官方提供的debian11固件如何启用wayland显示
固件文件名称:AIO-3588Q_Debian11-r106b_v1.0.6c_230114
固件下载地址:AIO-3588Q_Debian11-r106b_v1.0.6c_230114.img
Log日志:3588Q_log.txt
我想更换系统debian11自带的xfce4桌面 换成gnome桌面 然后使用wayland来进行显示,但是安装完gnome桌面后,进入系统显示协议还是X11的,我应该怎么操作,才可以将系统的显示协议更换为wayland呢。这个更改主要是为了安装waydroid,waydroid需要wayland桌面环境。
我在登录界面点击齿轮图标,选择了非gnome的桌面环境,进去桌面后,还是X11的桌面环境,求助大佬们,这个需要怎么修改,才能使用wayland桌面环境。
3588Q_log.txt (124 KB)
目前的进展是Weston桌面已经是wayland环境,也可以正常使用waydroid,只是无法开启硬件加速。但是在gnome桌面下,选择wayland显示无法登录到桌面,会闪退,gnome桌面下登录X11显示环境没有问题,/var/log/messages显示错误信息如下:
May 23 13:26:01 firefly gnome-session[33326]: Unable to init server: Could not connect: Connection refused
May 23 13:26:01 firefly gnome-session-c[33326]: cannot open display: :0
May 23 13:26:01 firefly gnome-session[33280]: gnome-session-binary[33280]: WARNING: software acceleration check failed: Child process exited with code 1
May 23 13:26:01 firefly gnome-session[33331]: Unable to init server: Could not connect: Connection refused
May 23 13:26:01 firefly gnome-session-f[33331]: Cannot open display:
May 23 13:26:02 firefly gdm3: Gdm: GdmDisplay: Session never registered, failing
May 23 13:26:02 firefly gsd-rfkill[2172]: Could not disable kernel handling of RFKILL related keys: Inappropriate ioctl for device
May 23 13:26:02 firefly gnome-shell[1891]: Failed to set hardware cursor (drmModeSetCursor failed: No such device or address), using OpenGL from now on
May 23 13:26:02 firefly goa-daemon[33336]: goa-daemon version 3.38.0 starting
May 23 13:26:02 firefly kernel: [ 9362.338798] dwhdmi-rockchip fde80000.hdmi: use tmds mode
May 23 13:26:02 firefly kernel: [ 9362.392779] dwhdmi-rockchip fde80000.hdmi: use tmds mode
May 23 13:26:02 firefly org.gnome.Shell.desktop[33363]: The XKEYBOARD keymap compiler (xkbcomp) reports:
May 23 13:26:02 firefly org.gnome.Shell.desktop[33363]: > Warning:          Unsupported maximum keycode 569, clipping.
May 23 13:26:02 firefly org.gnome.Shell.desktop[33363]: >                   X11 cannot support keycodes above 255.
May 23 13:26:02 firefly org.gnome.Shell.desktop[33363]: Errors from xkbcomp are not fatal to the X server
有没有人清楚这个问题呢
