MPP长时间使用死机
我们自研的底板,搭载的core-3588j核心板,长时间使用mpp模块,几个小时后系统崩溃挂掉
sdk使用的是rk3588_linux_release_20230403_v1.0.6f 对系统做了部分剪裁
内核主要修改部分:arch/arm64/boot/dts/rockchip/rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1.dts
// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
  • Copyright (c) 2021 Rockchip Electronics Co., Ltd.
/dts-v1/;
#include “rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1.dtsi”
model = “Firefly ITX-3588J MIPI(Linux)”;
compatible = “rockchip,rk3588-firefly-itx-3588j-mipi101-M101014-BE45-A1”, “rockchip,rk3588”;
ds18b20:ds18b20 {
    compatible = "maicro,rk3588-ds18b20";
    status = "okay";
    pinctrl-names = "default";
    pinctrl-0 = <&ds18b20_gpio_pin>;
    ds18b20-gpio = <&gpio3 RK_PD4 GPIO_ACTIVE_HIGH>;
fan_fg:fan_fg {
    compatible = "maicro,fan_fg";
    pinctrl-0 = <&fan_fg_pin0 &fan_fg_pin1>;
    fg0-gpio = <&gpio0 RK_PD1 IRQ_TYPE_EDGE_FALLING>;
    fg1-gpio = <&gpio0 RK_PD2 IRQ_TYPE_EDGE_FALLING>;
    status = "okay";
EM05 {
    compatible = "gpio-leds";
    power {
        label = "em05_power";
        gpios = <&pca9555 PCA_IO0_0 GPIO_ACTIVE_HIGH>;
        default-state = "on";
    reset {
        label = "em05_reset";
        gpios = <&pca9555 PCA_IO0_4 GPIO_ACTIVE_LOW>;
&pinctrl{
ds18b20_pin {
ds18b20_gpio_pin:ds18b20_gpio_pin{
rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>;
fan_fg_pin {
    fan_fg_pin0:fan_fg_pin0{
        rockchip,pins = <0 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
    fan_fg_pin1:fan_fg_pin1{
        rockchip,pins = <0 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
&pwm0 {
pinctrl-0 = <&pwm0m1_pins>;
status = “okay”;
&power_led {
gpios = <&gpio1 RK_PB3 GPIO_ACTIVE_LOW>;
&can1 {
status = “disabled”;
/* hdmi rx */
&hdmiin_sound{
&hdmirx_ctrler {
&hdmi1 {
&hdmi1_sound {
&hdmi1_in_vp1 {
&hdptxphy_hdmi1 {
&route_hdmi1{
&rkcif_mipi_lvds2 {
&vcc_sata_pwr_en {
错误log为:
39557.955066] rkvenc2_task_timeout_process:1657: session 8589:33 count 1 task 7762529 ref 2 timeout
[39557.955075] mpp_rkvenc2 fdbe0000.rkvenc-core: core 1 dump timeout status:
[39557.955079] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[[39557.955087] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5187]: 510c: 0x10102aa8
[39557.955089] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5188]: 5110: 0x00000000
[39557.955091] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5189]: 5114: 0x00000000
[39557.955094] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5190]: 5118: 0x43450f17
[39557.955096] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5191]: 511c: 0xc040e768
[39557.955099] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5192]: 5120: 0x38000000
[39557.955101] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5193]: 5124: 0x00000000
[39557.955103] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5194]: 5128: 0x00002000
[39557.955106] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5195]: 512c: 0x00000000
[39557.955108] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5196]: 5130: 0x00000000
[39557.955110] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5197]: 5134: 0x00000000
[39557.980493] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5198]: 5138: 0x00000000
[39557.980498] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5199]: 513c: 0x00000204
[39557.980501] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5200]: 5140: 0x00000000
[39557.980504] mpp_rkvenc2 fdbe0000.rkvenc-core: reg[5201]: 5144: 0x00000000
[39557.980611] SError Interrupt on CPU6, code 0xbe000011 – SError
[39557.980612] CPU: 6 PID: 8592 Comm: mpp_h265e_1600 Tainted: G W O 5.10.110 #5
[39557.980613] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39557.980614] pstate: 80400009 (Nzcv daif +PAN -UAO -TCO BTYPE=–)
[39557.980614] pc : dev_printk_emit+0x58/0x8c
[39557.980615] lr : __dev_printk+0x60/0x84
[39557.980616] sp : ffffffc01aafbab0
[39557.980616] x29: ffffffc01aafbab0 x28: 0000000000000000
[39557.980618] x27: 0000000000000000 x26: ffffff81292c1600
[39557.980620] x25: ffffff8103c46480 x24: ffffff81d6fa2e58
[39557.980621] x23: 0000000000000000 x22: 0000000000000000
[39557.980623] x21: 0000000000000033 x20: ffffffc01aafbb88
[39557.980624] x19: ffffff8101051810 x18: 0000000000000030
[39557.980625] x17: 0000000000000000 x16: 0000000000000000
[39557.980626] x15: ffffffffffffffff x14: 303030307830203a
[39557.980627] x13: 34343135203a5d31 x12: 3032355b67657220
[39557.980629] x11: 000000000007ed58 x10: 000000000007ed20
[39557.980630] x9 : ffffffc01155e798 x8 : ffffff8101228ec0
[39557.980631] x7 : ffffffc0124bb600 x6 : ffffffc01aafbb40
[39557.980633] x5 : ffffffc01aafbb40 x4 : ffffffc01aafbb40
[39557.980634] x3 : ffffffc01aafbac0 x2 : ffffffc011b045d0
[39557.980635] x1 : ffffff8101051810 x0 : 0000000000000003
[39557.980636] Kernel panic - not syncing: Asynchronous SError Interrupt
[39557.980637] CPU: 6 PID: 8592 Comm: mpp_h265e_1600 Tainted: G W O 5.10.110 #5
[39557.980638] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39557.980638] Call trace:
[39557.980639] dump_backtrace+0x0/0x1e0
[39557.980639] show_stack+0x24/0x30
[39557.980640] dump_stack_lvl+0xd0/0xf8
[39557.980641] dump_stack+0x18/0x38
[39557.980641] panic+0x16c/0x34c
[39557.980642] add_taint+0x0/0xc0
[39557.980642] arm64_serror_panic+0x8c/0x98
[39557.980643] arm64_is_fatal_ras_serror+0x34/0xb4
[39557.980645] do_serror+0x48/0x6c
[39557.980646] el1_error+0x90/0x110
[39557.980646] dev_printk_emit+0x58/0x8c
[39557.980647] __dev_printk+0x60/0x84
[39557.980647] _dev_err+0x6c/0x94
[39557.980648] mpp_reg_show+0x80/0x94
[39557.980649] rkvenc2_task_timeout_process+0xcc/0xe0
[39557.980649] rkvenc2_wait_result+0x288/0x790
[39557.980650] mpp_dev_ioctl+0x4bc/0x790
[39557.980651] __arm64_sys_ioctl+0xb4/0x100
[39557.980652] el0_svc_common.constprop.0+0xa4/0x2a0
[39557.980652] do_el0_svc+0x78/0xa0
[39557.980653] el0_svc+0x20/0x30
[39557.980654] el0_sync_handler+0xe8/0xf0
[39557.980654] el0_sync+0x1a0/0x1c0
[39557.980661] CPU7: stopping
[39557.980664] CPU4: stopping
[39557.980666] CPU3: stopping
[39557.980669] CPU0: stopping
[39557.980672] CPU2: stopping
[39557.980674] CPU1: stopping
[39557.980677] CPU5: stopping
[39557.980682] CPU: 4 PID: 1602 Comm: CHASSIS_FAN Tainted: G W O 5.10.110 #5
[39558.011751] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.012259] Call trace:
[39558.012481] dump_backtrace+0x0/0x1e0
[39558.012811] show_stack+0x24/0x30
[39558.013108] dump_stack_lvl+0xd0/0xf8
[39558.013437] dump_stack+0x18/0x38
[39558.013734] local_cpu_stop+0x78/0x80
[39558.014064] ipi_handler+0x170/0x280
[39558.014384] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.014851] __handle_domain_irq+0x80/0xe0
[39558.015212] gic_handle_irq+0x100/0x36c
[39558.015553] el1_irq+0xcc/0x180
[39558.015840] __delay+0x9c/0xb4
[39558.016114] __const_udelay+0x2c/0x3c
[39558.016452] ds18b20_read+0x48/0x140 [ds18b20]
[39558.016852] vfs_read+0xb8/0x1b0
[39558.017138] ksys_read+0x74/0x100
[39558.017434] __arm64_sys_read+0x28/0x34
[39558.017776] el0_svc_common.constprop.0+0xa4/0x2a0
[39558.018207] do_el0_svc+0x78/0xa0
[39558.018502] el0_svc+0x20/0x30
[39558.018776] el0_sync_handler+0xe8/0xf0
[39558.019116] el0_sync+0x1a0/0x1c0
[39558.019413] CPU: 0 PID: 8943 Comm: maicroship Tainted: G W O 5.10.110 #5
[39558.020102] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.020605] Call trace:
[39558.020828] dump_backtrace+0x0/0x1e0
[39558.021160] show_stack+0x24/0x30
[39558.021458] dump_stack_lvl+0xd0/0xf8
[39558.021789] dump_stack+0x18/0x38
[39558.022087] local_cpu_stop+0x78/0x80
[39558.022418] ipi_handler+0x170/0x280
[39558.022739] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.023199] __handle_domain_irq+0x80/0xe0
[39558.023561] gic_handle_irq+0x100/0x36c
[39558.023903] el0_irq_naked+0x4c/0x54
[39558.024223] CPU: 7 PID: 167 Comm: queue_work9 Tainted: G W O 5.10.110 #5
[39558.024909] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.025409] Call trace:
[39558.025630] dump_backtrace+0x0/0x1e0
[39558.025960] show_stack+0x24/0x30
[39558.026254] dump_stack_lvl+0xd0/0xf8
[39558.026580] dump_stack+0x18/0x38
[39558.026876] local_cpu_stop+0x78/0x80
[39558.027205] ipi_handler+0x170/0x280
[39558.027522] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.027979] __handle_domain_irq+0x80/0xe0
[39558.028339] gic_handle_irq+0x100/0x36c
[39558.028677] el1_irq+0xcc/0x180
[39558.028963] mutex_lock+0x10/0x70
[39558.029262] kthread_worker_fn+0xe0/0x1b0
[39558.029624] kthread+0x134/0x140
[39558.029907] ret_from_fork+0x10/0x3c
[39558.030227] CPU: 2 PID: 8957 Comm: maicroship Tainted: G W O 5.10.110 #5
[39558.030915] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.031417] Call trace:
[39558.031641] dump_backtrace+0x0/0x1e0
[39558.031972] show_stack+0x24/0x30
[39558.032271] dump_stack_lvl+0xd0/0xf8
[39558.032600] dump_stack+0x18/0x38
[39558.032899] local_cpu_stop+0x78/0x80
[39558.033230] ipi_handler+0x170/0x280
[39558.033549] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.034009] __handle_domain_irq+0x80/0xe0
[39558.034371] gic_handle_irq+0x100/0x36c
[39558.034712] el1_irq+0xcc/0x180
[39558.034999] __arch_copy_to_user+0x1a0/0x220
[39558.035386] _copy_to_iter+0x98/0x4d0
[39558.035721] simple_copy_to_iter+0x2c/0x44
[39558.036084] __skb_datagram_iter+0x18c/0x264
[39558.036468] skb_copy_datagram_iter+0x60/0xd0
[39558.036860] tcp_recvmsg+0x5ac/0x9d0
[39558.037183] inet_recvmsg+0x68/0x11c
[39558.037506] __sys_recvfrom+0x11c/0x160
[39558.037846] __arm64_sys_recvfrom+0x30/0x40
[39558.038221] el0_svc_common.constprop.0+0xa4/0x2a0
[39558.038649] do_el0_svc+0x78/0xa0
[39558.038947] el0_svc+0x20/0x30
[39558.039223] el0_sync_handler+0xe8/0xf0
[39558.039565] el0_sync+0x1a0/0x1c0
[39558.039865] CPU: 1 PID: 271787 Comm: sleep Tainted: G W O 5.10.110 #5
[39558.040532] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.041034] Call trace:
[39558.041258] dump_backtrace+0x0/0x1e0
[39558.041590] show_stack+0x24/0x30
[39558.041888] dump_stack_lvl+0xd0/0xf8
[39558.042218] dump_stack+0x18/0x38
[39558.042517] local_cpu_stop+0x78/0x80
[39558.042848] ipi_handler+0x170/0x280
[39558.043169] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.043630] __handle_domain_irq+0x80/0xe0
[39558.043991] gic_handle_irq+0x100/0x36c
[39558.044333] el1_irq+0xcc/0x180
[39558.044621] _raw_spin_unlock_irqrestore+0x28/0x5c
[39558.045054] release_pages+0x268/0x3c0
[39558.045389] free_pages_and_swap_cache+0xec/0x100
[39558.045809] tlb_finish_mmu+0x8c/0x1d0
[39558.046141] exit_mmap+0xf8/0x204
[39558.046439] mmput+0x7c/0x130
[39558.046707] do_exit+0x2d8/0x954
[39558.046993] do_group_exit+0x44/0xa4
[39558.047312] __arm64_sys_exit_group+0x24/0x2c
[39558.047697] el0_svc_common.constprop.0+0xa4/0x2a0
[39558.048125] do_el0_svc+0x78/0xa0
[39558.048422] el0_svc+0x20/0x30
[39558.048699] el0_sync_handler+0xe8/0xf0
[39558.049041] el0_sync+0x1a0/0x1c0
[39558.049339] CPU: 3 PID: 8529 Comm: airiaship_compr Tainted: G W O 5.10.110 #5
[39558.050062] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.050565] Call trace:
[39558.050789] dump_backtrace+0x0/0x1e0
[39558.051120] show_stack+0x24/0x30
[39558.051419] dump_stack_lvl+0xd0/0xf8
[39558.051749] dump_stack+0x18/0x38
[39558.052047] local_cpu_stop+0x78/0x80
[39558.052378] ipi_handler+0x170/0x280
[39558.052699] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.053159] __handle_domain_irq+0x80/0xe0
[39558.053520] gic_handle_irq+0x100/0x36c
[39558.053862] el1_irq+0xcc/0x180
[39558.054149] __tcp_transmit_skb+0xf8/0xaf0
[39558.054513] __tcp_send_ack.part.0+0xd4/0x1b0
[39558.054897] tcp_send_ack+0x30/0x40
[39558.055206] tcp_cleanup_rbuf+0x88/0x110
[39558.055559] tcp_recvmsg+0x1dc/0x9d0
[39558.055878] inet_recvmsg+0x68/0x11c
[39558.056197] __sys_recvfrom+0x11c/0x160
[39558.056540] __arm64_sys_recvfrom+0x30/0x40
[39558.056915] el0_svc_common.constprop.0+0xa4/0x2a0
[39558.057343] do_el0_svc+0x78/0xa0
[39558.057641] el0_svc+0x20/0x30
[39558.057919] el0_sync_handler+0xe8/0xf0
[39558.058260] el0_sync+0x1a0/0x1c0
[39558.058561] CPU: 5 PID: 111 Comm: kconsole Tainted: G W O 5.10.110 #5
[39558.059225] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39558.059732] Call trace:
[39558.059955] dump_backtrace+0x0/0x1e0
[39558.060288] show_stack+0x24/0x30
[39558.060584] dump_stack_lvl+0xd0/0xf8
[39558.060914] dump_stack+0x18/0x38
[39558.061211] local_cpu_stop+0x78/0x80
[39558.061543] ipi_handler+0x170/0x280
[39558.061862] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39558.062326] __handle_domain_irq+0x80/0xe0
[39558.062689] gic_handle_irq+0x100/0x36c
[39558.063029] el1_irq+0xcc/0x180
[39558.063319] console_thread+0xf4/0x2c0
[39558.063649] kthread+0x134/0x140
[39558.063935] ret_from_fork+0x10/0x3c
[39559.065900] rockchip-thermal fec00000.tsadc: channal 0: temperature(37 C)
[39559.066537] SMP: stopping secondary CPUs
[39559.066538] DSU CRU:
[39559.066539] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066540] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066542] 00000040: 000000c8 00002042 ffff0000 00000000 00000002 000007e0 00004000 00000000
[39559.066543] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066544] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066545] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066546] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066547] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066547] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066548] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066549] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066550] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066551] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066552] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066553] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066554] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066554] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066555] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066556] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066557] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066558] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066559] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066560] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066561] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066562] 00000300: 0000b0c0 00001083 00000843 00000063 00000665 0000403f 000020c1 0000e0c1
[39559.066563] 00000320: 00000000 00000000 00000000 00000000
[39559.066563] BIGCORE0 CRU:
[39559.066564] 00000000: 000000c8 00002042 ffff0000 00000000 00000002 000007e0 00004000 00000000
[39559.066565] 00000020: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066566] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066567] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066568] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066569] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066570] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066570] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066571] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066572] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066574] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066575] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066576] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066577] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066578] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066579] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066580] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066581] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066582] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066582] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066584] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066584] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066585] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066586] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066586] BIGCORE1 CRU:
[39559.066587] 00000000: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066588] 00000020: 000000c8 00002042 ffff0000 00000000 00000002 000007e0 00004000 00000000
[39559.066589] 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066590] 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066591] 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066592] 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066593] 000000c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066593] 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066594] 00000100: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066595] 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066596] 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066597] 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066598] 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066598] 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066599] 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066600] 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066601] 00000200: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066601] 00000220: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066602] 00000240: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066603] 00000260: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066604] 00000280: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066605] 000002a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066606] 000002c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066606] 000002e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[39559.066607] CPU0 online:0
[39559.066608] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066608] EL2(NS) PC: <0xffffffc01002a570> local_cpu_stop+0x50/0x80
[39559.066609] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066610]
[39559.066611] CPU1 online:0
[39559.066612] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066612]
[39559.066612] CPU2 online:0
[39559.066613] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066614]
[39559.066614] CPU3 online:0
[39559.066615] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066615]
[39559.066616] CPU4 online:0
[39559.066616] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066617]
[39559.066617] CPU5 online:0
[39559.066617] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066618]
[39559.066618] CPU6 online:1
[39559.066619] EL2(NS) PC: <0xffffffc0109e14f0> rockchip_panic_notify+0x370/0x450
[39559.066619]
[39559.066619] CPU7 online:0
[39559.066620] EL2(NS) PC: <0xffffffc01002a568> local_cpu_stop+0x48/0x80
[39559.066620]
[39559.066621] CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7
[39559.066622] 9: 0 0 0 0 0 0 0 0 GICv3 25 Level vgic
[39559.066623] 11: 0 0 0 0 0 0 0 0 GICv3 30 Level kvm guest ptimer
[39559.066624] 12: 0 0 0 0 0 0 0 0 GICv3 27 Level kvm guest vtimer
[39559.066625] 13: 32995628 37537186 37840717 39508731 24632195 20607319 22260541 22412967 GICv3 26 Level arch_timer
[39559.066626] 14: 640793 2614662 2602298 2544409 2016838 2106917 1522533 1454836 GICv3 321 Level rk_timer
[39559.066627] 15: 0 0 0 0 0 0 0 0 GICv3 23 Level arm-pmu
[39559.066628] 16: 2920 0 0 0 0 0 0 0 GICv3 105 Level dmc
[39559.066629] 17: 5972 0 0 0 0 0 0 0 GICv3 126 Level fb000000.gpu
[39559.066630] 18:
[39559.066631] Lost 216 message(s)!
[39559.141209] ------------[ cut here ]------------
[39559.141210] WARNING: CPU: 6 PID: 8609 at kernel/irq_work.c:95 irq_work_queue_on+0xc8/0xd0
[39559.141211] Modules linked in: ds18b20(O) ft5436(O) bcmdhd dhd_static_buf ahci_platform libahci_platform libahci libata scsi_mod ip_tables x_tables
[39559.141215] CPU: 6 PID: 8609 Comm: mpp_dec_parser Tainted: G W O 5.10.110 #5
[39559.141217] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39559.141218] pstate: 20400089 (nzCv daIf +PAN -UAO -TCO BTYPE=–)
[39559.141218] pc : irq_work_queue_on+0xc8/0xd0
[39559.141219] lr : update_util_handler+0x84/0x94
[39559.141220] sp : ffffffc01287bb50
[39559.141220] x29: ffffffc01287bb50 x28: ffffff8100922c40
[39559.141221] x27: 0000000000000000 x26: 0000000000000000
[39559.141223] x25: ffffffc0123eb318 x24: ffffffc0123ea000
[39559.141224] x23: ffffffc011064f90 x22: 0000000000000005
[39559.141225] x21: ffffff82fef1d408 x20: ffffff82fef1e740
[39559.141226] x19: ffffff82fef1d408 x18: 0000000000000022
[39559.141228] x17: 0000000000000022 x16: 0000000000000000
[39559.141230] x15: 0000000000000000 x14: ffffffc0115c9550
[39559.141231] x13: ffffffc012409f08 x12: 0000000000000000
[39559.141232] x11: 0000000000000013 x10: 0000000000000001
[39559.141233] x9 : ffffffc011064fec x8 : 000000000000b69c
[39559.141236] x7 : 000000000000001e x6 : 0000000000000400
[39559.141237] x5 : 0000000000000400 x4 : ffffffc0123ea8d8
[39559.141238] x3 : 0000000000000000 x2 : 0000000000000007
[39559.141239] x1 : ffffff82fef1d418 x0 : 0000000000000000
[39559.141240] Call trace:
[39559.141241] irq_work_queue_on+0xc8/0xd0
[39559.141242] update_util_handler+0x84/0x94
[39559.141243] update_load_avg+0x4b8/0x5c0
[39559.141244] enqueue_entity+0x70/0x6d4
[39559.141244] enqueue_task_fair+0x78/0x4f0
[39559.141245] enqueue_task+0x70/0x33c
[39559.141246] ttwu_do_activate+0x64/0x110
[39559.141246] try_to_wake_up+0x220/0x7e0
[39559.141247] default_wake_function+0x2c/0x50
[39559.141248] autoremove_wake_function+0x24/0x50
[39559.141248] __wake_up_common+0x8c/0x17c
[39559.141249] __wake_up_common_lock+0x80/0xd0
[39559.141250] __wake_up+0x24/0x30
[39559.141250] wake_up_klogd_work_func+0x74/0x84
[39559.141251] irq_work_single+0x3c/0x74
[39559.141251] irq_work_run_list+0x50/0x6c
[39559.141252] irq_work_run+0x34/0x44
[39559.141253] ipi_handler+0x1a8/0x280
[39559.141253] handle_percpu_devid_fasteoi_ipi+0x9c/0x174
[39559.141255] __handle_domain_irq+0x80/0xe0
[39559.141256] gic_handle_irq+0x100/0x36c
[39559.141256] el1_irq+0xcc/0x180
[39559.141257] _raw_spin_unlock_irq+0x24/0x50
[39559.141258] finish_task_switch+0x8c/0x280
[39559.141258] __schedule+0x384/0x97c
[39559.141259] schedule+0x54/0xe0
[39559.141259] futex_wait_queue_me+0xb8/0x140
[39559.141260] futex_wait+0xe0/0x200
[39559.141260] do_futex+0x144/0xc1c
[39559.141261] __arm64_sys_futex+0x124/0x1a0
[39559.141262] el0_svc_common.constprop.0+0xa4/0x2a0
[39559.141262] do_el0_svc+0x78/0xa0
[39559.141263] el0_svc+0x20/0x30
[39559.141264] el0_sync_handler+0xe8/0xf0
[39559.141264] el0_sync+0x1a0/0x1c0
[39559.141265]
[39559.141265] PC: 0xffffffc0101d2a2c:
[39559.141266] 282c d50323bf d65f03c0 d500409f d500419f d53cd059 d53cd041 d53cd041 d53cd042
[39559.141269] 284c d53cd042 d503245f b9400801 d503233f 36080081 d503203f b9400801 370fffc1
[39559.141272] 286c d50323bf d65f03c0 d503233f d50323bf d65f03c0 d503233f a9bf7bfd aa0003e1
[39559.141275] 288c 910003fd b9400802 910003e3 36100162 f000e1c2 9129c042 d53cd043 8b030042
[39559.141278] 28ac 941a0ac9 72001c1f 54000201 a8c17bfd d50323bf d65f03c0 f000e1c2 9129c042
[39559.141282] 28cc 91002042 d53cd043 8b030042 941a0abe 72001c1f 54fffec0 97f96310 a8c17bfd
[39559.141285] 28ec d50323bf d65f03c0 97fe00d4 72001c1f 54ffff41 a8c17bfd d50323bf d65f03c0
[39559.141288] 290c d503201f d503233f a9be7bfd 91002005 910003fd 52800462 f9000bf3 f98000b1
[39559.141291] 292c 885f7ca1 2a020023 8804fca3 35ffffa4 d5033bbf 2a2103e1 12000033 36000041
[39559.141295] 294c 97ffffcd 2a1303e0 f9400bf3 a8c27bfd d50323bf d65f03c0 d503245f 7100003f
[39559.141298] 296c 1100fc23 1a81b063 d503233f a9be7bfd 900110c4 13067c63 910003fd 91236084
[39559.141301] 298c 93407c63 f9000bf3 2a0103e2 aa0003e1 f8637880 9ac22400 36000440 91002026
[39559.141305] 29ac 52800463 f98000d1 885f7cc0 2a030004 8805fcc4 35ffffa5 d5033bbf 2a2003e0
[39559.141308] 29cc 12000013 360001a0 b000e140 91002000 d53cd043 b8636800 6b02001f 540001c0
[39559.141311] 29ec d5384100 b9401000 720c0c1f 54000101 2a0203e0 97fe1ff1 2a1303e0 f9400bf3
[39559.141314] 2a0c a8c27bfd d50323bf d65f03c0 d4210000 17fffff8 aa0103e0 97ffff97 17fffff7
[39559.141317] 2a2c* d4210000 17ffffde d503245f f000e1c0 9129c000 91002001 d503233f d53cd042
[39559.141320] 2a4c f8626821 f8626800 b4000220 b000e140 91002000 b8626802 900110c3 91236063
[39559.141323] 2a6c 52800020 7100005f 1100fc41 1a82b021 13067c21 93407c21 f8617861 9ac22422
[39559.141326] 2a8c 360000c2 d50323bf d65f03c0 52800000 d50323bf d65f03c0 d4210000 17fffffa
[39559.141329] 2aac d503201f d503233f a9be7bfd 52800021 910003fd 91002004 a90153f3 aa0003f3
[39559.141332] 2acc f9800091 885f7c94 0a210282 8803fc82 35ffffa3 d5033bbf f9400801 d63f0020
[39559.141335] 2aec 927f7a81 121e7680 91002264 f9800091 885f7c83 4a010062 35000082 8802fc80
[39559.141338] 2b0c 35ffff82 d5033bbf a94153f3 a8c27bfd d50323bf d65f03c0 d53b4222 12190041
[39559.141341] 2b2c 34000301 f9400001 b40002a1 d503233f a9be7bfd d2800001 910003fd f9000bf3
[39559.141344] 2b4c f9800011 c85f7c13 c802fc01 35ffffc2 d5033bbf b40000d3 d503201f aa1303e0
[39559.141347] 2b6c f9400273 97ffffd0 b5ffffb3 f9400bf3 a8c27bfd d50323bf d65f03c0 d65f03c0
[39559.141350] 2b8c d4210000 d503233f a9be7bfd f000e1c0 910003fd f9000bf3 9129c013 d53cd041
[39559.141353] 2bac 91002260 8b010000 97ffffdc d53cd041 8b010260 97ffffd9 f9400bf3 a8c27bfd
[39559.141356] 2bcc d50323bf d65f03c0 d503233f a9bf7bfd f000e1c0 9129c000 910003fd 91002001
[39559.141359] 2bec d53cd042 f8626821 8b020000 97ffffcb a8c17bfd d50323bf d65f03c0 d53cd043
[39559.141362] 2c0c d53cd043 d53cd043 d53cd042 d5384602 521b0841 d53cd041 d53cd041 d53cd042
[39559.141365]
[39559.141365] LR: 0xffffffc011065014:
[39559.141366] 4e14 f9407aa1 f240027f 9a971303 b873d822 aa1b03e1 97e1d077 b940faa2 8b20c294
[39559.141370] 4e34 11000673 8b1402c0 6b13005f 54fffeac a94363f7 d1000681 f9402bfb 52800140
[39559.141372] 4e54 78216ac0 aa1903e1 aa1a03e0 9414b17d aa1403e0 a94153f3 a9425bf5 a9446bf9
[39559.141375] 4e74 a8c67bfd d50323bf d65f03c0 92800001 d2800014 17fffff2 d503201f d503245f
[39559.141379] 4e94 aa1e03e9 d503201f d503233f a9ba7bfd 910003fd a9025bf5 aa0003f5 aa0103f6
[39559.141382] 4eb4 a9046bf9 9102801a aa1a03e0 a90153f3 9414b147 b940c2a1 aa0003f9 7100003f
[39559.141386] 4ed4 5400056d a90363f7 b0005557 9107c2f7 f9002bfb d0005498 9000593b aa1703e3
[39559.141389] 4ef4 f9405ea1 aa1603e0 91220318 911da37b 52800013 d2800014 b9400022 14000005
[39559.141392] 4f14 f9405ea1 f240027f 9a971303 b873d822 aa1b03e1 97e1d037 b940c2a2 8b20c294
[39559.141395] 4f34 11000673 8b1402c0 6b13005f 54fffeac a94363f7 d1000681 f9402bfb 52800140
[39559.141398] 4f54 78216ac0 aa1903e1 aa1a03e0 9414b13d aa1403e0 a94153f3 a9425bf5 a9446bf9
[39559.141400] 4f74 a8c67bfd d50323bf d65f03c0 92800001 d2800014 17fffff2 d503201f d503245f
[39559.141404] 4f94 aa1e03e9 d503201f d503233f a9be7bfd 910003fd f9000bf3 aa0003f3 3940e000
[39559.141406] 4fb4 35000300 f9400660 f9401662 f9400404 cb020022 f9406883 d37be860 cb030000
[39559.141409] 4fd4 8b000860 eb000c5f 540001c3 f9001661 b940d080 97c34de6 aa0003e3 f0009c00
[39559.141412] 4ff4 52800022 3900e262 f944c002 91004260 b9412261 8b030042 f9001a62 97c5b655
[39559.141415] 5014* f9400bf3 a8c27bfd d50323bf d65f03c0 d503245f aa1e03e9 d503201f d503233f
[39559.141419] 5034 a9bb7bfd 910003fd a90153f3 12800013 a9025bf5 b0009c36 912a82d6 a90363f7
[39559.141422] 5054 aa0003f7 f90023f9 f9402c00 f9400014 14000002 97c25e42 2a1303e0 aa1403e1
[39559.141425] 5074 97e176b3 2a0003f3 b94002c1 6b01001f 54ffff23 d0006d58 d0009c39 91102318
[39559.141428] 5094 910c6339 12800014 97c326e5 1400000e f8745b33 8b130313 91010275 aa1503e0
[39559.141431] 50b4 9414a503 91004260 97c5b5e5 3900e27f 91020260 97c361ea f900067f aa1503e0
[39559.141434] 50d4 97c27138 2a1403e0 aa1703e1 97e17698 2a0003f4 b94002c2 6b00005f 54fffda8
[39559.141438] 50f4 a94153f3 a9425bf5 a94363f7 f94023f9 a8c57bfd d50323bf d65f03c0 d503245f
[39559.141441] 5114 aa1e03e9 d503201f d503233f a9bb7bfd 910003fd a90153f3 a9025bf5 aa0003f5
[39559.141444] 5134 a90363f7 f90023f9 29470801 6b02003f 540005e3 b9403401 6b01005f 54000523
[39559.141447] 5154 d0006d56 b0009c37 911022d6 d0009c38 912a82f7 910c6318 12800013 14000004
[39559.141449] 5174 b900fa83 aa1903e0 9414b0b6 2a1303e0 aa1503e1 97e1766e 2a0003f3 b94002e1
[39559.141453] 5194 6b00003f 54000209 f8735b14 8b1402d4 91038299 aa1
[39559.141455] Lost 4528 message(s)!
[39559.220038] ------------[ cut here ]------------
[39559.220039] WARNING: CPU: 6 PID: 0 at kernel/rcu/tree.c:624 rcu_eqs_enter.constprop.0+0x9c/0x104
[39559.220039] Modules linked in: ds18b20(O) ft5436(O) bcmdhd dhd_static_buf ahci_platform libahci_platform libahci libata scsi_mod ip_tables x_tables
[39559.220044] CPU: 6 PID: 0 Comm: swapper/6 Tainted: G W O 5.10.110 #5
[39559.220045] Hardware name: Firefly ITX-3588J MIPI(Linux) (DT)
[39559.220045] pstate: 20c00089 (nzCv daIf +PAN +UAO -TCO BTYPE=–)
[39559.220046] pc : rcu_eqs_enter.constprop.0+0x9c/0x104
[39559.220046] lr : rcu_idle_enter+0x1c/0x30
[39559.220047] sp : ffffffc012a6be90
[39559.220047] x29: ffffffc012a6be90 x28: 0000000000000000
[39559.220048] x27: 0000000000000000 x26: 0000000000000000
[39559.220049] x25: 000023fa19d51e17 x24: ffffffc0126e96c0
[39559.220050] x23: 0000000000000000 x22: ffffff81043f3880
[39559.220051] x21: ffffff81043f3898 x20: ffffff82feefd568
[39559.220052] x19: ffffffc011e11680 x18: 0000000000000000
[39559.220053] x17: 0000000000000000 x16: 0000000000000000
[39559.220054] x15: 0000000000000000 x14: 0000000000000400
[39559.220055] x13: 0000000000000003 x12: ffffff82feede940
[39559.220056] x11: ffffff82feede940 x10: 0000000000000a80
[39559.220057] x9 : ffffffc01106b51c x8 : ffffff81008c2860
[39559.220059] x7 : ffffff82fee9e740 x6 : 000000c49eb612da
[39559.220060] x5 : 00ffffffffffffff x4 : 0000000000000015
[39559.220061] x3 : 00002000003c0e4e x2 : 4000000000000002
[39559.220062] x1 : 4000000000000000 x0 : ffffff82feeff680
[39559.220063] Call trace:
[39559.220064] rcu_eqs_enter.constprop.0+0x9c/0x104
[39559.220064] rcu_idle_enter+0x1c/0x30
[39559.220065] cpuidle_enter_state+0x23c/0x420
[39559.220066] cpuidle_enter+0x44/0x5c
[39559.220066] do_idle+0x238/0x2e4
[39559.220067] cpu_startup_entry+0x34/0x6c
[39559.220067] secondary_start_kernel+0x190/0x1ec
[39559.220068]
[39559.220068] PC: 0xffffffc011588edc:
[39559.220070] 8cdc d5033bbf d50323bf d65f03c0 d503201f d503201f d53cd041 b0004440 911a0000
[39559.220073] 8cfc 8b010000 d503233f 91040003 f9800071 885f7c61 11000821 8802fc61 35ffffa2
[39559.220076] 8d1c d5033bbf 36000121 52800021 aa0303e0 f9800011 885f7c02 0a210042 88037c02
[39559.220079] 8d3c 35ffffa3 d5033bbf d50323bf d65f03c0 d503201f d503233f a9be7bfd 910003fd
[39559.220082] 8d5c d53cd040 f9000bf3 b0004453 911a0273 8b000273 f9407a60 b40000e0 91000400
[39559.220085] 8d7c f9007a60 f9400bf3 a8c27bfd d50323bf d65f03c0 97ffffd8 90008b00 912b0000
[39559.220089] 8d9c b9410264 b9400801 7100003f 5400016c f9407e60 d2800021 f9007a61 b50003c0
[39559.220092] 8dbc d2e80000 f9007e60 f9400bf3 a8c27bfd d50323bf d65f03c0 f0004381 91002021
[39559.220096] 8ddc d53cd042 b8626822 d0007303 91236063 7100005f 1100fc41 1a82b021 13067c21
[39559.220099] 8dfc 93407c21 f8617861 9ac22422 3607fd22 f0008ee1 f9407a62 f9414021 f9401c00
[39559.220102] 8e1c b4000080 f9400400 d2800023 97ae6002 17ffffe0 d4210000 17ffffe2 d503201f
[39559.220105] 8e3c d503201f d503233f a9be7bfd d2e80001 910003fd f9000bf3 b0004453 911a0273
[39559.220109] 8e5c d53cd042 aa1303e0 8b020000 f9407c02 eb01005f 54000361 f9407802 f9007c1f
[39559.220113] 8e7c f100045f 540000e0 d1000442 f9007802 f9400bf3 a8c27bfd d50323bf d65f03c0
[39559.220116] 8e9c 90008b03 912b0063 b9410004 910003e0 aa0003e1 b9400865 710000bf 5400016c
[39559.220119] 8ebc d53cd040 8b000273 f9007a7f 97ffff7a f9400bf3 a8c27bfd d50323bf d65f03c0
[39559.220122] 8edc* d4210000 17ffffe5 f0004385 910020a5 d53cd047 aa0503e0 d0007306 b8676805
[39559.220125] 8efc 912360c6 710000bf 1100fca0 1a85b000 13067c00 93407c00 f86078c0 9ac52405
[39559.220129] 8f1c 3607fd05 f0008ee0 f9419001 f9401c60 b4000080 f9400400 d2800003 97ae5fbe
[39559.220131] 8f3c 910003e1 17ffffdf d503233f a9be7bfd b0004440 910003fd 911a0000 910003e1
[39559.220134] 8f5c f9000bf3 aa0003f3 d53cd042 8b020273 f9407e62 f100005f 540009ad d53cd041
[39559.220138] 8f7c 8b010000 b9410000 36080960 f9407e62 90008b00 b9410264 912b0000 f100045f
[39559.220141] 8f9c 54000140 b9400801 d1000843 7100003f 5400050c f9007e63 f9400bf3 a8c27bfd
[39559.220144] 8fbc d50323bf d65f03c0 b9400801 7100003f 5400014c f9007e7f d5384113 b9401260
[39559.220147] 8fdc 97ffff35 b9401260 f9400bf3 a8c27bfd d50323bf d65f03c0 f0004381 91002021
[39559.220151] 8ffc d53cd043 b8636823 b0007305 912360a5 7100007f 1100fc61 1a83b021 13067c21
[39559.220154] 901c 93407c21 f86178a1 9ac32423 3607fd43 d0008ee1 f941fc21 f9401c00 b4000080
[39559.220158] 903c f9400400 d2800003 97ae5f7b 17ffffe2 d0004381 91002021 d53cd045 b8656825
[39559.220161] 905c b0007306 912360c6 710000bf 1100fca1 1a85b021 13067c21 93407c21 f86178c1
[39559.220164] 907c 9ac52425 3607f985 d0008ee1 f941f821 f9401c00 b4000060 f9400400 97ae5f66
[39559.220168] 909c f9407e63 d1000863 17ffffc3 d4210000 17ffffb3 d4210000 17ffffb5 d503201f
[39559.220171] 90bc d503201f d503233f a9bf7bfd 910003fd 97ffff9e a8c17bfd d50323bf d65f03c0
[39559.220174]
[39559.220175] LR: 0xffffffc01012c3ac:
[39559.220175] c1ac b9400880 7100001f 54fff30d f000e660 91002016 aa1603e0 d00115e3 d53cd041
[39559.220179] c1cc b8616801 91236063 7100003f 1100fc20 1a81b000 13067c00 93407c00 f8607860
[39559.220182] c1ec 9ac12401 3607f121 f00131c0 d0011e01 f9418803 f9444c21 f9401c80 b4000060
[39559.220185] c20c f9400400 97ffd1b0 f9400262 17ffff7f f9400e81 aa1603e0 94001357 aa1303e1
[39559.220188] c22c aa1403e0 97fffe68 12001c15 90012de4 91210084 39004a7f f9400262 b9400880
[39559.220191] c24c 7100001f 54ffee2d 17ffffd9 aa1603e0 d00115e5 d53cd041 b8616801 912360a5
[39559.220194] c26c 7100003f 1100fc20 1a81b000 13067c00 93407c00 f86078a0 9ac12401 3607f361
[39559.220197] c28c f00131c0 d0011e01 f9418c03 f9444c21 f9401c40 b4000080 f9400400 aa0403e2
[39559.220200] c2ac 97ffd189 910003e3 17ffff90 d503201f d503201f aa1e03e9 d503201f d503233f
[39559.220203] c2cc a9bd7bfd 910003fd a90153f3 aa0003f3 f90013f5 d53b4235 121902a0 34000400
[39559.220206] c2ec f9400e74 f9400261 f9400e80 eb00003f 540001c1 39405260 72001c1f 54000161
[39559.220209] c30c d51b4235 900136c0 b9439800 7100001f 5400036c a94153f3 f94013f5 a8c37bfd
[39559.220212] c32c d50323bf d65f03c0 aa1403e0 945192ee 34fffe80 aa1303e1 aa1403e0 97ffff1a
[39559.220215] c34c 12001c13 aa1503e1 aa1403e0 9451943f 34fffe33 97fff2a5 17ffffef 900136c2
[39559.220218] c36c d2801401 d2800c00 b9439042 7100005f 9a81d000 d50342df 17ffffda d5033f9f
[39559.220222] c38c 17ffffe5 d503245f aa1e03e9 d503201f d503233f a9bf7bfd 910003fd 945172a6
[39559.220225] c3ac* a8c17bfd d50323bf d65f03c0 d503201f d503201f d503245f aa1e03e9 d503201f
[39559.220227] c3cc d503233f a9be7bfd 91040002 910003fd f9000bf3 aa0003f3 f9800051 885f7c40
[39559.220230] c3ec 0b1f0000 8801fc40 35ffffa1 d5033bbf 121f7801 b900ea61 360800c0 52800000
[39559.220233] c40c f9400bf3 a8c27bfd d50323bf d65f03c0 90012de0 91290000 b9400801 7100003f
[39559.220236] c42c 540002ac f9400e62 92f80003 f9400260 f9400c41 8b030000 eb01001f 54000144
[39559.220239] c44c f940ae62 92f80003 52800020 8b030042 eb01005f 54fffd65 8b030021 f900ae61
[39559.220242] c46c 17ffffe8 52800020 39005260 f9400c41 17fffff4 f000e661 91002021 d53cd042
[39559.220246] c48c b8626822 d00115e3 91236063 7100005f 1100fc41 1a82b021 13067c21 93407c21
[39559.220248] c4ac f8617861 9ac22422 3607fbe2 f00131c3 d0011e01 f9400262 f9419464 f9444c21
[39559.220251] c4cc b9418a63 f9401c00 b4000060 f9400400 97ffd219 17ffffd4 d503245f aa1e03e9
[39559.220254] c4ec d503201f d503233f a9b27bfd d5384100 910003fd a90153f3 d0011e13 91100273
[39559.220257] c50c a9025bf5 d00115e3 91236063 a90363f7 f00115d6 90012df7 a9046bf9 d00115f5
[39559.220261] c52c 90013598 a90573fb 912102f7 912602d6 f942a001 f9006fe1 d2800001 f00131c0
[39559.220264] c54c 91082000 a9070fe0 b000e720 911a0000 90012de3 91230063 f9004be0 90000000
[39559.220269] c56c 910f0000 f90033e3 b0000003 911bc063 a90a0fe0 f00115e0 910c6000 912722b5
[39559.220272] c58c f9416662 91262318 f9424e61 f90047e0 d00115e0 9126e000 f9004fe0 f000e660
[39559.220276]
[39559.220276] SP: 0xffffffc012a6be90:
[39559.220276] bc90 12a6bd40 ffffffc0 125c4b08 ffffffc0 12a6bcc0 ffffffc0 1003b888 ffffffc0
[39559.220280] bcb0 12a6bd40 ffffffc0 00000006 00000000 12a6bd00 ffffffc0 115873a4 ffffffc0
[39559.220283] bcd0 12a6bd40 ffffffc0 f2000800 00000000 b0028078 0000007f 11588edc ffffffc0
[39559.220286] bcf0 12a6bd00 ffffffc0 11587394 ffffffc0 12a6bd30 ffffffc0 11587b6c ffffffc0
[39559.220289] bd10 11e11680 ffffffc0 ffffffff 0000007f
[39559.220291] Lost 4127 message(s)!
您好,请问您解决了吗?怎么解决的呢?
