Are you ready to experience the next level of wireless connectivity? Look no further than Wally’s cutting-edge QCN9074 Wireless Solution, designed to revolutionize your wireless experience with its exceptional features and support for 2.4G, 5G, and 6E selectable frequencies
Seamless Connectivity:
With Wally’s QCN9074 Wireless Solution, you can enjoy seamless connectivity across multiple frequencies, allowing you to connect to the best available wireless network in any given environment. Whether you’re browsing the web, streaming your favorite movies, or engaging in online gaming, this solution provides reliable and high-speed connections, ensuring a smooth and uninterrupted experience.
Dual-Band Flexibility:
The QCN9074 Wireless Solution offers dual-band support, catering to both the 2.4GHz and 5GHz frequencies. The 2.4GHz band provides extended coverage and better penetration through walls and obstacles, making it ideal for larger spaces. On the other hand, the 5GHz band offers faster speeds and less interference, making it perfect for bandwidth-intensive tasks such as HD video streaming and online gaming.
6E Selectable Frequency:
But that’s not all! Wally’s QCN9074 Wireless Solution goes a step further by introducing support for the groundbreaking 6E frequency band. The 6E band utilizes the 6GHz spectrum, providing ultra-fast speeds and significantly reduced congestion. This allows for an exceptional wireless experience in crowded areas and dense environments, making it perfect for smart homes, offices, and public spaces.
Future-Proof Technology:
By supporting both 5G and 6E frequencies, Wally’s QCN9074 Wireless Solution ensures that you’re ready for the future of wireless connectivity. As more devices adopt these advanced frequencies, you can rest assured that your network will be able to handle the demands of tomorrow.
��� Enhanced Security:
Wally’s QCN9074 Wireless Solution prioritizes your security. It incorporates the latest encryption protocols and security features, ensuring that your data remains safe and protected while you enjoy the benefits of fast and reliable wireless connections.
Easy Integration:
Wally’s QCN9074 Wireless Solution is designed for easy integration into a variety of devices and applications. Whether you’re a manufacturer looking to enhance your products or an end-user seeking to upgrade your existing equipment, this solution provides a seamless integration experience.
Embrace the Future of Wireless Connectivity:
With Wally’s QCN9074 Wireless Solution, you can embrace the power of 2.4G, 5G, and 6E selectable frequencies. Say goodbye to connectivity limitations and hello to a world of seamless, high-speed, and future-proof wireless connections. Experience the difference today and unlock a new level of wireless performance!
1.DR9074E
Link here get more information
Features
■ Qualcomm Atheros QCN90X4
■ Maxim Tx power 20dBm per chain
■ Data Rateup to 4949Mbps
■ Support 5.180~5.825Ghz or 5.925GHz-7.125GHz or 5.180GHz- 7.125GHz
■ MiniPCIe connector
■ PCI Express 3.0 Interface
Applications
■ Security Surveillance
■ Commercial radio coverage
■ Hotel Wireless application
■ Forest fire protection engineering
■ Country coverage
■ Some special scene application
Product Description
DR9074E based on QCN90X4 Chipset is an enterprise wireless module integrated with 4x4 MU-MIMO Dual Band Wireless Module designed specifically to provide users with mobile access to high-bandwidth video streaming, voice, and data transmission for office and challenging RF environment in factories, warehouses establishment.
Absolute Maximum Rating
Parameter Rating Unit
Operating Temperature Range -20 to 70 ºC
Storage Temperature Range -40 to 90 ºC
Symbol Parameter
Chipset Qualcomm Atheros QCN9074(QCN9024)
WLAN Host Interface PCI Express 3.0 Interface
System Memory 2Mbit serial I²C bus EEPROM
Standard Operating Voltage 3.3V
Operating Systems QSDK
Host Interface MiniPCIE
Antenna Cable / Port 4 x MMCX Connectors,4T4R
Frequency Range5.180GHz-5.852GHz or 5.952GHz-7.125GHz
Data Rates for WALN
Maxim TX power 20dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz
Modulation Techniques OFDMA: BPSK, QPSK, DBPSK, DQPSK,16-QAM, 64-QAM, 256-QAM,1024-QAM, 4096-QAM
Temperature Range Operating: -20°C to 70°C, Storage: -40°C to 90°C
Humidity Operating: 5% to 95% (non-condensing), Storage: Max. 90% (non-condensing)
Certification TBD
Power Consumption 15W(Maximum),9.5W(Normally)
Dimensions (WxHxD) 30mm x 50mm x 14.5mm
2.DR9074-6E(PN02.7)
Features
■ Qualcomm Atheros QCN9074
■ 6GHz, max 23dBm per chain, up to 4949Mbps
■ Single Band 6GHz 4x4 WiFi 6E (802.11ax)
■ 4 spatial streams (4SS)
■ M.2 E Key Interface
Hardware Specifications
Symbol Parameter
Standard Operating Voltage 5V
Host Interface M.2 E Key
Frequency Range 5.925GHz-7.125GHz
Data Rates for WALN 6GHz, max 23dBm per chain, up to 4949Mbps
Support 20/40/80/160MHz at 6GHz
Certification TBD
Power Consumption TBD
Reference Design PN02.7
Dimensions (WxHxD) 57mm x 63mm x 6mm
More detail and opportunities attach Emile & Face book :sales4@wallystech.com. This is Jane for you
