Unveiling Relations Between IPQ8072, IPQ8072A, IPQ8074,IPQ8074A
Introduction:
In the realm of networking and wireless communication, Qualcomm Technologies has been a key player, continually introducing innovative solutions. Their IPQ8072, IPQ8072A, IPQ8074, and IPQ8074A are prominent members of their system-on-a-chip (SoC) lineup. In this blog post, we will explore the relations between these processors, shedding light on their features, capabilities, and use cases.
  1. IPQ8072:
The IPQ8072 is a high-performance SoC designed for Wi-Fi 6 (802.11ax) access points and routers. It combines a powerful quad-core ARM Cortex-A53 CPU with Qualcomm’s advanced Wi-Fi technology, offering impressive wireless performance, enhanced coverage, and efficient power consumption. The IPQ8072 supports dual-band concurrent operation and is optimized for multi-gigabit speeds, making it an excellent choice for demanding networking applications.
  1. IPQ8072A:
The IPQ8072A is an upgraded version of the IPQ8072, designed to provide even higher performance and additional features. While sharing the same quad-core ARM Cortex-A53 CPU, the IPQ8072A boasts enhanced Wi-Fi capabilities, including support for 8x8 MU-MIMO (Multi-User Multiple Input, Multiple Output) technology. This feature enables simultaneous communication with multiple devices, improving overall network efficiency and throughput.
  1. IPQ8074:
The IPQ8074 is another member of Qualcomm’s SoC family, specifically developed for enterprise-grade networking equipment. It features a more powerful quad-core ARM Cortex-A53 CPU, coupled with a dedicated networking processor, providing exceptional performance for demanding networking environments. With its advanced Wi-Fi features, such as 12x12 MU-MIMO, the IPQ8074 is designed to handle heavy workloads and deliver high-speed, reliable connectivity to numerous devices simultaneously.
  1. IPQ8074A:
The IPQ8074A is an upgraded iteration of the IPQ8074, delivering additional enhancements and capabilities. Building upon its predecessor, the IPQ8074A offers improved CPU performance, higher Wi-Fi speeds, and extended support for features like OFDMA (Orthogonal Frequency Division Multiple Access) and 160 MHz channels. These advancements enable more efficient data transmission and higher throughput, making the IPQ8074A ideal for advanced enterprise networking scenarios.
Conclusion:
Qualcomm Technologies’ IPQ8072, IPQ8072A, IPQ8074, and IPQ8074A are powerful system-on-a-chip solutions designed to meet the demands of modern networking equipment. Each variant offers unique features and capabilities, catering to different market segments and applications. Whether it’s high-performance consumer routers, enterprise-grade access points, or demanding networking environments, these processors deliver impressive wireless performance, enhanced connectivity, and improved network efficiency. As technology continues to evolve, Qualcomm’s SoCs play a vital role in shaping the future of wireless communication.
Wally IPQ8072, IPQ8072A, IPQ8074, and IPQ8074A wireless socs:
1.DR8072A(HK09)
Website:
https://www.wallystech.com/Routerboard/DR8072A-HK09-wifi6-Qualcomm-IPQ8072A-4T4R-2-2.5GE-port-support-OpenWRT-802.11AX-MU-MIMO-OFDMA.html
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate 8 MB NOR Flash, 256MB NAND Flash
■ On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ Support 802.11ac TX Beamforming
■ Support 802.11ac/802.11ax MU-MIMO DL and UL
■ Support OFDMA DL and UL
■ Tri-band support with 5G SBS (4x4/5GHz ) + 4x4/2.4GHz
■ Supports Dynamic Frequency Selection (DFS)
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to +70 ºC
Storage Temperature Range -40 to +90 ºC
Storage Humidity Range 0 to +90 (non-condensing)
Hardware Specifications
Symbol Parameter
CPU Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency Derived from Qualcomm Atheros AP.HK09
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface
Frequency Range 2.412~2.472GHz, 5.150~5.825GHz
MiniPCIe Slot 1x MiniPCIe Slot with PCIe 3.0
Modulation Techniques OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash NOR Flash: 8 MB
NAND Flash: 256MB
Wireless On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 17dBm per chain 8x U.FL Connectors
Reset Buttons 1x S/W Reset Button
DC Jack Input 1x DC Jack Connector: 12V
Interface 4x 1Gbps Ethernet Port, 2x 2.5Gbps Ethernet Port 2x USB 3.0 Port 1x JTAG 20 Pin Connector 1x Serial Port 4 Pin Connector
LED 2x RGB LED Indicators
Power Consumption TBD
2.DR8072V01
Website:
https://www.wallystech.com/Routerboard/DR8072V01-wifi6-Qualcomm-IPQ8072A-4T4R-support-OpenWRT-802.11AX-supporting-10GE-port-10G-SFP.html
Features
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND Flash(NAND Flash can be up to 1GB as optional)
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Symbol Parameter
System Memory 1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range 2.412~2.472GHz, 5.150~5.825GHZ M.2 Slot 1x M.2 Slot with PCIe 3.0
NOR Flash: 8 MB
Interface 4x 1Gbps Ethernet Port, 1x 10Gbps Ethernet Port 1x 10Gbps SFP
Our company:
Wallys Communications (Suzhou) Co., LTD www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
