Introducing the Powerful WiFi6 Socs Famliy
If you’re seeking lightning-fast, reliable, and high-performance wireless connectivity, look no further than the impressive lineup of WiFi 6 solutions. Today, we’ll delve into some remarkable options that promise to revolutionize your internet experience. Let’s explore the features and capabilities of these cutting-edge chips: IPQ6010, IPQ6018, IPQ5018, IPQ8072A, IPQ8074A, IPQ4019, and IPQ4018.
1 IPQ6010: This robust WiFi 6 chip offers enhanced performance and efficiency. With support for multi-gigabit speeds, it ensures faster downloads, smoother streaming, and lag-free gaming. It boasts an advanced architecture that optimizes network capacity and minimizes interference, providing a seamless wireless experience.
2 IPQ6018: Designed to meet the demands of high-performance applications, the IPQ6018 chip is a powerhouse in the WiFi 6 realm. It combines impressive speeds, advanced security features, and intelligent traffic management to deliver unparalleled connectivity. Whether you’re running a smart home, office network, or a crowded public space, this chip has you covered.
3 IPQ5018: With a focus on affordability and efficiency, the IPQ5018 chip brings WiFi 6 capabilities to a wider range of devices. It provides reliable and fast wireless connectivity without compromising on performance. From smart TVs and IoT devices to smartphones and laptops, the IPQ5018 enables seamless connectivity for all your gadgets.
4 IPQ8072A: If you’re looking for enterprise-grade networking, the IPQ8072A chip is an excellent choice. It supports multi-gigabit speeds, advanced security protocols, and robust traffic management features. Whether it’s a large office, university campus, or any other high-density environment, this chip ensures reliable and secure connectivity for a vast number of users.
5 IPQ8074A: Taking WiFi 6 to the next level, the IPQ8074A chip is a beast in terms of performance and capacity. With its advanced features like MU-MIMO, OFDMA, and 1024-QAM, it can handle the most demanding networking scenarios effortlessly. It’s an ideal solution for gaming, 4K streaming, and data-intensive applications that require ultra-low latency.
6 IPQ4019: Compact yet powerful, the IPQ4019 chip is designed for small to medium-sized networks. It offers excellent range, efficient power consumption, and reliable connectivity. From home routers and mesh systems to small office setups, the IPQ4019 chip ensures a stable and seamless WiFi experience for all connected devices.
7 IPQ4018: Similar to the IPQ4019, the IPQ4018 chip is optimized for compact devices that require WiFi 6 capabilities. It strikes a balance between performance and power efficiency, making it an ideal choice for smart home devices, IoT sensors, and other low-power applications.
These WiFi 6 solutions, including the IPQ6010, IPQ6018, IPQ5018, IPQ8072A, IPQ8074A, IPQ4019, and IPQ4018, represent the pinnacle of wireless connectivity. They provide faster speeds, reduced latency, improved capacity, and enhanced security features. Whether you’re a tech enthusiast, a business professional, or a home user, upgrading to WiFi 6 will undoubtedly elevate your internet experience.
Say goodbye to buffering, connectivity hiccups, and slow downloads. Embrace the future of wireless technology with these incredible WiFi 6 solutions!
Wallys supports IPQ6010 IPQ6018 IPQ5018 IPQ8072A IPQ8074A IPQ4019 IPQ4018 All Solutions
DR6018 V4
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Ratin
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter
CPU Qualcomm-Atheros IPQ6010
CPU Frequency
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE3 x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0
SD Card Slot
1x SD Card Slot
USB /header
1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
4 x MMCX Connectors
Bluetooth CSR8811 BLE 4.2
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension 185mm x 116mm
Radio TX Specifications(5180MHz-5825MHz)
DR6018-S V01
[b][u]https://www.wallystech.com/Routerboard/DR6018CV01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA-SFP.html[/u][/b]
8MB NOR Flash, 256MB NAND Flash
Absolute Maximum Rating
Paramete Rating Unit
Supply Voltage 24V~48V(DC Jack) V
Symbol Parameter
CPU Frequency Quad-core ARM 64 bit A53 @1.8 GHz processor
Ethernet Port 1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot 1x SD Card Slot(Option)
USB /header 1x USB 3.0 Port(Option)
DC Jack 24V~48V power supply
LED header 2.0 pitch pin header
Wireless
4 x MMCX Connectors
Nor Flash 8MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension
125mm x 105mm x 20mmOperating Humidity Range 5 to +95 (non-condensing) %
DR6018(CP01)
[u]https://www.wallystech.com/Routerboard/DR6018-CP01-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-CP01-802-11AX-MU-MIMO-OFDMA.html[/u]
Operating Humidity Range 5 to +95 (non-condensing %
Symbol Parameter
CPU Qualcomm-Atheros IPQ6018
CPU Frequency
Ethernet Port 5x 1Gbps Ethernet Ports , 1x 2.5Gbps Ethernet Port
USB /header 1x USB 2.0 Port, 1x USB 3.0 Type-C Port
DC Jack 12V power supply
Serial Port 1x Serial Port 12 Pin Connector
Wireless
4x U.FL Connectors
Nor Flash 32MB
Nand Flash 256MB
DDR 256MB~512MB
Dimension (W x H x D) 219mm x 150mm x 16.5mm (Without Heatsink)
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile :sales4@wallystech.com.
