WiFi 6 Socs : Differences between QCN9074, QCN9024, QCN9072,QCN6024
QCN9074, QCN9024, QCN9072, and QCN6024 are all members of the Qualcomm Networking Pro series of system-on-chip (SoC) products. These SoCs are designed specifically for use in wireless access points, routers, gateways, and other networking devices.
Here are some of the differences between these four SoCs:
  1. QCN9074:
The QCN9074 is the most powerful SoC in the Qualcomm Networking Pro series. It is based on the quad-core ARM Cortex-A53 CPU and has a clock speed of up to 2.2 GHz. It supports 8x8 MU-MIMO (multi-user multiple-input, multiple-output) and 160 MHz channels, allowing it to deliver high-speed Wi-Fi connectivity to multiple devices simultaneously. The QCN9074 also includes a dedicated security engine, which provides hardware acceleration for encryption and decryption algorithms, improving the device’s overall security.
  1. QCN9024:
The QCN9024 is a mid-range SoC that is based on the quad-core ARM Cortex-A53 CPU, but with a slightly lower clock speed of up to 1.8 GHz. It supports 4x4 MU-MIMO and 80 MHz channels, making it suitable for use in smaller networking devices that don’t require the same level of performance as the QCN9074.
  1. QCN9072:
The QCN9072 is similar to the QCN9074 in terms of performance, but it has fewer features. It is also based on the quad-core ARM Cortex-A53 CPU with a clock speed of up to 2.2 GHz. However, it supports 4x4 MU-MIMO and 80 MHz channels, making it more suitable for use in mid-range networking devices.
  1. QCN6024:
The QCN6024 is the entry-level SoC in the Qualcomm Networking Pro series. It is based on the dual-core ARM Cortex-A53 CPU with a clock speed of up to 1.8 GHz. It supports 2x2 MU-MIMO and 40 MHz channels, making it suitable for use in small networking devices such as home routers or IoT gateways.
In summary, the QCN9074 is the most powerful and feature-rich SoC in the Qualcomm Networking Pro series, while the QCN9024, QCN9072, and QCN6024 are progressively less powerful and have fewer features. The choice of which SoC to use in a particular networking device will depend on the device’s intended use case and performance requirements.
Wallys QCN9074, QCN9024, QCN9072, and QCN6024 WiFi 6E Socs:
1.DR9074E
Link here get more information
[b][u]https://www.wallystech.com/Network_Card/DR9074E-Qualcomm-QCN9074-QCN9024-WiFi6-and-WiFi6E-4x4-MU-MIMO-Dual-Band-WiFi-Module-MiniPCIe.html[/u][/b]
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Data Rateup to 4949Mbps
■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Product Description
DR9074E based on QCN90X4 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO Dual Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074(QCN9024)
WLAN Host Interface PCI Express 3.0 Interface
System Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 3.3V
Operating Systems QSDK
Host Interface MiniPCIE
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALN
Maxim TX power 20dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Power Consumption 15W(Maximum),9.5W(Normally)
Dimensions (WxHxD) 30mm x 50mm x 14.5mm
2.DR9074-6E(PN02.7)
[b][u]https://www.wallystech.com/Network_Card/DR9074-6E-Wifi6E-Qualcomm-QCN9074-Single-Band-6GHz-4T4R-M-2-E-Key-Interface-802-11ax.html[/u][/b]
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
Hardware Specifications
Symbol Parameter
Standard Operating Voltage 5V
Host Interface M.2 E Key
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 6GHz
Certification TBD
Power Consumption TBD
Reference Design PN02.7
Dimensions (WxHxD) 57mm x 63mm x 6mm
3.DR9074-5G(PN02.1)
[b][u]https://www.wallystech.com/Network_Card/DR9074-5G-PN02.1-Wifi-6-Qualcomm-QCN9074-Single-Band-5-GHz-4T4R-M.2-E-Key-Interface-802.11ax.html[/u][/b]
Features
■ 5GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 5GHz 4x4 WiFi 6 (802.11ax)
■ Supports Dynamic Frequency Selection (DFS)
Symbol Parameter
Frequency Range 5.15GHz-5.95GHz
Data Rates for WALN 5GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 5GHz
Certification TBD
Reference Design PN02.1
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
