WallysTech DR6018 and DR40X9 series are two popular wireless routers that are widely used by people around the world. These routers are known for their fast and reliable connectivity, making them a popular choice for both personal and business use.
One of the key features of these routers is their support for TIP wireless controllers. TIP (Tunneling Internet Protocol) is a networking protocol that enables the creation of secure and private networks over public networks such as the Internet. By using TIP wireless controllers with WallysTech DR6018 and DR40X9 series routers, users can enjoy a more secure and reliable wireless network.
TIP wireless controllers provide a number of benefits, including:
1. Improved Security: TIP wireless controllers use advanced encryption protocols to protect data as it travels over the wireless network. This ensures that sensitive information, such as passwords and financial data, is kept safe from prying eyes.
2. Increased Reliability: TIP wireless controllers help to reduce wireless interference and ensure that wireless signals are transmitted and received accurately. This can help to prevent dropped connections and other connectivity issues.
- Simplified Management: TIP wireless controllers can be easily configured and managed using a web-based interface. This makes it easy to set up and manage the wireless network, even for non-technical users.
Overall, if you are looking for a fast, reliable, and secure wireless network, then WallysTech DR6018 and DR40X9 series routers with TIP wireless controllers are an excellent choice. These routers offer a range of advanced features that make them ideal for both personal and business use, and are backed by WallysTech’s excellent customer support.
TIP (The Industrial Partners) wireless controller is a device that allows you to wirelessly control your industrial equipment. It is designed for use in harsh industrial environments and provides a reliable and robust communication solution. The TIP wireless controller is ideal for use in a range of industries, including oil and gas, mining, agriculture, and manufacturing.
One of the key features of the TIP wireless controller is its long-range wireless connectivity. It uses advanced wireless communication technologies to ensure that your equipment can be controlled from a distance of up to 20km (12.5 miles) away. This is particularly useful in industries where equipment is located in remote or hard-to-reach areas.
Another key feature of the TIP wireless controller is its rugged construction. It is designed to withstand harsh environmental conditions such as extreme temperatures, humidity, and vibration. The device is also dust and water-resistant, making it suitable for use in outdoor and indoor environments.The TIP wireless controller comes with a range of built-in features to make it easy to integrate with your existing equipment. It has a range of inputs and outputs, including digital and analog inputs, relay outputs, and RS232/485 serial ports. The device is also compatible with a range of industrial communication protocols, including Modbus RTU, Modbus TCP/IP, and Ethernet/IP.
In addition to its built-in features, the TIP wireless controller also comes with a range of software tools to help you set up and configure the device. The device can be easily programmed using TIP Studio, a software tool that allows you to create custom logic and control functions. TIP Studio also comes with a range of pre-built function blocks, making it easy to configure the device for common industrial applications.
Wallys IPQ 6018 IPQ6010 IPQ4019 IPQ4029 Network Solutions:
- DR6018
Website:
Yuotube:
[b][u]https://www.youtube.com/watch?v=RPk_6fZbHZU[/u][/b]
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2.DR4019
Product Parameter
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Storage Humidity Range 0 to +90 (non-condensing)%
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional)
3G/4G 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
DC Jack 24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
EMAIL:sales4@wallystech.com
