Introducing the WiFi 5 Networking Socs IPQ4019 IPQ4029 IPQ4018 IPQ4028
Are you tired of slow and unreliable internet connections? Say hello to the WiFi 5 Networking Solution, featuring the powerful IPQ4019, IPQ4029, IPQ4018, and IPQ4028 chipsets. These cutting-edge networking solutions are designed to provide lightning-fast and stable wireless connections for a wide range of applications.
What is WiFi 5?
WiFi 5, also known as 802.11ac, is the fifth generation of wireless networking technology. It offers significant improvements over its predecessors, delivering faster speeds, better coverage, and increased capacity. WiFi 5 operates on the 5GHz frequency band and supports multiple input, multiple output (MIMO) technology for enhanced performance.
The Power of IPQ4019:
The IPQ4019 is a high-performance networking chipset built to deliver exceptional wireless connectivity. It features a quad-core ARM Cortex-A7 processor and supports 2x2 MIMO with up to 867 Mbps wireless speeds. With its advanced features and robust performance, the IPQ4019 is ideal for residential and small business environments.
Unleash the IPQ4029:
The IPQ4029 takes WiFi 5 networking to the next level. It boasts a quad-core ARM Cortex-A53 processor and supports 4x4 MIMO, delivering wireless speeds of up to 1.7 Gbps. With its advanced beamforming and MU-MIMO capabilities, the IPQ4029 ensures seamless connectivity in busy network environments, making it suitable for medium-sized businesses and high-density deployments.
Empowering with IPQ4018:
The IPQ4018 is a versatile networking solution designed for enterprise-grade applications. It features a quad-core ARM Cortex-A7 processor and supports 2x2 MIMO with up to 867 Mbps wireless speeds. Equipped with advanced security features, the IPQ4018 provides a reliable and secure wireless network for businesses, schools, and healthcare facilities.
Uncompromising Performance with IPQ4028:
The IPQ4028 offers unparalleled performance and reliability for demanding networking environments. It features a quad-core ARM Cortex-A53 processor and supports 4x4 MIMO, enabling wireless speeds of up to 1.7 Gbps. The IPQ4028 also incorporates advanced QoS (Quality of Service) features, ensuring optimal performance for voice, video, and data applications.
Robust Security:
The WiFi 5 Networking Solution with IPQ4019, IPQ4029, IPQ4018, and IPQ4028 chipsets prioritizes security. It supports the latest security protocols, including WPA3, to safeguard your network from unauthorized access and ensure the privacy of your data.
Applications:
The WiFi 5 Networking Solution is suitable for various applications, including:
1Home Networks: Enjoy fast and reliable internet connections for streaming, gaming, and smart home devices.
2Small Businesses: Create a robust wireless network for small offices, cafes, and retail stores.
3Medium-Sized Businesses: Provide reliable and high-performance WiFi for mid-sized offices, warehouses, and venues.
4Enterprises: Build secure and scalable networks for large organizations, hospitals, and educational institutions.
Upgrade your wireless network with the WiFi 5 Networking Solution featuring the IPQ4019, IPQ4029, IPQ4018, and IPQ4028 chipsets. Say goodbye to slow connections and embrace the power of fast, reliable, and secure WiFi!
Wallys support All IPQ4019, IPQ4029, IPQ4018, IPQ4028 wireless solutions
1.DR4018L
Website:
[b]https://www.wallystech.com/Routerboard/DR4018L-Qualcomm-IPQ4018-2T2R-Dual-Band-2-4GHz-5GHz-support-MU-MIMO-802.11ac-Wave-2.html[/b]
Featuring with industrial-grade IPQ4018 chipset
Integrated with 2x 2 5G Radio module and 2x2 Radio module
Support 5.180GHz to 5.825GHz Frequency Range
Support 2.412GHz to 2.482GHz
Support 2 x 5G UFL Connectors and 2x2.4G UFL
20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC wave2 mode
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
2.DR4019
Website [b][u]https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html[/u][/b]
Product Parameter
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Storage Humidity Range 0 to +90 (non-condensing)%
Hardware Specifications
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional)
3G/4G 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
