Introducing the Powerful Wireless Solution: IPQ8072/IPQ8072A&&QCN9074
In our fast-paced, interconnected world, reliable and high-speed wireless connectivity is essential. Today, we’re thrilled to share an exciting wireless solution that promises to take your connectivity experience to the next level: the IPQ8072/IPQ8072A chipset coupled with the QCN9074 module.
Unleashing the Power of IPQ8072/IPQ8072A
The IPQ8072 and IPQ8072A are advanced system-on-chips (SoCs) developed by Qualcomm Technologies, Inc., renowned for their expertise in wireless communication technologies. These chips are specifically designed for Wi-Fi 6 and Wi-Fi 6E, the latest wireless standards, delivering exceptional performance, increased capacity, and low latency.
The IPQ8072/IPQ8072A chips boast a powerful quad-core ARM Cortex-A53 processor, providing ample processing power to handle demanding networking tasks. With integrated hardware accelerators and advanced networking features, these chips can effortlessly handle high-speed data transfers, multiple device connections, and robust network management.
Accelerating Connectivity with QCN9074
Complementing the IPQ8072/IPQ8072A, the QCN9074 is an industry-leading Wi-Fi 6E module, developed to harness the full potential of the wireless solution. The QCN9074 leverages the 6 GHz frequency band, unlocked by Wi-Fi 6E, to provide expanded wireless capacity and reduced interference.
Equipped with the QCN9074 module, devices can achieve lightning-fast wireless speeds, enabling smooth 4K video streaming, lag-free gaming, and swift file transfers. Whether you’re at home, in the office, or in public spaces, the QCN9074 ensures a seamless wireless experience with excellent range and reliability.
Embracing Future-Proof Connectivity
The IPQ8072/IPQ8072A with QCN9074 is more than just a wireless solution for today—it’s a future-proof investment. With support for the latest wireless standards, these chips and modules ensure compatibility with upcoming technologies and a smooth transition into the era of Wi-Fi 7.
Moreover, the IPQ8072/IPQ8072A chipset offers advanced security features, including WPA3 encryption, protecting your wireless network and sensitive data from unauthorized access. With robust security measures in place, you can enjoy peace of mind while staying connected.
Powering Diverse Applications
The IPQ8072/IPQ8072A with QCN9074 is a versatile wireless solution that caters to various applications. From smart homes and connected devices to enterprise-level networking and industrial automation, this solution offers exceptional performance and scalability.
Whether you’re a tech enthusiast, a business owner, or an industry professional, the IPQ8072/IPQ8072A with QCN9074 will elevate your wireless experience, empowering you to unlock the full potential of your connected world.
The Future of Wireless is Here
With the IPQ8072/IPQ8072A chipset and QCN9074 module, Qualcomm Technologies sets a new standard for wireless connectivity. From faster speeds and increased capacity to advanced security and future-proof compatibility, this wireless solution has it all.
Are you ready to embrace the power of wireless connectivity? Stay tuned for the arrival of devices powered by the IPQ8072/IPQ8072A with QCN9074, and get ready to experience a whole new level of wireless performance.
Wallys IPQ8072/IPQ8072A with QCN9074 Wireless Solutions
1.DR8072A(HK09)
Website:
https://www.wallystech.com/Routerboard/DR8072A-HK09-wifi6-Qualcomm-IPQ8072A-4T4R-2-2.5GE-port-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
MiniPCIe Slot 1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash NOR Flash: 8 MB
NAND Flash: 256MB
Wireless On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain 8x U.FL Connectors
Reset Buttons 1x S/W Reset Button
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port 2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR8072V01
Website:
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
Features
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Symbol Parameter
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
NOR Flash: 8 MB
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
