基于官方提供的ubuntu固件 nfs服务器启动失败
固件文件名称:AIO-3399C_Ubuntu18.04-r240_v2.5.1d_230330.img
Log日志:MobaXterm_COM6SiliconLabsCP210xUSBtoUARTBridgeCOM6_20230605_143505.zip
说明:
上传的log日志为开机启动日志,其中有个报错:[FAILED] Failed to start NFSv4 ID-name mapping service.
See ‘systemctl status nfs-idmapd.service’ for details.
root@firefly:~# systemctl status nfs-idmapd.service
● nfs-idmapd.service - NFSv4 ID-name mapping service
Loaded: loaded (/lib/systemd/system/nfs-idmapd.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2023-06-05 07:17:45 UTC; 10min ago
Process: 1646 ExecStart=/usr/sbin/rpc.idmapd $RPCIDMAPDARGS (code=exited, status=1/FAILURE)
Jun 05 07:17:45 firefly systemd[1]: Starting NFSv4 ID-name mapping service…
Jun 05 07:17:45 firefly rpc.idmapd[1648]: main: fcntl(/run/rpc_pipefs/nfs): Invalid argument
Jun 05 07:17:45 firefly systemd[1]: nfs-idmapd.service: Control process exited, code=exited status=1
Jun 05 07:17:45 firefly systemd[1]: nfs-idmapd.service: Failed with result ‘exit-code’.
Jun 05 07:17:45 firefly systemd[1]: Failed to start NFSv4 ID-name mapping service.
1、nfs服务器启动失败root@firefly:~# service rpcbind status
● rpcbind.service - RPC bind portmap service
Loaded: loaded (/lib/systemd/system/rpcbind.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2021-02-19 03:20:15 UTC; 2 years 3 months ago
Docs: man:rpcbind(8)
Main PID: 598 (rpcbind)
Tasks: 1 (limit: 4596)
CGroup: /system.slice/rpcbind.service
└─598 /sbin/rpcbind -f -w
Feb 19 03:20:15 firefly systemd[1]: Starting RPC bind portmap service…
Feb 19 03:20:15 firefly systemd[1]: Started RPC bind portmap service.
root@firefly:~# service nfs-kernel-server restart
Job for nfs-server.service canceled.
root@firefly:~# service nfs-kernel-server status
● nfs-server.service - NFS server and services
Loaded: loaded (/lib/systemd/system/nfs-server.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2023-06-05 07:17:45 UTC; 3min 28s ago
Process: 1653 ExecStopPost=/usr/sbin/exportfs -f (code=exited, status=0/SUCCESS)
Process: 1652 ExecStopPost=/usr/sbin/exportfs -au (code=exited, status=0/SUCCESS)
Process: 1651 ExecStartPre=/usr/sbin/exportfs -r (code=exited, status=1/FAILURE)
Jun 05 07:17:45 firefly systemd[1]: Starting NFS server and services…
Jun 05 07:17:45 firefly exportfs[1651]: exportfs: /etc/exports:2: unknown keyword “no_root_aquash”
Jun 05 07:17:45 firefly systemd[1]: nfs-server.service: Control process exited, code=exited status=1
Jun 05 07:17:45 firefly systemd[1]: nfs-server.service: Failed with result ‘exit-code’.
Jun 05 07:17:45 firefly systemd[1]: Stopped NFS server and services.
共享目录创建后已配置到文件中 /etc/exports
2、启动nfs客户端也同样失败
root@firefly:~# service nfs-common restart
Job for nfs-common.service failed because the control process exited with error code.
See “systemctl status nfs-common.service” and “journalctl -xe” for details.
root@firefly:~# service nfs-common status
● nfs-common.service - LSB: NFS support files common to client and server
Loaded: loaded (/etc/init.d/nfs-common; generated)
Active: failed (Result: exit-code) since Mon 2023-06-05 07:22:44 UTC; 14s ago
Docs: man:systemd-sysv-generator(8)
Process: 1701 ExecStart=/etc/init.d/nfs-common start (code=exited, status=1/FAILURE)
CGroup: /system.slice/nfs-common.service
└─1709 /sbin/rpc.statd
Jun 05 07:22:44 firefly systemd[1]: Starting LSB: NFS support files common to client and server…
Jun 05 07:22:44 firefly nfs-common[1701]: * Starting NFS common utilities
Jun 05 07:22:44 firefly rpc.statd[1709]: Version 1.3.3 starting
Jun 05 07:22:44 firefly sm-notify[1710]: Version 1.3.3 starting
Jun 05 07:22:44 firefly nfs-common[1701]: …fail!
Jun 05 07:22:44 firefly systemd[1]: nfs-common.service: Control process exited, code=exited status=1
Jun 05 07:22:44 firefly systemd[1]: nfs-common.service: Failed with result ‘exit-code’.
Jun 05 07:22:44 firefly systemd[1]: Failed to start LSB: NFS support files common to client and serv
查看系统已载入的文件系统,已包含有nfs
root@firefly:~# cat /proc/filesystems
nodev sysfs
nodev rootfs
nodev ramfs
nodev bdev
nodev proc
nodev cpuset
nodev cgroup
nodev cgroup2
nodev tmpfs
nodev devtmpfs
nodev configfs
nodev debugfs
nodev tracefs
nodev securityfs
nodev sockfs
nodev pipefs
nodev rpc_pipefs
nodev devpts
ext3
ext2
ext4
squashfs
nodev hugetlbfs
vfat
iso9660
nodev nfs
nodev nfs4
nodev nfsd
ntfs
nodev autofs
fuseblk
nodev fuse
nodev fusectl
nodev overlay
xfs
nodev pstore
nodev mqueue
btrfs
nodev functionfs
MobaXterm_COM6SiliconLabsCP210xUSBtoUARTBridgeCOM6_20230605_143505.zip (21.3 KB)
