固件文件名称:rk356x_linux_release_20220726_v1.3.0a
固件下载地址:rk356x_linux_release_20220726_v1.3.0a
Log日志:2#核心板系统故障日志_2023-06-27_17_23_48.zip
核心板运行一段时间后,不能正常启动,日志如下 ,烦请各位大佬指点 ,出现此情况的原因是什么 ?
ddrconfig:7
LP4 MR14:0x4d
LPDDR4, 324MHz
BW=32 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=4096MB
tdqss: cs0 dqs0: 361ps, dqs1: 265ps, dqs2: 289ps, dqs3: 192ps,
tdqss: cs1 dqs0: 361ps, dqs1: 265ps, dqs2: 313ps, dqs3: 192ps,
change to: 324MHz
PHY drv:clk:38,ca:38,DQ:30,odt:0
vrefinner:41%, vrefout:41%
dram drv:40,odt:0
clk skew:0x58
change to: 528MHz
dram drv:40,odt:0
clk skew:0x7d
change to: 780MHz
dram drv:40,odt:0
clk skew:0x64
change to: 1560MHz(final freq)
PHY drv:clk:38,ca:38,DQ:30,odt:60
vrefinner:16%, vrefout:29%
dram drv:40,odt:80
vref_ca:00000068
clk skew:0x17
cs 0:
the read training result:
DQS0:0x2d, DQS1:0x2c, DQS2:0x37, DQS3:0x2a,
min :0x11 0x13 0x13 0xf 0x2 0x5 0x9 0x5 , 0xc 0xd 0x6 0x2 0xb 0x9 0xb 0x5 ,
0x17 0x19 0x11 0x12 0x8 0x1 0x6 0x7 , 0xb 0xb 0x8 0x1 0x7 0xd 0x8 0xb ,
mid :0x27 0x29 0x29 0x27 0x18 0x1a 0x1e 0x19 ,0x23 0x24 0x1c 0x18 0x22 0x1e 0x21 0x1b ,
0x30 0x32 0x2a 0x29 0x1f 0x1a 0x1e 0x1e ,0x22 0x22 0x20 0x19 0x1f 0x22 0x20 0x21 ,
max :0x3e 0x40 0x40 0x3f 0x2e 0x30 0x33 0x2d ,0x3b 0x3b 0x32 0x2f 0x3a 0x33 0x38 0x31 ,
0x4a 0x4b 0x43 0x41 0x36 0x33 0x37 0x36 ,0x3a 0x39 0x39 0x31 0x38 0x37 0x38 0x38 ,
range:0x2d 0x2d 0x2d 0x30 0x2c 0x2b 0x2a 0x28 ,0x2f 0x2e 0x2c 0x2d 0x2f 0x2a 0x2d 0x2c ,
0x33 0x32 0x32 0x2f 0x2e 0x32 0x31 0x2f ,0x2f 0x2e 0x31 0x30 0x31 0x2a 0x30 0x2d ,
the write training result:
DQS0:0x5f, DQS1:0x4b, DQS2:0x50, DQS3:0x3d,
min :0x94 0x9a 0x9c 0x99 0x8b 0x8e 0x91 0x92 0x90 ,0x7f 0x82 0x7a 0x79 0x84 0x83 0x83 0x7d 0x7a ,
0x89 0x8b 0x84 0x87 0x79 0x77 0x7a 0x7c 0x7f ,0x73 0x73 0x70 0x6b 0x75 0x77 0x73 0x77 0x6d ,
mid :0xb0 0xb6 0xb7 0xb4 0xa3 0xa8 0xab 0xac 0xab ,0x9a 0x9a 0x93 0x92 0x9c 0x99 0x9a 0x96 0x94 ,
0xa5 0xa6 0x9d 0xa0 0x93 0x90 0x92 0x95 0x97 ,0x8e 0x8d 0x8b 0x87 0x8e 0x92 0x8d 0x92 0x87 ,
max :0xcd 0xd2 0xd2 0xcf 0xbc 0xc3 0xc6 0xc6 0xc6 ,0xb5 0xb3 0xac 0xab 0xb5 0xb0 0xb2 0xb0 0xaf ,
0xc2 0xc2 0xb7 0xb9 0xad 0xa9 0xaa 0xaf 0xb0 ,0xaa 0xa7 0xa6 0xa3 0xa8 0xad 0xa7 0xad 0xa2 ,
range:0x39 0x38 0x36 0x36 0x31 0x35 0x35 0x34 0x36 ,0x36 0x31 0x32 0x32 0x31 0x2d 0x2f 0x33 0x35 ,
0x39 0x37 0x33 0x32 0x34 0x32 0x30 0x33 0x31 ,0x37 0x34 0x36 0x38 0x33 0x36 0x34 0x36 0x35 ,
cs 1:
DQS0:0x2d, DQS1:0x29, DQS2:0x33, DQS3:0x28,
min :0x10 0x13 0x14 0x11 0x2 0x7 0x8 0x5 , 0x9 0xc 0x5 0x1 0xa 0x8 0x9 0x4 ,
0x16 0x19 0x10 0xf 0x5 0x1 0x3 0x5 , 0xb 0xa 0x7 0x2 0x8 0xe 0xa 0xe ,
mid :0x26 0x2a 0x2a 0x28 0x17 0x1c 0x1d 0x19 ,0x1f 0x21 0x1a 0x16 0x20 0x1c 0x1f 0x19 ,
0x2d 0x2f 0x27 0x24 0x1a 0x18 0x1a 0x1a ,0x21 0x20 0x1f 0x18 0x20 0x22 0x20 0x23 ,
max :0x3d 0x41 0x41 0x40 0x2d 0x32 0x33 0x2e ,0x36 0x37 0x2f 0x2c 0x37 0x30 0x35 0x2f ,
0x44 0x46 0x3e 0x3a 0x30 0x2f 0x31 0x30 ,0x37 0x36 0x37 0x2f 0x39 0x37 0x37 0x39 ,
range:0x2d 0x2e 0x2d 0x2f 0x2b 0x2b 0x2b 0x29 ,0x2d 0x2b 0x2a 0x2b 0x2d 0x28 0x2c 0x2b ,
0x2e 0x2d 0x2e 0x2b 0x2b 0x2e 0x2e 0x2b ,0x2c 0x2c 0x30 0x2d 0x31 0x29 0x2d 0x2b ,
min :0x93 0x9a 0x9a 0x99 0x89 0x8d 0x8f 0x90 0x8f ,0x7c 0x7c 0x77 0x76 0x7f 0x7d 0x7f 0x7c 0x79 ,
0x8e 0x90 0x87 0x8a 0x7c 0x7a 0x7c 0x82 0x85 ,0x75 0x74 0x73 0x6e 0x76 0x78 0x73 0x7a 0x6e ,
mid :0xae 0xb4 0xb4 0xb3 0xa2 0xa7 0xa9 0xa9 0xa8 ,0x97 0x97 0x90 0x8f 0x98 0x95 0x97 0x94 0x92 ,
0xaa 0xab 0xa1 0xa5 0x97 0x94 0x96 0x9a 0x9e ,0x8e 0x8c 0x8b 0x86 0x8e 0x91 0x8b 0x92 0x86 ,
max :0xca 0xcf 0xcf 0xcd 0xbb 0xc1 0xc4 0xc2 0xc2 ,0xb3 0xb2 0xaa 0xa9 0xb2 0xad 0xaf 0xad 0xac ,
0xc7 0xc7 0xbc 0xc1 0xb2 0xaf 0xb0 0xb3 0xb7 ,0xa8 0xa5 0xa3 0x9f 0xa7 0xab 0xa4 0xaa 0x9f ,
range:0x37 0x35 0x35 0x34 0x32 0x34 0x35 0x32 0x33 ,0x37 0x36 0x33 0x33 0x33 0x30 0x30 0x31 0x33 ,
0x39 0x37 0x35 0x37 0x36 0x35 0x34 0x31 0x32 ,0x33 0x31 0x30 0x31 0x31 0x33 0x31 0x30 0x31 ,
CA Training result:
cs:0 min :0x4d 0x41 0x42 0x31 0x41 0x2f 0x4d ,0x4b 0x36 0x3d 0x2f 0x3f 0x2e 0x4a ,
cs:0 mid :0x82 0x82 0x77 0x75 0x76 0x70 0x72 ,0x80 0x7a 0x72 0x6f 0x73 0x6e 0x70 ,
cs:0 max :0xb7 0xc4 0xad 0xb9 0xac 0xb2 0x97 ,0xb5 0xbe 0xa8 0xaf 0xa8 0xaf 0x97 ,
cs:0 range:0x6a 0x83 0x6b 0x88 0x6b 0x83 0x4a ,0x6a 0x88 0x6b 0x80 0x69 0x81 0x4d ,
cs:1 min :0x3f 0x45 0x37 0x37 0x36 0x36 0x36 ,0x40 0x3c 0x3a 0x34 0x39 0x34 0x36 ,
cs:1 mid :0x80 0x80 0x74 0x71 0x74 0x6f 0x6f ,0x81 0x7a 0x74 0x6e 0x74 0x6d 0x6d ,
cs:1 max :0xc1 0xbc 0xb1 0xac 0xb2 0xa8 0xa9 ,0xc3 0xb9 0xaf 0xa8 0xaf 0xa6 0xa4 ,
cs:1 range:0x82 0x77 0x7a 0x75 0x7c 0x72 0x73 ,0x83 0x7d 0x75 0x74 0x76 0x72 0x6e ,
out
U-Boot SPL board init
U-Boot SPL 2017.09(u-boot commit id: 02accb940fa124f562f99de3acb5cf14face82e5)(sdk version: rk356x_linux_release_20220726_v1.3.0a.xml)-g02accb940f #root (Nov 03 2022 - 18:30:46)
Trying to boot from MMC2
mmc_init: -95, time 9
Trying to boot from MMC1
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 … sha256(6204b6f381…) + OK
## Checking uboot 0x00a00000 … sha256(84621eb095…) + OK
## Checking fdt 0x00b2fba8 … sha256(dbcc8ef6d0…) + OK
## Checking atf-2 0xfdcc1000 … sha256(5563d929da…) + OK
## Checking atf-3 0x0006a000 … sha256(b04372ab0f…) + OK
## Checking atf-4 0xfdcd0000 … sha256(b46eaa95b8…) + OK
## Checking atf-5 0xfdcce000 … sha256(2f8839c803…) + OK
## Checking atf-6 0x00068000 … sha256(6e9d32ba23…) + OK
## Checking optee 0x08400000 … sha256(66bbd17352…) + OK
Total: 152.677 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-365-gae7c295ca:derrick.huang
NOTICE: BL31: Built : 15:37:13, May 17 2022
INFO: pmu v1 is valid 220114
INFO: dfs DDR fsp_param[0].freq_mhz= 1560MHz
INFO: boot cpu mask: 0
INFO: BL31: Initializing BL32
I/TC:
I/TC: OP-TEE version: 3.13.0-641-g4167319d3 #hisping.lin (gcc version 10.2.1 20201103 (GNU Toolchain for the A-profile Architecture 10.2-2020.11 (arm-10.16))) #8 Wed Mar 16 15:14:56 CST 2022 aarch64
INFO: SPSR = 0x3c9
U-Boot 2017.09(u-boot commit id: 02accb940fa124f562f99de3acb5cf14face82e5)(sdk version: rk356x_linux_release_20220726_v1.3.0a.xml)-g02accb940f #root (Nov 03 2022 - 18:30:46 +0800)
Model: Firefly RK3568 Board
PreSerial: 2, raw, 0xfe660000
DRAM: 4 GiB
Sysmem: init
Relocation Offset: ed349000
Relocation fdt: eb9f8880 - eb9fecd8
CR: M/C/I
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
DM: v1
boot mode: None
** File not found rk-kernel.dtb **
No resource partition
Failed to load DTB, ret=-19
No find valid DTB, ret=-22
Failed to get kernel dtb, ret=-22
io-domain: OK
rockchip_set_serialno: could not find efuse/otp device
apll 816000 KHz
dpll 780000 KHz
gpll 1188000 KHz
cpll 1000000 KHz
npll 24000 KHz
vpll 24000 KHz
hpll 24000 KHz
ppll 200000 KHz
armclk 816000 KHz
aclk_bus 150000 KHz
pclk_bus 50000 KHz
aclk_top_high 300000 KHz
aclk_top_low 200000 KHz
hclk_top 150000 KHz
pclk_top 50000 KHz
aclk_perimid 300000 KHz
hclk_perimid 150000 KHz
pclk_pmu 100000 KHz
Net: No ethernet found.
optee api revision: 2.0
Not AVB images, AVB skip
No valid android hdr
Android image load failed
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
## Booting Rockchip Format Image
Could not find kernel partition, ret=-1
switch to partitions #0, OK
Scanning mmc 0:3…
## Error: “mtd_boot” not defined
starting USB…
Bus dwc3@fcc00000: Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: Register 2000140 NbrPorts 2
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices… 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices… 1 USB Device(s) found
scanning usb for storage devices… 0 Storage Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: pxeuuid
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
2#核心板系统故障日志_2023-06-27_17_23_48.zip (5.21 KB)
