Android无法使用USB网卡上网
固件文件名称:ROC-RK3588S-PC_Android12_HDMI_230307
固件下载地址:百度网盘
Log日志:Desktop.zip
USB网卡使用的是RTL8152
使用ifconfig指令可以看到eth1 已经link了
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope: Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 TX bytes:0
dummy0    Link encap:Ethernet  HWaddr c6:15:76:35:c3:48
          inet6 addr: fe80::c415:76ff:fe35:c348/64 Scope: Link
          UP BROADCAST RUNNING NOARP  MTU:1500  Metric:1
          TX packets:5 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 TX bytes:350
eth0      Link encap:Ethernet  HWaddr d2:13:ab:8b:bc:df  Driver rk_gmac-dwmac
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          Interrupt:75
ip_vti0   Link encap:UNSPEC
          NOARP  MTU:1480  Metric:1
ip6_vti0  Link encap:UNSPEC
          NOARP  MTU:1364  Metric:1
sit0      Link encap:IPv6-in-IPv4
ip6tnl0   Link encap:UNSPEC
          NOARP  MTU:1452  Metric:1
wlan0     Link encap:Ethernet  HWaddr 68:4e:05:05:d0:77  Driver rtl8821cu
p2p0      Link encap:Ethernet  HWaddr 6a:4e:05:05:d0:77  Driver rtl8821cu
eth1      Link encap:Ethernet  HWaddr 00:e0:4c:36:01:d6  Driver r8152
          inet addr:172.16.151.37  Bcast:172.16.151.255  Mask:255.255.255.0
          inet6 addr: fe80::c1d3:ca43:41b0:1238/64 Scope: Link
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:208 errors:0 dropped:0 overruns:0 frame:0
          TX packets:16 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:15124 TX bytes:1864
Desktop.zip (28.7 KB)
  1. 目前的SDK支持双以太网,但是只能一个是外网,另一个是内网,需要在板卡端 /vendor/build.prop 里添加属性,比如
    ro.net.eth_primary=eth0
    ro.net.eth_aux=eth1
    其中 ro.net.eth_primary 是配置主网口,只有这个网口才能上外网
  2. 如果要双以太网都能连通外网,需要打补丁,请联系商务 sales@t-firefly.com
