perf domain
[ 5.398192] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[ 5.398753] cpu cpu4: EM: OPP:816000 is inefficient
[ 5.398756] cpu cpu4: EM: OPP:600000 is inefficient
[ 5.398853] cpu cpu4: EM: created perf domain
[ 5.398879] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 5.407160] cpu cpu6: EM: OPP:816000 is inefficient
[ 5.407164] cpu cpu6: EM: OPP:600000 is inefficient
[ 5.407279] cpu cpu6: EM: created perf domain
[ 5.407655] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[ 5.423706] sdhci: Secure Digital Host Controller Interface driver
[ 5.423741] sdhci: Copyright(c) Pierre Ossman
[ 5.423748] Synopsys Designware Multimedia Card Interface Driver
[ 5.424091] sdhci-pltfm: SDHCI platform and OF driver helper
[ 5.427109] arm-scmi firmware:scmi: Failed. SCMI protocol 17 not active.
[ 5.427184] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 5.427891] cryptodev: driver 1.12 loaded.
[ 5.427945] hid: raw HID events driver (C) Jiri Kosina
[ 5.428129] usbcore: registered new interface driver usbhid
[ 5.428135] usbhid: USB HID core driver
[ 5.428344] ashmem: initialized
[ 5.431709] Firefly adc init
[ 5.431724] Firefly adc–>FIREFLY_ADC_SAMPLE_JIFFIES: 16
[ 5.431731] Firefly adc–>MSEC_PER_SEC: 1000
[ 5.431736] Firefly adc–>HZ: 300
[ 5.431919] Firefly adc–>ret: 0
[ 5.432115] optee: probing for conduit method.
[ 5.432135] optee: revision 3.13 (4542e1ef)
[ 5.432686] optee: initialized driver
[ 5.433300] usbcore: registered new interface driver snd-usb-audio
[ 5.441459] firefly-multicodecs es8388-sound: Failed to get hw-ver
[ 5.453882] ES8323 3-0011: ASoC: error at soc_component_write_no_lock on ES8323.3-0011: -5
[ 5.457109] mmc0: SDHCI controller on fe2e0000.mmc [fe2e0000.mmc] using ADMA
[ 5.488882] mmc0: Host Software Queue enabled
[ 5.488920] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.489406] mmcblk0: mmc0:0001 Y29256 233 GiB
[ 5.489606] mmcblk0boot0: mmc0:0001 Y29256 partition 1 4.00 MiB
[ 5.489787] mmcblk0boot1: mmc0:0001 Y29256 partition 2 4.00 MiB
[ 5.489947] mmcblk0rpmb: mmc0:0001 Y29256 partition 3 4.00 MiB, chardev (234:0)
[ 5.493364] mmcblk0: p1 p2 p3 p4 p5 p6 p7
[ 5.502610] input: rockchip-es8388 Headset as /devices/platform/es8388-sound/sound/card0/input1
[ 5.504289] Initializing XFRM netlink socket
[ 5.504519] NET: Registered protocol family 10
[ 5.505083] Segment Routing with IPv6
[ 5.505232] NET: Registered protocol family 17
[ 5.505248] NET: Registered protocol family 15
[ 5.505280] Bridge firewalling registered
[ 5.505285] can: controller area network core
[ 5.505311] NET: Registered protocol family 29
[ 5.505317] can: raw protocol
[ 5.505324] can: broadcast manager protocol
[ 5.505332] can: netlink gateway - max_hops=1
[ 5.505447] Bluetooth: RFCOMM TTY layer initialized
[ 5.505457] Bluetooth: RFCOMM socket layer initialized
[ 5.505469] Bluetooth: RFCOMM ver 1.11
[ 5.505478] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.505483] Bluetooth: BNEP filters: protocol multicast
[ 5.505490] Bluetooth: BNEP socket layer initialized
[ 5.505495] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.505501] Bluetooth: HIDP socket layer initialized
[ 5.505529] 8021q: 802.1Q VLAN Support v1.8
[ 5.505546] [BT_RFKILL]: Enter rfkill_rk_init
[ 5.505550] [WLAN_RFKILL]: Enter rfkill_wlan_init
[ 5.506222] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[ 5.506244] [WLAN_RFKILL]: can’t find rockchip,grf property
[ 5.506250] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6275p
[ 5.506256] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[ 5.506261] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[ 5.506278] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,poweren_gpio = 20 flags = 0.
[ 5.506295] [WLAN_RFKILL]: wlan_platdata_parse_dt: WIFI,host_wake_irq = 10, flags = 0.
[ 5.506306] [WLAN_RFKILL]: wlan_platdata_parse_dt: The ref_wifi_clk not found !
[ 5.506311] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[ 5.506316] [WLAN_RFKILL]: rfkill_set_wifi_bt_power: 1
[ 5.506322] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[ 5.506968] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 34.
[ 5.506986] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 22.
[ 5.506996] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 21.
[ 5.507006] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 0.
[ 5.507065] [BT_RFKILL]: Request irq for bt wakeup host
[ 5.507115] [BT_RFKILL]: ** disable irq
[ 5.507169] [BT_RFKILL]: bt_default device registered.
[ 5.507235] Key type dns_resolver registered
[ 5.508347] xc7160 3-001b: T-chip firefly camera driver version: 00.01.04
[ 5.508471] xc7160 3-001b: supply avdd not found, using dummy regulator
[ 5.508572] xc7160 3-001b: supply dovdd not found, using dummy regulator
[ 5.508615] xc7160 3-001b: supply dvdd not found, using dummy regulator
[ 5.508652] xc7160 3-001b: could not get default pinstate
[ 5.508658] xc7160 3-001b: could not get sleep pinstate
[ 5.508674] xc7160 3-001b: Success to get xc7160 endpoint data lanes, dts uses 4 lanes
[ 5.525762] xc7160 3-001b: write XC7160_REG_HIGH_SELECT failed
[ 5.526038] xc7160: probe of 3-001b failed with error -5
[ 5.526468] registered taskstats version 1
[ 5.526478] Loading compiled-in X.509 certificates
[ 5.526638] vendor storage:20190527 ret = 0
[ 5.527492] Btrfs loaded, crc32c=crc32c-generic
[ 5.527587] pstore: Using crash dump compression: deflate
[ 5.528039] rga3_core0 fdb60000.rga: Adding to iommu group 2
[ 5.528069] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.528223] rga: rga3_core0, irq = 34, match scheduler
[ 5.528456] rga: rga3_core0 hardware loaded successfully, hw_version:3.0.76831.
[ 5.528476] rga: rga3_core0 probe successfully
[ 5.528812] rga3_core1 fdb70000.rga: Adding to iommu group 3
[ 5.528829] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 5.528979] rga: rga3_core1, irq = 35, match scheduler
[ 5.529219] rga: rga3_core1 hardware loaded successfully, hw_version:3.0.76831.
[ 5.529236] rga: rga3_core1 probe successfully
[ 5.529559] rga: rga2, irq = 36, match scheduler
[ 5.529839] rga: rga2 hardware loaded successfully, hw_version:3.2.63318.
[ 5.529856] rga: rga2 probe successfully
[ 5.530032] rga_iommu: IOMMU binding successfully, default mapping core[0x1]
[ 5.530193] rga: Module initialized. v1.2.23
[ 5.530203] ********************************************************************
[ 5.530208] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 5.530212] ** **
[ 5.530216] ** WRITEABLE clk DebugFS SUPPORT HAS BEEN ENABLED IN THIS KERNEL **
[ 5.530221] ** **
[ 5.530225] ** This means that this kernel is built to expose clk operations **
[ 5.530228] ** such as parent or rate setting, enabling, disabling, etc. **
[ 5.530232] ** to userspace, which may compromise security on your system. **
[ 5.530236] ** **
[ 5.530240] ** If you see this message and you are not debugging the **
[ 5.530244] ** kernel, report this immediately to your vendor! **
[ 5.530248] ** **
[ 5.530252] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
[ 5.530256] ********************************************************************
[ 5.561629] mali fb000000.gpu: Kernel DDK version g15p0-01eac0
[ 5.561968] vcc_sata_pwr_en: supplied by vcc12v_dcin
[ 5.562284] mali fb000000.gpu: bin=0
[ 5.562461] mali fb000000.gpu: leakage=21
[ 5.562491] debugfs: Directory ‘fb000000.gpu-mali’ with parent ‘vdd_gpu_s0’ already present!
[ 5.563888] mali fb000000.gpu: pvtm=887
[ 5.563919] mali fb000000.gpu: pvtm-volt-sel=4
[ 5.564499] mali fb000000.gpu: avs=0
[ 5.564580] W : [File] : drivers/gpu/arm/bifrost/platform/rk/mali_kbase_config_rk.c; [Line] : 136; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[ 5.565083] mali fb000000.gpu: GPU hardware issue table may need updating:
r0p0 status 5 is unknown; treating as r0p0 status 0
[ 5.565092] mali fb000000.gpu: GPU identified as 0x7 arch 10.8.6 r0p0 status 0
[ 5.565175] mali fb000000.gpu: No priority control manager is configured
[ 5.565306] mali fb000000.gpu: No memory group manager is configured
[ 5.565328] mali fb000000.gpu: Protected memory allocator not available
[ 5.565598] mali fb000000.gpu: Capping CSF_FIRMWARE_TIMEOUT to CSF_FIRMWARE_PING_TIMEOUT
[ 5.566274] mali fb000000.gpu: Couldn’t find power_model DT node matching ‘arm,mali-simple-power-model’
[ 5.566295] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.static-coefficient = 1*[0]
[ 5.566549] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.dynamic-coefficient = 1*[0]
[ 5.566775] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.ts = 4*[0]
[ 5.566999] mali fb000000.gpu: Error -22, no DT entry: mali-simple-power-model.thermal-zone = ‘’
[ 5.570240] mali fb000000.gpu: Using configured power model mali-lodx-power-model, and fallback mali-simple-power-model
[ 5.570419] mali fb000000.gpu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 5.570694] vcc5v0_host: supplied by vcc5v0_usb
[ 5.571996] vcc5v0_host3: supplied by vcc5v0_usb
[ 5.572241] mali fb000000.gpu: Probed as mali0
[ 5.573841] pcie30_avdd1v8: supplied by avcc_1v8_s0
[ 5.574240] pcie30_avdd0v75: supplied by avdd_0v75_s0
[ 5.575975] rockchip-dmc dmc: leakage=47
[ 5.575987] rockchip-dmc dmc: leakage-volt-sel=2
[ 5.576303] rockchip-dmc dmc: avs=0
[ 5.576315] rockchip-dmc dmc: current ATF version 0x100
[ 5.576410] rockchip-dmc dmc: normal_rate = 1560000000
[ 5.576418] rockchip-dmc dmc: reboot_rate = 2112000000
[ 5.576424] rockchip-dmc dmc: suspend_rate = 528000000
[ 5.576430] rockchip-dmc dmc: video_4k_rate = 1560000000
[ 5.576436] rockchip-dmc dmc: video_4k_10b_rate = 1560000000
[ 5.576442] rockchip-dmc dmc: video_svep_rate = 1560000000
[ 5.576448] rockchip-dmc dmc: boost_rate = 2112000000
[ 5.576453] rockchip-dmc dmc: fixed_rate(isp|cif0|cif1|dualview) = 2112000000
[ 5.576460] rockchip-dmc dmc: performance_rate = 2112000000
[ 5.576465] rockchip-dmc dmc: hdmirx_rate = 2112000000
[ 5.576474] rockchip-dmc dmc: failed to get vop bandwidth to dmc rate
[ 5.576479] rockchip-dmc dmc: failed to get vop pn to msch rl
[ 5.576572] rockchip-dmc dmc: l=10000 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 5.577148] rockchip-dmc dmc: could not find power_model node
[ 5.599677] rk-pcie fe170000.pcie: PCIe Link up, LTSSM is 0x30011
[ 5.599827] rk-pcie fe170000.pcie: PCI host bridge to bus 0002:20
[ 5.599848] pci_bus 0002:20: root bus resource [bus 20-2f]
[ 5.599862] pci_bus 0002:20: root bus resource [??? 0xf2000000-0xf20fffff flags 0x0]
[ 5.599875] pci_bus 0002:20: root bus resource [io 0x0000-0xfffff] (bus address [0xf2100000-0xf21fffff])
[ 5.599884] pci_bus 0002:20: root bus resource [mem 0xf2200000-0xf2ffffff]
[ 5.599897] pci_bus 0002:20: root bus resource [mem 0x980000000-0x9bfffffff pref]
[ 5.599952] pci 0002:20:00.0: [1d87:3588] type 01 class 0x060400
[ 5.599985] pci 0002:20:00.0: reg 0x38: [mem 0x00000000-0x0000ffff pref]
[ 5.600063] pci 0002:20:00.0: supports D1 D2
[ 5.600071] pci 0002:20:00.0: PME# supported from D0 D1 D3hot
[ 5.605535] pci 0002:20:00.0: Primary bus is hard wired to 0
[ 5.605544] pci 0002:20:00.0: bridge configuration invalid ([bus 01-ff]), reconfiguring
[ 5.605738] pci 0002:21:00.0: [14e4:449d] type 00 class 0x028000
[ 5.605825] pci 0002:21:00.0: reg 0x10: [mem 0x00000000-0x0000ffff 64bit]
[ 5.605879] pci 0002:21:00.0: reg 0x18: [mem 0x00000000-0x003fffff 64bit]
[ 5.606398] pci 0002:21:00.0: supports D1 D2
[ 5.606406] pci 0002:21:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 5.620415] pci_bus 0002:21: busn_res: [bus 21-2f] end is updated to 21
[ 5.620466] pci 0002:20:00.0: BAR 8: assigned [mem 0xf2200000-0xf27fffff]
[ 5.620478] pci 0002:20:00.0: BAR 6: assigned [mem 0xf2800000-0xf280ffff pref]
[ 5.620490] pci 0002:21:00.0: BAR 2: assigned [mem 0xf2400000-0xf27fffff 64bit]
[ 5.620534] pci 0002:21:00.0: BAR 0: assigned [mem 0xf2200000-0xf220ffff 64bit]
[ 5.620578] pci 0002:20:00.0: PCI bridge to [bus 21]
[ 5.620587] pci 0002:20:00.0: bridge window [mem 0xf2200000-0xf27fffff]
[ 5.620829] lzf debug reg_fixed_voltage_probe_firefly-286
[ 5.622574] pcieport 0002:20:00.0: PME: Signaling with IRQ 150
[ 5.625060] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 5.625075] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 5.625124] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 5.625138] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 5.625201] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -517
[ 5.625527] [drm] failed to init overlay plane Cluster0-win1
[ 5.625597] [drm] failed to init overlay plane Cluster1-win1
[ 5.625635] [drm] failed to init overlay plane Cluster2-win1
[ 5.625670] [drm] failed to init overlay plane Cluster3-win1
[ 5.642156] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc011744ee0)
[ 5.643977] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 5.644476] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc01174d728)
[ 5.644565] dw-mipi-dsi2 fde20000.dsi: [drm:dw_mipi_dsi2_bind] ERROR Failed to find panel or bridge: -517
[ 5.650899] panel-simple-dsi fde20000.dsi.0: supply power not found, using dummy regulator
[ 5.662072] phy phy-fd5d4000.syscon:usb2-phy@4000.11: illegal mode
[ 5.662092] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 5.662215] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 3
[ 5.662322] xhci-hcd xhci-hcd.7.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000080002010010
[ 5.662347] xhci-hcd xhci-hcd.7.auto: irq 135, io mem 0xfc400000
[ 5.662495] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.662501] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.662506] usb usb3: Product: xHCI Host Controller
[ 5.662510] usb usb3: Manufacturer: Linux 5.10.110 xhci-hcd
[ 5.662515] usb usb3: SerialNumber: xhci-hcd.7.auto
[ 5.662809] hub 3-0:1.0: USB hub found
[ 5.662823] hub 3-0:1.0: 1 port detected
[ 5.662947] xhci-hcd xhci-hcd.7.auto: xHCI Host Controller
[ 5.663126] xhci-hcd xhci-hcd.7.auto: new USB bus registered, assigned bus number 4
[ 5.663139] xhci-hcd xhci-hcd.7.auto: Host supports USB 3.0 SuperSpeed
[ 5.663176] usb usb4: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 5.663221] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.663227] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.663232] usb usb4: Product: xHCI Host Controller
[ 5.663236] usb usb4: Manufacturer: Linux 5.10.110 xhci-hcd
[ 5.663241] usb usb4: SerialNumber: xhci-hcd.7.auto
[ 5.663613] hub 4-0:1.0: USB hub found
[ 5.663627] hub 4-0:1.0: 1 port detected
[ 5.663942] input: adc-keys as /devices/platform/adc-keys/input/input2
[ 5.670790] debugfs: File ‘Capture’ in directory ‘dapm’ already present!
[ 5.671359] input: rockchip-dp0 rockchip-dp0 as /devices/platform/dp0-sound/sound/card2/input3
[ 5.673832] ohci-platform fc8c0000.usb: Generic Platform OHCI controller
[ 5.673937] ohci-platform fc8c0000.usb: new USB bus registered, assigned bus number 5
[ 5.673995] ohci-platform fc8c0000.usb: irq 23, io mem 0xfc8c0000
[ 5.733934] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 5.733960] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.733968] usb usb5: Product: Generic Platform OHCI controller
[ 5.733977] usb usb5: Manufacturer: Linux 5.10.110 ohci_hcd
[ 5.733984] usb usb5: SerialNumber: fc8c0000.usb
[ 5.734394] hub 5-0:1.0: USB hub found
[ 5.734424] hub 5-0:1.0: 1 port detected
[ 5.735055] ehci-platform fc880000.usb: EHCI Host Controller
[ 5.735244] ehci-platform fc880000.usb: new USB bus registered, assigned bus number 6
[ 5.735366] ehci-platform fc880000.usb: irq 22, io mem 0xfc880000
[ 5.749856] ehci-platform fc880000.usb: USB 2.0 started, EHCI 1.00
[ 5.750175] usb usb6: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.750195] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.750211] usb usb6: Product: EHCI Host Controller
[ 5.750225] usb usb6: Manufacturer: Linux 5.10.110 ehci_hcd
[ 5.750240] usb usb6: SerialNumber: fc880000.usb
[ 5.751016] hub 6-0:1.0: USB hub found
[ 5.751073] hub 6-0:1.0: 1 port detected
[ 5.754812] ohci-platform fc840000.usb: Generic Platform OHCI controller
[ 5.755231] ohci-platform fc840000.usb: new USB bus registered, assigned bus number 7
[ 5.755408] ohci-platform fc840000.usb: irq 21, io mem 0xfc840000
[ 5.813988] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10
[ 5.814038] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.814052] usb usb7: Product: Generic Platform OHCI controller
[ 5.814064] usb usb7: Manufacturer: Linux 5.10.110 ohci_hcd
[ 5.814078] usb usb7: SerialNumber: fc840000.usb
[ 5.814785] hub 7-0:1.0: USB hub found
[ 5.814837] hub 7-0:1.0: 1 port detected
[ 5.816028] ehci-platform fc800000.usb: EHCI Host Controller
[ 5.816334] ehci-platform fc800000.usb: new USB bus registered, assigned bus number 8
[ 5.816471] ehci-platform fc800000.usb: irq 20, io mem 0xfc800000
[ 5.829894] ehci-platform fc800000.usb: USB 2.0 started, EHCI 1.00
[ 5.830423] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.830458] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.830484] usb usb8: Product: EHCI Host Controller
[ 5.830509] usb usb8: Manufacturer: Linux 5.10.110 ehci_hcd
[ 5.830532] usb usb8: SerialNumber: fc800000.usb
[ 5.831896] hub 8-0:1.0: USB hub found
[ 5.831992] hub 8-0:1.0: 1 port detected
[ 5.838999] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x5, primary plane phy id: 2
[ 5.839083] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp1 assign plane mask: 0xa, primary plane phy id: 3
[ 5.839140] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x140, primary plane phy id: 8
[ 5.839176] rockchip-vop2 fdd90000.vop: [drm:vop2_bind] vp3 assign plane mask: 0x280, primary plane phy id: 9
[ 5.839219] rockchip-drm display-subsystem: failed to get hdmi1_phy_pll: -517
[ 5.840106] [drm] failed to init overlay plane Cluster0-win1
[ 5.840206] [drm] failed to init overlay plane Cluster1-win1
[ 5.840305] [drm] failed to init overlay plane Cluster2-win1
[ 5.840403] [drm] failed to init overlay plane Cluster3-win1
[ 5.862960] rockchip-drm display-subsystem: bound fdd90000.vop (ops 0xffffffc011744ee0)
[ 5.865500] dwhdmi-rockchip fde80000.hdmi: registered ddc I2C bus driver
[ 5.866237] rockchip-drm display-subsystem: bound fde80000.hdmi (ops 0xffffffc01174d728)
[ 5.866275] Daijh: 2
[ 5.866285] Firefly: full_name dsi@fde20000: id 0
[ 5.999803] usb 6-1: new high-speed USB device number 2 using ehci-platform
[ 6.147859] usb 6-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[ 6.147961] usb 6-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 6.147987] usb 6-1: Product: USB 2.0 Hub [MTT]
[ 6.149418] hub 6-1:1.0: USB hub found
[ 6.149632] hub 6-1:1.0: 4 ports detected
[ 6.216394] dw-mipi-dsi2 fde20000.dsi: [drm:cri_fifos_wait_avail] ERROR command interface is busy
[ 6.216429] [Firefly]-[panel_simple_xfer_dsi_cmd_seq]-[268]: ret = -110, read 4 = 0
[ 6.216438] [Firefly]-[panel_simple_xfer_dsi_cmd_seq]-[272]: Not Found ID = 83 MIPI!
[ 6.216448] [Firefly]-[panel_simple_prepare]-[582]: Parse cmd Fail!
[ 6.273171] [zyk debug] panel_simple_disable: done
[ 6.299725] rockchip-drm display-subsystem: failed to bind fde20000.dsi (ops 0xffffffc01174f968): -999
[ 6.300007] rockchip-drm display-subsystem: bound fde50000.dp (ops 0xffffffc01174fce8)
[ 6.300183] rockchip-drm display-subsystem: bound fde60000.dp (ops 0xffffffc01174fce8)
[ 6.302807] rockchip-drm display-subsystem: No available crtc or connector for display
[ 6.456774] es8323_line1_line2_line2diff_switch:0
[ 6.478308] rockchip-drm display-subsystem: route-dp1: failed to get logo,offset
[ 6.478575] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 6.478762] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 6.529574] usb 6-1.4: new high-speed USB device number 3 using ehci-platform
[ 6.689019] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 6.739305] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[ 6.803827] rockchip-vop2 fdd90000.vop: [drm:vop2_wait_power_domain_off] ERROR wait pd7 off timeout power_ctrl: 0x7f
[ 6.820812] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_disable] ERROR unexpected power on pd7
[ 6.820884] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000
[ 6.821050] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2
[ 6.821119] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
[ 6.821395] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
[ 6.821400] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000
[ 6.821434] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000
[ 6.821467] dwhdmi-rockchip fde80000.hdmi: don’t use dsc mode
[ 6.821470] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode
[ 6.821475] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000
[ 6.821667] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
[ 6.831449] usb 6-1.4: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
[ 6.831456] usb 6-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.831462] usb 6-1.4: Product: Android
[ 6.831466] usb 6-1.4: Manufacturer: Android
[ 6.833054] option 6-1.4:1.0: GSM modem (1-port) converter detected
[ 6.833474] usb 6-1.4: GSM modem (1-port) converter now attached to ttyUSB0
[ 6.833806] option 6-1.4:1.1: GSM modem (1-port) converter detected
[ 6.834216] usb 6-1.4: GSM modem (1-port) converter now attached to ttyUSB1
[ 6.834572] option 6-1.4:1.2: GSM modem (1-port) converter detected
[ 6.834971] usb 6-1.4: GSM modem (1-port) converter now attached to ttyUSB2
[ 6.835326] option 6-1.4:1.3: GSM modem (1-port) converter detected
[ 6.835672] usb 6-1.4: GSM modem (1-port) converter now attached to ttyUSB3
[ 6.836827] qmi_wwan_q 6-1.4:1.4: cdc-wdm0: USB WDM device
[ 6.837324] qmi_wwan_q 6-1.4:1.4: Quectel Android work on RawIP mode
[ 6.838318] qmi_wwan_q 6-1.4:1.4: rx_urb_size = 1520
[ 6.838996] qmi_wwan_q 6-1.4:1.4 wwan0: register ‘qmi_wwan_q’ at usb-fc880000.usb-1.4, WWAN/QMI device, ce:7b:36:27:25:28
[ 6.877789] rk_iommu fdd97e00.iommu: Enable stall request timed out, retry_count = 0, status: 0x00001d
[ 6.877793] rk_iommu fdd97e00.iommu: Enable stall request timed out, retry_count = 0, status: 0x00030b
[ 6.888406] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 6.936262] Console: switching to colour frame buffer device 240x67
[ 6.936350] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 6.957902] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
[ 6.958903] [drm] Initialized rockchip 3.0.0 20140818 for display-subsystem on minor 0
[ 6.960735] input: rockchip-hdmi0 rockchip-hdmi0 as /devices/platform/hdmi0-sound/sound/card3/input4
[ 6.963766] rkcif rkcif-mipi-lvds2: clear unready subdev num: 1
[ 6.963782] rockchip-csi2-dphy0: No link between dphy and sensor
[ 6.964311] rockchip-csi2-dphy0: No link between dphy and sensor
[ 6.964339] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 6.964373] rkcif-mipi-lvds2: Async subdev notifier completed
[ 6.964381] rockchip-csi2-dphy0: No link between dphy and sensor
[ 6.964394] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 6.964400] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
[ 6.964410] rockchip-csi2-dphy0: No link between dphy and sensor
[ 6.964433] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 6.964440] rkcif-mipi-lvds2: There is not terminal subdev, not synchronized with ISP
[ 6.964995] pc9202: sw2001_read(0x1) return 0x1
[ 6.965003] status=0x1
[ 6.965009] ====== i2c detect success watchdog init ======
[ 6.966486] dwmmc_rockchip fe2c0000.mmc: IDMAC supports 32-bit address mode.
[ 6.966534] dwmmc_rockchip fe2c0000.mmc: Using internal DMA controller.
[ 6.966547] dwmmc_rockchip fe2c0000.mmc: Version ID is 270a
[ 6.966594] dwmmc_rockchip fe2c0000.mmc: DW MMC controller at irq 81,32 bit host data width,256 deep fifo
[ 6.967194] RKNPU fdab0000.npu: Adding to iommu group 0
[ 6.967226] iommu: Failed to allocate default IOMMU domain of type 4 for group (null) - Falling back to IOMMU_DOMAIN_DMA
[ 6.967370] RKNPU fdab0000.npu: RKNPU: rknpu iommu is enabled, using iommu mode
[ 6.968646] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdab0000-0xfdabffff]
[ 6.968672] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdac0000-0xfdacffff]
[ 6.968690] RKNPU fdab0000.npu: can’t request region for resource [mem 0xfdad0000-0xfdadffff]
[ 6.969079] [drm] Initialized rknpu 0.8.2 20220829 for fdab0000.npu on minor 1
[ 6.972881] RKNPU fdab0000.npu: bin=0
[ 6.973068] RKNPU fdab0000.npu: leakage=12
[ 6.973124] debugfs: Directory ‘fdab0000.npu-rknpu’ with parent ‘vdd_npu_s0’ already present!
[ 6.979900] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[ 6.980140] RKNPU fdab0000.npu: pvtm=890
[ 6.984852] RKNPU fdab0000.npu: pvtm-volt-sel=4
[ 6.985900] RKNPU fdab0000.npu: avs=0
[ 6.986097] RKNPU fdab0000.npu: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=800000000 h_table=0
[ 6.995186] RKNPU fdab0000.npu: failed to find power_model node
[ 6.995202] RKNPU fdab0000.npu: RKNPU: failed to initialize power model
[ 6.995212] RKNPU fdab0000.npu: RKNPU: failed to get dynamic-coefficient
[ 6.997099] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.004377] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 7.006301] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 7.007496] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 405; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘15:46:31’, on ‘Mar 3 2023’.
[ 7.007926] Mali:
[ 7.007930] Mali device driver loaded
[ 7.009066] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 7.009082] cfg80211: failed to load regulatory.db
[ 7.014832] ret 1024 0
[ 7.014953] ALSA device list:
[ 7.014961] #0: rockchip-es8388
[ 7.014968] #1: rockchip,hdmiin
[ 7.014976] #2: rockchip-dp0
[ 7.014981] #3: rockchip-hdmi0
[ 7.020081] Freeing unused kernel memory: 7616K
[ 7.039687] Run /init as init process
[ 7.039703] with arguments:
[ 7.039707] /init
[ 7.039709] with environment:
[ 7.039712] HOME=/
[ 7.039714] TERM=linux
[ 7.039717] storagemedia=emmc
[ 7.039722] dsi-0=2
[ 7.039724] storagenode=/mmc@fe2e0000
[ 7.039728] overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1
[ 7.039730] cgroup_enable=memory
[ 7.536370] rk-pcie fe150000.pcie: PCIe Link Fail
[ 7.536437] rk-pcie fe150000.pcie: failed to initialize host
[ 7.587506] rk_hdmirx fdee0000.hdmirx-controller: hdmirx_cancel_cpu_limit_freq freq qos nod add
[ 7.720412] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. Opts: (null)
[ 7.899990] Freeing drm_logo memory: 1240K
[ 8.249026] EXT4-fs (mmcblk0p7): recovery complete
[ 8.249442] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
[ 8.362365] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ 8.362441] ext4 filesystem being mounted at /root/boot supports timestamps until 2038 (0x7fffffff)
[ 8.534101] systemd[1]: Failed to find module ‘autofs4’
[ 8.552383] systemd[1]: systemd 245.4-4ubuntu4.11 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 8.553840] systemd[1]: Detected architecture arm64.
[ 8.557499] systemd[1]: Set hostname to .
[ 8.926493] usb 4-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[ 8.951563] usb 4-1: New USB device found, idVendor=05e3, idProduct=0620, bcdDevice=93.91
[ 8.951608] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.951618] usb 4-1: Product: USB3.2 Hub
[ 8.951626] usb 4-1: Manufacturer: GenesysLogic
[ 8.969036] systemd[1]: Created slice system-modprobe.slice.
[ 8.970106] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.970698] systemd[1]: Created slice User and Session Slice.
[ 8.970947] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.971613] systemd[1]: Condition check resulted in Arbitrary Executable File Formats File System Automount Point being skipped.
[ 8.971709] systemd[1]: Reached target User and Group Name Lookups.
[ 8.972123] systemd[1]: Reached target Remote File Systems.
[ 8.972643] systemd[1]: Reached target Slices.
[ 8.973070] systemd[1]: Reached target Mounting snaps.
[ 8.973553] systemd[1]: Reached target Mounted snaps.
[ 8.974042] systemd[1]: Reached target Swap.
[ 8.975638] systemd[1]: Listening on Syslog Socket.
[ 8.976101] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.976951] systemd[1]: Listening on Journal Audit Socket.
[ 8.977602] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.978191] systemd[1]: Listening on Journal Socket.
[ 8.978700] systemd[1]: Listening on udev Control Socket.
[ 8.979193] systemd[1]: Listening on udev Kernel Socket.
[ 8.981503] systemd[1]: Mounting Huge Pages File System…
[ 8.982464] hub 4-1:1.0: USB hub found
[ 8.982822] hub 4-1:1.0: 4 ports detected
[ 8.983383] systemd[1]: Mounting POSIX Message Queue File System…
[ 8.985393] systemd[1]: Mounting Kernel Debug File System…
[ 8.987107] systemd[1]: Mounting Kernel Trace File System…
[ 8.989357] systemd[1]: Starting Journal Service…
[ 8.991751] systemd[1]: Starting Set the console keyboard layout…
[ 8.994309] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 8.996520] systemd[1]: Starting Load Kernel Module chromeos_pstore…
[ 8.997180] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 8.997245] systemd[1]: Condition check resulted in Load Kernel Module efi_pstore being skipped.
[ 8.998623] systemd[1]: Starting Load Kernel Module pstore_blk…
[ 9.000652] systemd[1]: Starting Load Kernel Module pstore_zone…
[ 9.000830] systemd[1]: Condition check resulted in Load Kernel Module ramoops being skipped.
[ 9.001163] systemd[1]: Condition check resulted in OpenVSwitch configuration for cleanup being skipped.
[ 9.002632] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.005196] systemd[1]: Starting Load Kernel Modules…
[ 9.007320] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 9.009393] systemd[1]: Starting udev Coldplug all Devices…
[ 9.012535] systemd[1]: Mounted Huge Pages File System.
[ 9.013420] systemd[1]: Mounted POSIX Message Queue File System.
[ 9.014132] systemd[1]: Mounted Kernel Debug File System.
[ 9.014862] systemd[1]: Mounted Kernel Trace File System.
[ 9.016141] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 9.017315] systemd[1]: modprobe@chromeos_pstore.service: Succeeded.
[ 9.017871] systemd[1]: Finished Load Kernel Module chromeos_pstore.
[ 9.018777] systemd[1]: modprobe@pstore_blk.service: Succeeded.
[ 9.019290] systemd[1]: Finished Load Kernel Module pstore_blk.
[ 9.020103] systemd[1]: modprobe@pstore_zone.service: Succeeded.
[ 9.020563] systemd[1]: Finished Load Kernel Module pstore_zone.
[ 9.021801] systemd[1]: Finished Load Kernel Modules.
[ 9.024316] systemd[1]: Mounting FUSE Control File System…
[ 9.026634] systemd[1]: Mounting Kernel Configuration File System…
[ 9.028995] systemd[1]: Starting Apply Kernel Variables…
[ 9.030231] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 9.032559] systemd[1]: Mounted FUSE Control File System.
[ 9.035254] systemd[1]: Mounted Kernel Configuration File System.
[ 9.036619] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 9.038219] systemd[1]: Starting Platform Persistent Storage Archival…
[ 9.040065] systemd[1]: Starting Load/Save Random Seed…
[ 9.041851] systemd[1]: Starting Create System Users…
[ 9.048131] systemd[1]: Finished Apply Kernel Variables.
[ 9.061932] systemd[1]: Finished Create System Users.
[ 9.064681] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 9.072235] systemd[1]: Finished Platform Persistent Storage Archival.
[ 9.072895] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 9.076721] systemd[1]: Finished Load/Save Random Seed.
[ 9.091684] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 9.093987] systemd[1]: Starting udev Kernel Device Manager…
[ 9.094970] systemd[1]: Finished Set the console keyboard layout.
[ 9.095395] systemd[1]: Reached target Local File Systems (Pre).
[ 9.095702] systemd[1]: Reached target Local File Systems.
[ 9.096635] systemd[1]: Condition check resulted in Load AppArmor profiles being skipped.
[ 9.098260] systemd[1]: Starting Enable support for additional executable binary formats…
[ 9.100059] systemd[1]: Starting Set console font and keymap…
[ 9.101622] systemd[1]: Starting netfilter persistent configuration…
[ 9.103221] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data…
[ 9.103460] systemd[1]: Condition check resulted in Load AppArmor profiles managed internally by snapd being skipped.
[ 9.103572] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
[ 9.103734] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
[ 9.109840] systemd[1]: Finished Set console font and keymap.
[ 9.111131] systemd[1]: Finished Enable support for additional executable binary formats.
[ 9.111794] systemd[1]: Started Journal Service.
[ 9.130346] systemd-journald[547]: Received client request to flush runtime journal.
[ 9.218771] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=93.91
[ 9.218784] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 9.218788] usb 3-1: Product: USB2.1 Hub
[ 9.218792] usb 3-1: Manufacturer: GenesysLogic
[ 9.270249] hub 3-1:1.0: USB hub found
[ 9.270544] hub 3-1:1.0: 4 ports detected
[ 9.442637] br0: port 1(eth1) entered blocking state
[ 9.442641] br0: port 1(eth1) entered disabled state
[ 9.442717] device eth1 entered promiscuous mode
[ 9.443183] br0: port 2(eth0) entered blocking state
[ 9.443186] br0: port 2(eth0) entered disabled state
[ 9.443247] device eth0 entered promiscuous mode
[ 9.454456] SCSI subsystem initialized
[ 9.460761] libata version 3.00 loaded.
[ 9.464256] phy_rtl8211f_led_fixup in
[ 9.471115] ahci fe210000.sata: supply ahci not found, using dummy regulator
[ 9.471179] ahci fe210000.sata: supply phy not found, using dummy regulator
[ 9.471217] ahci fe210000.sata: supply target not found, using dummy regulator
[ 9.471308] ahci fe210000.sata: forcing port_map 0x0 → 0x1
[ 9.471322] ahci fe210000.sata: AHCI 0001.0300 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 9.471325] ahci fe210000.sata: flags: ncq sntf pm led clo only pmp fbs pio slum part ccc apst
[ 9.471330] ahci fe210000.sata: port 0 can do FBS, forcing FBSCP
[ 9.480676] scsi host0: ahci
[ 9.480807] ata1: SATA max UDMA/133 mmio [mem 0xfe210000-0xfe210fff] port 0x100 irq 80
[ 9.485594] [dhd] STATIC-MSG) dhd_static_buf_init : 101.10.361.18 (wlan=r892223-20220519-1)
[ 9.485713] [dhd] STATIC-MSG) dhd_init_wlan_mem : prealloc ok for index 0: 8131584(7941K)
[ 9.504980] hcq : phy_rtl8211e_eee_fixup in
[ 9.514341] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.514394] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 9.514421] stream_cif_mipi_id3: update sensor info failed -19
[ 9.518950] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.518999] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 9.519018] rkcif_tools_id0: update sensor info failed -19
[ 9.520227] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.520251] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 9.520258] rkcif_tools_id2: update sensor info failed -19
[ 9.520615] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.520666] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 9.520679] rkcif_scale_ch0: update sensor info failed -19
[ 9.520850] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.520869] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 9.520874] rkcif_scale_ch1: update sensor info failed -19
[ 9.526505] phy_rtl8211f_led_fixup in
[ 9.532081] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.532138] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 9.532158] stream_cif_mipi_id1: update sensor info failed -19
[ 9.534933] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.534979] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 9.535002] rkcif_scale_ch2: update sensor info failed -19
[ 9.537251] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.537306] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 9.537334] rkcif_tools_id1: update sensor info failed -19
[ 9.537833] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.537858] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 9.537866] stream_cif_mipi_id2: update sensor info failed -19
[ 9.539701] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.539757] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 9.539772] rkcif_scale_ch3: update sensor info failed -19
[ 9.543139] rockchip-csi2-dphy0: No link between dphy and sensor
[ 9.543161] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 9.543170] stream_cif_mipi_id0: update sensor info failed -19
[ 9.548969] hcq : phy_rtl8211e_eee_fixup in
[ 9.616210] rk_gmac-dwmac fe1c0000.ethernet eth1: PHY [stmmac-1:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[ 9.618251] dwmac4: Master AXI performs any burst length
[ 9.618266] rk_gmac-dwmac fe1c0000.ethernet eth1: No Safety Features support found
[ 9.618281] rk_gmac-dwmac fe1c0000.ethernet eth1: IEEE 1588-2008 Advanced Timestamp supported
[ 9.618385] rk_gmac-dwmac fe1c0000.ethernet eth1: registered PTP clock
[ 9.618492] rk_gmac-dwmac fe1c0000.ethernet eth1: configuring for phy/rgmii-rxid link mode
[ 9.624920] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.636327] usb 3-1.3: new high-speed USB device number 3 using xhci-hcd
[ 9.646469] 8021q: adding VLAN 0 to HW filter on device eth1
[ 9.646477] rk_gmac-dwmac fe1c0000.ethernet eth1: Adding VLAN in promisc mode not supported
[ 9.646731] phy_rtl8211f_led_fixup in
[ 9.653800] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.665150] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.667386] hcq : phy_rtl8211e_eee_fixup in
[ 9.680406] [BT_RFKILL]: rfkill_rk_set_power: set bt wake_host high!
[ 9.687260] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.688318] phy_rtl8211f_led_fixup in
[ 9.708969] hcq : phy_rtl8211e_eee_fixup in
[ 9.733228] [BT_RFKILL]: ENABLE UART_RTS
[ 9.756290] rk_gmac-dwmac fe1b0000.ethernet eth0: PHY [stmmac-0:01] driver [RTL8211F Gigabit Ethernet] (irq=POLL)
[ 9.765153] dwmac4: Master AXI performs any burst length
[ 9.765176] rk_gmac-dwmac fe1b0000.ethernet eth0: No Safety Features support found
[ 9.765189] rk_gmac-dwmac fe1b0000.ethernet eth0: IEEE 1588-2008 Advanced Timestamp supported
[ 9.765436] rk_gmac-dwmac fe1b0000.ethernet eth0: registered PTP clock
[ 9.765610] rk_gmac-dwmac fe1b0000.ethernet eth0: configuring for phy/rgmii-rxid link mode
[ 9.787366] usb 3-1.3: New USB device found, idVendor=1871, idProduct=1130, bcdDevice= 1.00
[ 9.787381] usb 3-1.3: New USB device strings: Mfr=2, Product=1, SerialNumber=3
[ 9.787385] usb 3-1.3: Product: EP28WD
[ 9.787389] usb 3-1.3: Manufacturer: C-ASPIRE
[ 9.787392] usb 3-1.3: SerialNumber: ASPIRE2003230020
[ 9.793155] 8021q: adding VLAN 0 to HW filter on device eth0
[ 9.793164] rk_gmac-dwmac fe1b0000.ethernet eth0: Adding VLAN in promisc mode not supported
[ 9.796358] ata1: SATA link down (SStatus 0 SControl 300)
[ 9.839538] [BT_RFKILL]: DISABLE UART_RTS
[ 9.839583] [BT_RFKILL]: bt turn on power
[ 9.839601] [BT_RFKILL]: Request irq for bt wakeup host
[ 9.839624] [BT_RFKILL]: ** disable irq
[ 9.841057] br0: port 2(eth0) entered blocking state
[ 9.841061] br0: port 2(eth0) entered forwarding state
[ 9.841073] br0: port 1(eth1) entered blocking state
[ 9.841075] br0: port 1(eth1) entered forwarding state
[ 9.847283] uvcvideo: Found UVC 1.00 device EP28WD (1871:1130)
[ 9.861701] file system registered
[ 9.925767] [dhd] _dhd_module_init: in Dongle Host Driver, version 101.10.361.20 (wlan=r892223-20220701-3)
drivers/net/wireless/rockchip_wlan/rkwifi/bcmdhd compiled on Mar 3 2023 at 15:52:28
[ 9.925797] [dhd] ANDROID_VERSION = 12
[ 9.925803] [dhd] ======== dhd_wlan_init_plat_data ========
[ 9.925807] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[ 9.925864] [dhd] dhd_wlan_init_gpio: WL_HOST_WAKE=-1, oob_irq=153, oob_irq_flags=0x4
[ 9.925867] [dhd] dhd_wlan_init_gpio: WL_REG_ON=-1
[ 9.925872] [dhd] dhd_wifi_platform_load: Enter
[ 9.926055] [dhd] dhdpcie_pci_probe : no mutex held
[ 9.926058] [dhd] dhdpcie_pci_probe : set mutex lock
[ 9.926063] [dhd] PCI_PROBE: bus 21, slot 0,vendor 14E4, device 449D(good PCI location)
[ 9.926069] [dhd] dhdpcie_init: found adapter info ‘DHD generic adapter’
[ 9.926074] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 3, size 139264
[ 9.926094] [dhd] succeed to alloc static buf
[ 9.926097] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 4, size 0
[ 9.926160] pcieh 0002:21:00.0: enabling device (0000 → 0002)
[ 9.926583] [dhd] Disable CTO
[ 9.927302] [dhd] ******** Perform FLR ********
[ 9.952888] usb 3-1.4: new full-speed USB device number 4 using xhci-hcd
[ 9.963947] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.976788] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 9.982895] read descriptors
[ 9.982918] read strings
[ 10.002922] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.002991] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003054] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003118] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003181] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003243] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003306] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003368] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003431] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003493] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003556] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003619] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003682] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003745] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003807] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003870] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003933] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.003995] [dhd] read_config: reg=0x88 read val=0xb080
[ 10.004058] [dhd] read_config: reg=0x88 read val=0x8080
[ 10.004455] [dhd] ******** FLR Succedeed ********
[ 10.004768] [dhd] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 10.004771] [dhd] dhdpcie_bar1_window_switch_enab: bar1_switch_enab=0 ramstart=0x170000 ramend=0x2affff bar1_size=0x0
[ 10.004807] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 7, size 35072
[ 10.004849] [dhd] dhd_conf_set_chiprev : devid=0x449d, chip=0xaae8, chiprev=2, svid=0x14e4, ssid=0xaae8
[ 10.004872] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 0, size 1776
[ 10.016502] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 5, size 65536
[ 10.017199] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017209] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017212] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017216] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017223] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017225] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017229] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017231] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017235] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017239] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017242] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017245] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017249] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017253] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.017407] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 19, size 65712
[ 10.017463] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 20, size 262144
[ 10.017525] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 22, size 65536
[ 10.017643] [dhd] dhd_attach(): thread:dhd_watchdog_thread:3d3 started
[ 10.017668] [dhd] dhd_deferred_work_init: work queue initialized
[ 10.017682] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 3
[ 10.017686] [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=10, TCPDATA_INFO_MAXNUM=10
[ 10.017713] [dhd] dhd_cpumasks_init CPU masks primary(big)=0xf0 secondary(little)=0xe
[ 10.018987] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 10.019000] [dhd] dhdpcie_bus_attach: making DHD_BUS_DOWN
[ 10.019016] [dhd] dhdpcie_init: rc_dev from dev->bus->self (1d87:3588) is ffffff8105274000
[ 10.019136] [dhd] dhdpcie_init: rc_ep_aspm_cap: 1 rc_ep_l1ss_cap: 1
[ 10.019172] [dhd] dhdpcie_request_irq: INTx enabled
[ 10.019288] [dhd] dhdpcie_bar1_window_switch_enab: bar1_switch_enab=0 ramstart=0x170000 ramend=0x2affff bar1_size=0x400000
[ 10.019302] [dhd] dhd_bus_download_firmware: firmware path=/vendor/etc/firmware/fw_bcmdhd.bin, nvram path=/vendor/etc/firmware/nvram.txt
[ 10.019308] [dhd] dhdpcie_dump_resource: BAR0(VA): 0xffffffc013bd0000, BAR0¶: 0x00000000f2200000, SIZE: 32768
[ 10.019314] [dhd] dhdpcie_dump_resource: BAR1(VA): 0xffffffc016c00000, BAR1¶: 0x00000000f2400000, SIZE: 4194304
[ 10.019344] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin
[ 10.019347] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_AP6275P.txt
[ 10.019350] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_pcie_ag.blob
[ 10.019353] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 10.040285] [dhd] dhd_get_download_buffer: Open image file failed /vendor/etc/firmware/config.txt
[ 10.040296] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 10.040305] [dhd] d2h_intr_method → PCIE_INTX(0); d2h_intr_control → D2H_INTMASK(0)
[ 10.040423] [dhd] dhdpcie_download_code_file: dhd_tcm_test_enable 0
[ 10.040427] [dhd] dhdpcie_download_code_file: download firmware /vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin
[ 10.046768] [dhd] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin (857142 bytes) open success
[ 10.071503] usb 3-1.4: New USB device found, idVendor=046d, idProduct=c534, bcdDevice=29.01
[ 10.071518] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.071522] usb 3-1.4: Product: USB Receiver
[ 10.071525] usb 3-1.4: Manufacturer: Logitech
[ 10.093756] of_dma_request_slave_channel: dma-names property of node ‘/serial@feb90000’ missing or empty
[ 10.093786] dw-apb-uart feb90000.serial: failed to request DMA, use interrupt mode
[ 10.121998] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.140532] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.151400] [dhd] dhd_os_open_image1: /vendor/etc/firmware/nvram_AP6275P.txt (7335 bytes) open success
[ 10.152105] [dhd] dhdpcie_download_nvram: dhd_get_download_buffer len 7335
[ 10.152112] [dhd] # AP6275P_NVRAM_V1.1_20200702
[ 10.152139] [dhd] dhdpcie_download_nvram: process_nvram_vars len 5860
[ 10.168923] input: Logitech USB Receiver as /devices/platform/usbdrd3_1/fc400000.usb/xhci-hcd.7.auto/usb3/3-1/3-1.4/3-1.4:1.0/0003:046D:C534.0001/input/input5
[ 10.169837] [dhd] dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 10.170043] [dhd] dhd_bus_aer_config: Configure AER registers for EP
[ 10.170081] [dhd] dhd_bus_aer_config: Configure AER registers for RC
[ 10.223556] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-xhci-hcd.7.auto-1.4/input0
[ 10.227160] input: Logitech USB Receiver Mouse as /devices/platform/usbdrd3_1/fc400000.usb/xhci-hcd.7.auto/usb3/3-1/3-1.4/3-1.4:1.1/0003:046D:C534.0002/input/input6
[ 10.249715] [dhd] ### Total time ARM OOR to Readshared pass took 79715 usec ###
[ 10.249725] [dhd] dhdpcie_readshared: PCIe shared addr (0x001f8974) read took 80000 usec before dongle is ready
[ 10.250030] [dhd] H2D DMA WR INDX : array size 172 = 4 * 43
[ 10.250041] [dhd] D2H DMA RD INDX : array size 16 = 4 * 4
[ 10.250053] [dhd] D2H DMA WR INDX : array size 16 = 4 * 4
[ 10.250061] [dhd] H2D DMA RD INDX : array size 172 = 4 * 43
[ 10.250065] [dhd] dhdpcie_readshared: max H2D queues 40
[ 10.250069] [dhd] FW supports debug buf dest ? N
[ 10.250220] [dhd] dhd_bus_init: Enabling bus->intr_enabled
[ 10.250237] [dhd] dhdpcie_oob_intr_register OOB irq=153 flags=0x4
[ 10.250281] [dhd] dhdpcie_oob_intr_register: enable_irq_wake
[ 10.250288] [dhd] dhd_bus_start: Initializing 43 h2drings
[ 10.250320] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 9, size 32896
[ 10.250365] [dhd] dhd_prot_init:3925: h2d_max_txpost = 512
[ 10.250486] [dhd] dhd_prot_init:3940: MAX_RXBUFPOST = 511
[ 10.250490] [dhd] ENABLING DW:0
[ 10.250492] [dhd] IDMA not enabled in FW !!
[ 10.250495] [dhd] IFRM not enabled in FW !!
[ 10.250498] [dhd] DAR not enabled in FW !!
[ 10.250502] [dhd] Enable hostcap: EXTD TXS in txcpl
[ 10.250563] [dhd] dhd_prot_d2h_sync_init(): D2H sync mechanism is NONE
[ 10.250577] [dhd] dhd_bus_hostready : Read PCICMD Reg: 0x00100006
[ 10.250592] [dhd] dhd_bus_dump_dar_registers: dar_clk_ctrl(0xa08:0x10b0040) dar_pwr_ctrl(0xa0c:0x30000) dar_intstat(0xa10:0x0)
[ 10.250596] [dhd] dhd_bus_dump_dar_registers: dar_errlog(0xa60:0x0) dar_erraddr(0xa64:0x0) dar_pcie_mbint(0xa68:0x0)
[ 10.250602] [dhd] dhd_bus_hostready: Ring Hostready:1
[ 10.250605] [dhd] Attach flowrings pool for 40 rings
[ 10.252872] [dhd] dhd_send_d2h_ringcreate ringid: 3 idx: 46 max_h2d: 43
[ 10.253049] [dhd] dhd_prot_process_d2h_ring_create_complete ring create Response status = 0 ring 3, id 0xfffc
[ 10.253060] [dhd] info buffer post after ring create
[ 10.255131] [dhd] wlc_ver_major 12, wlc_ver_minor 1
[ 10.255138] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 10.257732] [dhd] dhd_sync_with_dongle: GET_REVINFO device 0x449d, vendor 0x14e4, chipnum 0xaae8
[ 10.260369] [dhd] dhd_sync_with_dongle: RxBuf Post : 2048
[ 10.266198] [dhd] dhd_preinit_ioctls: preinit_status IOVAR not supported, use legacy preinit
[ 10.266210] [dhd] dhd_tcpack_suppress_set 377: already set to 3
[ 10.269615] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.269883] [dhd] dhd_legacy_preinit_ioctls: hostwake_oob enabled
[ 10.271967] [dhd] dhd_legacy_preinit_ioctls: use firmware generated mac_address 10:2c:6b:fc:ff:f0
[ 10.272092] [dhd] dhd_os_open_image1: /vendor/etc/firmware/clm_bcm43752a2_pcie_ag.blob (29225 bytes) open success
[ 10.273488] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.274786] [dhd] dhd_check_current_clm_data: ----- This FW is not included CLM data -----
[ 10.284385] input: Logitech USB Receiver Consumer Control as /devices/platform/usbdrd3_1/fc400000.usb/xhci-hcd.7.auto/usb3/3-1/3-1.4/3-1.4:1.1/0003:046D:C534.0002/input/input7
[ 10.284666] input: Logitech USB Receiver System Control as /devices/platform/usbdrd3_1/fc400000.usb/xhci-hcd.7.auto/usb3/3-1/3-1.4/3-1.4:1.1/0003:046D:C534.0002/input/input8
[ 10.284970] hid-generic 0003:046D:C534.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-xhci-hcd.7.auto-1.4/input1
[ 10.320953] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.321156] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.321511] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.321589] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.343386] [dhd] dhd_check_current_clm_data: ----- This FW is included CLM data -----
[ 10.355043] [dhd] Firmware up: op_mode=0x0005, MAC=10:2c:6b:fc:ff:f0
[ 10.380538] [dhd] dhd_legacy_preinit_ioctls: event_log_max_sets: 26 ret: 0
[ 10.391416] [dhd] arp_enable:1 arp_ol:0
[ 10.405822] [dhd] Driver: 101.10.361.20 (wlan=r892223-20220701-3)
[dhd] Firmware: wl0: Aug 3 2021 17:38:16 version 18.35.387.23.57 (gdc961cae) FWID 01-ea656a70
[dhd] CLM: 9.9.8_SS (2021-05-10 15:05:58)
[ 10.407365] [dhd] dhd_pno_init: Support Android Location Service
[ 10.407369] [dhd] dhd_rtt_init ENTRY
[ 10.410080] [dhd] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 10.410083] [dhd] dhd_rtt_init : FTM is not supported
[ 10.410084] [dhd] dhd_rtt_init EXIT, err = 0
[ 10.417576] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.422161] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.427423] [dhd] [INIT] logset:8 is preserve/chatty
[ 10.429707] [dhd] [INIT] logset:10 is preserve/chatty
[ 10.448514] [dhd] dhd_ecounter_autoconfig Ecounter autoconfig in FW not supported
[ 10.459580] br0: port 1(eth1) entered disabled state
[ 10.459633] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.459889] br0: port 2(eth0) entered disabled state
[ 10.459919] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.459970] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.478802] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 10.478977] [dhd] dhd_rx_frame: net device is NOT registered. drop event packet
[ 10.483748] [dhd] dhd_rx_frame: net device is NOT registered. drop event packet
[ 10.484455] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 10.497517] [dhd] Dongle Host Driver, version 101.10.361.20 (wlan=r892223-20220701-3)
[ 10.500236] [dhd] Register interface [wlan0] MAC: 10:2c:6b:fc:ff:f0
[ 10.500330] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 3 → mode 0
[ 10.500333] [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=10, TCPDATA_INFO_MAXNUM=10
[ 10.500339] [dhd] [wlan0] wl_android_wifi_off : in g_wifi_on=1, on_failure=1
[ 10.500343] [dhd] dhd_rtt_deinit: ENTER
[ 10.500345] [dhd] dhd_rtt_deinit: EXIT, err = 0
[ 10.500350] [dhd] dhd_bus_devreset: == Power OFF ==
[ 10.500457] [dhd] dhd_bus_stop: making DHD_BUS_DOWN
[ 10.500591] [dhd] dhd_dpc_kill: tasklet disabled
[ 10.502710] [dhd] dhd_bus_devreset: making DHD_BUS_DOWN
[ 10.502715] [dhd] dhd_bus_devreset: WLAN OFF Done
[ 10.502721] [dhd] wifi_platform_set_power = 0, delay: 0 msec
[ 10.502723] [dhd] ======== PULL WL_REG_ON(-1) LOW! ========
[ 10.502726] [WLAN_RFKILL]: rockchip_wifi_power: 0
[ 10.502729] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 10.502731] wifi power off
[ 10.528113] [dhd] dhd_query_bus_erros: Dongle Reset occurred, cannot proceed
[ 10.528118] [dhd] [Repeats 0 times]
[ 10.528123] [dhd] CFG80211-ERROR) wl_cfg80211_dump_station : WLC_GET_ASSOCLIST error -19
[ 10.550064] [dhd] dhd_pri_open : probe is already running! return.
[ 10.556536] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.556684] [dhd] dhd_pri_open : probe is already running! return.
[ 10.557546] [dhd] dhd_pri_open : probe is already running! return.
[ 10.572519] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.604527] [dhd] dhd_pri_open : probe is already running! return.
[ 10.606214] [WLAN_RFKILL]: wifi shut off power [GPIO20-0]
[ 10.606225] [dhd] [wlan0] wl_android_wifi_off : out
[ 10.606235] [dhd] dhdpcie_pci_probe : mutex is released.
[ 10.606447] [dhd] _dhd_module_init: Exit err=0
[ 10.700623] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.705764] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.734738] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.738500] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 10.832982] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.840478] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.973660] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 10.990816] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 11.061615] android_work: did not send uevent (0 0 0000000000000000)
[ 11.123765] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 11.688175] rk_gmac-dwmac fe1c0000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx
[ 11.688236] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 11.688406] br0: port 1(eth1) entered blocking state
[ 11.688414] br0: port 1(eth1) entered forwarding state
[ 11.688549] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.688646] IPv6: ADDRCONF(NETDEV_CHANGE): br0: link becomes ready
[ 11.688752] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 11.764693] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.764783] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.764816] stream_cif_mipi_id0: update sensor info failed -19
[ 11.764989] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765005] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 11.765013] stream_cif_mipi_id1: update sensor info failed -19
[ 11.765171] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765184] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 11.765192] rkcif_tools_id2: update sensor info failed -19
[ 11.765350] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765362] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 11.765369] stream_cif_mipi_id2: update sensor info failed -19
[ 11.765534] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765568] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 11.765576] stream_cif_mipi_id3: update sensor info failed -19
[ 11.765745] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765756] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.765764] rkcif_scale_ch0: update sensor info failed -19
[ 11.765926] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.765938] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 11.765946] rkcif_scale_ch1: update sensor info failed -19
[ 11.766109] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.766120] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[2] get remote terminal sensor failed!
[ 11.766128] rkcif_scale_ch2: update sensor info failed -19
[ 11.766340] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.766352] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[3] get remote terminal sensor failed!
[ 11.766367] rkcif_scale_ch3: update sensor info failed -19
[ 11.766998] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.767012] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[0] get remote terminal sensor failed!
[ 11.767020] rkcif_tools_id0: update sensor info failed -19
[ 11.767186] rockchip-csi2-dphy0: No link between dphy and sensor
[ 11.767198] rkcif-mipi-lvds2: rkcif_update_sensor_info: stream[1] get remote terminal sensor failed!
[ 11.767206] rkcif_tools_id1: update sensor info failed -19
[ 12.665432] [dhd] dhd_pri_open : no mutex held
[ 12.665443] [dhd] dhd_pri_open : set mutex lock
[ 12.665449] [dhd] [wlan0] dhd_open : Enter
[ 12.665454] [dhd] Dongle Host Driver, version 101.10.361.20 (wlan=r892223-20220701-3)
[ 12.665461] [dhd] dhd_open: ######### called for ifidx=0 #########
[ 12.665477] [dhd] [wlan0] wl_android_wifi_on : in g_wifi_on=0
[ 12.665483] [dhd] wifi_platform_set_power = 1, delay: 200 msec
[ 12.665488] [dhd] ======== PULL WL_REG_ON(-1) HIGH! ========
[ 12.665493] [WLAN_RFKILL]: rockchip_wifi_power: 1
[ 12.665499] [WLAN_RFKILL]: rockchip_wifi_power: toggle = false
[ 12.772949] [WLAN_RFKILL]: wifi turn on power [GPIO20-1]
[ 13.079751] [dhd] dhd_bus_devreset: == Power ON ==
[ 13.079761] [dhd] dhd_bus_devreset: dhdpcie_bus_start_host_dev OK
[ 13.079818] [dhd] dhd_bus_aspm_enable_dev: EP already disabled linkctrl: 0x10110000
[ 13.079828] [dhd] dhd_bus_aspm_enable_dev: RC already disabled linkctrl: 0x30110000
[ 13.080329] [dhd] Disable CTO
[ 13.081185] [dhd] DHD: dongle ram size is set to 1310720(orig 1310720) at 0x170000
[ 13.081193] [dhd] dhdpcie_bar1_window_switch_enab: bar1_switch_enab=0 ramstart=0x170000 ramend=0x2affff bar1_size=0x400000
[ 13.081218] [dhd] dhdpcie_request_irq: INTx enabled
[ 13.081264] [dhd] dhd_bus_download_firmware: firmware path=/vendor/etc/firmware/fw_bcmdhd.bin, nvram path=/vendor/etc/firmware/nvram.txt
[ 13.081277] [dhd] dhdpcie_dump_resource: BAR0(VA): 0xffffffc0169f0000, BAR0¶: 0x00000000f2200000, SIZE: 32768
[ 13.081283] [dhd] dhdpcie_dump_resource: BAR1(VA): 0xffffffc017400000, BAR1¶: 0x00000000f2400000, SIZE: 4194304
[ 13.081304] [dhd] dhd_conf_set_path_params : Final fw_path=/vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin
[ 13.081309] [dhd] dhd_conf_set_path_params : Final nv_path=/vendor/etc/firmware/nvram_AP6275P.txt
[ 13.081314] [dhd] dhd_conf_set_path_params : Final clm_path=/vendor/etc/firmware/clm_bcm43752a2_pcie_ag.blob
[ 13.081318] [dhd] dhd_conf_set_path_params : Final conf_path=/vendor/etc/firmware/config.txt
[ 13.081358] [dhd] dhd_get_download_buffer: Open image file failed /vendor/etc/firmware/config.txt
[ 13.081364] [dhd] dhd_conf_read_config : Ignore config file /vendor/etc/firmware/config.txt
[ 13.081372] [dhd] d2h_intr_method → PCIE_INTX(0); d2h_intr_control → D2H_INTMASK(0)
[ 13.081455] [dhd] dhdpcie_download_code_file: dhd_tcm_test_enable 0
[ 13.081461] [dhd] dhdpcie_download_code_file: download firmware /vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin
[ 13.081489] [dhd] dhd_os_open_image1: /vendor/etc/firmware/fw_bcm43752a2_pcie_ag.bin (857142 bytes) open success
[ 13.167693] [dhd] dhd_os_open_image1: /vendor/etc/firmware/nvram_AP6275P.txt (7335 bytes) open success
[ 13.167705] [dhd] dhdpcie_download_nvram: dhd_get_download_buffer len 7335
[ 13.167708] [dhd] # AP6275P_NVRAM_V1.1_20200702
[ 13.167737] [dhd] dhdpcie_download_nvram: process_nvram_vars len 5860
[ 13.185499] [dhd] dhdpcie_bus_write_vars: Download, Upload and compare of NVRAM succeeded.
[ 13.185702] [dhd] dhd_bus_aer_config: Configure AER registers for EP
[ 13.185723] [dhd] dhd_bus_aer_config: Configure AER registers for RC
[ 13.266609] [dhd] ### Total time ARM OOR to Readshared pass took 80950 usec ###
[ 13.266623] [dhd] dhdpcie_readshared: PCIe shared addr (0x001f8974) read took 80000 usec before dongle is ready
[ 13.267033] [dhd] H2D DMA WR INDX : array size 172 = 4 * 43
[ 13.267039] [dhd] D2H DMA RD INDX : array size 16 = 4 * 4
[ 13.267045] [dhd] D2H DMA WR INDX : array size 16 = 4 * 4
[ 13.267050] [dhd] H2D DMA RD INDX : array size 172 = 4 * 43
[ 13.267056] [dhd] dhdpcie_readshared: max H2D queues 40
[ 13.267061] [dhd] FW supports debug buf dest ? N
[ 13.267101] [dhd] dhd_bus_init: Enabling bus->intr_enabled
[ 13.267109] [dhd] dhdpcie_oob_intr_register OOB irq=153 flags=0x4
[ 13.267188] [dhd] dhdpcie_oob_intr_register: enable_irq_wake
[ 13.267199] [dhd] dhd_bus_start: Initializing 43 h2drings
[ 13.267246] [dhd] STATIC-MSG) dhd_wlan_mem_prealloc : sectoin 9, size 32896
[ 13.267298] [dhd] dhd_prot_init:3925: h2d_max_txpost = 512
[ 13.267305] [dhd] dhd_prot_init:3940: MAX_RXBUFPOST = 511
[ 13.267312] [dhd] ENABLING DW:0
[ 13.267315] [dhd] IDMA not enabled in FW !!
[ 13.267317] [dhd] IFRM not enabled in FW !!
[ 13.267320] [dhd] DAR not enabled in FW !!
[ 13.267322] [dhd] Enable hostcap: EXTD TXS in txcpl
[ 13.267355] [dhd] dhd_prot_d2h_sync_init(): D2H sync mechanism is NONE
[ 13.267370] [dhd] dhd_bus_hostready : Read PCICMD Reg: 0x00100006
[ 13.267387] [dhd] dhd_bus_dump_dar_registers: dar_clk_ctrl(0xa08:0x10b0040) dar_pwr_ctrl(0xa0c:0x30000) dar_intstat(0xa10:0x0)
[ 13.267391] [dhd] dhd_bus_dump_dar_registers: dar_errlog(0xa60:0x0) dar_erraddr(0xa64:0x0) dar_pcie_mbint(0xa68:0x0)
[ 13.267398] [dhd] dhd_bus_hostready: Ring Hostready:1
[ 13.267653] [dhd] dhd_send_d2h_ringcreate ringid: 3 idx: 46 max_h2d: 43
[ 13.268417] [dhd] dhd_prot_process_d2h_ring_create_complete ring create Response status = 0 ring 3, id 0xfffc
[ 13.268424] [dhd] info buffer post after ring create
[ 13.270329] [dhd] wlc_ver_major 12, wlc_ver_minor 1
[ 13.270335] [dhd] dhd_get_memdump_info: MEMDUMP ENABLED = 3
[ 13.270841] [dhd] dhd_sync_with_dongle: GET_REVINFO device 0x449d, vendor 0x14e4, chipnum 0xaae8
[ 13.271353] [dhd] dhd_sync_with_dongle: RxBuf Post : 2048
[ 13.275663] [dhd] dhd_preinit_ioctls: preinit_status IOVAR not supported, use legacy preinit
[ 13.275673] [dhd] dhd_tcpack_suppress_set: TCP ACK Suppress mode 0 → mode 3
[ 13.275677] [dhd] dhd_tcpack_suppress_set: TCPACK_INFO_MAXNUM=10, TCPDATA_INFO_MAXNUM=10
[ 13.276646] [dhd] dhd_legacy_preinit_ioctls: hostwake_oob enabled
[ 13.277856] [dhd] dhd_legacy_preinit_ioctls: use firmware generated mac_address 10:2c:6b:fc:ff:f0
[ 13.277918] [dhd] dhd_os_open_image1: /vendor/etc/firmware/clm_bcm43752a2_pcie_ag.blob (29225 bytes) open success
[ 13.278418] [dhd] dhd_check_current_clm_data: ----- This FW is not included CLM data -----
[ 13.312291] [dhd] dhd_check_current_clm_data: ----- This FW is included CLM data -----
[ 13.319953] [dhd] Firmware up: op_mode=0x0005, MAC=10:2c:6b:fc:ff:f0
[ 13.356469] [dhd] dhd_legacy_preinit_ioctls: event_log_max_sets: 26 ret: 0
[ 13.360847] [dhd] arp_enable:1 arp_ol:0
[ 13.365916] [dhd] Driver: 101.10.361.20 (wlan=r892223-20220701-3)
[ 13.366539] [dhd] dhd_pno_init: Support Android Location Service
[ 13.366547] [dhd] dhd_rtt_init ENTRY
[ 13.367092] [dhd] rtt_do_get_ioctl: failed to send getbuf proxd iovar (CMD ID : 1), status=-23
[ 13.367097] [dhd] dhd_rtt_init : FTM is not supported
[ 13.367102] [dhd] dhd_rtt_init EXIT, err = 0
[ 13.369992] mali fb000000.gpu: Loading Mali firmware 0x1010000
[ 13.374049] mali fb000000.gpu: Mali firmware git_sha: 9b8db9aa05a7b4f3066fd75dbdff695262f891fe
[ 13.375644] [dhd] [INIT] logset:8 is preserve/chatty
[ 13.376876] [dhd] [INIT] logset:10 is preserve/chatty
[ 13.386017] [dhd] dhd_ecounter_autoconfig Ecounter autoconfig in FW not supported
[ 13.387882] [dhd] dhd_conf_set_country : set country CN, revision 0
[ 13.387920] [dhd] dhd_rx_frame: net device is NOT registered. drop event packet
[ 13.392451] [dhd] dhd_conf_set_country : Country code: CN (CN/0)
[ 13.403902] [dhd] dhd_bus_devreset: WLAN Power On Done
[ 13.403911] [dhd] [wlan0] wl_android_wifi_on : Success
[ 13.430034] [dhd] dhd_rx_frame: net device is NOT registered. drop event packet
[ 13.455706] [dhd] dhd_bus_aspm_enable_dev: RC ENABLE , linkctrl_before: 0x30110000 linkctrl_after: 0x30110002
[ 13.455875] [dhd] dhd_bus_aspm_enable_dev: EP already enabled linkctrl: 0x10110142
[ 13.457445] [dhd] [wlan0] dhd_open : Exit ret=0
[ 13.457455] [dhd] [wlan0] dhd_pri_open : tx queue started
[ 13.457476] [dhd] [wlan0] custom_xps_map_set : Done. mapping cpu
[ 13.457479] [dhd] dhd_pri_open : mutex is released.
[ 13.458678] br0: port 3(wlan0) entered blocking state
[ 13.458688] br0: port 3(wlan0) entered disabled state
[ 13.459017] device wlan0 entered promiscuous mode
[ 13.459085] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 13.459155] br0: port 3(wlan0) entered blocking state
[ 13.459160] br0: port 3(wlan0) entered forwarding state
[ 13.459327] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.778004] ttyFIQ ttyFIQ0: tty_port_close_start: tty->count = 1 port count = 2
[ 14.793126] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.793541] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 14.793956] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.978243] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.978432] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.978743] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 16.978793] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 17.518530] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 17.721797] dwhdmi-rockchip fde80000.hdmi: use tmds mode
[ 17.772129] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_disable] Crtc atomic disable vp0
[ 17.838110] rockchip-vop2 fdd90000.vop: [drm:vop2_wait_power_domain_off] ERROR wait pd7 off timeout power_ctrl: 0x7f
[ 17.855147] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_disable] ERROR unexpected power on pd7
[ 17.855280] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] Update mode to 1920x1080p60, type: 11(if:800) for vp0 dclk: 148500000
[ 17.855414] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx_ropll_cmn_config bus_width:16a8c8 rate:1485000
[ 17.855717] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy pll locked!
[ 17.855776] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] dclk_out0 div: 0 dclk_core0 div: 2
[ 17.855797] rockchip-vop2 fdd90000.vop: [drm:vop2_crtc_atomic_enable] set dclk_vop0 to 148500000, get 148500000
[ 17.855839] dwhdmi-rockchip fde80000.hdmi: final tmdsclk = 148500000
[ 17.855881] dwhdmi-rockchip fde80000.hdmi: don’t use dsc mode
[ 17.855888] dwhdmi-rockchip fde80000.hdmi: dw hdmi qp use tmds mode
[ 17.855900] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: bus_width:0x16a8c8,bit_rate:1485000
[ 17.856109] rockchip-hdptx-phy-hdmi fed60000.hdmiphy: hdptx phy lane locked!
[ 18.472955] [dhd] [wlan0] wl_cfg80211_add_del_bss : wl bss 2 bssidx:0
[ 18.476819] [dhd] [wlan0] wl_cfg80211_set_channel : netdev_ifidx(8), chan_type(1) target channel(2g-11)
[ 18.479925] [dhd] [wlan0] wl_cfg80211_add_del_bss : wl bss 2 bssidx:0
[ 18.482399] [dhd] [wlan0] wl_cfg80211_bcn_bringup_ap : Creating AP with sec=wpa2/psk/mfpn/aes
[ 18.559793] [dhd] [wlan0] wl_notify_connect_status_ap : AP/GO Link up
[ 18.559830] [dhd] [wlan0] wl_iw_event : Link UP with 10:2c:6b:fc:ff:f0
[ 18.559867] [dhd] [wlan0] wl_ext_iapsta_event : [A] Link up w/o creating? (etype=16)
[ 18.562445] [dhd] [wlan0] wl_cfg80211_del_station : Disconnect STA : ff:ff:ff:ff:ff:ff scb_val.val 3
[ 18.732959] [dhd] dhd_prot_flow_ring_create: Send Flow Create Req flow ID 41 for peer 33:33:00:00:00:fb prio 0 ifindex 0 items 512
[ 18.733517] [dhd] dhd_prot_flow_ring_create_response_process: Flow Create Response status = 0 Flow 41
[ 21.055418] br0: port 3(wlan0) entered disabled state
[ 21.057153] br0: port 3(wlan0) entered blocking state
[ 21.057166] br0: port 3(wlan0) entered forwarding state
[ 21.115107] br0: port 3(wlan0) entered disabled state
[ 21.115860] br0: port 3(wlan0) entered blocking state
[ 21.115870] br0: port 3(wlan0) entered forwarding state
[ 21.117248] [dhd] P2P interface registered
[ 21.134942] [dhd] CFGP2P-ERROR) wl_cfgp2p_start_p2p_device : SEC IFACE present. Initialize p2p from discovery context
[ 23.448121] device wlan0 left promiscuous mode
[ 23.448393] br0: port 3(wlan0) entered disabled state
[ 23.477256] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 23.503756] [dhd] [wlan0] wl_cfg80211_stop_ap : stopping AP operation
[ 23.505790] [dhd] wl_process_host_event: Deleting all STA from assoc list and flowrings.
[ 23.505805] [dhd] dhd_flow_rings_delete: ifindex 0
[ 23.505874] [dhd] dhd_prot_flow_ring_delete: Send Flow Delete Req RING ID 41 for peer 33:33:00:00:00:fb prio 0 ifindex 0
[ 23.506237] [dhd] [wlan0] wl_iw_event : Link Down with 10:2c:6b:fc:ff:f0, reason=4
[ 23.506272] [dhd] [wlan0] wl_ext_iapsta_event : [A] Link down, reason=4
[ 23.508604] [dhd] dhd_prot_flow_ring_delete_response_process: Flow Delete Response status = 0 Flow 41
[ 23.509166] [dhd] [wlan0] wl_cfg80211_add_del_bss : wl bss 3 bssidx:0
[ 23.518137] [dhd] [wlan0] wl_ext_set_chanspec : channel 5g-153(0xe19b)
[ 23.519241] [dhd] [wlan0] wl_conn_debug_info : Connecting with 7c:1e:06:af:42:01 ssid “Guest_msdi”, len (10), channel=5g-153(chan_cnt=1), sec=open/mfpc/none, rssi=-30
[ 23.644122] [dhd] [wlan0] wl_iw_event : Link UP with 7c:1e:06:af:42:01
[ 23.644161] [dhd] [wlan0] wl_ext_iapsta_event : [S] Link UP with 7c:1e:06:af:42:01
[ 23.647615] [dhd] [wlan0] wl_bss_connect_done : Report connect result - connection succeeded
[ 23.681349] [dhd] dhd_prot_flow_ring_create: Send Flow Create Req flow ID 41 for peer ff:ff:ff:ff:ff:ff prio 3 ifindex 0 items 512
[ 23.681810] [dhd] dhd_prot_flow_ring_create_response_process: Flow Create Response status = 0 Flow 41
[ 23.687754] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.709005] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.709014] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.709505] [dhd] dhd_prot_flow_ring_create: Send Flow Create Req flow ID 40 for peer ff:ff:ff:ff:ff:ff prio 0 ifindex 0 items 512
[ 23.709935] [dhd] dhd_prot_flow_ring_create_response_process: Flow Create Response status = 0 Flow 40
[ 23.729428] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.729437] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.767834] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.869912] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.898901] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.898910] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 23.958407] NOHZ tick-stop error: Non-RCU local softirq work is pending, handler #08!!!
[ 24.689796] IPv6: wlan0: IPv6 duplicate address fe80::dc63:c53c:24fa:6f25 used by 70:f7:54:56:a3:00 detected!
[ 24.786063] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 24.790056] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 24.798533] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 24.804297] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.106350] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.107131] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.107784] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.326426] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.326739] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 47.327132] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 69.577793] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 69.578204] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 69.578822] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 69.579001] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 99.699253] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 99.699695] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 99.700070] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 101.550417] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 101.550877] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 101.551375] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 101.551515] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 131.804213] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 131.804820] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 131.805329] [dhd] CFG80211-ERROR) wl_cfg80211_netdev_notifier_call : wdev null. Do nothing
[ 624.430825] [dhd] dhd_prot_flow_ring_create: Send Flow Create Req flow ID 39 for peer 0c:3a:fa:f2:6b:60 prio 1 ifindex 0 items 512
[ 624.431328] [dhd] dhd_prot_flow_ring_create_response_process: Flow Create Response status = 0 Flow 39
[ 842.664278] hrtimer: interrupt took 203298 ns
[ 4076.834812] usb 4-1.1: new SuperSpeed Gen 1 USB device number 3 using xhci-hcd
[ 4076.855378] usb 4-1.1: New USB device found, idVendor=325d, idProduct=6410, bcdDevice= 1.10
[ 4076.855390] usb 4-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4076.855395] usb 4-1.1: Product: U330
[ 4076.855399] usb 4-1.1: Manufacturer: aigo
[ 4076.855404] usb 4-1.1: SerialNumber: 900015A8204D2533
[ 4076.900193] usb-storage 4-1.1:1.0: USB Mass Storage device detected
[ 4076.901873] scsi host1: usb-storage 4-1.1:1.0
[ 4076.902706] usbcore: registered new interface driver usb-storage
[ 4076.906912] usbcore: registered new interface driver uas
[ 4077.912823] scsi 1:0:0:0: Direct-Access aigo U330 PMAP PQ: 0 ANSI: 6
[ 4077.947149] sd 1:0:0:0: [sda] 121241600 512-byte logical blocks: (62.1 GB/57.8 GiB)
[ 4077.952458] sd 1:0:0:0: [sda] Write Protect is off
[ 4077.952477] sd 1:0:0:0: [sda] Mode Sense: 45 00 00 00
[ 4077.957737] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 4078.061479] sda: sda1
[ 4078.076262] sd 1:0:0:0: [sda] Attached SCSI removable disk
[ 4099.399366] usb 4-1.1: USB disconnect, device number 3
[ 4099.402268] blk_update_request: I/O error, dev sda, sector 320 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 0
[ 4099.402383] Buffer I/O error on dev sda1, logical block 36, lost async page write
[ 4099.406940] blk_update_request: I/O error, dev sda, sector 6291496 op 0x1:(WRITE) flags 0x0 phys_seg 1 prio class 0
[ 4099.407196] Buffer I/O error on dev sda1, logical block 786433, lost async page write
[20996.169405] usb 4-1.1: new SuperSpeed Gen 1 USB device number 4 using xhci-hcd
[20996.189704] usb 4-1.1: New USB device found, idVendor=0951, idProduct=1666, bcdDevice= 1.10
[20996.189729] usb 4-1.1: New USB device strings: Mfr=2, Product=3, SerialNumber=4
[20996.189745] usb 4-1.1: Product: DataTraveler 3.0
[20996.189760] usb 4-1.1: Manufacturer: Kingston
[20996.189776] usb 4-1.1: SerialNumber: E0D55EA573E71681F9320834
[20996.192407] usb-storage 4-1.1:1.0: USB Mass Storage device detected
[20996.194264] scsi host1: usb-storage 4-1.1:1.0
[20997.210209] scsi 1:0:0:0: Direct-Access Kingston DataTraveler 3.0 0000 PQ: 0 ANSI: 6
[20997.214455] sd 1:0:0:0: [sda] 121077761 512-byte logical blocks: (62.0 GB/57.7 GiB)
[20997.215012] sd 1:0:0:0: [sda] Write Protect is off
[20997.215024] sd 1:0:0:0: [sda] Mode Sense: 23 00 00 00
[20997.215478] sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[20997.264567] sda: sda1
[20997.268230] sd 1:0:0:0: [sda] Attached SCSI removable disk
firefly@firefly:~$
799959745 发表于 2023-4-27 11:26
插入u盘的时候,板子终端执行dmesg命令。将输出的信息发上来分析。
你好,打印日志在楼下
1、不插入U盘的情况下,鼠标和键盘是否都正常使用?
2、是只有插在USB3.0的情况下,鼠标和键盘才会出现卡顿吗?
3、换一块U盘测试一下看看
2、是只有插在USB3.0的情况下,鼠标和键盘才会出现卡 …
1、不插U盘的情况下,键鼠正常使用
2、因为这块板子只有3.0 的USB口,没试过其他的口
3、换了其他两个U盘也是一样的,换成3.0接口的移动机械硬盘,也一样
还有,我搞错板子型号了,因为3588Q和3588JQ都买了,出问题的板子是3588Q,固件也是官网的3588Q的固件,打印日志也是3588Q的日志,3588JQ没有卡得动不了,但是鼠标的移动也明显变卡顿了。
spp 发表于 2023-4-28 09:31
还有,我搞错板子型号了,因为3588Q和3588JQ都买了,出问题的板子是3588Q,固件也是官网的3588Q的固件, …
好像是你的 u 盘有问题。换一块 u 盘试一下,或者尝试格式化 u 盘试一下行不行
貌似使用过程中改了什么配置,重新烧了固件,没有出现这个问题了
