WiFi6 Solution IPQ4019/IPQ4029 With MT7915
WiFi6 Solution IPQ4019/IPQ4029 With MT7915 :Provide Greater Performance and Capacity
The IPQ4019 and IPQ4029 are networking solutions developed by Qualcomm, designed to provide high-speed and reliable Wi-Fi connectivity to a wide range of devices. These solutions are often used in routers, access points, and other networking devices, and they are capable of handling multiple streams of data simultaneously, making them ideal for busy environments.
One of the key features of the IPQ4019 and IPQ4029 is their support for the latest Wi-Fi 6 (802.11ax) standard, which provides faster speeds, higher capacity, and improved reliability compared to previous Wi-Fi standards. Additionally, these solutions include advanced features such as MU-MIMO (Multi-User Multiple Input Multiple Output) and beamforming, which help to ensure that devices receive the best possible Wi-Fi signal, even in challenging environments.
To further enhance the performance of the IPQ4019 and IPQ4029, they can be paired with the MT7915, a high-performance Wi-Fi 6E (802.11ax) chipset developed by MediaTek.
The MT7915 is a networking solution developed by MediaTek that offers high-speed connectivity and advanced networking features. This solution is designed to provide reliable and efficient connectivity for a wide range of applications, from home and office networking to industrial and commercial environments.
One of the key features of the MT7915 is its support for Wi-Fi 6E, which is the latest Wi-Fi standard that operates in the 6 GHz frequency band. This frequency band offers more bandwidth and less interference than previous Wi-Fi standards, which translates into faster and more reliable wireless connections.
The MT7915 also supports multiple-input, multiple-output (MIMO) technology, which allows multiple antennas to be used to transmit and receive data simultaneously. This technology increases the throughput and range of Wi-Fi networks, especially in environments with many devices.
In addition to Wi-Fi connectivity, the MT7915 also supports Ethernet connectivity through its integrated Gigabit Ethernet switch. This allows wired devices to connect to the network at high speeds and with low latency.
To ensure the security of the network, the MT7915 includes advanced security features such as WPA3 encryption and VPN support. It also includes Quality of Service (QoS) features that prioritize network traffic based on the application, ensuring that critical applications receive the necessary bandwidth and low latency.
Overall, the MT7915 is a powerful networking solution that offers high-speed connectivity, advanced networking features, and robust security. It is suitable for a wide range of applications, from home and small office networking to industrial and commercial environments that require reliable and efficient connectivity.
In summary, the IPQ4019 and IPQ4029 are powerful networking solutions that provide high-speed, reliable Wi-Fi connectivity, and when paired with the MT7915, they can offer even greater performance and capacity. Whether you’re looking to upgrade your home network or deploy a Wi-Fi solution for a business or public space, these solutions are definitely worth considering.
Here comes the Wallys IPQ4019/IPQ4029 With MT7915 wireless solution:
1.DR40X9:
[u]https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html[/u]
One of the key features of the DR4019S is its powerful processor, which is a quad-core ARM Cortex-A15 CPU with a clock speed of 1.4 GHz. This processor can handle heavy network traffic and complex routing tasks with ease, ensuring smooth and fast data transfers and low latency.
The DR4019S also comes with 2 GB of DDR4 RAM and 8 GB of eMMC storage, which can be expanded with a microSD card slot. This ample amount of memory and storage allows you to store and run multiple applications and services, such as VPNs, firewalls, QoS, and more.
In terms of connectivity, the DR4019S has a rich set of ports and interfaces, including:
10 Gigabit Ethernet ports (1x SFP+ and 9x RJ45)
1 Gigabit Ethernet port (RJ45)
1 USB 3.0 port
1 serial console port
1 microUSB port (for power)
2.DR7915
[u]https://www.wallystech.com/Network_Card/DR7915-wifi6-MT7915-MT7975-2T2R-support-OpenWRT-802.11AX-supporting-MiniPCIe-Module.html[/u]
Product Description
MT7915+MT7975 Chipset
2.4GHz max 23dBm & 5GHz max 20dBm output power
IEEE 802.11ac / ax compliant & backward compatible with 802.11ax/ac/a/b/g/n
2×2 2.4G & 2×2 5G MIMO Technology, up to 1.8Gbps Mini PCI Express edge connector
SupporttheFrequency2412MHz~2482MHz
SupporttheFrequency5180MHz~5825MHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Supports Spatial Multiplexing,Cyclic-Delay Diversity (CDD), Low-Density Parity Check (LDPC) Codes,Maximal Ratio Combining (MRC), Space Time Block Code (STBC)
Supports IEEE 802.11d, e, h, i, k, r, v time stamp, and w standards
Cards are individually calibrated for Quality Assurance
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
Our products link:https://www.wallystech.com/product.html
EMAIL:​sales4@wallystech.com
