SDK包名称:rk356x_linux_release_20230330_v1.3.2b
SDK修改内容:配置选择的roc-rk3568-pc-ubuntu.mk, 文件系统使用的Ubuntu18.04-Lxde_RK3568_v2.40_20230331
Log日志:20-RK3568-打印信息.rar
自己编译的固件,感觉文件系统加载失败了,一直卡在下面这个地方
[ 13.541559] RKNPU fde40000.npu: pvtm-volt-sel=1
[ 13.542918] RKNPU fde40000.npu: avs=0
[ 13.544063] RKNPU fde40000.npu: l=0 h=2147483647 hyst=5000 l_limit=0 h_limit=0 h_table=0
[ 13.544827] RKNPU fde40000.npu: failed to find power_model node
[ 13.545357] RKNPU fde40000.npu: RKNPU: failed to initialize power model
[ 13.545944] RKNPU fde40000.npu: RKNPU: failed to get dynamic-coefficient
[ 13.549294] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 13.559410] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 13.561296] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[ 13.561899] rockchip-suspend not set sleep-mode-config for mem-lite
[ 13.562455] rockchip-suspend not set wakeup-config for mem-lite
[ 13.562984] rockchip-suspend not set sleep-mode-config for mem-ultra
[ 13.563583] rockchip-suspend not set wakeup-config for mem-ultra
[ 13.565336] I : [File] : drivers/gpu/arm/mali400/mali/linux/mali_kernel_linux.c; [Line] : 413; [Func] : mali_module_init(); svn_rev_string_from_arm of this mali_ko is ‘’, rk_ko_ver is ‘5’, built at ‘20:36:17’, on ‘May 26 2023’.
[ 13.568508] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 13.569276] cfg80211: failed to load regulatory.db
[ 13.570459] Mali:
[ 13.570462] Mali device driver loaded
[ 13.571078] rkisp rkisp-vir0: clear unready subdev num: 4
[ 13.571563] rockchip-csi2-dphy0: No link between dphy and sensor
[ 13.572782] rockchip-csi2-dphy0: No link between dphy and sensor
[ 13.573396] rkisp-vir0: update sensor failed
v 13.580062]
而从官司网下载的ROC-RK3568-PC-RTLINUX_Ubuntu20.04-r240_v1.3.2b_230403 固件能正常启动。请教这个是什么原因,需要怎么解决?
谢谢!!
20-RK3568-打印信息.rar (39.3 KB)
