The Cost-effective WiFi 6E Solution: DR5018 with IPQ5018 and QCN6122
Faster, more reliable, and with expanded capacity, WiFi 6E is the latest breakthrough in wireless technology. Today, we are excited to introduce the DR5018, a cost-effective WiFi 6E solution that combines the power of IPQ5018 and QCN6122 to deliver unparalleled performance and connectivity.
The DR5018 is built upon the IPQ5018 system-on-chip (SoC), which boasts a quad-core ARM Cortex-A53 CPU and a powerful Qualcomm Hexagon 683 DSP. This combination ensures robust processing power and enables the device to handle high data traffic and complex network demands with ease.
The QCN6122 is a cutting-edge WiFi 6E chipset that supports 2x2 dual-band concurrent operation, offering simultaneous connections on both 2.4 GHz and 5 GHz frequency bands. This allows for efficient utilization of available spectrum and provides seamless connectivity across a wide range of devices.
With the DR5018, you can experience the following benefits:
Blazing Fast Speeds: WiFi 6E brings gigabit speeds to your fingertips, ensuring lightning-fast downloads, smooth streaming, and lag-free online gaming. Say goodbye to buffering and enjoy a seamless online experience.
Enhanced Capacity: The DR5018’s support for WiFi 6E enables it to utilize the newly available 6 GHz frequency band, providing additional channels for congestion-free connections. This means more devices can connect simultaneously without sacrificing performance.
Lower Latency: The combination of IPQ5018 and QCN6122 reduces latency, allowing for near-instantaneous response times. This is especially crucial for applications such as online gaming, video conferencing, and real-time IoT interactions.
Extended Range: WiFi 6E utilizes wider channels and higher transmission power, resulting in increased coverage and improved signal strength. Whether you’re in a large office or a multi-story home, the DR5018 ensures a stable and reliable connection throughout your space.
Secure Connectivity: The DR5018 incorporates advanced security features, including WPA3 encryption and improved protection against common vulnerabilities. Your network and connected devices remain safeguarded from potential threats.
The DR5018 with IPQ5018 and QCN6122 is a cost-effective WiFi 6E solution that offers exceptional performance, improved capacity, and reliable connectivity. Whether you’re a business looking to upgrade your wireless infrastructure or a homeowner seeking a high-speed, future-proof network, the DR5018 is the perfect choice.
Learn more about the DR5018 and how it can transform your wireless experience Wallys
DR5018
https://www.wallystech.com/Routerboard/DR5018-wifi6-Qualcomm-IPQ5018-2T2R-2.5G-ETH-port-802.11AX-MU-MIMO-OFDMA-supporting-QCN9074-wifi-card.htm
Feature:
Dual-core ARM 64bit A53@1.0GHz Processor
512MB DDRL3L System Memory
4MB NOR Flash, 128MB NAND Flash
2x2 On-board 2.4GHz radio,up to 573Mbps physical Data Rate
Support BT5.1
Absolute Maximum Rating:
Supply Voltage 12 V
Storage Temperature Range -45 to +105ºC
Hardware Specifications:
CPU: Qualcomm-Atheros IPQ5018
CPU Frequency: Dual-core ARM 64 bit A53 @1.0 GHz processor
System Memory:512MB DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port:4 x 1Gbps Ethernet Ports or 1 x 1Gbps Ethernet Port & Poe
NGFF Slot:M.2 Card Slot for 5G (QUECTEL RM 500Q-GL) ;M.2 Card Slot for QCN9074 WIFI 6E Card
EMMC:4G/8G(optional)
USB /header:1x USB 3.0 Port
POE:NA
DC Jack:12V power supply
LED header LED for power ,Wifi strength
Serial Port support
Wireless:On-board 2x22.4GHz MU-MIMO OFDMA: 802.11b/802.11g/802.11n/802.11ax,max 23dBm per chain
2x IPEX Connectors
Bluetooth: BT5.1
Nor Flash: 8MB
Nand Flash: 128 MB
DDR: 512MB
Dimension:170mm x 120mm x 15mm[/url]
Our company:
Wallys Communications (SuZhou) Co.,Ltd was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
