ubuntu启动卡在init进程
Secure Boot state: 0
bootrk: do_bootm_linux…
Loading Device Tree to 0480d000, end 04826f68 … OK
[ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.10.0 (jackxu@jackxu-G751JY) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #94 SMP PREEMPT Wed Oct 28 13:38:30 CST 2015 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: Rockchip RK3288 (Flattened Device Tree), model: rockchip,rk3288 [ 0.000000] hdmi init vic is -1 [ 0.000000] rockchip_ion_reserve [ 0.000000] cma: CMA: reserved 16 MiB at 2e800000 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] Boot mode: NORMAL (0) flag: (0xc35242ff) [ 0.000000] PERCPU: Embedded 9 pages/cpu @c1ed4000 s14016 r8192 d14656 u36864 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 522768 [ 0.000000] Kernel command line: console=ttyFIQ0 console=ttyFIQ0 earlyprintk root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init mtdparts=rk29xxnand:0x00008000@0x00002000(resource),0x00008000@0x0000A000(boot),0x00002000@0x00012000(misc),0x0001a000@0x00014000(backup),-@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2015-10-27_18:43:55 hdmi.vic=-1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 2048MB = 2048MB total [ 0.000000] Memory: 2045604k/2045604k available, 51548k reserved, 1318912K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0a907d8 (10786 kB) [ 0.000000] .init : 0xc0a91000 - 0xc0ce06c0 (2366 kB) [ 0.000000] .data : 0xc0ce2000 - 0xc0d81148 ( 637 kB) [ 0.000000] .bss : 0xc0d81148 - 0xc0e9e684 (1142 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] rk_clk_tree_init start! cru base = 0xfed00000 [ 0.000000] rk_get_uboot_display_flag: uboot_logo_on = 0 [ 0.000000] rkclk_init_clks: cnt_parent = 7 [ 0.000000] rkclk_init_clks: cnt_rate = 32 [ 0.000000] Architected local timer running at 24.00MHz (phys). [ 0.000000] Switching to timer-based delay loop [ 0.000000] sched_clock: ARM arch timer >56 bits at 24000kHz, resolution 41ns [ 0.000000] process version: 0 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:2, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:0, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] channel:1, lkg:0 [ 0.000000] target-temp:95 [ 0.000000] sched_clock: 32 bits at 100 Hz, resolution 10000000ns, wraps every 4294967286ms [ 0.000000] Console: colour dummy device 80x30 [ 0.523522] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.523573] pid_max: default: 32768 minimum: 301 [ 0.523908] Security Framework initialized [ 0.523950] SELinux: Initializing. [ 0.524182] Mount-cache hash table entries: 512 [ 0.526231] Initializing cgroup subsys debug [ 0.526275] Initializing cgroup subsys freezer [ 0.526368] CPU: Testing write buffer coherency: ok [ 0.527125] /cpus/cpu@0 missing clock-frequency property [ 0.527170] /cpus/cpu@1 missing clock-frequency property [ 0.527204] /cpus/cpu@2 missing clock-frequency property [ 0.527236] /cpus/cpu@3 missing clock-frequency property [ 0.527343] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.527456] Setting up static identity map for 0xc07a0c60 - 0xc07a0cb8 [ 0.531768] last_log: 0x2e100000 map to 0xf0004000 and copy to 0xf0086000, size 0x80000 early 0x141b (version 3.0) [ 0.611345] CPU1: Booted secondary processor [ 0.611437] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.631087] CPU2: Booted secondary processor [ 0.631169] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.650861] CPU3: Booted secondary processor [ 0.650943] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.651306] Brought up 4 CPUs [ 0.651406] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.651436] CPU: All CPU(s) started in SVC mode. [ 0.653660] devtmpfs: initialized [ 0.671095] pinctrl core: initialized pinctrl subsystem [ 0.671840] regulator-dummy: no parameters [ 0.673467] NET: Registered protocol family 16 [ 0.678640] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.679757] ion_snapshot: 0x2e230000 map to 0xf0107000 and copy to 0xc0e79d54 (version 0.1) [ 0.680254] Registered FIQ tty driver [ 0.683782] console [ttyFIQ0] enabled [ 0.684261] Registered fiq debugger ttyFIQ0 [ 0.686041] rockchip_get_bank_data:name=base start=0xff750000,end=0xff7500ff [ 0.686128] rockchip_get_bank_data:name=mux_bank0 start=0xff730084,end=0xff73008f [ 0.686201] rockchip_get_bank_data:name=pull_bank0 start=0xff730064,end=0xff73006f [ 0.686272] rockchip_get_bank_data:name=drv_bank0 start=0xff730070,end=0xff73007b [ 0.686532] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio1@ff780000 start=0xff780000,end=0xff7800ff [ 0.686764] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio2@ff790000 start=0xff790000,end=0xff7900ff [ 0.686988] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio3@ff7a0000 start=0xff7a0000,end=0xff7a00ff [ 0.687212] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio4@ff7b0000 start=0xff7b0000,end=0xff7b00ff [ 0.687435] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio5@ff7c0000 start=0xff7c0000,end=0xff7c00ff [ 0.687658] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio6@ff7d0000 start=0xff7d0000,end=0xff7d00ff [ 0.687884] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio7@ff7e0000 start=0xff7e0000,end=0xff7e00ff [ 0.688110] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio8@ff7f0000 start=0xff7f0000,end=0xff7f00ff [ 0.688365] rockchip_get_bank_data:name=/pinctrl@ff770000/gpio15@ff7f2000 start=0xff7f2000,end=0xff7f20ff [ 0.688602] rockchip_pinctrl_probe:name=RK3288-GPIO,type=3 [ 0.688660] rockchip_pinctrl_probe:name=base start=0xff770000,end=0xff77013f [ 0.688714] rockchip_pinctrl_probe:name=pull start=0xff770140,end=0xff7701bf [ 0.688768] rockchip_pinctrl_probe:name=drv start=0xff7701c0,end=0xff77023f [ 0.690523] rockchip_interrupts_register:bank_num=7 [ 0.697230] of_get_gpio_init_config:gpio[0] = 257, value = 0 [ 0.697316] of_get_gpio_init_config:gpio[1] = 233, value = 0 [ 0.697467] rockchip_pinctrl_probe:init ok [ 0.716925] rk_iommu ff900800.iep_mmu: (iep) Enter [ 0.717279] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.717335] rk_iommu ff900800.iep_mmu: (iep) Initialized [ 0.717911] rk_iommu ff950800.vip_mmu: (vip) Enter [ 0.718237] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.718292] rk_iommu ff950800.vip_mmu: (vip) Initialized [ 0.718835] rk_iommu ff930300.vopb_mmu: (vopb) Enter [ 0.719161] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.719216] rk_iommu ff930300.vopb_mmu: (vopb) Initialized [ 0.719777] rk_iommu ff940300.vopl_mmu: (vopl) Enter [ 0.720103] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.720157] rk_iommu ff940300.vopl_mmu: (vopl) Initialized [ 0.720771] rk_iommu ff9c0440.hevc_mmu: (hevc) Enter [ 0.721163] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.721217] rk_iommu ff9c0440.hevc_mmu: (hevc) Initialized [ 0.721791] rk_iommu ff9a0800.vpu_mmu: (vpu) Enter [ 0.722115] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.722170] rk_iommu ff9a0800.vpu_mmu: (vpu) Initialized [ 0.722742] rk_iommu ff914000.isp_mmu: (isp_mmu) Enter [ 0.723123] IOVMM: Created 0x3ffff000 B IOVMM from 0x10000000. [ 0.723177] rk_iommu ff914000.isp_mmu: (isp_mmu) Initialized [ 0.728038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.728093] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.728712] DDR DEBUG: version 1.00 20140603 [ 0.728795] DDR DEBUG: Channel a: [ 0.728832] DDR DEBUG: LPDDR3 Device [ 0.728882] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Total Capability=1024MB [ 0.728924] DDR DEBUG: Channel b: [ 0.728956] DDR DEBUG: LPDDR3 Device [ 0.729002] DDR DEBUG: Bus Width=32 Col=10 Bank=8 Row=14 CS=2 Total Capability=1024MB [ 0.729046] DDR DEBUG: addr=0xd87000 [ 0.729084] DDR DEBUG: stride=9, size=256, halfcap=40000000 [ 0.729125] DDR DEBUG: socAddr[0]=0xd87000, socAddr[1]=0xd87100 [ 0.729166] DDR DEBUG: chAddr[0]=0xd87000, chAddr[1]=0xd87000 [ 0.729212] DDR DEBUG: dtar[0]=0x701b0000, dtar[1]=0x701b0000 [ 0.729373] DDR DEBUG: init success!!! freq=200MHz [ 0.729409] DDR DEBUG: Channel a: [ 0.729457] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729516] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729575] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729633] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729687] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.729730] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.729769] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.729803] DDR DEBUG: Channel b: [ 0.729849] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729907] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.729965] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.730023] DDR DEBUG: DTONE=0x3, DTERR=0x0, DTIERR=0x0, DTPASS=4,4, DGSL=1,1 extra clock, DGPS=180,180 [ 0.730075] DDR DEBUG: ZERR=0, ZDONE=0, ZPD=0x0, ZPU=0x0, OPD=0x0, OPU=0x0 [ 0.730117] DDR DEBUG: DRV Pull-Up=0x19, DRV Pull-Dwn=0x19 [ 0.730156] DDR DEBUG: ODT Pull-Up=0x2, ODT Pull-Dwn=0x2 [ 0.806284] bio: create slab at 0 [ 0.808141] Enter firefly_noatx8_init [ 0.809166] SCSI subsystem initialized [ 0.809664] usbcore: registered new interface driver usbfs [ 0.809819] usbcore: registered new interface driver hub [ 0.810108] usbcore: registered new device driver usb [ 0.813067] rockchip_i2c ff650000.i2c: i2c-0: Rockchip I2C adapter [ 0.816778] rockchip_i2c ff140000.i2c: i2c-1: Rockchip I2C adapter [ 0.817583] rockchip_i2c ff660000.i2c: i2c-2: Rockchip I2C adapter [ 0.818393] rockchip_i2c ff150000.i2c: i2c-3: Rockchip I2C adapter [ 0.819282] rockchip_i2c ff160000.i2c: i2c-4: Rockchip I2C adapter [ 0.821576] media: Linux media interface: v0.10 [ 0.821719] Linux video capture interface: v2.00 [ 0.821876] pps_core: LinuxPPS API ver. 1 registered [ 0.821920] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email]giometti@linux.it[/email]> [ 0.822003] PTP clock support registered [ 0.822410] rockchip_temp_probe,line=362 [ 0.823198] tsadc ff280000.tsadc: initialized [ 0.824392] rockchip_ion_parse_dt: num_heaps = 1 [ 0.824452] 0: 0 3 vmalloc 0x (null) [ 0.825198] Rockchip ion module is successfully loaded (v1.0) [ 0.825702] Advanced Linux Sound Architecture Driver Initialized. [ 0.826856] Bluetooth: Core ver 2.16 [ 0.827023] NET: Registered protocol family 31 [ 0.827067] Bluetooth: HCI device and connection manager initialized [ 0.827129] Bluetooth: HCI socket layer initialized [ 0.827181] Bluetooth: L2CAP socket layer initialized [ 0.827288] Bluetooth: SCO socket layer initialized [ 0.827949] cfg80211: Calling CRDA to update world regulatory domain [ 0.830412] act8846_i2c_probe,line=880 [ 0.831773] act8846_parse_dt,line=744 [ 0.833130] act8846_i2c_probe: act8846_pmic_hold=1 [ 0.833201] act8846_i2c_probe: act8846_pmic_sleep=1 [ 0.835637] act_dcdc1: 1200 mV [ 0.839344] vccio: 3300 mV [ 0.841969] vdd_logic: 700 <--> 1500 mV at 1100 mV [ 0.845650] act_dcdc4: 2000 mV [ 0.847571] vccio_sd: 1800 <--> 3300 mV at 3300 mV [ 0.850472] act_ldo2: 1050 mV [ 0.853318] act_ldo3: 1800 mV [ 0.856134] act_ldo4: 3300 mV [ 0.859056] act_ldo5: 3300 mV [ 0.861889] act_ldo6: 1100 mV [ 0.864733] vcc_18: 1800 mV [ 0.867576] act_ldo8: 1850 mV [ 0.873978] vdd_arm: 712 <--> 1500 mV at 1000 mV [ 0.880376] vdd_gpu: 712 <--> 1500 mV at 1000 mV [ 0.885319] Switching to clocksource arch_sys_counter [ 0.915765] usb_battery_charger_detect_synop , battery_charger_detect 1, pass DCD, dcd_state = 1 [ 0.951493] rk-fb rockchip-fb: rk fb ion client create success! [ 0.951561] rk-fb rockchip-fb: rockchip framebuffer driver probe [ 0.952600] rk-screen rk_screen.9: rockchip screen probe success [ 0.953343] rk32-lvds rk32-lvds: rk32 lvds driver probe success [ 0.954059] rk32-edp ff970000.edp: screen is not edp! [ 0.954132] rk32-edp: probe of ff970000.edp failed with error -22 [ 0.955317] rk3288-lcdc lcdc0: can't find power_ctr node for lcdc0 [ 0.956095] graphics fb0: rockchip framebuffer registerd:fb0 [ 0.957166] graphics fb1: rockchip framebuffer registerd:fb1 [ 0.957786] graphics fb2: rockchip framebuffer registerd:fb2 [ 0.958323] graphics fb3: rockchip framebuffer registerd:fb3 [ 0.958871] graphics fb4: rockchip framebuffer registerd:fb4 [ 0.960493] rk_iommu ff930300.vopb_mmu: (vopb) Enabled [ 0.960925] rk3288-lcdc lcdc0: lcdc0: dclk:148500000>>fps:60 [ 0.960998] rk3288-lcdc lcdc0: wakeup from standby! [ 1.095474] alloc_buffer:ion_phy_addr=0x10000000 [ 1.138793] fb0:phy:10000000>>vir:f0191000>>len:0x1800000 [ 1.248586] rk3288-lcdc lcdc0: lcdc0 probe ok, iommu enabled [ 1.249757] rockchip_set_mux:warning ignore bank num 15 [ 1.250197] rockchip_set_mux:warning ignore bank num 15 [ 1.250597] rockchip_set_mux:warning ignore bank num 15 [ 1.250988] rockchip_set_mux:warning ignore bank num 15 [ 1.251373] rockchip_set_mux:warning ignore bank num 15 [ 1.251763] rockchip_set_mux:warning ignore bank num 15 [ 1.252642] rockchip_set_mux:warning ignore bank num 15 [ 1.253142] rockchip_set_mux:warning ignore bank num 15 [ 1.254008] rockchip_set_mux:warning ignore bank num 15 [ 1.254505] rockchip_set_mux:warning ignore bank num 15 [ 1.255318] rockchip_set_mux:warning ignore bank num 15 [ 1.255805] rockchip_set_mux:warning ignore bank num 15 [ 1.256605] rockchip_set_mux:warning ignore bank num 15 [ 1.257119] rockchip_set_mux:warning ignore bank num 15 [ 1.280539] NET: Registered protocol family 2 [ 1.282031] TCP established hash table entries: 8192 (order: 4, 65536 bytes) [ 1.282522] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 1.283019] TCP: Hash tables configured (established 8192 bind 8192) [ 1.283170] TCP: reno registered [ 1.283224] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.283357] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.283991] NET: Registered protocol family 1 [ 1.284546] Unpacking initramfs... [ 1.794259] Freeing initrd memory: 2516K (c4bf0000 - c4e65000) [ 1.795955] hw perfevents: enabled with ARMv7 Cortex-A12 PMU driver, 7 counters available [ 1.797308] probe device ff9a0000.vpu_service [ 1.797743] vpu_service: power on [ 1.798898] checking hw id 4831 [ 1.799988] vpu_service set to auto frequency mode [ 1.800158] vcodec vpu_service: vcodec ion client create success! [ 1.801303] vpu_service: power off... [ 1.801399] done [ 1.801432] init success [ 1.801603] probe device ff9c0000.hevc_service [ 1.802196] hevc_service: power on [ 1.803336] checking hw id 6867 [ 1.804166] vcodec hevc_service: vcodec ion client create success! [ 1.805030] hevc_service: power off... [ 1.805126] done [ 1.805160] init success [ 1.805489] rknandbase v1.0 2014-03-31 [ 1.805913] rknand_driver:ret = 0 [ 1.806982] audit: initializing netlink socket (disabled) [ 1.807096] type=2000 audit(1.290:1): initialized [ 1.809350] bounce pool size: 64 pages [ 1.824775] fuse init (API version 7.22) [ 1.825994] msgmni has been set to 1456 [ 1.832201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246) [ 1.832262] io scheduler noop registered [ 1.832303] io scheduler deadline registered [ 1.832623] io scheduler cfq registered (default) [ 1.834007] Console: switching to colour frame buffer device 240x67 [ 1.882848] rga ff920000.rga: rga ion client create success! [ 1.883255] rga: Driver loaded succesfully [ 1.884674] IEP Power ON [ 1.884793] iep ion client create success! [ 1.885751] rk_iommu ff900800.iep_mmu: (iep) Enabled [ 1.885842] IEP Power OFF [ 1.885888] rk_iommu ff900800.iep_mmu: (iep) Disabled [ 1.885941] rk_iommu ff900800.iep_mmu: rockchip_iommu_detach_device: Detached IOMMU with pgtable 0x2e272000 [ 1.886004] IEP Driver loaded succesfully [ 1.886285] Module initialized. [ 1.888755] dma-pl330 ffb20000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.888827] dma-pl330 ffb20000.pdma: DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10 [ 1.893469] dma-pl330 ff250000.pdma: Loaded driver for PL330 DMAC-2364208 [ 1.893541] dma-pl330 ff250000.pdma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 1.894260] pwm-voltage-regulator pwm_regulator.23: unable to request PWM, trying legacy API [ 1.894325] pwm-voltage-regulator pwm_regulator.23: unable to request legacy PWM [ 1.894369] pwm_regulator_probe:error [ 1.894444] platform pwm_regulator.23: Driver pwm-voltage-regulator requests probe deferral [ 1.895507] rk_serial.c v1.8 2014-03-04 [ 1.896151] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 87) is a rk29_serial.0 [ 1.896769] serial ff180000.serial: membase f017e000 [ 1.906360] loop: module loaded [ 1.908132] SCSI Media Changer driver v0.25 [ 1.909153] tun: Universal TUN/TAP device driver, 1.6 [ 1.909202] tun: (C) 1999-2004 Max Krasnyansky <[email]maxk@qualcomm.com[/email]> [ 1.910840] stmmac_probe_config_dt: Can not read property: pmu_regulator. [ 1.910897] stmmac_probe_config_dt: Can not read property: pmu_enable_level. [ 1.910946] stmmac_probe_config_dt: clock input or output? (input). [ 1.910992] stmmac_probe_config_dt: TX delay(0x30). [ 1.911032] stmmac_probe_config_dt: RX delay(0x10). [ 1.911142] stmmac_probe_config_dt: is rockchip,rk3288-gmac [ 1.911182] stmmc_pltfr_init: [ 1.911219] stmmc_pltfr_init: ERROR: Get power-gpio failed. [ 1.911258] stmmc_pltfr_init: ERROR: Get reset-gpio failed. [ 1.911295] stmmc_pltfr_init: init for RGMII [ 1.911336] tx delay=0x30 [ 1.911336] rx delay=0x10 [ 1.912761] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 1.912802] Normal descriptors [ 1.912834] Ring mode enabled [ 1.912868] DMA HW capability register supported [ 1.912908] RX Checksum Offload Engine supported (type 2) [ 1.912947] TX Checksum insertion supported [ 1.912981] Wake-Up On Lan supported [ 1.913111] Enable RX Mitigation via HW Watchdog Timer [ 1.914456] PPP generic driver version 2.4.2 [ 1.914940] PPP BSD Compression module registered [ 1.914987] PPP Deflate Compression module registered [ 1.915050] PPP MPPE Compression module registered [ 1.915095] NET: Registered protocol family 24 [ 1.915188] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled). [ 1.915238] CSLIP: code copyright 1989 Regents of the University of California. [ 1.915284] Rockchip WiFi SYS interface (V1.00) ... [ 1.915533] usbcore: registered new interface driver catc [ 1.915675] usbcore: registered new interface driver kaweth [ 1.915722] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver [ 1.915878] usbcore: registered new interface driver pegasus [ 1.916017] usbcore: registered new interface driver rtl8150 [ 1.916152] usbcore: registered new interface driver r8152 [ 1.916193] hso: drivers/net/usb/hso.c: Option Wireless [ 1.916448] usbcore: registered new interface driver hso [ 1.916609] usbcore: registered new interface driver asix [ 1.916739] usbcore: registered new interface driver ax88179_178a [ 1.916904] usbcore: registered new interface driver cdc_ether [ 1.917032] usbcore: registered new interface driver cdc_eem [ 1.917156] usbcore: registered new interface driver dm9601 [ 1.917278] usbcore: registered new interface driver dm9620 [ 1.917432] usbcore: registered new interface driver smsc75xx [ 1.917586] usbcore: registered new interface driver smsc95xx [ 1.917721] usbcore: registered new interface driver gl620a [ 1.917849] usbcore: registered new interface driver net1080 [ 1.917975] usbcore: registered new interface driver plusb [ 1.918101] usbcore: registered new interface driver rndis_host [ 1.918226] usbcore: registered new interface driver cdc_subset [ 1.918345] usbcore: registered new interface driver zaurus [ 1.918476] usbcore: registered new interface driver MOSCHIP usb-ethernet driver [ 1.918721] usbcore: registered new interface driver int51x1 [ 1.918876] usbcore: registered new interface driver kalmia [ 1.919010] usbcore: registered new interface driver ipheth [ 1.919153] usbcore: registered new interface driver sierra_net [ 1.919283] usbcore: registered new interface driver cx82310_eth [ 1.919439] usbcore: registered new interface driver cdc_ncm [ 1.919568] usbcore: registered new interface driver qmi_wwan [ 1.919708] usbcore: registered new interface driver cdc_mbim [ 1.919753] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.922967] ehci_rk_probe f1a00000 f1a00010 [ 1.923026] rockchip_ehci_host ff500000.usb: Rockchip On-Chip EHCI Host Controller [ 1.923124] rockchip_ehci_host ff500000.usb: new USB bus registered, assigned bus number 1 [ 1.924187] rockchip_ehci_host ff500000.usb: irq 56, io mem 0xff500000 [ 1.938445] rockchip_ehci_host ff500000.usb: USB 0.0 started, EHCI 1.00 [ 1.938680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.938742] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.938796] usb usb1: Product: Rockchip On-Chip EHCI Host Controller [ 1.938847] usb usb1: Manufacturer: Linux 3.10.0 ehci_hcd [ 1.938894] usb usb1: SerialNumber: ff500000.usb [ 1.940200] hub 1-0:1.0: USB hub found [ 1.940281] hub 1-0:1.0: 1 port detected [ 1.967930] ehci_rk_probe ok [ 1.968361] usbcore: registered new interface driver cdc_acm [ 1.968409] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 1.968593] usbcore: registered new interface driver usblp [ 1.968735] usbcore: registered new interface driver cdc_wdm [ 1.968960] usbcore: registered new interface driver usb-storage [ 1.969092] usbcore: registered new interface driver ums-alauda [ 1.969219] usbcore: registered new interface driver ums-cypress [ 1.969359] usbcore: registered new interface driver ums-datafab [ 1.969491] usbcore: registered new interface driver ums_eneub6250 [ 1.969616] usbcore: registered new interface driver ums-freecom [ 1.969742] usbcore: registered new interface driver ums-isd200 [ 1.969868] usbcore: registered new interface driver ums-jumpshot [ 1.969993] usbcore: registered new interface driver ums-karma [ 1.970121] usbcore: registered new interface driver ums-onetouch [ 1.970250] usbcore: registered new interface driver ums-sddr09 [ 1.970378] usbcore: registered new interface driver ums-sddr55 [ 1.970504] usbcore: registered new interface driver ums-usbat [ 1.970790] usbcore: registered new interface driver usbserial [ 1.970938] usbcore: registered new interface driver usbserial_generic [ 1.971051] usbserial: USB Serial support registered for generic [ 1.971189] usbcore: registered new interface driver option [ 1.971298] usbserial: USB Serial support registered for GSM modem (1-port) [ 1.971534] usbcore: registered new interface driver trancevibrator [ 1.971580] usb20_otg: version 3.10a 21-DEC-2012 [ 1.972633] f1a80040 [ 1.972683] Core Release: 3.10a [ 1.972737] Setting default values for core params [ 1.973152] Using Buffer DMA mode [ 1.973195] Periodic Transfer Interrupt Enhancement - disabled [ 1.973235] Multiprocessor Interrupt Enhancement - disabled [ 1.973276] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.973313] ^^^^^^^^^^^^^^^^^Device Mode [ 1.973369] Dedicated Tx FIFOs mode [ 1.973431] pcd_init otg_dev = ee348dc0 [ 1.973932] usb20_otg ff580000.usb: DWC OTG Controller [ 1.974032] usb20_otg ff580000.usb: new USB bus registered, assigned bus number 2 [ 1.974148] usb20_otg ff580000.usb: irq 55, io mem 0x00000000 [ 1.974337] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.974398] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.974450] usb usb2: Product: DWC OTG Controller [ 1.974496] usb usb2: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.974543] usb usb2: SerialNumber: ff580000.usb [ 1.975905] hub 2-0:1.0: USB hub found [ 1.975983] hub 2-0:1.0: 1 port detected [ 1.976880] usb20_host: version 3.10a 21-DEC-2012 [ 1.980378] f1b00040 [ 1.980426] Core Release: 3.10a [ 1.980465] Setting default values for core params [ 1.980868] Using Buffer DMA mode [ 1.980911] Periodic Transfer Interrupt Enhancement - disabled [ 1.980951] Multiprocessor Interrupt Enhancement - disabled [ 1.980992] OTG VER PARAM: 0, OTG VER FLAG: 0 [ 1.981029] ^^^^^^^^^^^^^^^^^^Host Mode [ 1.981111] usb20_host ff540000.usb: DWC OTG Controller [ 1.981202] usb20_host ff540000.usb: new USB bus registered, assigned bus number 3 [ 1.981307] usb20_host ff540000.usb: irq 57, io mem 0x00000000 [ 1.981474] Init: Power Port (0) [ 1.981672] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 1.981733] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 1.981786] usb usb3: Product: DWC OTG Controller [ 1.981832] usb usb3: Manufacturer: Linux 3.10.0 dwc_otg_hcd [ 1.981879] usb usb3: SerialNumber: ff540000.usb [ 1.983234] hub 3-0:1.0: USB hub found [ 1.983312] hub 3-0:1.0: 1 port detected [ 1.984939] .. rk pwm remotectl v1.0 init [ 1.985192] remotectl probe j=0x0 [ 1.985705] input: ff680000.pwm as /devices/ff680000.pwm/input/input0 [ 1.986323] pwm enable val=0x646205 [ 1.987230] usbcore: registered new interface driver xpad [ 1.987419] usbcore: registered new interface driver usb_acecad [ 1.987653] usbcore: registered new interface driver aiptek [ 1.987822] usbcore: registered new interface driver gtco [ 1.987978] usbcore: registered new interface driver hanwang [ 1.988133] usbcore: registered new interface driver kbtab [ 1.988323] usbcore: registered new interface driver wacom [ 1.989370] sensor_register_slave:mma8452,id=17 [ 1.989421] sensor_register_slave:cm3217,id=44 [ 1.989461] sensor_register_slave:cm3218,id=45 [ 1.989498] tchip_rm_init is here! [ 1.991048] input: tchip_remote_key as /devices/virtual/input/input1 [ 1.991453] tchiprm_register_device is here! [ 1.991927] input: tchip_remote_touch as /devices/virtual/input/input2 [ 1.992312] tchip_remote_abs_register_device is here! [ 1.992773] input: tchip_remote_gsensor as /devices/virtual/input/input3 [ 1.993149] tchip_remote_gsensor_register_device is here! [ 1.999976] rtc_hym8563 0-0051: rtc core: registered hym8563 as rtc0 [ 2.000124] i2c /dev entries driver [ 2.002305] IR NEC protocol handler initialized [ 2.002352] IR RC5(x) protocol handler initialized [ 2.002389] IR RC6 protocol handler initialized [ 2.002425] IR JVC protocol handler initialized [ 2.002460] IR Sony protocol handler initialized [ 2.002496] IR RC5 (streamzap) protocol handler initialized [ 2.002533] IR SANYO protocol handler initialized [ 2.002569] IR MCE Keyboard/mouse protocol handler initialized [ 2.002824] usbcore: registered new interface driver uvcvideo [ 2.002867] USB Video Class driver (1.1.1) [ 2.002913] CamSys driver version: v0.19.0, CamSys head file version: v0.8.0 [ 2.006105] D1:camsys_platform_probe(1061): 1-gpios-cifpower: gpio=236 [ 2.006188] D1:camsys_platform_probe(1064): gpios-cifpower: gpio_request [ 2.006254] D1:camsys_platform_probe(1066): 1-gpios-cifpower: gpio_request=0 [ 2.006316] D1:camsys_platform_probe(1075): gpios-cifpower: 236 high [ 2.006529] D1:camsys_mipiphy_probe_cb(163): ff910000.isp mipi phy0 probe success(reg_phy: 0x0 reg_vir: 0x0 size: 0x0) [ 2.006989] D1:camsys_mipiphy_probe_cb(160): ff910000.isp mipi phy1 probe success(reg_phy: 0xff968000 reg_vir: 0xf19a8000 size: 0x4000) [ 2.009193] D1:camsys_platform_probe(1208): ff910000.isp memory: [ 2.009255] D1:camsys_platform_probe(1218): Register memory (phy: 0xff910000 vir: 0xf19e0000 size: 0x10000) [ 2.009315] D1:camsys_platform_probe(1213): I2c memory (phy: 0x2da6f000 vir: 0xeda6f000 size: 0x1000) [ 2.009366] D1:camsys_platform_probe(1233): Probe ff910000.isp device success [ 2.012231] device-mapper: uevent: version 1.0.3 [ 2.012968] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: [email]dm-devel@redhat.com[/email] [ 2.013918] Bluetooth: HCI UART driver ver 2.2 [ 2.013973] Bluetooth: HCI H4 protocol initialized [ 2.014013] Bluetooth: HCILL protocol initialized [ 2.697542] cpufreq version 1.0, suspend freq 1200 MHz [ 2.698159] cpuidle: using governor ladder [ 2.698207] cpuidle: using governor menu [ 2.698329] Synopsys Designware Multimedia Card Interface Driver [ 2.699079] dwmmc_rockchip ff0f0000.rksdmmc: Version ID is 270a [ 2.699919] dwmmc_rockchip ff0f0000.rksdmmc: Using internal DMA controller. [ 2.700446] 3291..dw_mci_init_slot: fmin=400000, fmax=52000000 [mmc0] [ 2.700497] mmc0 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.700951] 1381..dw_mci_set_ios: no card. [mmc0] [ 2.715834] 1381..dw_mci_set_ios: no card. [mmc0] [ 2.735436] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out 800000Hz for init[mmc0] [ 2.735461] dwmmc_rockchip ff0f0000.rksdmmc: DW MMC controller at irq 67, 32 bit host data width, 256 deep fifo [ 2.735474] dwmmc_rockchip ff0f0000.rksdmmc: 1 slots initialized [ 2.735802] dwmmc_rockchip ff0c0000.rksdmmc: Version ID is 270a [ 2.736644] dwmmc_rockchip ff0c0000.rksdmmc: Using internal DMA controller. [ 2.736854] 3285..dw_mci_init_slot: fmin=300000, fmax=50000000 [mmc1] [ 2.736872] mmc1 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.737381] 1381..dw_mci_set_ios: no card. [mmc1] [ 2.755094] 1381..dw_mci_set_ios: no card. [mmc1] [ 2.774902] dwmmc_rockchip ff0c0000.rksdmmc: DW MMC controller at irq 64, 32 bit host data width, 256 deep fifo [ 2.774921] dwmmc_rockchip ff0c0000.rksdmmc: 1 slots initialized [ 2.775253] dwmmc_rockchip ff0d0000.rksdmmc: Version ID is 270a [ 2.775469] dwmmc_rockchip ff0d0000.rksdmmc: Using internal DMA controller. [ 2.775598] 3291..dw_mci_init_slot: fmin=200000, fmax=50000000 [mmc2] [ 2.775613] mmc2 : Rockchip specific MHSC: Ver 1.13 2014-09-05 [ 2.775712] 1381..dw_mci_set_ios: no card. [mmc2] [ 2.794432] 1381..dw_mci_set_ios: no card. [mmc2] [ 2.814327] dwmmc_rockchip ff0d0000.rksdmmc: DW MMC controller at irq 65, 32 bit host data width, 256 deep fifo [ 2.814340] dwmmc_rockchip ff0d0000.rksdmmc: 1 slots initialized [ 2.814559] hidraw: raw HID events driver (C) Jiri Kosina [ 2.815895] usbcore: registered new interface driver usbhid [ 2.815907] usbhid: USB HID core driver [ 2.816185] ashmem: initialized [ 2.816306] logger: created 256K log 'log_main' [ 2.816399] logger: created 256K log 'log_events' [ 2.816490] logger: created 256K log 'log_radio' [ 2.816595] logger: created 256K log 'log_system' [ 2.817254] rk-keypad: probe of key.30 failed with error -307976704 [ 2.817992] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 2.818023] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 2.818039] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 2.818144] u32 classifier [ 2.818152] Actions configured [ 2.818165] Netfilter messages via NETLINK v0.30. [ 2.818223] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 2.818552] ctnetlink v0.93: registering with nfnetlink. [ 2.818627] NF_TPROXY: Transparent proxy support initialized, version 4.1.0 [ 2.818637] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. [ 2.818909] xt_time: kernel timezone is -0000 [ 2.819126] ip_tables: (C) 2000-2006 Netfilter Core Team [ 2.819263] arp_tables: (C) 2002 David S. Miller [ 2.819303] TCP: cubic registered [ 2.819311] Initializing XFRM netlink socket [ 2.819523] NET: Registered protocol family 10 [ 2.820051] mip6: Mobile IPv6 [ 2.820078] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 2.820199] sit: IPv6 over IPv4 tunneling driver [ 2.820543] NET: Registered protocol family 17 [ 2.820570] NET: Registered protocol family 15 [ 2.820625] Bridge firewalling registered [ 2.820639] Ebtables v2.0 registered [ 2.820800] Bluetooth: RFCOMM TTY layer initialized [ 2.820827] Bluetooth: RFCOMM socket layer initialized [ 2.820836] Bluetooth: RFCOMM ver 1.11 [ 2.820844] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.820851] Bluetooth: BNEP filters: protocol multicast [ 2.820864] Bluetooth: BNEP socket layer initialized [ 2.820872] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.820885] Bluetooth: HIDP socket layer initialized [ 2.820914] l2tp_core: L2TP core driver, V2.0 [ 2.820929] l2tp_ppp: PPPoL2TP kernel driver, V2.0 [ 2.820937] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 2.821107] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 2.821119] wlan_platdata_parse_dt: wifi_chip_type = bcmwifi [ 2.821129] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 2.821139] [WLAN_RFKILL]: wlan_platdata_parse_dt: disable wifi io reference voltage control. [ 2.821149] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio. [ 2.821173] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,poweren_gpio = 156, flags = 0. [ 2.821196] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 158, flags = 0. [ 2.821206] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 2.821234] [WLAN_RFKILL]: rockchip_wifi_voltage_select: wifi & sdio reference voltage: 1.8V [ 2.821282] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 2.821323] [BT_RFKILL]: Enter rfkill_rk_init [ 2.821449] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 147. [ 2.821469] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,power_gpio = 155. [ 2.821486] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 157. [ 2.821502] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 154. [ 2.821518] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 159. [ 2.821567] [BT_RFKILL]: Request irq for bt wakeup host [ 2.821672] [BT_RFKILL]: ** disable irq [ 2.821759] [BT_RFKILL]: ap6335 device registered. [ 2.837482] mmc0: BKOPS_EN bit is not set [ 2.856098] rk_sdmmc: BOOT Bus speed=0Hz,Bus width=8bits.[mmc0] [ 2.873570] mmc_host mmc0: Bus speed (slot 0) = 52000000Hz (slot req 52000000Hz, actual 52000000HZ div = 0) [ 2.873594] rk_sdmmc: BOOT dw_mci_setup_bus: argue clk_mmc workaround out normal clock [mmc0] [ 2.888734] rk_sdmmc: BOOT [ 2.888734] execute tuning: candidates_degree = SDMMC_SHIFT_DEGREE_90 SDMMC_SHIFT_DEGREE_180 SDMMC_SHIFT_DEGREE_INVALID SDMMC_SHIFT_DEGREE_INVALID[mmc0] [ 2.893189] mmc0: new HS200 MMC card at address 0001 [ 2.893495] mmcblk0: mmc0:0001 HAG2e 14.6 GiB [ 2.893796] resource: 0x000400000 -- 0x001400000 (16 MB) [ 2.893808] boot: 0x001400000 -- 0x002400000 (16 MB) [ 2.893819] misc: 0x002400000 -- 0x002800000 (4 MB) [ 2.893827] backup: 0x002800000 -- 0x005c00000 (52 MB) [ 2.893837] linuxroot: 0x005c00000 -- 0x3ab400000 (14936 MB) [ 2.893856] mmcblk0: p1 p2 p3 p4 p51381..dw_mci_set_ios: no card. [mmc1] [ 2.895455] 1381..dw_mci_set_ios: no card. [mmc2] [ 3.128976] [EDID] check header error [ 3.128988] rk3288-hdmi ff980000.hdmi: [HDMI] parse edid base block error [ 3.502903] [EDID] check header error [ 3.502913] rk3288-hdmi ff980000.hdmi: [HDMI] parse edid base block error rror 3.876814] [Ey:D]tehein hrd fr [ 3.876823] rk3288-hdmi ff980000.hdmi: [HDMI] parsL edid , seealo k itro. y: ar3.se68ion 2k3 8-hdmi ff980000.hdmi: warning: EDID error, assume sink as DVI !!!! ode parsed from EDID !!!!i ff980000.hdmi: waxni:s: rt Cec vone3 [ 3.876857] ******** Show Sink Info ******** g es e 3i87 867vers ... Support video mode: [ 3.876872] 3840x2160p@60Hz [ 3.876876] 3840x2160p@50Hz [ 3FA76L:0Cou 3840t2l6ap@/lHb [ u es/3870.05m 3le4.xep16Np@suHh [l r 87re89] y3840x2160 p@24Hz [ 3.876894] 1920x1080p@60Hz [ 3.876898] 1920x1080p@50Hz [ 3.876903] 1920x1080p@30Hz [ 3.876907] 1920x1080p@25Hz [ 3.876911] 1920x1080p@24Hz [ 3.876916] 1280x72FATAL: Could not0p@60H load /lib/modules/3.10.0/modules.dep: No such filez or directory[ 3.876920] 1280x720p@50Hz [ 3.876924] 1280x720p@30Hz [ 3.876928] 1280x720p@25Hz [ 3.876932] 1280x720p@24Hz [ 3.876936] 720x576p@50Hz [ 3.876940] 720x480p@60Hz [ 3.876AT4]: uoulrtnotdeo co oradodli mo 3.876/4910 0/mo [l .de8: N6 53]hSfipo rt ideectolyr depth: [ 3.876957] 24bit [ FATAL87Co6ld Sotpora audib/topele ow Sinknenf [/ 10.0/6o6u]es*****p: No such file or directory o ******** [ 3.876983] [ 3.876983] rk_fb_egitchRucnien /sdcipd 0 nite reeoant ..e 1 [ 3.876994] fb0 win id 1 state 1 [ 3.877059] rk3288-lcdc lcdc0: lcdc0: dclk:74250000>>fps:60 [ 3.877083] fb1 win id 0 state 0 [ 3.877089] fb2 win id 2 state 0 [ 3.877095] fb3 win id 3 state 0 [ on 3 77100] fb4 win iBe4 n:atou0ti[ oo.8fi1e ] ste ..3.877105] rk_fb_switch_screen lcdc_id 0 type 6 enable 1 done [ 3.877105] [ 3.877122] pixel clk is 7425eg00: mun cng /scr42t00lo fig_video] sucess output DVI.980000.hdmi: [hdmi_devxto [Be n:88un39ngrk32r8-tsmiocf9-p00moudm . r 3288 hdmi probe sucess. le /3 30.08mo4]lek1d00: od s 4h 06le orc_irantoer returned -11 [ 3.910446] rk1000_coddo 4.0 60: i2c_transfer() retTAne C-1ld [ot l3.d 29ib] od10es_3.de.0prode est=ex0 N[ su 3 f13e 4r dgrerkor00 standby [ 3.914884] rk1000_codec 4-0060: ASoC: no sink widget found for Mic Bias1 [ 3.914895] rk1000_codec 4-0060: ASoC: Failed to add route Mic Jack -> direct -> Mic Bias1 [ 3.914903] rk1000_codec 4-0060: ASoC: no source widget found for Mic Bias1 [ 3.914911] rk1000_codec 4-0060: ASoC: Failed to add route Mic Bias1 -> direct -> MIC1 [ 3.914919] rk1000_codec 4-0060: ASoC: no source widget found for HPOL [ 3.914927] rk1000_codec 4-0060: ASoC: Failed to add route HPOL -> direct -> Headphone Jack [ 3.914935] rk1000_codec 4-0060: ASoC: no source widget found for HPOR [ 3.914942] rk1000_codec 4-0060: ASoC: Failed to add route HPOR -> direct -> Headphone Jack [ 3.914950] rk1000_codec 4-0060: ASoC: no source widget found for SPOL [ 3.914957] rk1000_codec 4-0060: ASoC: Failed to add route SPOL -> direct -> Ext Spk [ 3.914965] rk1000_codec 4-0060: ASoC: no source widget found for SPOR [ 3.914972] rk1000_codec 4-0060: ASoC: Failed to add route SPOR -> direct -> Ext Spk [ 3.914980] rk1000_codec 4-0060: ASoC: DAPM unknown pin HP_L [ 3.914987] rk1000_codec 4-0060: ASoC: DAPM unknown pin HP_R [ 3.918310] rockchip-rk1000 rockchip-rk1000.28: rk1000_codec <-> rockchip-i2s.0 mapping ok [ 3.919021] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0 [ 3.919040] rk3288_init_suspend [ 3.919048] rk3288_suspend_init enter [ 3.919185] rk3288_suspend_init: pm_ctrbits =40017 [ 3.919218] gpio_get_dts_info suspend:8 [ 3.919224] gpio_get_dts_info resume:8 [ 3.919230] rockchip,pmic-suspend_gpios:1007c30 1007c40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.919254] rockchip,pmic-resume_gpios:2007c32 2007c42 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 [ 3.919377] clks_gating_suspend_init:clkgt info ok [ 3.919464] Registering SWP/SWPB emulation handler [ 3.919747] ddrfreq: verion 1.2 20140526 [ 3.919758] ddrfreq: normal 456MHz video_1080p 0MHz video_4k 456MHz dualview 0MHz idle 0MHz suspend 200MHz reboot 456MHz [ 3.919766] ddrfreq: auto-freq=0 [ 3.919771] ddrfreq: auto-freq-table[0] 240MHz [ 3.919777] ddrfreq: auto-freq-table[1] 324MHz [ 3.919782] ddrfreq: auto-freq-table[2] 456MHz [ 3.919787] ddrfreq: auto-freq-table[3] 528MHz [ 3.921551] act_ldo8: disabling [ 3.922388] act_ldo4: disabling [ 3.923218] act_ldo3: disabling [ 3.924047] act_ldo2: disabling [ 3.924658] regulator-dummy: disabling [ 3.924919] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: ASoC: CPU DAI (null) not registered [ 3.924942] rockchip_hdmi_spdif_audio_probe() register card failed:-517 [ 3.924956] platform rockchip-hdmi-spdif.27: Driver rockchip-hdmi-spdif requests probe deferral [ 3.925041] pcd_pullup, is_on 0 [ 3.925076] file system registered [ 3.925597] android_usb gadget: Mass Storage Function,eger: onnn20g /s9/ip /lo l-92t60m a. roid_usb gadgene doer.ofxLU:s=2rt[ ec 3o9 461 ] lun0: LBN:inemRuabin f/lcr (ts mniiubo o ..3.925619] lun1: LUN: removable file: (no medium) [ 3.925734] android_usb gadget: android_usb ready [ 3.925789] sensor_init: Probe name sensors t between two gsensors 2013-09-01ioupp ed new interface driver snd-usb-audio utaco s: tigist c tst20t -0ct01n16 [ 3.931588] ALSA device list: [ 3.931593] #0: RK_RK1000 [ 3.932885] Freeing unused kernel memory: 2364K (c0a91000 - c0ce0000) [ 3.933264] rockchip-hdmi-spdif rockchip-hdmi-spdif.27: rk-hdmi-spdif-hifi <-> rockchip-spdif mapping ok [ 3.945730] [ 3.945730] rk_fb_switch_screen lcdc_id 0 type 6 enable 0 [ 3.962352] udevd[136]: starting version 175 [ 4.365787] EXT4-fs (mmcblk0p5): recovery complete [ 4.366440] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null) SELinux: Could not open policy file <= /etc/selinux/targeted/policy/policy.29: No such file or directory [ 4.614412] init: plymouth-upstart-bridge main process (275) terminated with status 1 [ 4.614510] init: plymouth-upstart-bridge main process ended, respawning [ 4.633624] init: plymouth-upstart-bridge main process (285) terminated with status 1 [ 4.633705] init: plymouth-upstart-bridge main process ended, respawning [ 4.642257] init: plymouth-upstart-bridge main process (288) terminated with status 1 [ 4.642306] init: plymouth-upstart-bridge main process ended, respawning [ 4.653241] init: plymouth-upstart-bridge main process (289) terminated with status 1 [ 4.653308] init: plymouth-upstart-bridge main process ended, respawning [ 4.672622] init: ureadahead main process (278) terminated with status 5 [ 4.788444] init: mounted-proc main process (303) terminated with status 1 * Starting Mount filesystems on boot[ OK ] * Starting Signal sysvinit that the rootfs is mounted[ OK ] * Starting Populate and link to /run filesystem[ OK ] * Stopping Populate and link to /run filesystem[ OK ] * Starting Initialize or finalize resolvconf[ OK ] * Starting Clean /tmp directory[ OK ] * Stopping Track if upstart is running in a container[ OK ] * Stopping Clean /tmp directory[ OK ] * Starting Signal sysvinit that virtual filesystems are mounted[ OK ] * Starting Signal sysvinit that virtual filesystems are mounted[ OK ] * Starting Bridge udev events into upstart[ OK ] * Starting Signal sysvinit that remote filesystems are mounted[ OK ] * Starting device node and kernel event manager[ OK ] * Starting Signal sysvinit that local filesystems are mounted[ OK ] * Starting restore software rfkill state[ OK ] * Starting load modules from /etc/modules[ OK ] * Starting cold plug devices[ OK ] * Starting log initial device creation[ OK ] * Stopping Mount filesystems on boot[ OK ] * Stopping restore software rfkill state[ OK ] * Stopping load modules from /etc/modules[ OK ] * Starting flush early job output to logs[ OK ] * Stopping flush early job output to logs[ OK ] * Starting D-Bus system message bus[ OK ] * Starting SystemD login management service[ OK ] * Starting set console font[ OK ] * Stopping set console font[ OK ] * Starting userspace bootsplash[ OK ] * Starting Send an event to indicate plymouth is up[ OK ] * Starting configure network device security[ OK ] * Starting configure network device[ OK ] * Stopping Send an event to indicate plymouth is up[ OK ] * Starting system logging daemon[ OK ] * Stopping userspace bootsplash[ OK ] * Starting bluetooth initialization[ OK ] * Starting bluetooth initialization[fail] * Starting bluetooth daemon[ OK ] * Starting configure network device security[ OK ] * Starting configure network device security[ OK ] * Starting configure network device[ OK ] * Starting Mount network filesystems[ OK ] * Starting Failsafe Boot Delay[ OK ] * Starting configure network device[ OK ] * Stopping Failsafe Boot Delay[ OK ] * Stopping Mount network filesystems[ OK ] * Starting System V initialisation compatibility[ OK ] * Starting configure network device security[ OK ] * Starting Turn on/off the ap6335 bluetooth[ OK ] [ OK ]ting up X socket directories... * Stopping System V initialisation compatibility[ OK ] * Starting System V runlevel compatibility[ OK ] * Starting save kernel messages[ OK ] * Starting configure network device security[ OK ] * Starting anac(h)ronistic cron[ OK ] * Starting regular background program processing daemon[ OK ] * Stopping save kernel messages[ OK ] * Starting configure virtual network devices[ OK ] * Stopping Restore Sound Card State[ OK ] * Starting OpenSSH server[ OK ] [ 6.512341] turn on mali power * Stopping System V runlevel compatibility[ OK ]
各位有没有遇到,firefly代码跑ubuntu的时候,出现过,卡在* Stopping System V runlevel compatibility[ OK ] 的情况。
好长的log,楼主的内核修改了哪里?先定位一下
主要适配硬件做了dts修改
附件这是我的dts配置,请大神帮忙检查一下
DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
搞了一下,终于不再init进程里面,看到ubuntu啦。进到tty2终端中啦,但是还是出错,
Ubuntu 14.04.1 LTS firefly ttyS2
firefly login: root (automatic login)
[ 59.636452] BUG: soft lockup - CPU#0 stuck for 21s! [upstart-udev-br:460]
[ 65.156718] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 65.353532] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 65.550326] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 65.553319] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 65.747112] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 65.750096] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 65.750220] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1200000(was 937500)mV
[ 65.943927] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 66.140727] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 66.337511] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 66.340502] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 66.534327] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 66.537310] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 66.537434] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1200000(was 937500)mV
[ 66.731126] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 66.927911] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.124727] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.127718] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 67.321527] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.324510] DVFS ERR: dvfs_regulator_set_voltage_readback: set ERROR AND NOT effected, volt=937500
[ 67.324633] DVFS ERR: dvfs_scale_volt_direct: vd_arm set voltage up err ret = -110, Vnew = 1200000(was 937500)mV
[ 67.518312] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.715125] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.911926] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd: 0x10
[ 67.914917] DVFS ERR: dvfs_regulator_set_voltage_readback: now read back to check voltage
[ 68.108711] rockchip_i2c ff650000.i2c: Addr[0x0040] wait event timeout, state: 1, is_busy: 1, error: 0, complete_what: 0x0, ipd:
请各位大神继续帮忙看看
用的是哪个板子?
i2c busy了,要排查下哪里影响到了那个DCDC,
楼主怎么解决了,能不能说下?
楼主怎么解决了,能不能说下?
