设备树文件rk3588-firefly-aio-3588q.dtsi中那个是网口配置呢?
固件文件名称:官方自带
固件下载地址:官方自带
Log日志:log.txt
rt,求教
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
  • Copyright (c) 2021 Rockchip Electronics Co., Ltd.
#define rk3588
#include “rk3588-firefly-port.dtsi”
#include “rk3588-diff.dtsi”
#define M2_SATA_OR_PCIE 1 /*1 = SATA , 0 = PCIe */
chosen: chosen {
bootargs = “earlycon=uart8250,mmio32,0xfeb50000 console=ttyFIQ0 irqchip.gicv3_pseudo_nmi=0 root=PARTLABEL=rootfs rootfstype=ext4 ro rootwait overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1”;
fan: pwm-fan {
compatible = “pwm-fan”;
#cooling-cells = <2>;
fan-supply = <&vcc12v_dcin>;
pwms = <&pwm15 0 50000 0>;
cooling-levels = <0 85/1/ 95 105 115 125 135 145 155/8/ 165 175 185 195 205 215 225 235 245 255/18/>;
/* recovery key*/
&adc_keys{
keyup-threshold-microvolt = <550000>;
status=“okay”;
/* led */
&power_led{
gpios = <&gpio3 RK_PB2 GPIO_ACTIVE_HIGH>;
pinctrl-names = “default”;
pinctrl-0 = <&led_power>;
&user_led{
gpios = <&pca9555 PCA_IO0_3 GPIO_ACTIVE_HIGH>;
&center_thermal {
thermal-governor = “step_wise”;
polling-delay-passive = <20>; /* milliseconds /
polling-delay = <1000>; /
milliseconds */
//thermal-sensors = <&tsadc 0>;
trips {
	fan_alert0: trip-point-0 {
		temperature = <30000>;
		hysteresis = <2000>;
		type = "active";
	fan_alert1: trip-point-1 {
		temperature = <50000>;
		type = "active";
	fan_alert2: trip-point-2 {
		temperature = <65000>;
		type = "active";
	fan_alert3: trip-point-3 {
		temperature = <75000>;
		type = "active";
cooling-maps {
	map0 {
	   trip = <&fan_alert0>;
	   cooling-device = <&fan THERMAL_NO_LIMIT 1>;
	   contribution = <1024>;
	map1 {
		trip = <&fan_alert1>;
		cooling-device = <&fan 1 8>;
	map2 {
		trip = <&fan_alert2>;
		cooling-device = <&fan 1 18>;
	map3 {
		trip = <&fan_alert3>;
		cooling-device = <&fan 18 THERMAL_NO_LIMIT>;
&pwm15 {
pinctrl-0 = <&pwm15m2_pins>;
status = “okay”;
/* tf-card */
&sdmmc {
status = “okay”;
&vcc_sdcard_pwr_en{
gpio = <&pca9555 PCA_IO1_5 GPIO_ACTIVE_HIGH>; //PCA_IO 15
status = “okay”;
/* can1 */
&can1 {
status = “okay”;
assigned-clocks = <&cru CLK_CAN1>;
assigned-clock-rates = <200000000>;
pinctrl-0 = <&can1m1_pins>;
/* es8323 audio codec */
&i2c3 {
status = “okay”;
&es8388_sound{
firefly,not-use-dapm;
/delete-property/ spk-con-gpio;
io-channels = <&saradc 1>;
linein-type = <4>;
status = “okay”;
&es8388{
status = “okay”;
&i2s0_8ch{
status = “okay”;
/* hdmi rx */
&hdmiin_sound{
status = “okay”;
&hdmirx_ctrler {
status = “okay”;
hpd-trigger-level = <1>;
hdmirx-det-gpios = <&gpio1 RK_PD5 GPIO_ACTIVE_LOW>;
/* hdmi0 */
&hdmi0 {
enable-gpios = <&gpio4 RK_PA0 GPIO_ACTIVE_HIGH>;
status = “okay”;
&hdmi0_in_vp0 {
status = “okay”;
&hdmi0_sound {
status = “okay”;
&hdptxphy_hdmi0 {
status = “okay”;
&route_hdmi0{
status = “okay”;
/ap6275 : bluetooth/
&wireless_bluetooth{
status = “okay”;
&uart6 {
pinctrl-0 = <&uart6m1_xfer &uart6m1_ctsn>;
status = “okay”;
/* ap6275 : wifi */
&wireless_wlan{
wifi_chip_type = “ap6275p”;
status = “okay”;
&combphy1_ps {
status = “okay”;
&pcie2x1l0 {
reset-gpios = <&gpio1 RK_PB4 GPIO_ACTIVE_HIGH>;
rockchip,skip-scan-in-resume;
status = “okay”;
/* RS232_0 */
&uart0{
pinctrl-0 = <&uart0m2_xfer>;
status = “okay”;
/* RS232_1 */
&uart5{
pinctrl-0 = <&uart5m1_xfer>;
status = “okay”;
/* RS485 */
&uart1{
pinctrl-0 = <&uart1m1_xfer>;
status = “okay”;
/* spi1 */
&spi1 {
status = “okay”;
pinctrl-0 = <&spi1m2_cs0 &spi1m2_pins>;
num-cs = <1>;
max-freq = <50000000>;
spidev1: spidev@0{
compatible = “rockchip,spidev”;
status = “okay”;
reg = <0x0>;
spi-max-frequency = <50000000>;
/* gamc0 */
&gmac0 {
snps,reset-gpio = <&gpio3 RK_PC7 GPIO_ACTIVE_LOW>;
tx_delay = <0x47>;
status = “okay”;
&gmac0_tx_bus2{
rockchip,pins =
/* gmac0_txd0 /
<2 RK_PB6 1 &pcfg_pull_up_drv_level_6>,
gmac0_txd1 /
<2 RK_PB7 1 &pcfg_pull_up_drv_level_6>,
gmac0_txen */
<2 RK_PC0 1 &pcfg_pull_none>;
&gmac0_rgmii_bus{
rockchip,pins =
/* gmac0_rxd2 /
<2 RK_PA6 1 &pcfg_pull_none>,
gmac0_rxd3 /
<2 RK_PA7 1 &pcfg_pull_none>,
gmac0_txd2 /
<2 RK_PB1 1 &pcfg_pull_up_drv_level_6>,
gmac0_txd3 */
<2 RK_PB2 1 &pcfg_pull_up_drv_level_6>;
/* gmac1 */
&gmac1 {
snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
tx_delay = <0x4f>;
status = “okay”;
&gmac1_tx_bus2{
rockchip,pins =
/* gmac1_txd0 /
<3 RK_PB3 1 &pcfg_pull_up_drv_level_6>,
gmac1_txd1 /
<3 RK_PB4 1 &pcfg_pull_up_drv_level_6>,
gmac1_txen */
<3 RK_PB5 1 &pcfg_pull_none>;
&gmac1_rgmii_bus{
rockchip,pins =
/* gmac1_rxd2 /
<3 RK_PA2 1 &pcfg_pull_none>,
gmac1_rxd3 /
<3 RK_PA3 1 &pcfg_pull_none>,
gmac1_txd2 /
<3 RK_PA0 1 &pcfg_pull_up_drv_level_6>,
gmac1_txd3 */
<3 RK_PA1 1 &pcfg_pull_up_drv_level_6>;
/* pcie3.0 x 4 slot */
&pcie30phy {
status = “okay”;
&pcie3x4 {
reset-gpios = <&gpio4 RK_PB6 GPIO_ACTIVE_HIGH>;
vpcie3v3-supply = <&vcc3v3_pcie30>;
status = “okay”;
&vcc3v3_pcie30{
gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>;
startup-delay-us = <5000>;
status = “okay”;
/* sata pm */
&combphy0_ps {
status = “okay”;
#if M2_SATA_OR_PCIE
&sata0 {
//pinctrl-names = “default”;
//pinctrl-0 = <&sata_reset>;
status = “okay”;
#else
&pcie2x1l2 {
reset-gpios = <&pca9555 PCA_IO1_6 GPIO_ACTIVE_HIGH>;
vpcie3v3-supply = <&vcc_sata_pwr_en>;
status = “okay”;
#endif
&vcc_sata_pwr_en{
status = “okay”;
gpio = <&pca9555 PCA_IO1_2 GPIO_ACTIVE_HIGH>; //PCA_IO 12
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-always-on;
enable-active-high;
vin-supply = <&vcc12v_dcin>;
/* usb power */
&vcc5v0_host{
gpio = <&pca9555 PCA_IO0_5 GPIO_ACTIVE_HIGH>;
vin-supply = <&vcc5v0_usb>;
status = “okay”;
&vcc_hub_reset{
status = “okay”;
gpio = <&pca9555 PCA_IO0_4 GPIO_ACTIVE_HIGH>; //PCA_IO 04
&vcc_hub3_reset{
status = “okay”;
compatible = “regulator-fixed-firefly”;
regulator-name = “vcc_hub3_reset”;
enable-active-high;
regulator-fixed-kernel-reset-ms = <3000>;
gpio = <&pca9555 PCA_IO0_6 GPIO_ACTIVE_HIGH>; //PCA_IO 06
&vcc5v0_host3{
gpio = <&pca9555 PCA_IO0_7 GPIO_ACTIVE_HIGH>; //PCA_IO 07
status = “okay”;
&i2c0 {
status = “okay”;
pc9202@3c {
    status = "okay";
    compatible = "firefly,pc9202";
    reg = <0x3c>;
	//pinctrl-names = "default";
	//pinctrl-0 = <&pc9202_en_pin>;
    //wd-en-gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
/* i2c6 */
&i2c6 {
clock-frequency = <400000>; // For others Display Port Screen
status = “okay”;
pca9555_1: gpio@20 {
    compatible = "nxp,pca9555";
    reg = <0x20>;
    gpio-controller;
    #gpio-cells = <2>;
    gpio-group-num = <300>;
    status = "okay";
/* pca9555 */
&pca9555{
status = “okay”;
/* rtc */
&hym8563{
interrupt-parent = <&gpio0>;
interrupts = <RK_PB0 IRQ_TYPE_LEVEL_LOW>;
status = “okay”;
/* display port0 */
&spdif_tx2{
status = “okay”;
&dp0_sound{
status = “okay”;
&dp0 {
status = “okay”;
&dp0_in_vp2 {
status = “okay”;
&usbc0{
status = “okay”;
interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>;
&vbus5v0_typec_pwr_en{
status = “okay”;
gpio = <&pca9555 PCA_IO1_4 GPIO_ACTIVE_HIGH>; //PCA_IO 14
&usbdp_phy0 {
sbu1-dc-gpios = <&pca9555 PCA_IO1_0 GPIO_ACTIVE_HIGH>;
sbu2-dc-gpios = <&pca9555 PCA_IO1_1 GPIO_ACTIVE_HIGH>;
/* display port1 to vga */
&dp1_in_vp2 {
status = “okay”;
&dp1 {
pinctrl-0 = <&dp1_hpd>;
hpd-gpios = <&gpio1 RK_PA4 GPIO_ACTIVE_HIGH>;
status = “okay”;
&route_dp1{
status = “okay”;
connect = <&vp2_out_dp1>;
/usb3.1 host2 controller for 5G module/
&usbhost3_0 {
status = “okay”;
&usbhost_dwc3_0 {
dr_mode = “host”;
status = “okay”;
&combphy2_psu {
status = “okay”; // USB3.1/SATA/PCIe Combo PHY
/* pinctrl */
&pinctrl {
dp {
	dp1_hpd: dp1-hpd {
		 rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
leds {
	led_power: led-power {
		rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
hdmirx {
	hdmirx_det: hdmirx-det {
		rockchip,pins = <1 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>;
headphone {
	hp_det: hp-det {
		rockchip,pins = <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_none>;
hym8563 {
	hym8563_int: hym8563-int {
		rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
lcd {
	lcd_rst_gpio: lcd-rst-gpio {
		rockchip,pins = <2 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
touch {
	touch_gpio: touch-gpio {
		rockchip,pins =
			<0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>,
			<0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
usb-typec {
	usbc0_int: usbc0-int {
		rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>;
wireless-bluetooth {
	uart6_gpios: uart6-gpios {
		rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
	bt_reset_gpio: bt-reset-gpio {
		rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
	bt_wake_gpio: bt-wake-gpio {
		rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
	bt_irq_gpio: bt-irq-gpio {
		rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_down>;
wireless-wlan {
	wifi_host_wake_irq: wifi-host-wake-irq {
		rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down>;
	wifi_poweren_gpio: wifi-poweren-gpio {
		rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up>;
rk3588-firefly-aio-3588q.dtsi (9.74 KB)
log.txt (132 KB)
gmac0与gmac1节点
