IPQ 6010 With QCN9074 and QCN9024: High Power to Long Distance Transmission
The Network Solution IPQ 6010 is a powerful system-on-a-chip (SoC) designed for networking applications. It features a quad-core ARM Cortex-A53 processor and a dual-core network subsystem, making it an ideal choice for high-performance routers, gateways, and access points.
The IPQ 6010 is paired with two complementary chips: the QCN9074 and the QCN9024. The QCN9074 is a 4x4 Wi-Fi 6E radio, providing multi-gigabit wireless connectivity with support for up to 160 MHz channels and 1024-QAM modulation. The QCN9024, on the other hand, is a 2.5 Gbps Ethernet switch, offering high-speed wired connectivity for multiple devices.
Together, these three components provide a complete networking solution that can handle the demands of modern high-bandwidth applications such as online gaming, video streaming, and virtual reality.
One of the key benefits of the Network Solution IPQ 6010 with QCN9074 and QCN9024 is its ability to handle multiple devices and users simultaneously, without compromising performance. This is achieved through advanced technologies such as MU-MIMO (multi-user multiple input, multiple output) and OFDMA (orthogonal frequency division multiple access), which allow for more efficient use of the available wireless bandwidth.
Another advantage of this solution is its support for the latest networking standards, including Wi-Fi 6E and 2.5 Gbps Ethernet. These technologies provide faster speeds, greater range, and lower latency, resulting in a better overall user experience.
Overall, the Network Solution IPQ 6010 with QCN9074 and QCN9024 is a powerful and versatile networking solution that can meet the demands of even the most demanding applications. Whether you’re looking to build a high-performance router, gateway, or access point, this solution is definitely worth considering.
Wallys IPQ 6010 With QCN9074 and QCN9024 Networking Solution:
Wallys Routerboard DR6018 series is a powerful and reliable solution for long-distance transmission. With its advanced technology and high-quality components, this routerboard is capable of supporting data transmission over distances of up to 6km.
The DR6018 series routerboard features a powerful processor, high-speed wireless connectivity, and a range of advanced features that make it ideal for a wide range of applications. Whether you’re looking to set up a wireless network in a rural area, connect remote buildings, or establish a long-range wireless link, the DR6018 series is a great choice.
One of the key features of the DR6018 series is its long-range transmission capabilities. Thanks to its powerful wireless technology and advanced antenna design, this routerboard can reliably transmit data over distances of up to 6km. This makes it an ideal choice for applications where traditional wired networks are not feasible or cost-effective.
In addition to its long-range transmission capabilities, the DR6018 series also offers a range of advanced features that make it easy to set up and manage. The routerboard includes a user-friendly web interface, which allows you to configure the device and monitor its performance from anywhere with an internet connection. It also includes advanced security features to help protect your network from unauthorized access and attacks.
Overall, the Wallys Routerboard DR6018 series is a powerful and reliable solution for long-range wireless transmission. Whether you’re looking to set up a wireless network in a rural area, connect remote buildings, or establish a long-range wireless link, this routerboard is a great choice. With its advanced technology, high-quality components, and user-friendly interface, the DR6018 series is sure to meet all of your wireless networking needs.
1. DR6018
Website:
[b][u]https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html[/u][/b]
Yuotube:
[b][u]https://www.youtube.com/watch?v=RPk_6fZbHZU[/u][/b]
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2.DR6018(CP01)
Website below:
[u]https://www.wallystech.com/Routerboard/DR6018-CP01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-CP01-802-11AX-MU-MIMO-OFDMA.html[/u]
Qualcomm-Atheros IPQ6018
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
DC Jack 12V power supply
Serial Port 1x Serial Port 12 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/802.11n/802.11ac/802.11ax, max 20dBm per chain
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D)219mm x 150mm x 16.5mm (Without Heatsink)
3.DR 6018-S
Website:
[b][u]https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html[/u][/b]
Youtube:
[b][u]https://www.youtube.com/watch?v=BX0-nb3RAIY[/u][/b]
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
8MB NOR Flash, 256MB NAND Flash
Supply Voltage 24V~48V(DC Jack) V
Symbol Parameter
CPU Qualcomm-Atheros IPQ6010
Ethernet Port 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot 1x SD Card Slot(Option)
USB /header 1x USB 3.0 Port(Option)
POE Option 1: 48V~56V passive POE/Active POE(Suport 802.3at)
Option 2: 24V~48V passive POE
DC Jack 24V~48V power supply
LED header 2.0 pitch pin header
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
4 x MMCX Connectors
Nor Flash 8MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension 125mm x 105mm x 20mm
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
Our products link:https://www.wallystech.com/product.html
EMAIL:​sales4@wallystech.com
