rk3566刷ubuntu卡在logo界面,求大神看看什么问题
固件文件名称:ROC-RK3566-PC_Ubuntu20.04-r240_v1.3.2b_230331
Log日志:20230522.txt
更新完重启卡在firefly的logo界面
[21:58:16.910]收←◆SoftReset, 4873410 us
[21:58:16.942]收←◆DDR V1.15 ec2fae0c96 huan.he 22/11/08-20:06:42
ln
ddrconfig:7
LPDDR4X, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB
tdqss: cs0 dqs0: 72ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps,
tdqss: cs1 dqs0: 72ps, dqs1: -96ps, dqs2: -48ps, dqs3: -144ps,
change to: 324MHz
PHY drv:clk:36,ca:36,DQ:29,odt:0
vrefinner:24%, vrefout:41%
dram drv:40,odt:0
clk skew:0x61
change to: 528MHz
dram drv:40,odt:0
clk skew:0x58
change to: 780MHz
dram drv:40,odt:0
clk skew:0x58
change to: 1056MHz(final freq)
vrefinner:16%, vrefout:22%
dram drv:40,odt:80
vref_ca:00000071
clk skew:0x39
cs 0:
the read training result:
DQS0:0x3d, DQS1:0x3d, DQS2:0x40, DQS3:0x3b,
min : 0xe 0xd 0xe 0xe 0x2 0x2 0x6 0x4 , 0xb 0x8 0x6 0x2 0xd 0xc 0x10 0xc ,
0x11 0x11 0xe 0xd 0x6 0x2 0x3 0x5 , 0xb 0x6 0x6 0x1 0xe 0xd 0xa 0xe ,
mid :0x2c 0x2c 0x2e 0x2c 0x20 0x21 0x24 0x22 ,0x27 0x28 0x24 0x22 0x2a 0x2b 0x2e 0x2a ,
0x2f 0x2e 0x2b 0x29 0x24 0x20 0x22 0x23 ,0x2a 0x26 0x25 0x20 0x2d 0x2c 0x2a 0x2c ,
max :0x4b 0x4b 0x4e 0x4a 0x3f 0x40 0x42 0x40 ,0x43 0x48 0x42 0x42 0x48 0x4a 0x4c 0x48 ,
0x4e 0x4c 0x48 0x46 0x42 0x3f 0x41 0x42 ,0x49 0x46 0x44 0x3f 0x4c 0x4b 0x4b 0x4b ,
range:0x3d 0x3e 0x40 0x3c 0x3d 0x3e 0x3c 0x3c ,0x38 0x40 0x3c 0x40 0x3b 0x3e 0x3c 0x3c ,
0x3d 0x3b 0x3a 0x39 0x3c 0x3d 0x3e 0x3d ,0x3e 0x40 0x3e 0x3e 0x3e 0x3e 0x41 0x3d ,
the write training result:
DQS0:0x42, DQS1:0x2d, DQS2:0x33, DQS3:0x26,
min :0x68 0x6b 0x6c 0x6b 0x5d 0x60 0x64 0x67 0x65 ,0x4f 0x50 0x4b 0x4b 0x55 0x55 0x57 0x56 0x50 ,
0x59 0x59 0x56 0x55 0x50 0x4e 0x50 0x53 0x56 ,0x4e 0x4c 0x4b 0x47 0x51 0x50 0x4f 0x54 0x4c ,
mid :0x83 0x86 0x87 0x85 0x76 0x7a 0x7d 0x7e 0x7d ,0x6b 0x6a 0x66 0x64 0x6d 0x6c 0x6e 0x6d 0x6a ,
0x76 0x75 0x71 0x6f 0x69 0x61 0x65 0x6b 0x6e ,0x69 0x63 0x61 0x5e 0x6a 0x6a 0x65 0x6d 0x63 ,
max :0x9f 0xa1 0xa2 0xa0 0x8f 0x94 0x97 0x96 0x95 ,0x87 0x85 0x81 0x7e 0x86 0x83 0x85 0x85 0x85 ,
0x93 0x91 0x8c 0x8a 0x83 0x75 0x7b 0x84 0x87 ,0x85 0x7b 0x78 0x75 0x84 0x85 0x7b 0x87 0x7a ,
range:0x37 0x36 0x36 0x35 0x32 0x34 0x33 0x2f 0x30 ,0x38 0x35 0x36 0x33 0x31 0x2e 0x2e 0x2f 0x35 ,
0x3a 0x38 0x36 0x35 0x33 0x27 0x2b 0x31 0x31 ,0x37 0x2f 0x2d 0x2e 0x33 0x35 0x2c 0x33 0x2e ,
cs 1:
DQS0:0x3b, DQS1:0x3c, DQS2:0x40, DQS3:0x39,
min : 0xb 0xc 0xd 0xc 0x1 0x2 0x4 0x2 , 0x8 0x6 0x4 0x1 0xc 0x9 0xe 0xa ,
0x11 0x11 0xe 0xd 0x6 0x2 0x3 0x5 , 0xa 0x6 0x6 0x1 0xe 0xb 0x9 0xd ,
mid :0x29 0x2a 0x2c 0x29 0x1e 0x20 0x21 0x20 ,0x25 0x26 0x22 0x20 0x2a 0x28 0x2c 0x28 ,
0x2f 0x2e 0x2b 0x29 0x24 0x20 0x21 0x23 ,0x28 0x24 0x24 0x1f 0x2c 0x2a 0x29 0x2b ,
max :0x48 0x48 0x4b 0x46 0x3c 0x3f 0x3f 0x3e ,0x42 0x46 0x41 0x40 0x48 0x47 0x4a 0x47 ,
0x4d 0x4c 0x48 0x45 0x42 0x3f 0x40 0x42 ,0x46 0x43 0x42 0x3e 0x4a 0x49 0x49 0x4a ,
range:0x3d 0x3c 0x3e 0x3a 0x3b 0x3d 0x3b 0x3c ,0x3a 0x40 0x3d 0x3f 0x3c 0x3e 0x3c 0x3d ,
0x3c 0x3b 0x3a 0x38 0x3c 0x3d 0x3d 0x3d ,0x3c 0x3d 0x3c 0x3d 0x3c 0x3e 0x40 0x3d ,
min :0x69 0x6b 0x6c 0x6b 0x5f 0x61 0x66 0x69 0x65 ,0x4f 0x4f 0x4a 0x4a 0x53 0x52 0x56 0x55 0x4f ,
0x5a 0x59 0x56 0x56 0x51 0x4e 0x50 0x54 0x56 ,0x4d 0x4b 0x4a 0x45 0x4f 0x50 0x4e 0x52 0x4b ,
mid :0x84 0x86 0x88 0x85 0x77 0x7b 0x7e 0x7f 0x7d ,0x6b 0x69 0x62 0x63 0x6b 0x6a 0x6d 0x6d 0x66 ,
0x76 0x75 0x71 0x70 0x69 0x61 0x66 0x6c 0x6f ,0x68 0x61 0x60 0x5b 0x68 0x6a 0x65 0x6c 0x61 ,
max :0xa0 0xa1 0xa4 0x9f 0x8f 0x95 0x97 0x96 0x95 ,0x87 0x84 0x7b 0x7d 0x84 0x83 0x85 0x85 0x7e ,
0x93 0x92 0x8c 0x8a 0x81 0x75 0x7d 0x85 0x88 ,0x84 0x78 0x76 0x72 0x81 0x85 0x7c 0x87 0x77 ,
range:0x37 0x36 0x38 0x34 0x30 0x34 0x31 0x2d 0x30 ,0x38 0x35 0x31 0x33 0x31 0x31 0x2f 0x30 0x2f ,
0x39 0x39 0x36 0x34 0x30 0x27 0x2d 0x31 0x32 ,0x37 0x2d 0x2c 0x2d 0x32 0x35 0x2e 0x35 0x2c ,
CA Training result:
cs:0 min :0x50 0x52 0x46 0x46 0x48 0x45 0x4d ,0x4c 0x4c 0x45 0x46 0x46 0x43 0x4b ,
cs:0 mid :0x8f 0x90 0x85 0x85 0x85 0x83 0x7e ,0x8b 0x8b 0x84 0x83 0x84 0x81 0x7a ,
cs:0 max :0xcf 0xcf 0xc4 0xc5 0xc3 0xc1 0xaf ,0xca 0xca 0xc3 0xc1 0xc2 0xbf 0xaa ,
cs:0 range:0x7f 0x7d 0x7e 0x7f 0x7b 0x7c 0x62 ,0x7e 0x7e 0x7e 0x7b 0x7c 0x7c 0x5f ,
cs:1 min :0x4d 0x56 0x42 0x4b 0x42 0x49 0x49 ,0x48 0x4e 0x43 0x49 0x42 0x45 0x49 ,
cs:1 mid :0x8f 0x91 0x84 0x84 0x84 0x82 0x7c ,0x8a 0x8a 0x85 0x84 0x84 0x81 0x7b ,
cs:1 max :0xd1 0xcd 0xc7 0xbe 0xc6 0xbc 0xaf ,0xcd 0xc6 0xc8 0xc0 0xc7 0xbd 0xad ,
cs:1 range:0x84 0x77 0x85 0x73 0x84 0x73 0x66 ,0x85 0x78 0x85 0x77 0x85 0x78 0x64 ,
out
U-Boot SPL board init
[21:58:17.069]收←◆
U-Boot SPL 2017.09(u-boot commit id: 0f621b0e434b6944de865b517687e096930885b9)(sdk version: rk356x_linux_release_20230330_v1.3.2b.xml)-g0f621b0e43 #llq (Mar 31 2023 - 12:07:48)
Trying to boot from MMC2
mmc_init: -95, time 9
Trying to boot from MMC1
[21:58:17.164]收←◆Magic is incorrect.
Error validating A/B metadata from disk. Resetting and writing new A/B metadata to disk.
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(df3dd620f7…) + OK
## Checking uboot 0x00a00000 … sha256(765d3da1f5…) + OK
## Checking fdt 0x00b2f9b8 … sha256(c48a8872c1…) + OK
## Checking atf-2 0xfdcc1000 … sha256(455304ad25…) + OK
## Checking atf-3 0x0006a000 … sha256(919db4e965…) + OK
## Checking atf-4 0xfdcd0000 … sha256(d4e8257343…) + OK
## Checking atf-5 0xfdcce000 … sha256(cb025e3a5b…) + OK
## Checking atf-6 0x00068000 … sha256(6e9d32ba23…) + OK
## Checking optee 0x08400000 … sha256(af414b9c9f…) + OK
Total: 160.533 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-460-g2c8be93f9:huan.he
NOTICE: BL31: Built : 19:45:17, Nov 8 2022
INFO: pmu v1 is valid 220114
INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
[21:58:17.276]收←◆I/TC:
I/TC: OP-TEE version: 3.13.0-651-gd84087907 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #5 Fri Sep 16 15:39:33 CST 2022 aarch64
INFO: SPSR = 0x3c9
[21:58:17.364]收←◆
U-Boot 2017.09(u-boot commit id: 0f621b0e434b6944de865b517687e096930885b9)(sdk version: rk356x_linux_release_20230330_v1.3.2b.xml)-g0f621b0e43 #llq (Mar 31 2023 - 12:07:48 +0800)
Model: Firefly RK3566 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 7.7 GiB
Sysmem: init
Relocation Offset: ed249000
Relocation fdt: eb9f8680 - eb9fecc8
[21:58:17.416]收←◆CR: M/C/I
[21:58:17.499]收←◆Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
boot mode: recovery (misc)
=================begin===================
130202 bytes read in 8 ms (15.5 MiB/s)
DTB(Distro): rk-kernel.dtb
[21:58:17.534]收←◆I2c0 speed: 100000Hz
PMIC: RK8090 (on=0x40, off=0x00)
vdd_logic init 900000 uV
vdd_gpu init 900000 uV
vdd_npu init 900000 uV
io-domain: OK
get vp0 plane mask:0x3f, primary id:4, cursor_plane:-1, from dts
Model: Firefly RK3566-ROC-PC HDMI(Linux)
vp0 have layer nr:6[0 1 2 3 4 5 ], primary plane: 4
vp1 have layer nr:0, primary plane: 0
vp2 have layer nr:0, primary plane: 0
hdmi@fe0a0000 disconnected
No FDT memory address configured. Default at 0x08300000
apll 816000 KHz
dpll 528000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 1200000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 100000 KHz
aclk_top_high 500000 KHz
aclk_top_low 400000 KHz
hclk_top 150000 KHz
pclk_top 100000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: eth1: ethernet@fe010000
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image
[21:58:17.800]收←◆at 0xe96d1e40 with size 0x02125800
Fdt Ramdisk skip relocation
## Loading kernel from FIT Image at e96d1e40 …
Using ‘conf’ configuration
## Verified-boot: 0
Trying ‘kernel’ kernel subimage
Description: unavailable
Type: Kernel Image
Compression: uncompressed
Data Start: 0xe96f2440
Data Size: 24805384 Bytes = 23.7 MiB
Architecture: AArch64
OS: Linux
Load Address: 0x00280000
Entry Point: 0x00280000
Hash algo: sha256
Hash value: dee421890976fbac368287aab1c5e1eea10dc951987e1739df50879dfac75085
Verifying Hash Integrity … sha256
[21:58:17.974]收←◆+ OK
## Loading ramdisk from FIT Image at e96d1e40 …
Trying ‘ramdisk’ ramdisk subimage
Type: RAMDisk Image
Data Start: 0xeae9a640
Data Size: 9818024 Bytes = 9.4 MiB
OS: Linux
Load Address: 0x0a200000
Entry Point: unavailable
Hash algo: sha256
Hash value: 2f5de603deedb025c2cefcb6b6d3d708b30211729cbadc652632eb3e781a80dc
[21:58:18.050]收←◆+ OK
Loading ramdisk from 0xeae9a640 to 0x0a200000
## Loading fdt from FIT Image at e96d1e40 …
Trying ‘fdt’ fdt subimage
Type: Flat Device Tree
Data Start: 0xe96d2640
Data Size: 130202 Bytes = 127.2 KiB
Load Address: 0x08300000
Hash algo: sha256
Hash value: 6d7224871b82c84baf1e5a2f9010c12073f31b08fa0443febf90a2a4f9f5a84b
Verifying Hash Integrity … sha256+ OK
Loading fdt from 0x08300000 to 0x08300000
Booting using the fdt blob at 0x08300000
Loading Kernel Image from 0xe96f2440 to 0x00280000 … OK
kernel loaded at 0x00280000, end = 0x01a28008
Using Device Tree in place at 0000000008300000, end 0000000008322c99
Adding bank: 0x100000000 - 0x200000000 (size: 0x100000000)
Total: 821.360 ms
[ 0.000000] Linux version 4.19.232 (llq@tchip14) (rk356x/firefly: 907f3f88e2a63cbe70cd16bef8dcb011de66d78f) (sdk version: rk356x_linux_release_20230330_v1.3.2b.xml) (gcc version 10.3.1 20210621 (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)), GNU ld (GNU Toolchain for the A-profile Architecture 10.3-2021.07 (arm-10.29)) 2.36.1.20210621) #738 SMP Fri Mar 31 11:36:47 CST 2023
[ 0.000000] Machine model: Firefly RK3566-ROC-PC HDMI(Linux)
[ 0.000000] earlycon: uart8250 at MMIO32 0x00000000fe660000 (options ‘’)
[ 0.000000] OF: fdt: Reserved memory: failed to reserve memory for node ‘drm-cubic-lut@00000000’: base 0x0000000000000000, size 0 MiB
[ 0.000000] cma: Reserved 16 MiB at 0x00000000ef000000
[21:58:18.387]收←◆[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] percpu: Embedded 24 pages/cpu s60136 r8192 d29976 u98304
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1995336
[ 0.000000] Kernel command line: storagemedia=emmc androidboot.storagemedia=emmc androidboot.mode=normal storagenode=/sdhci@fe310000 androidboot.verifiedbootstate=orange ro rootwait earlycon=uart8250,mmio32,0xfe660000 console=ttyFIQ0 root=PARTLABEL=rootfs rootfstype=ext4 overlayroot=device:dev=PARTLABEL=userdata,fstype=ext4,mkfs=1 coherent_pool=1m systemd.gpt_auto=0 cgroup_enable=memory swapaccount=1 swiotlb=0x10000
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[21:58:18.450]收←◆[ 0.000000] software IO TLB: mapped [mem 0xe5f00000-0xedf00000] (128MB)
[21:58:18.575]收←◆[ 0.000000] Memory: 7778816K/8108032K available (15294K kernel code, 1952K rwdata, 5320K rodata, 1600K init, 596K bss, 312832K reserved, 16384K cma-reserved)
[ 0.000000] ftrace: allocating 54541 entries in 214 pages
[21:58:18.716]收←◆[ 0.000000] rcu: Hierarchical
[21:58:18.738]收←◆ RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] ITS@0x00000000fd440000: allocated 8192 Devices @ee810000 (indirect, esz 8, psz 64K, shr 0)
[ 0.000000] ITS@0x00000000fd440000: allocated 32768 Interrupt Collections @ee820000 (flat, esz 2, psz 64K, shr 0)
[ 0.000000] GIC: using LPI property table @0x00000000ee830000
[ 0.000000] CPU0: using LPI pending table @0x00000000ee840000
[ 0.000000] random: random: get_random_bytes called from start_kernel+0x358/0x4e4 with crng_init=0
[21:58:18.813]收←◆[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[ 0.002365] Console: colour dummy device 80x25
[ 0.002834] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
[ 0.003793] pid_max: default: 32768 minimum: 301
[ 0.004394] Security Framework initialized
[ 0.004790] AppArmor: AppArmor disabled by boot time parameter
[ 0.005430] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.006139] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.008834] ASID allocator initialised with 32768 entries
[ 0.009564] rcu: Hierarchical SRCU implementation.
[ 0.013060] Platform MSI: interrupt-controller@fd440000 domain created
[ 0.014233] PCI/MSI: /interrupt-controller@fd400000/interrupt-controller@fd440000 domain created
[ 0.015909] smp: Bringing up secondary CPUs …
[ 0.017924] Detected VIPT I-cache on CPU1
[ 0.017966] GICv3: CPU1: found redistributor 100 region 0:0x00000000fd480000
[ 0.018026] CPU1: using LPI pending table @0x00000000ee850000
[ 0.018090] CPU1: Booted secondary processor 0x0000000100 [0x412fd050]
[ 0.019723] Detected VIPT I-cache on CPU2
[ 0.019760] GICv3: CPU2: found redistributor 200 region 0:0x00000000fd4a0000
[ 0.019816] CPU2: using LPI pending table @0x00000000ee860000
[ 0.019867] CPU2: Booted secondary processor 0x0000000200 [0x412fd050]
[ 0.021442] Detected VIPT I-cache on CPU3
[ 0.021476] GICv3: CPU3: found redistributor 300 region 0:0x00000000fd4c0000
[ 0.021529] CPU3: using LPI pending table @0x00000000ee870000
[ 0.021579] CPU3: Booted secondary processor 0x0000000300 [0x412fd050]
[ 0.021724] smp: Brought up 1 node, 4 CPUs
[ 0.028661] SMP: Total of 4 processors activated.
[21:58:18.845]收←◆0.029106] CPU features: detected: GIC system register CPU interface
[ 0.029705] CPU features: detected: Privileged Access Never
[ 0.030228] CPU features: detected: LSE atomic instructions
[ 0.030770] CPU features: detected: User Access Override
[ 0.031266] CPU features: detected: 32-bit EL0 Support
[ 0.031750] CPU features: detected: RAS Extension Support
[ 0.032455] CPU: All CPU(s) started at EL2
[ 0.032873] alternatives: patching kernel code
[ 0.042431] devtmpfs: initialized
[ 0.071826] Registered cp15_barrier emulation handler
[ 0.072323] Registered setend emulation handler
[ 0.073161] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.074092] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.075573] pinctrl core: initialized pinctrl subsystem
[ 0.077284] NET: Registered protocol family 16
[ 0.078917] audit: initializing netlink subsys (disabled)
[ 0.079712] audit: type=2000 audit(0.069:1): state=initialized audit_enabled=0 res=1
[ 0.083630] cpuidle: using governor menu
[ 0.084039] Registered FIQ tty driver
[ 0.085352] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.087577] DMA: preallocated 1024 KiB pool for atomic allocations
[21:58:18.909]收←◆[ 0.091783] ramoops: dmesg-0 0x20000@0x0000000000110000
[ 0.092301] ramoops: console 0x80000@0x0000000000130000
[ 0.092801] ramoops: pmsg 0x50000@0x00000000001b0000
[ 0.093848] console [pstore-1] enabled
[ 0.094202] pstore: Registered ramoops as persistent store backend
[ 0.094782] ramoops: attached 0xf0000@0x110000, ecc: 0/0
[21:58:18.940]收←◆[ 0.133836] rockchip-gpio fdd60000.gpio: probed gpio0 (fdd60000.gpio)
[ 0.135184] rockchip-gpio fe740000.gpio: probed gpio1 (fe740000.gpio)
[ 0.136484] rockchip-gpio fe750000.gpio: probed gpio2 (fe750000.gpio)
[ 0.137812] rockchip-gpio fe760000.gpio: probed gpio3 (fe760000.gpio)
[ 0.139110] rockchip-gpio fe770000.gpio: probed gpio4 (fe770000.gpio)
[ 0.139829] rockchip-pinctrl pinctrl: probed pinctrl
[ 0.157665] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.158544] cryptd: max_cpu_qlen set to 1000
[[ 0.161071] console [ttyFIQ0] enabled
[ 0.161762] bootconsole [uart8250] disabled
[ 0.162434] Registered fiq debugger ttyFIQ0
[ 0.163604] vcc3v3_sys: supplied by dc_12v
[ 0.164105] vcc5v0_sys: supplied by dc_12v
[ 0.165875] vcc2v5-sys: supplied by vcc3v3_sys
[ 0.166393] vcc3v3_vga: supplied by vcc3v3_sys
[ 0.166945] pcie30_avdd0v9: supplied by vcc3v3_sys
[ 0.167441] pcie30_avdd1v8: supplied by vcc3v3_sys
[ 0.167928] vcc3v3_bu: supplied by vcc5v0_sys
[ 0.169911] rk_iommu fde4b000.iommu: version = 2
[ 0.170697] rk_iommu fdea0800.iommu: version = 2
[ 0.171235] rk_iommu fded0480.iommu: version = 2
[ 0.171637] rk_iommu fdee0800.iommu: version = 2
[ 0.172003] rk_iommu fdef0800.iommu: version = 2
[ 0.172377] rk_iommu fdf40f00.iommu: version = 2
[ 0.172816] rk_iommu fdf80800.iommu: version = 2
[ 0.173264] rk_iommu fdff1a00.iommu: version = 2
[ 0.173609] rk_iommu fe043e00.iommu: version = 2
[ 0.174736] SCSI subsystem initialized
[ 0.175083] usbcore: registered new interface driver usbfs
[ 0.175172] usbcore: registered new interface driver hub
[ 0.175251] usbcore: registered new device driver usb
[ 0.175386] media: Linux media interface: v0.10
[ 0.175463] videodev: Linux video capture interface: v2.00
[ 0.175594] pps_core: LinuxPPS API ver. 1 registered
[ 0.175620] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.175664] PTP clock support registered
[ 0.176093] arm-scmi firmware:scmi: SCMI Protocol v2.0 ‘rockchip:’ Firmware version 0x0
[ 0.179181] Advanced Linux Sound Architecture Driver Initialized.
[ 0.179916] Bluetooth: Core ver 2.22
[ 0.179983] NET: Registered protocol family 31
[ 0.180011] Bluetooth: HCI device and connection manager initialized
[ 0.180044] Bluetooth: HCI socket layer initialized
[ 0.180077] Bluetooth: L2CAP socket layer initialized
[ 0.180137] Bluetooth: SCO socket layer initialized
[ 0.182310] rockchip-cpuinfo cpuinfo: SoC : 35662000
[ 0.182356] rockchip-cpuinfo cpuinfo: Serial : ae6a76e75bb39c69
[ 0.184067] clocksource: Switched to clocksource arch_sys_counter
[21:58:19.097]收←◆[ 0.281889] thermal thermal_zone1: power_allocator: sustainable_power will be estimated
[ 0.282349] NET: Registered protocol family 2
[ 0.282894] IP idents hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.286957] tcp_listen_portaddr_hash hash table entries: 4096 (order: 5, 163840 bytes)
[ 0.287174] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.287790] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes)
[ 0.289817] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.290108] UDP hash table entries: 4096 (order: 6, 393216 bytes)
[ 0.290556] UDP-Lite hash table entries: 4096 (order: 6, 393216 bytes)
[ 0.291322] NET: Registered protocol family 1
[ 0.293283] Trying to unpack rootfs image as initramfs…
[21:58:19.668]收←◆[ 0.855703] Freeing initrd memory: 9584K
[ 0.857691] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.858562] kvm [1]: 16-bit VMID
[ 0.858607] kvm [1]: GICv3: no GICV resource entry
[ 0.858622] kvm [1]: disabling GICv2 emulation
[ 0.858633] kvm [1]: GIC system register CPU interface enabled
[ 0.858818] kvm [1]: vgic interrupt IRQ1
[ 0.859042] kvm [1]: VHE mode initialized successfully
[ 0.861630] Initialise system trusted keyrings
[ 0.861912] workingset: timestamp_bits=45 max_order=21 bucket_order=0
[ 0.871648] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.872085] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.872379] fuse init (API version 7.27)
[ 0.873007] SGI XFS with security attributes, no debug enabled
[ 0.876951] NET: Registered protocol family 38
[ 0.877012] Key type asymmetric registered
[ 0.877028] Asymmetric key parser ‘x509’ registered
[ 0.877100] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 244)
[ 0.877301] io scheduler noop registered
[ 0.877327] io scheduler deadline registered
[ 0.877566] io scheduler cfq registered (default)
[ 0.877596] io scheduler mq-deadline registered
[ 0.877620] io scheduler kyber registered
[ 0.879022] rockchip-csi2-dphy csi2-dphy0: csi2 dphy0 probe successfully!
[ 0.879227] rockchip-csi2-dphy-hw fe870000.csi2-dphy-hw: csi2 dphy hw probe successfully!
[ 0.882101] phy phy-fe8a0000.usb2-phy.0: Linked as a consumer to regulator.4
[ 0.882445] phy phy-fe8a0000.usb2-phy.1: No vbus specified for otg port
[ 0.884303] extcon extcon1: failed to create extcon usb2-phy link
[ 0.884484] phy phy-fe8b0000.usb2-phy.2: Linked as a consumer to regulator.4
[ 0.884726] phy phy-fe8b0000.usb2-phy.3: Linked as a consumer to regulator.4
[ 0.884898] phy phy-fe8b0000.usb2-phy.3: No vbus specified for otg port
[ 0.895350] mpp_service mpp-srv: ddc1c24c52b5 author: Herman Chen 2022-11-16 video: rockchip: mpp: Fix mpp_dev_release crash
[ 0.895404] mpp_service mpp-srv: probe start
[ 0.897634] iommu: Adding device fdf40000.rkvenc to group 5
[ 0.897705] mpp_rkvenc fdf40000.rkvenc: Linked as a consumer to fdf40f00.iommu
[ 0.898000] mpp_rkvenc fdf40000.rkvenc: probing start
[ 0.898449] mpp_rkvenc fdf40000.rkvenc: venc regulator not ready, retry
[ 0.898468] rkvenc_init:1199: failed to add venc devfreq
[ 0.900212] iommu: Adding device fdea0400.vdpu to group 1
[ 0.900257] mpp_vdpu2 fdea0400.vdpu: Linked as a consumer to fdea0800.iommu
[ 0.900497] mpp_vdpu2 fdea0400.vdpu: probe device
[ 0.901184] mpp_vdpu2 fdea0400.vdpu: probing finish
[ 0.901954] iommu: Adding device fdee0000.vepu to group 3
[ 0.902010] mpp_vepu2 fdee0000.vepu: Linked as a consumer to fdee0800.iommu
[ 0.902266] mpp_vepu2 fdee0000.vepu: probe device
[ 0.902920] mpp_vepu2 fdee0000.vepu: probing finish
[ 0.903650] iommu: Adding device fdef0000.iep to group 4
[ 0.903705] mpp-iep2 fdef0000.iep: Linked as a consumer to fdef0800.iommu
[ 0.903924] mpp-iep2 fdef0000.iep: probe device
[ 0.904469] mpp-iep2 fdef0000.iep: allocate roi buffer failed
[ 0.904746] mpp-iep2 fdef0000.iep: probing finish
[ 0.905442] iommu: Adding device fded0000.jpegd to group 2
[ 0.905497] mpp_jpgdec fded0000.jpegd: Linked as a consumer to fded0480.iommu
[ 0.905775] mpp_jpgdec fded0000.jpegd: probe device
[ 0.906453] mpp_jpgdec fded0000.jpegd: probing finish
[ 0.907199] iommu: Adding device fdf80200.rkvdec to group 6
[ 0.907256] mpp_rkvdec2 fdf80200.rkvdec: Linked as a consumer to fdf80800.iommu
[ 0.907623] mpp_rkvdec2 fdf80200.rkvdec: probing start
[ 0.907696] mpp_rkvdec2 fdf80200.rkvdec: 16 task capacity link mode detected
[ 0.908186] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_a is not found!
[ 0.908222] rkvdec2_init:925: No niu aclk reset resource define
[ 0.908250] mpp_rkvdec2 fdf80200.rkvdec: shared_niu_h is not found!
[ 0.908270] rkvdec2_init:928: No niu hclk reset resource define
[ 0.908362] mpp_rkvdec2 fdf80200.rkvdec: vdec regulator not ready, retry
[ 0.908386] rkvdec2_init:942: failed to add vdec devfreq
[ 0.908679] mpp_rkvdec2 fdf80200.rkvdec: probe sub driver failed
[ 0.909115] mpp_service mpp-srv: probe success
[ 0.915317] dma-pl330 fe530000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.915362] dma-pl330 fe530000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.918736] dma-pl330 fe550000.dmac: Loaded driver for PL330 DMAC-241330
[ 0.918778] dma-pl330 fe550000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-32 Num_Events-16
[ 0.920533] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[ 0.921939] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.923142] fe650000.serial: ttyS1 at MMIO 0xfe650000 (irq = 61, base_baud = 1500000) is a 16550A
[ 0.926765] random: fast init done
[ 0.927378] random: crng init done
[ 0.927546] iommu: Adding device fe040000.vop to group 8
[ 0.927609] rockchip-vop2 fe040000.vop: Linked as a consumer to fe043e00.iommu
[ 0.933888] rockchip-drm display-subsystem: Linked as a consumer to fe040000.vop
[ 0.935548] rockchip-drm display-subsystem: Linked as a consumer to fe0a0000.hdmi
[ 0.938338] rockchip-drm display-subsystem: defer getting devfreq
[ 0.938710] vp0: rgb_pixelclk: 0
[ 0.938760] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp0 assign plane mask: 0x3f, primary plane phy id: 4
[ 0.938790] vp1: rgb_pixelclk: 0
[ 0.938820] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp1 assign plane mask: 0x0, primary plane phy id: -1
[ 0.938846] vp2: rgb_pixelclk: 0
[ 0.938873] rockchip-vop2 fe040000.vop: [drm:vop2_bind] vp2 assign plane mask: 0x0, primary plane phy id: -1
[ 0.939101] [drm] unsupported AFBC format[3432564e]
[ 0.939178] [drm] failed to init overlay plane Cluster0-win1, ret:-13
[ 0.939336] rockchip-drm display-subsystem: bound fe040000.vop (ops 0xffffff8009052400)
[ 0.939661] dwhdmi-rockchip fe0a0000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY)
[ 0.940496] dwhdmi-rockchip fe0a0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 0.941444] rockchip-drm display-subsystem: bound fe0a0000.hdmi (ops 0xffffff8009056c30)
[ 0.941469] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 0.941497] [drm] No driver support for vblank timestamp query.
[ 0.941722] get_framebuffer_by_node: failed to get logo,offset
[ 0.941760] rockchip-drm display-subsystem: can’t not find any loader display
[ 0.941790] rockchip-drm display-subsystem: failed to show loader logo
[ 0.941867] [drm] Cannot find any crtc or sizes
[ 0.942022] [drm] Cannot find any crtc or sizes
[ 0.943146] [drm] Initialized rockchip 2.0.0 20140818 for display-subsystem on minor 0
[ 0.950611] mali fde60000.gpu: Kernel DDK version g7p1-01bet0
[ 0.950764] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 0.950828] mali fde60000.gpu: Device initialization Deferred
[ 0.951843] brd: module loaded
[ 0.961813] loop: module loaded
[ 0.962503] zram: Added device: zram0
[ 0.962688] lkdtm: No crash points registered, enable through debugfs
[ 0.966198] register firefly_spi_init spi return v = :0
[ 0.966627] CAN device driver interface
[ 0.968805] rk_gmac-dwmac fe010000.ethernet: no regulator found
[ 0.968845] rk_gmac-dwmac fe010000.ethernet: clock input or output? (input).
[ 0.968864] rk_gmac-dwmac fe010000.ethernet: TX delay(0x4e).
[ 0.968881] rk_gmac-dwmac fe010000.ethernet: RX delay(0x2c).
[ 0.968901] rk_gmac-dwmac fe010000.ethernet: integrated PHY? (no).
[ 0.968983] rk_gmac-dwmac fe010000.ethernet: clock input from PHY
[ 0.969258] rk_gmac-dwmac fe010000.ethernet: init for RGMII
[ 0.969598] rk_gmac-dwmac fe010000.ethernet: User ID: 0x30, Synopsys ID: 0x51
[ 0.969639] rk_gmac-dwmac fe010000.ethernet: DWMAC4/5
[ 0.969658] rk_gmac-dwmac fe010000.ethernet: DMA HW capability register supported
[ 0.969685] rk_gmac-dwmac fe010000.ethernet: RX Checksum Offload Engine supported
[ 0.969707] rk_gmac-dwmac fe010000.ethernet: TX Checksum insertion supported
[ 0.969727] rk_gmac-dwmac fe010000.ethernet: Wake-Up On Lan supported
[ 0.969782] rk_gmac-dwmac fe010000.ethernet: TSO supported
[ 0.969808] rk_gmac-dwmac fe010000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[ 0.969834] rk_gmac-dwmac fe010000.ethernet: TSO feature enabled
[21:58:19.920]收←◆[ 1.107952] usbcore: registered new interface driver rndis_wlan
[ 1.108059] usbcore: registered new interface driver rtl8150
[ 1.108149] usbcore: registered new interface driver r8152
[ 1.108230] usbcore: registered new interface driver asix
[ 1.108315] usbcore: registered new interface driver ax88179_178a
[ 1.108391] usbcore: registered new interface driver cdc_ether
[ 1.108474] usbcore: registered new interface driver rndis_host
[ 1.108569] usbcore: registered new interface driver cdc_ncm
[ 1.108654] usbcore: registered new interface driver qmi_wwan_q
[ 1.108731] usbcore: registered new interface driver qmi_wwan
[ 1.108804] usbcore: registered new interface driver cdc_mbim
[ 1.110468] dwc3 fcc00000.dwc3: Failed to get clk ‘ref’: -2
[ 1.117708] dwc3 fd000000.dwc3: Failed to get clk ‘ref’: -2
[ 1.124388] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.124442] ehci-pci: EHCI PCI platform driver
[ 1.124550] ehci-platform: EHCI generic platform driver
[ 1.126929] ehci-platform fd800000.usb: EHCI Host Controller
[ 1.127209] ehci-platform fd800000.usb: new USB bus registered, assigned bus number 1
[ 1.127800] ehci-platform fd800000.usb: irq 11, io mem 0xfd800000
[ 1.140769] ehci-platform fd800000.usb: USB 2.0 started, EHCI 1.00
[ 1.141116] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.141148] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.141172] usb usb1: Product: EHCI Host Controller
[ 1.141194] usb usb1: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.141215] usb usb1: SerialNumber: fd800000.usb
[ 1.141898] hub 1-0:1.0: USB hub found
[ 1.141984] hub 1-0:1.0: 1 port detected
[ 1.144839] ehci-platform fd880000.usb: EHCI Host Controller
[ 1.145099] ehci-platform fd880000.usb: new USB bus registered, assigned bus number 2
[ 1.145623] ehci-platform fd880000.usb: irq 13, io mem 0xfd880000
[ 1.157432] ehci-platform fd880000.usb: USB 2.0 started, EHCI 1.00
[ 1.157782] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[ 1.157813] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.157843] usb usb2: Product: EHCI Host Controller
[ 1.157866] usb usb2: Manufacturer: Linux 4.19.232 ehci_hcd
[ 1.157887] usb usb2: SerialNumber: fd880000.usb
[ 1.158529] hub 2-0:1.0: USB hub found
[ 1.158612] hub 2-0:1.0: 1 port detected
[ 1.159730] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.159782] ohci-platform: OHCI generic platform driver
[ 1.160146] ohci-platform fd840000.usb: Generic Platform OHCI controller
[ 1.160433] ohci-platform fd840000.usb: new USB bus registered, assigned bus number 3
[21:59:19.971]收←◆[ 61.157378] rcu: INFO: rcu_sched detected stalls on CPUs/tasks:
[ 61.157419] rcu: 2-…0: (0 ticks this GP) idle=922/1/0x4000000000000000 softirq=40/40 fqs=6000
[ 61.157431] rcu: (detected by 1, t=18002 jiffies, g=-979, q=2)
[ 61.157448] Task dump for CPU 2:
[ 61.157459] swapper/0 R running task 0 1 0 0x0000002a
[ 61.157502] Call trace:
[ 61.157549] __switch_to+0xcc/0x130
[ 61.157572] 0xffffffc1fff44740
[ 61.157602] CPU0 online:1
[ 61.157638] EL2(NS) PC: <0xffffff80080a2418> cpu_do_idle+0x4/0xc
[ 61.157772]
[ 61.157789] CPU1 online:1
[ 61.157813] EL2(NS) PC: <0xffffff800863a604> rockchip_panic_notify+0x274/0x33c
[ 61.157838] EL2(NS) PC: <0xffffff800863a600> rockchip_panic_notify+0x270/0x33c
[ 61.157864] EL2(NS) PC: <0xffffff800863a604> rockchip_panic_notify+0x274/0x33c
[ 61.157890] EL2(NS) PC: <0xffffff800863a600> rockchip_panic_notify+0x270/0x33c
[ 61.157915] EL2(NS) PC: <0xffffff800863a604> rockchip_panic_notify+0x274/0x33c
[ 61.157938] EL2(NS) PC: <0xffffff800863a600> rockchip_panic_notify+0x270/0x33c
[ 61.158049]
[ 61.158066] CPU2 online:1
[ 61.158098] EL2(NS) PC: <0xffffff8008a17a08> ohci_init+0x7c/0x3d8
[ 61.158223]
[ 61.158241] CPU3 online:1
[ 61.158271] EL2(NS) PC: <0xffffff800811b09c> set_next_entity+0xb8/0x6b4
[ 61.158297] EL2(NS) PC: <0xffffff8008f37d1c> rb_erase_cached+0x8/0x358
[ 61.158320] EL2(NS) PC: <0xffffff800811b018> set_next_entity+0x34/0x6b4
[ 61.158348] EL2(NS) PC: <0xffffff8008132890> __update_load_avg_se+0x58/0x238
[ 61.158372] EL2(NS) PC: <0xffffff8008f37d1c> rb_erase_cached+0x8/0x358
[ 61.158397] EL2(NS) PC: <0xffffff8008132a88> __update_load_avg_cfs_rq+0x18/0x1f8
[ 61.158421] EL2(NS) PC: <0xffffff800811b5e0> set_next_entity+0x5fc/0x6b4
[ 61.158446] EL2(NS) PC: <0xffffff8008086f7c> arch_cpu_idle_exit+0x4/0x24
[ 61.158468] EL2(NS) PC: <0xffffff8008631954> console_putc+0x30/0x68
[ 61.158496] EL2(NS) PC: <0xffffff800812508c> pick_next_task_fair+0x1c0/0x620
[ 61.158520] EL2(NS) PC: <0xffffff8008124f90> pick_next_task_fair+0xc4/0x620
[ 61.158545] EL2(NS) PC: <0xffffff800811b0b8> set_next_entity+0xd4/0x6b4
[ 61.158569] EL2(NS) PC: <0xffffff800811b5e0> set_next_entity+0x5fc/0x6b4
[ 61.158595] EL2(NS) PC: <0xffffff8008132b00> __update_load_avg_cfs_rq+0x90/0x1f8
[ 61.158619] EL2(NS) PC: <0xffffff800811b158> set_next_entity+0x174/0x6b4
[ 61.158644] EL2(NS) PC: <0xffffff800812503c> pick_next_task_fair+0x170/0x620
[ 61.158669] EL2(NS) PC: <0xffffff8008132ac4> __update_load_avg_cfs_rq+0x54/0x1f8
[ 61.158696] EL2(NS) PC: <0xffffff8008144c68> __handle_domain_irq+0xa8/0xc0
[ 61.158715] EL2(NS) PC: <0xffffff8008631954> console_putc+0x30/0x68
[ 61.158744] EL2(NS) PC: <0xffffff800811b010> set_next_entity+0x2c/0x6b4
[ 61.158769] EL2(NS) PC: <0xffffff80081328b8> __update_load_avg_se+0x80/0x238
[ 61.158794] EL2(NS) PC: <0xffffff800811b09c> set_next_entity+0xb8/0x6b4
[ 61.158821] EL2(NS) PC: <0xffffff8008087368> tls_preserve_current_state+0x38/0x3c
[ 61.158846] EL2(NS) PC: <0xffffff800811cf88> pick_next_entity+0x1c/0x11c
[ 61.158871] EL2(NS) PC: <0xffffff8008132ac0> __update_load_avg_cfs_rq+0x50/0x1f8
[ 61.158897] EL2(NS) PC: <0xffffff8008124fb0> pick_next_task_fair+0xe4/0x620
[ 61.158921] EL2(NS) PC: <0xffffff8008f37d1c> rb_erase_cached+0x8/0x358
[ 61.158946] EL2(NS) PC: <0xffffff8008086f7c> arch_cpu_idle_exit+0x4/0x24
[ 61.158965] EL2(NS) PC: <0xffffff8008631954> console_putc+0x30/0x68
[ 61.158986] EL2(NS) PC: <0xffffff8008115a24> get_nohz_timer_target+0x38/0x144
[ 61.159011] EL2(NS) PC: <0xffffff800811d040> pick_next_entity+0xd4/0x11c
[ 61.159036] EL2(NS) PC: <0xffffff8008124f74> pick_next_task_fair+0xa8/0x620
[ 61.159051]
[ 61.159071] CPU0 CPU1 CPU2 CPU3
[ 61.159101] 1: 0 0 0 0 GICv3 25 Level vgic
[ 61.159119] 1: 0 0 0 0 GICv3 25 Level vgic
[ 61.159138] 1: 0 0 0 0 GICv3 25 Level vgic
[ 61.159165] 4: 0 0 0 0 GICv3 27 Level kvm guest timer
[ 61.159191] 5: 513 18154 217 443 GICv3 26 Level arch_timer
[ 61.159210] 6: 0 0 0 0 GICv3 141 Level rk_timer
[ 61.159231] 7: 0 0 0 0 GICv3 260 Level arm-pmu
[ 61.159256] 8: 0 0 0 0 GICv3 261 Level arm-pmu
[ 61.159281] 9: 0 0 0 0 GICv3 262 Level arm-pmu
[ 61.159306] 10: 0 0 0 0 GICv3 263 Level arm-pmu
[ 61.159330] 11: 0 0 0 0 GICv3 162 Level ehci_hcd:usb1
[ 61.159347] 11: 0 0 0 0 GICv3 162 Level ehci_hcd:usb1
[ 61.159373] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 61.159391] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 61.159409] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 61.159436] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 61.159448] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 61.159459] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 61.159476] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 61.159504] 20: 0 0 0 0 GICv3 171 Level fdea0400.vdpu
[ 61.159530] 21: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 61.159548] 21: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 61.159574] 23: 0 0 0 0 GICv3 94 Level fded0000.jpegd
[ 61.159599] 24: 0 0 0 0 GICv3 93 Level fded0480.iommu
[ 61.159626] 25: 0 0 0 0 GICv3 96 Level fdee0000.vepu
[ 61.159652] 26: 0 0 0 0 GICv3 95 Level fdee0800.iommu
[ 61.159678] 27: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 61.159690] 27: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 61.159708] 29: 0 0 0 0 GICv3 173 Level fdf40f00.iommu
[ 61.159734] 30: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 61.159752] 30: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 61.159779] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 61.159797] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 61.159816] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 61.159834] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 61.159861] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 61.159878] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 61.159897] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 61.159925] 39: 0 0 0 0 GICv3 180 Level fe043e00.iommu, fe040000.vop
[ 61.159945] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.159965] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.159985] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160003] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160022] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160040] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160059] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160078] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160095] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160114] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160133] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160150] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160169] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160181] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 61.160200] 54: 0 0 0 0 GICv3 46 Level fe530000.dmac
[ 61.160227] 55: 0 0 0 0 GICv3 45 Level fe530000.dmac
[ 61.160252] 56: 0 0 0 0 GICv3 48 Level fe550000.dmac
[ 61.160277] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160294] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160315] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160333] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160351] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160370] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160389] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160408] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 61.160427] 65: 1 0 0 0 GICv3 167 Level rockchip_usb2phy
[ 61.160447] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160464] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160484] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160502] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160521] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160540] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160557] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 61.160583] 73: 0 0 0 0 GICv3 150 Level debug
[ 61.160602] 73: 0 0 0 0 GICv3 150 Level debug
[ 61.160619] 73: 0 0 0 0 GICv3 150 Level debug
[21:59:20.964]收←◆[ 62.160767] CPU0 CPU1 CPU2 CPU3
[ 62.160795] 1: 0 0 0 0 GICv3 25 Level vgic
[ 62.160808] 1: 0 0 0 0 GICv3 25 Level vgic
[ 62.160819] 1: 0 0 0 0 GICv3 25 Level vgic
[ 62.160836] 4: 0 0 0 0 GICv3 27 Level kvm guest timer
[ 62.160854] 5: 518 18154 217 793 GICv3 26 Level arch_timer
[ 62.160894] 6: 0 0 0 0 GICv3 141 Level rk_timer
[ 62.160927] 7: 0 0 0 0 GICv3 260 Level arm-pmu
[ 62.160959] 8: 0 0 0 0 GICv3 261 Level arm-pmu
[ 62.160987] 9: 0 0 0 0 GICv3 262 Level arm-pmu
[ 62.161017] 10: 0 0 0 0 GICv3 263 Level arm-pmu
[ 62.161046] 11: 0 0 0 0 GICv3 162 Level ehci_hcd:usb1
[ 62.161064] 11: 0 0 0 0 GICv3 162 Level ehci_hcd:usb1
[ 62.161083] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 62.161094] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 62.161105] 13: 0 0 0 0 GICv3 165 Level ehci_hcd:usb2
[ 62.161128] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 62.161145] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 62.161165] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 62.161184] 16: 0 0 0 0 GICv3 183 Level fde4b000.iommu
[ 62.161210] 20: 0 0 0 0 GICv3 171 Level fdea0400.vdpu
[ 62.161234] 21: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 62.161251] 21: 0 0 0 0 GICv3 170 Level fdea0800.iommu
[ 62.161276] 23: 0 0 0 0 GICv3 94 Level fded0000.jpegd
[ 62.161300] 24: 0 0 0 0 GICv3 93 Level fded0480.iommu
[ 62.161324] 25: 0 0 0 0 GICv3 96 Level fdee0000.vepu
[ 62.161343] 26: 0 0 0 0 GICv3 95 Level fdee0800.iommu
[ 62.161361] 27: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 62.161379] 27: 0 0 0 0 GICv3 88 Level fdef0800.iommu, fdef0000.iep
[ 62.161408] 29: 0 0 0 0 GICv3 173 Level fdf40f00.iommu
[ 62.161432] 30: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 62.161449] 30: 0 0 0 0 GICv3 174 Level fdf40f00.iommu
[ 62.161475] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 62.161493] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 62.161511] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 62.161530] 32: 0 0 0 0 GICv3 124 Level fdf80800.iommu
[ 62.161554] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 62.161572] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 62.161584] 36: 0 0 0 0 GICv3 91 Level fdff1a00.iommu
[ 62.161603] 39: 0 0 0 0 GICv3 180 Level fe043e00.iommu, fe040000.vop
[ 62.161629] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161647] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161666] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161685] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161704] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161723] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161741] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161760] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161778] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161797] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161815] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161827] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161838] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161848] 40: 0 0 0 0 GICv3 77 Level fe0a0000.hdmi, dw-hdmi-cec
[ 62.161873] 54: 0 0 0 0 GICv3 46 Level fe530000.dmac
[ 62.161898] 55: 0 0 0 0 GICv3 45 Level fe530000.dmac
[ 62.161922] 56: 0 0 0 0 GICv3 48 Level fe550000.dmac
[ 62.161947] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.161965] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.161982] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162001] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162021] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162039] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162058] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162070] 57: 0 0 0 0 GICv3 47 Level fe550000.dmac
[ 62.162088] 65: 1 0 0 0 GICv3 167 Level rockchip_usb2phy
[ 62.162111] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162128] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162148] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162168] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162186] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162204] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162222] 66: 0 0 0 0 GICv3 168 Level rockchip_usb2phy
[ 62.162247] 73: 0 0 0 0 GICv3 150 Level debug
[ 62.162264] 73: 0 0 0 0 GICv3 150 Level debug
[ 62.162283] 73: 0 0 0 0 GICv3 150 Level debug
[ 62.162301] PMU:
[ 62.162326] 00000000: 03003566 00000e0c 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.162347] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.162374] 00000040: 00000000 00000000 00000000 00000000 0000016e 00000000 00000000 00000000
[ 62.162402] 00000060: 0000016e 00000000 0000016e 00000000 0000ffff 0000000f 00000000 00000000
[ 62.162429] 00000080: 00000000 00000000 00000000 00000002 00000000 00000000 00000077 00000000
[ 62.162457] 000000a0: 00000077 00000000 00000003 00000000 00000000 00000000 00000000 00000000
[ 62.162485] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.162513] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 62.162531] Kernel Offset: disabled
[ 62.162550] CPU features: 0x00000004,22002a38
[ 62.162561] Memory Limit: none
20230522.txt (54.4 KB)
