We are thrilled to announce the arrival of a dynamic duo that will take your wireless networking experience to new heights. Presenting the cutting-edge IPQ6018 chipset paired with the QCN9074 radio module, creating an unbeatable combination that supports an impressive 180+ clients simultaneously.
The IPQ6018 is a state-of-the-art system-on-a-chip (SoC) designed for high-performance Wi-Fi routers and access points. Powered by the latest technologies, this chipset boasts exceptional processing power, advanced wireless capabilities, and robust security features. With its quad-core ARM Cortex-A53 CPU and integrated 2x2 Wi-Fi 6 support, the IPQ6018 provides blazing-fast speeds and low latency, ensuring smooth and reliable connectivity for all your devices.
Taking the IPQ6018’s capabilities to the next level is the QCN9074 radio module. This radio module is built on the advanced Wi-Fi 6E standard, leveraging the 6 GHz frequency band to deliver unparalleled wireless performance. With 4x4 MU-MIMO technology and beamforming capabilities, the QCN9074 provides exceptional coverage, increased capacity, and reduced interference. It allows you to connect and serve a staggering 180+ clients concurrently, making it ideal for crowded environments such as stadiums, large offices, or public venues.
But it doesn’t stop there! The IPQ6018 with QCN9074 offers additional features that ensure a seamless networking experience. With support for the latest Wi-Fi security protocols, such as WPA3, your network remains protected against unauthorized access. Furthermore, advanced Quality of Service (QoS) capabilities prioritize bandwidth allocation, ensuring that each connected device receives the necessary resources for optimal performance.
Whether you’re a tech enthusiast, a business owner, or a network administrator, the IPQ6018 with QCN9074 opens up a world of possibilities. Enjoy lightning-fast speeds, robust connectivity, and the ability to serve an impressive number of clients simultaneously.
Stay tuned for upcoming products that harness the power of the IPQ6018 with QCN9074, as leading networking equipment manufacturers integrate this exceptional combo into their latest routers and access points. Upgrade your wireless experience and embrace the future of connectivity!
1. DR6018
Website:
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mmDR9074E
2 DR9074
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Data Rateup to 4949Mbps
■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
BY:https://www.wallystech.com/
More detail and opportunities attach Emile:sales4@wallystech.com. This is Jane for you
