Are you tired of dealing with weak Wi-Fi signals, dead zones, and slow internet speeds at home or in your office? Look no further! Wallys is proud to present the IPQ series of wireless solutions, including the IPQ 6018, IPQ 6010, and IPQ 6000. With these cutting-edge devices, you can enjoy a powerful and reliable wireless network that covers every nook and cranny of your space.
Unleash the Power of Wallys IPQ Technology
The Wallys IPQ wireless solutions are built on the IPQ chipset technology, a breakthrough in the field of wireless connectivity. This chipset combines advanced features and optimizations to provide exceptional performance and coverage for a seamless wireless experience. Whether you have a small apartment, a large house, or a bustling office, Wallys has got you covered!
IPQ 6018: Unrivaled Performance and Speed
The IPQ 6018 is the flagship wireless solution in the IPQ series. Powered by state-of-the-art hardware and intelligent software algorithms, this device delivers unparalleled performance and lightning-fast speeds. With its impressive range and capacity, the IPQ 6018 ensures that every device in your network enjoys a lag-free connection, even during peak usage.
IPQ 6010: Seamless Roaming and Extended Reach
If you’re looking for a wireless solution that offers seamless roaming capabilities and extended reach, the IPQ 6010 is the perfect choice. Equipped with intelligent beamforming technology, this device dynamically adjusts its signal direction to focus on connected devices, ensuring a stable connection as you move around your space. With the IPQ 6010, dead zones become a thing of the past!
IPQ 6000: High-Performance for Mid-sized Environments
The IPQ 6000 is designed to cater to the needs of mid-sized environments such as apartments, small offices, and shops. This compact yet powerful device provides reliable connectivity and impressive coverage within its range. With the IPQ 6000, you can stream videos, play online games, and connect multiple devices simultaneously without experiencing any slowdowns.
Security and Reliability You Can Trust
Wallys IPQ wireless solutions prioritize security and reliability. With advanced encryption protocols and robust firewalls, you can rest easy knowing that your network is protected against unauthorized access. Additionally, the devices undergo rigorous testing to ensure their durability and performance, so you can rely on them day in and day out.
Upgrade Your Wireless Experience with Wallys
1.DR6018
Website:
Qualcomm-Atheros IPQ6010
1GB DDRL3L System Memory
Support: QUECTEL RM500Q-GL
Support: QCN9074 WiFi 6E Card
Absolute Maximum Rating
Parameter Rating Unit
Supply Voltage 24V~48 V
Hardware Specifications
Symbol Parameter CPU
CPU Frequency
SD Card Slot 1x SD Card Slot
USB /header 1x USB 2.0 Port
DC Jack 24V power supply
LED header FFC/FPC Connector
4 x MMCX Connectors
Bluetooth optional
Nand Flash 256MB
DDR 1GB
Dimension 185mm x 116mm
Say goodbye to weak signals and unreliable connections! Wallys wireless solutions bring power and full coverage to your home or office, enabling you to enjoy fast and seamless connectivity no matter where you are. Don’t settle for less when it comes to your wireless network—choose Wallys and experience the difference today!
Our company:
Wallys Communications (SuZhou) Co.,Ltd https://www.wallystech.com/was established in 2010. The company is a techno-innovation enterprise specializing in the independent R&D, production and sales of wireless network products and offering wireless solutions.
More detail and opportunities attach Emile :sales4@wallystech.com. This is Jane for you
