In the rapidly evolving world of wireless communication, Wally has emerged as a leading innovator with their groundbreaking IPQ6010, IPQ6018, and IPQ6000 wireless solutions. These cutting-edge technologies are designed to support long-distance transmission of data, covering an impressive range of up to 23 kilometers. Let’s delve deeper into these remarkable wireless solutions.
IPQ6010: Pushing Boundaries in Long-Range Communication
The IPQ6010 by Wally is a game-changer when it comes to long-range wireless transmission. Powered by advanced technology, this solution offers exceptional performance, enabling seamless connectivity over distances of up to 23 kilometers. Whether you’re looking to establish robust wireless links for rural connectivity, industrial applications, or remote monitoring, the IPQ6010 has got you covered.
IPQ6018: Empowering High-Speed Connectivity
For scenarios that demand high-speed communication over long distances, Wally’s IPQ6018 comes to the fore. With its impressive range capabilities of up to 23 kilometers, this solution provides lightning-fast data transfer rates, ensuring that your network remains robust and reliable. Whether it’s video streaming, large file transfers, or real-time communication, the IPQ6018 delivers an exceptional wireless experience.
IPQ6000: A Versatile Wireless Solution for Diverse Applications
The IPQ6000 wireless solution from Wally offers a versatile range of features and applications. With its ability to support long-distance transmission of up to 23 kilometers, the IPQ6000 is ideal for various industries and scenarios. It can be deployed in sectors such as telecommunications, transportation, smart cities, and more. Its adaptability and reliability make it a powerful tool for extending connectivity to previously unreachable areas.
Wallys Commitment to Cutting-Edge Technology
Wally is renowned for its commitment to pushing the boundaries of wireless communication. With the IPQ6010, IPQ6018, and IPQ6000 wireless solutions, they have successfully addressed the challenge of long-range transmission, enabling connectivity over vast distances of up to 23 kilometers. These solutions open up new possibilities for industries, businesses, and communities, bridging the digital divide and transforming the way we connect.
Embrace the Future of Wireless Connectivity with Wally
Wallys IPQ6010, IPQ6018, and IPQ6000 wireless solutions represent a significant leap forward in wireless technology. With their remarkable range capabilities and robust performance, these solutions enable seamless long-range transmission of up to 23 kilometers. By embracing Wally’s innovative wireless solutions, you can unlock a world of possibilities and usher in a new era of connectivity.
1.DR6018
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
More detail and opportunities attach Emile :sales4@wallystech.com. This is Jane for you
Connect. Innovate. Thrive. Together with Wallys.
