Wallys IPQ4019 IPQ4029 QCA9880 Socs :Powerful to 802.11ac Wave 2 standard
IPQ4019 Motherboard:
The IPQ4019 is a high-performance, highly integrated System-on-Chip (SoC) designed for networking applications. It offers advanced features and capabilities that make it ideal for building powerful and efficient routers, access points, and other networking devices. Here are some key highlights:
:one: Processing Power: The IPQ4019 boasts a quad-core ARM Cortex-A7 CPU clocked at up to 717 MHz, providing ample processing power to handle data-intensive networking tasks.
:two: Wireless Connectivity: It includes a built-in 2.4 GHz and 5 GHz Wi-Fi radios, supporting the latest wireless standards such as 802.11ac Wave 2. This enables fast and reliable wireless connections for devices in your network.
:three: Networking Interfaces: The motherboard offers multiple Gigabit Ethernet ports, allowing you to connect wired devices with high-speed, low-latency connections.
:four: Hardware Acceleration: The IPQ4019 supports hardware acceleration for network packet processing, enabling efficient handling of network traffic and improved overall performance.
:gear: QCA9880 Mini PCIe Card:
The QCA9880 is a Mini PCIe wireless network card from Qualcomm Atheros, renowned for its quality and performance. It provides excellent wireless connectivity options for various networking applications. Here are its noteworthy features:
:one: Wireless Speeds: The QCA9880 supports 3-stream 802.11ac technology, delivering wireless speeds of up to 1.3 Gbps. This allows for faster file transfers, smooth streaming, and lag-free online gaming experiences.
:two: Dual-Band Support: With simultaneous dual-band functionality, the card operates in both the 2.4 GHz and 5 GHz frequency bands. This ensures flexibility in connecting devices to the most suitable frequency, depending on their capabilities and the network environment.
:three: MIMO Technology: Multiple-Input Multiple-Output (MIMO) technology is supported by the QCA9880, enhancing wireless performance and reliability by utilizing multiple antennas for improved signal strength and coverage.
:four: Mini PCIe Form Factor: The card comes in a compact Mini PCIe form factor, making it compatible with a wide range of devices such as laptops, mini PCs, and embedded systems.
Combining the IPQ4019 motherboard and the QCA9880 Mini PCIe card can unlock a world of possibilities for your networking setup. Whether you’re building a high-performance router or upgrading an existing network device, these components provide the power and wireless capabilities needed for a seamless and efficient networking experience. Happy networking
1.DR4019
Website https://www.wallystech.com/Routerboard/DR40X9-Qualcomm-IPQ-4019-4029-DUAL-BAND-802.11AC-WAVE2-MU-MIMO-ONBOARD-WIFI-RADIO-EMBEDDED-BOARD-supporting-LTE.html
Product Parameter
Featuring with industrial-grade IPQ4019/IPQ4029 chipset
Integrated with 2x 2 5G high power Radio module and 2x2 2.4G high power Radio module
Support 4.940GHz to 5.825GHz Frequency Range
Support 2.400GHz to 2.482GHz
Support 2 x 5G MMCX Connectors and 2x2.4G MMCX
Support 5MHz/10MHz/20MHz/40MHz/80MHz Bandwidth
Support 11ABGN/AC
Support fixed data rate
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
Our Firmware supports all the modules of Quectel
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Storage Humidity Range 0 to +90 (non-condensing)%
Hardware Specifications
Symbol Parameter
CPU IPQ4029(Quad core ARM Cortex A7 at 716.8 MHz)
Antenna Connector 2 x 5G MMCX connectors;2x2.4G MMCX 10/100/1000Mbps Gigabit Ethernet
2xRJ45
SFP connector 1xSFP fiber module connector (optional)
3G/4G 1xminipcie 3G/4G connector support with two sim card
USB connector 1xUSB 3.0 connector
POE 24V~48V passive POE
DC Jack 24V~48V power supply
ROHS ComplianceYES
Dimension115mm x 105mm x 16mm
Max Power48.1V x 0.180A= 8.658W
Nor Flash2MB~32MB
Nand Flash128MB
DDR 256MB~512MB
Our company:
Wallys Communications (Suzhou) Co., LTD https://www.wallystech.com/index.html
EMAIL:​sales4@wallystech.com
