IPQ4019 IPQ4029 IPQ6010 Wireless Socs Support Openwrt OpenWifi
Great news for all networking enthusiasts and OpenWrt/OpenWiFi supporters! It’s time to celebrate as the highly anticipated support for IPQ4019, IPQ4029, and IPQ6010 has been added to OpenWrt and OpenWiFi!
For those who may not be familiar, OpenWrt is a popular open-source operating system for embedded devices, particularly routers. It provides a customizable and feature-rich platform that allows users to take control of their network devices and tailor them to their specific needs.
The IPQ4019, IPQ4029, and IPQ6010 are powerful and versatile system-on-a-chip (SoC) solutions developed by Qualcomm Technologies. These chips are commonly used in a wide range of networking devices, including routers, access points, and gateways, due to their robust performance, advanced features, and excellent wireless capabilities.
Now, with the addition of support for these Qualcomm chips in OpenWrt and OpenWiFi, users can take full advantage of the open-source ecosystem to enhance and customize their networking devices. Whether you’re a networking professional, a hobbyist, or simply someone looking to optimize your home network, this development opens up a world of possibilities.
With OpenWrt/OpenWiFi on IPQ4019, IPQ4029, and IPQ6010, you can:
Enjoy the flexibility of open-source software, enabling you to modify, extend, and fine-tune your network device to suit your specific requirements.
Strengthen security by leveraging the robust security features and active community support provided by OpenWrt/OpenWiFi.
Explore a vast range of additional features, including VPN support, advanced QoS (Quality of Service), VLAN support, guest networks, and much more.
Benefit from frequent updates and bug fixes contributed by the vibrant OpenWrt/OpenWiFi community.
Whether you’re a developer or an end-user, this development unlocks new possibilities for networking customization and performance optimization. You can now unleash the full potential of your IPQ4019, IPQ4029, or IPQ6010-powered devices with OpenWrt and OpenWiFi.
So, if you’re passionate about networking and crave the freedom to customize your networking devices, it’s time to dive into the world of OpenWrt and OpenWiFi. Join the active community, explore the extensive documentation, and start transforming your IPQ4019, IPQ4029, or IPQ6010-based devices into networking powerhouses!
Remember, the possibilities are endless when open-source and powerful hardware come together. Happy networking with OpenWrt and OpenWiFi on IPQ4019, IPQ4029, and IPQ6010!
Wallys IPQ 6010 Networking Socs
1.DR6018
Website:
https://www.wallystech.com/Routerboard/DR6018V4-wifi6-Qualcomm-IPQ6010-IPQ6018-FAMILY-2T2R-2.5G-ETH-port-supporting-5G-celluar-Modem-802-11AX-MU-MIMO-OFDMA.html
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth
