ROC-RK3588S-PC主板上跑buildroot,如何打开NEON?
SDK包名称:rk3588_linux_release_20230114_v1.06c
SDK修改内容:buildroot/arch/Config.in.arm
512 config BR2_cortex_a76_a55
513 bool "cortex-A76/A55 big.LITTLE"
514 select BR2_ARM_CPU_HAS_ARM if !BR2_ARCH_IS_64
515 select BR2_ARM_CPU_HAS_NEON if !BR2_ARCH_IS_64
Log日志:log.zip
RK3588如何打开NEON?
支持NEON需要打开 BR2_ARM_CPU_HAS_NEON配置,从buildroot上看 这个配置默认是关闭,如果强行打开 编译会报错,是否有解决方案?
错误log:
2023-06-19T17:20:48 checking whether /work/code/rk3588.2/hvml_rk3588s/buildroot/output/firefly_rk3588/host/bin/aarch64-buildroot-linux-gnu-gcc knows __sync_bool_compare_and_swap()… yes
2023-06-19T17:20:49 configure: error: *** Compiler does not support -mfpu=neon or CFLAGS override -mfpu
2023-06-19T17:20:49 make: *** [package/pkg-generic.mk:287: /work/code/rk3588.2/hvml_rk3588s/buildroot/output/firefly_rk3588/build/pulseaudio-14.2/.stamp_configured] Error 1
log.zip (426 Bytes)
你好。这个问题有解决了吗?
