The WiFi6E wireless solution, featuring the IPQ6000, IPQ6010, and IPQ6018 chipsets along with the QCN9074 and QCN9024 radios, is the latest offering from Qualcomm Technologies, Inc. This technology promises to revolutionize the way we use wireless networks by providing faster speeds, increased capacity, and improved reliability.
The IPQ6000 is a high-performance Wi-Fi 6E SoC designed for residential and enterprise wireless access points, routers, and gateways. It features a quad-core ARM Cortex-A53 CPU and supports dual-band Wi-Fi 6E with up to 8 streams, MU-MIMO, and OFDMA. The IPQ6010 and IPQ6018 are similar but designed for smaller access points and routers. All three chipsets are built on a 14nm process and support up to 2.2 Gbps per stream.
The QCN9074 and QCN9024 are 4x4 and 2x2 Wi-Fi 6E radios, respectively, that can be paired with the IPQ6000, IPQ6010, and IPQ6018. They support up to 160 MHz channels, 1024-QAM, and up to 5.9 Gbps per radio. The radios also support Qualcomm’s FastConnect 6900 system, which includes advanced features like Wi-Fi 6E Multi-User Spatial Reuse, Wi-Fi 6E SmartScan, and Wi-Fi 6E Latency Reduction.
Together, these technologies enable high-speed, low-latency Wi-Fi 6E networks that can support a large number of devices simultaneously. They are ideal for applications like 4K/8K video streaming, online gaming, and virtual reality. They also provide the capacity and performance required for enterprise and industrial applications like smart cities, healthcare, and manufacturing.
Overall, the WiFi6E wireless solution with the IPQ6000, IPQ6010, and IPQ6018 chipsets and QCN9074 and QCN9024 radios represents a significant step forward in wireless networking technology. It provides faster speeds, increased capacity, and improved reliability, enabling new and exciting applications that were not possible with previous generations of Wi-Fi technology.
The WAllys WiFi6E wireless solution:
1.DR6018
Website:
Yuotube:
https://www.youtube.com/watch?v=RPk_6fZbHZU
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
2.DR6000
Website:
Qualcomm-Atheros IPQ6000
Quad-core ARM 64 bit A53s 1.2GHz processor
2.4GHz, 2x2 MU-MIMO OFDMA Technology, up to 573Mbps
5GHz, 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
2 on board radios (Dual Band Concurrent Radio)
Supply Voltage 12 V
Operating Temperature Range -20 to +70ºC
Storage Temperature Range -45 to +90 ºC
Operating Humidity Range 5 to +95 (non-condensing)%
Symbol Parameter
CPU Qualcomm-Atheros IPQ6000
CPU Frequency Quad-core ARM 64 bit A53 @1.2GHz processor
System Memory DDR3L 512MB 16-bit interface
Nand Flash 128MB
NOR Flash 16MB
Ethernet Port 2x 1Gbps Ethernet Ports
DC Jack Input 1x DC Jack Connector: 12V
Power Consumption(Board Only) 1TD
On Board Radio 2 radios (Dual band concurrent radio)
Wireless On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 20dBm per chain On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain 2x U.FL Connectors, diplexer allows dual band concurrent operation
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz 2.4GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 573Mbps 5GHz Data Rate 2x2 MU-MIMO OFDMA Technology, up to 1201Mbps
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM,1024QAM
LED 4x LED Indicators
USB /Header 1x MicroUSB 2.0 Port
Serial Port 1x Serial Interface 12 Pin Connectors
Certification TBD
Humidity Operating: 5% to 95% (non-condensing) Storage: Max. 90% (non-condensing)
Temperature Range
Operating: TBD Storage: -40ºC to 90ºC
Dimension (Diameter x Height) 100mm x 23.5mm (Without Heatsink)
3.DR9074E
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Data Rateup to 4949Mbps
■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Product Description
DR9074E based on QCN90X4 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO Dual Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
Our company:
Wallys Communications (SuZhou) Co.,Ltd https://www.wallystech.com/was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile :sales4@wallystech.com. This is Jane for you
