SDK包名称:rk3588_linux_bsp_release_20230403_v1.0.6f
SDK修改内容:根据《Rockchip Developer Guide Dual Storage CN》进行修改
Log日志:session.log
RK3588Q从外挂的SSD引导系统
硬件:AIO-3588Q+Samsung SSD(nvme,1TB)
软件:buildroot (sdk 版本:v1.0.6f.)
按照文档《Rockchip Developer Guide Dual StorageCN》(Rockchip_Developer_Guide_Dual_Storage_CN.pdf)中的步骤,在uboot及kernel中进行dts设置如下:
1、 在内核中修改rk3588-firefly-aio-3588q.dtsi文件中的宏M2_SATA_OR_PCIE为0。
2、 在uboot中:
rk3588-u-boot.dtsi文件,
chosen{
stdout-path= &uart2;
//u-boot,spl-boot-order = &sdmmc, &sdhci, &spi_nand, &spi_nor;
u-boot,spl-boot-order= &sdhci, &spi_nand, &spi_nor;
在根节点上添加如下:
vcc12v_dcin:vcc12v_dcin {
u-boot,dm-pre-reloc;
compatible= "regulator-fixed";
regulator-name= "vcc12v_dcin";
regulator-always-on;
regulator-boot-on;
//status= "okay";
regulator-min-microvolt= <12000000>;
regulator-max-microvolt= <12000000>;
vcc_sata_pwr_en:vcc-sata-pwr-en-regulator {
regulator-name= "vcc_sata_pwr_en";
regulator-min-microvolt= <3300000>;
regulator-max-microvolt= <3300000>;
regulator-boot-on;
enable-active-high;
status= "okay";
gpio= <&pca9555 PCA_IO1_2 GPIO_ACTIVE_HIGH>;
startup-delay-us= <5000>;
vin-supply= <&vcc12v_dcin>;
并使能相应模块
&combphy0_ps {
status= "okay";
/* pca9555 */
&pca9555{
status= "okay";
&pcie2x1l2 {
reset-gpios= <&pca9555 PCA_IO1_6GPIO_ACTIVE_HIGH>;
vpcie3v3-supply= <&vcc_sata_pwr_en>;
status= "okay";
&i2c6 {
clock-frequency= <400000>;
status= "okay";
pinctrl-names= "default";
pinctrl-0= <&i2c6m0_xfer>;
pca9555_1:gpio@20 {
compatible = "nxp,pca9555";
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
gpio-group-num = <300>;
status = "okay";
pca9555:gpio@21 {
compatible= "nxp,pca9555";
reg= <0x21>;
gpio-controller;
#gpio-cells= <2>;
gpio-group-num= <200>;
status= "okay";
&pcfg_pull_none_smt {
u-boot,dm-spl;
bias-disable;
input-schmitt-enable;
在pinctrl节点中,添加:
i2c6{
u-boot,dm-spl;
i2c6m0_xfer:i2c6m0-xfer {
u-boot,dm-spl;
rockchip,pins=
/*i2c6_scl_m0 */
<0RK_PD0 9 &pcfg_pull_none_smt>,
/*i2c6_sda_m0 */
<0RK_PC7 9 &pcfg_pull_none_smt>;
修改firefly-linux.config文件:
CONFIG_OF_U_BOOT_REMOVE_PROPS=“clock-namesinterrupt-parent assigned-clocks assigned-clock-ratesassigned-clock-parents”
并添加如下内容:
CONFIG_CMD_I2C=y
CONFIG_CMD_PCI=y
CONFIG_NVME=y
CONFIG_PCI=y
CONFIG_DM_PCI=y
CONFIG_DM_PCI_COMPAT=y
CONFIG_PCIE_DW_ROCKCHIP=y
CONFIG_PHY_ROCKCHIP_NANENG_COMBOPHY=y
CONFIG_PHY_ROCKCHIP_SNPS_PCIE3=y
CONFIG_DM_REGULATOR_FIXED=y
CONFIG_ROCKCHIP_BOOTDEV=“nvme 0”
CONFIG_EMBED_KERNEL_DTB_ALWAYS=y
#CONFIG_EMBED_KERNEL_DTB_PATH=“dts/kern.dtb”
CONFIG_SPL_FIT_IMAGE_KB=2560
将编译内核时编译出来的dtb拷贝到u-boot/dts/kern.dtb中。
修改完成后,重新编译,可以在uboot中识别出ssd。信息如下:
=> pci scan
Scanning PCI devices on bus 0
BusDevFun VendorId DeviceId Device Class Sub-Class
00.00.00 0x1d87 0x3588 Bridge device 0x04
=> pci 1
Scanning PCI devices on bus 1
01.00.00 0x144d 0xa809 Mass storage controller 0x08
=> nvme scan
=> nvme details
Blk device 0: Optional Admin CommandSupport:
Namespace Management/Attachment: no
Firmware Commit/Image download: yes
Format NVM: yes
Security Send/Receive: yes
Blk device 0: Optional NVM Command Support:
Reservation: yes
Save/Select field in the Set/Get features: no
Write Zeroes: yes
Dataset Management: no
Write Uncorrectable: yes
Blk device 0: Format NVM Attributes:
Support Cryptographic Erase: yes
Support erase a particular namespace: Yes
Support format a particular namespace: No
Blk device 0: LBA Format Support:
Blk device 0: End-to-End DataProtectCapabilities:
As last eight bytes: No
As first eight bytes: No
Support Type3: No
Support Type2: No
Support Type1: No
Blk device 0: Metadata capabilities:
As part of a separate buffer: No
As part of an extended data LBA: No
Format NVM: yes
Reservation: yes
Write Zeroes: yes
Support Type3: No
Support Type2: No
Support Type1: No
=> nvme info
Device 0: Vendor: 0x144d Rev: 3B4QFXO7Prod: S649NL0W205605E
Type: Hard Disk
Capacity: 953869.7 MB = 931.5 GB (1953525168 x 512)
使用RKDevTool.exe(v2.96)烧录各个固件:
其中: parameter_emmc.txt文件的内容如下:
FIRMWARE_VER: 1.0
MACHINE_MODEL: RK3588
MACHINE_ID: 007
MANUFACTURER: RK3588
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 0xffffffff
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE: mtdparts=rk29xxnand:0x00004000@0x00004000(uboot)
parameter_nvme.txt文件的内容如下:
FIRMWARE_VER: 1.0
MACHINE_ID: 007
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: 0xffffffff
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE: mtdparts=rk29xxnand:0x00002000@0x00008000(misc),0x00080000@0x0000a000(boot:bootable),0x00040000@0x0008a000(recovery),0x00010000@0x000ca000(backup),0x00c00000@0x000da000(rootfs),-@0x0cda000(userdata:grow)
uuid:rootfs=614e0000-0000-4b53-8000-1d28000054a9
在进行分区配置时,会如下错误。
点击“执行”按钮后,软件会报错:”xxx” did not find matchpartition(xxx分别为:misc、boot、recovery、backup、rootfs、userdata)
不理会错误,重新进入maskrom模式后,选择“强制按地址写”,从软件的日志上看,似乎可以正确烧录。
烧录完成后,自动重启,串口打印如下信息:
done
Saving random seed: OK
realpath: /dev/block/by-name: No such fileor directory
Will now mount all partitions in /etc/fstab
strings: : No such file or directory
Note: Will skip fsck, remove /.skip_fsck toenable
Log saved to /tmp/mountall.log
Starting network: cmdline=storagemedia=nvmeandroidboot.storagemedia=nvme androidboot.mode=normal storagenode=/pcie@fe190000androidboot.verifiedbootstate=orange ro rootwaitearlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1
read console from cmdline is /dev/ttyFIQ0
Starting recovery on Thu May 18 09:00:192023
Recovery System have UI defined.
failed to read font: res=-1, fall back tothe compiled-in font
OK
Debug: configfs_init
rotate degree: 0 - none, 1 - right, 2 -down, 3 - left.
current rotate degree is : 0
mkdir: can’t create directory’/sys/kernel/config/usb_gadget/rockchip/functions/uac1.gs0’: No such file ordirectory
mkdir: can’t create directory’/sys/kernel/config/usb_gadget/rockchip/functions/uac2.gs0’: No such file ordirectory
[ 7.857208] file system registered
mkdir: can’t create directory’/sys/kernel/config/usb_gadget/rockchip/functions/mtp.gs0’: No such file ordirectory
[ 7.864041] using random self ethernet address
[ 7.864085] using random host ethernet address
[ 7.868268] Mass Storage Function, version: 2009/09/11
[ 7.868334] LUN: removable file: (no medium)
mkdir: can’t create directory’/sys/kernel/config/usb_gadget/rockchip/functions/hid.usb0’: No such file ordirectory
[ 7.898766] read descriptors
[ 7.898825] read strings
[ 8.158843] rk_hdmirx fdee0000.hdmirx-controller:hdmirx_cancel_cpu_limit_freq freq qos nod add
[ 8.171203] rk-pcie fe150000.pcie: PCIe Link Fail
[ 8.171217] rk-pcie fe150000.pcie: failed to initialize host
Starting input-event-daemon:input-event-daemon: Start parsing /etc/input-event-daemon.conf…
input-event-daemon: Adding device:/dev/input/event0…
input-event-daemon: Adding device:/dev/input/event1…
input-event-daemon: Adding device:/dev/input/event2…
input-event-daemon: Adding device:/dev/input/event3…
input-event-daemon: Adding device:/dev/input/event4…
input-event-daemon: Start listening on 5devices…
done
[root@RK3588:/]# [ 9.106625] dwc3 fc000000.usb: device reset
[ 9.231491] android_work: sent uevent USB_STATE=CONNECTED
[ 9.410018] dwc3 fc000000.usb: device reset
recovery filesystem table
0(null) /tmp ramdisk (null) (null) (null)
1/dev/root / ext4 rw,noauto 0 1
2proc /proc proc defaults 0 0
3devpts /dev/pts devpts defaults,gid=5,mode=620 0 0
4tmpfs /dev/shm tmpfs mode=0777 0 0
5tmpfs /tmp tmpfs mode=1777 0 0
6tmpfs /run tmpfs mode=0755,nosuid,nodev 0 0
7sysfs /sys sysfs defaults 0 0
8/dev/block/by-name/misc /misc emmc defaults 0 0
9/dev/block/by-name/userdata /userdata ext4 defaults 0 0
10/dev/block/by-name/oem /oem ext2 defaults 0 0
11/dev/sda1 /mnt/usb_storage vfat defaults 0 0
12/dev/mmcblk1p1 /mnt/external_sd vfat defaults 0 0
13/dev/block/by-name/oem /oem ext2 defaults 0 2
14/dev/block/by-name/userdata /userdata ext4 defaults 0 2
executing ‘/usr/bin/relink-block.sh’
executed ‘/usr/bin/relink-block.sh’ done
executed ‘/usr/bin/relink-block.sh’ return0
stat /dev/block/by-name/misc try 1: No suchfile or directory
[ 9.494680] usb 4-1: new SuperSpeed Gen 1 USB device number 2 usingxhci-hcd
[ 9.519634] usb 4-1: New USB device found, idVendor=05e3, idProduct=0620,bcdDevice=93.91
[ 9.519701] usb 4-1: New USB device strings: Mfr=1, Product=2,SerialNumber=0
[ 9.519716] usb 4-1: Product: USB3.2 Hub
[ 9.519729] usb 4-1: Manufacturer: GenesysLogic
[ 9.548335] hub 4-1:1.0: USB hub found
[ 9.548757] hub 4-1:1.0: 4 ports detected
[ 9.574729] android_work: sent uevent USB_STATE=CONFIGURED
[ 9.638183] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 9.781305] usb 3-1: New USB device found, idVendor=05e3, idProduct=0610,bcdDevice=93.91
[ 9.781352] usb 3-1: New USB device strings: Mfr=1, Product=2,SerialNumber=0
[ 9.781365] usb 3-1: Product: USB2.1 Hub
[ 9.781376] usb 3-1: Manufacturer: GenesysLogic
[ 9.836774] hub 3-1:1.0: USB hub found
[ 9.837194] hub 3-1:1.0: 4 ports detected
stat /dev/block/by-name/misc try 2: No suchfile or directory
stat /dev/block/by-name/misc try 3: No suchfile or directory
stat /dev/block/by-name/misc try 4: No suchfile or directory
stat /dev/block/by-name/misc try 5: No suchfile or directory
stat /dev/block/by-name/misc try 6: No suchfile or directory
stat /dev/block/by-name/misc try 7: No suchfile or directory
stat /dev/block/by-name/misc try 8: No suchfile or directory
stat /dev/block/by-name/misc try 9: No suchfile or directory
stat /dev/block/by-name/misc try 10: Nosuch file or directory
failed to stat /dev/block/by-name/misc
emmc_point is /dev/mmcblk0
sd_point is (null)
sd_point_2 is (null)
Recovery start…
read cmdline
Boot from non-SDcard
[I/]RECOVERY devices is not MTD.
[E/]RECOVERY Can’t open/dev/block/by-name/misc
(No such file or directory)
[E/]RECOVERY failed to mount /userdata (Nosuch file or directory)
[E/]RECOVERY Can’t mount/userdata/recovery/command
Command: “/usr/bin/recovery”
finish_recovery Enter…
[E/]RECOVERY Can’t mount/userdata/recovery/log
[E/]RECOVERY Can’t open/userdata/recovery/log
[E/]RECOVERY Can’t mount/userdata/recovery/last_log
[E/]RECOVERY Can’t open/userdata/recovery/last_log
[W/]RECOVERY Can’t unlink/userdata/recovery/command
发现没有进入weston桌面,也没有发现其他分区:
[root@RK3588:/]#
[root@RK3588:/]# ls /dev/block/
179:0 179:64 253:0 7:0 7:2 7:4 7:6 by-name
179:32 1:0 259:0 7:1 7:3 7:5 7:7
[root@RK3588:/]# ls /dev/block/by-name/
misc
[root@RK3588:/]# ls /dev/nvme0
nvme0 nvme0n1
[root@RK3588:/]# ls /dev/nvme*
/dev/nvme0 /dev/nvme0n1
[root@RK3588:/]#
除了uboot.img外,其他同样的镜像文件,烧录到emmc上,使用emmc启动引导,可以正常进入weston桌面。
不知道是什么原因。开机启动日志见附件
session.log (91.2 KB)
